View Full Version : 3rd Gen Durango
Pages :
1]
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
- rear heater core
- obd codes po2135,po222,po221
- 2019 Durango Overheating but reservoir has antifreeze
- How yall think my new to me 2012 hemi is coming?
- Durango Tow mirrors
- So what’s with the press not giving the DD love?
- rear ceiling vent question
- Service electronic stability control alert
- 2020 Durango rt overheating
- OEM seat upgrades
- Dealership Damaged My Vehicle (Disabled Veteran)
- Engine brake like noise from rear passenger side.
- Idling rough
- 15' Citadel, no rear heat
- 2012 Jeep SRT8 Cluster in a 2011 Durango RT.... Help!!!
- MBRP Exhaust users?
- Brake pads - Dealer OEM vs after market
- Buying a Durango, which years are good/bad
- overheating
- 2022 Durango Right Rear Ratting Noise
- cold air induction?
- 2024 Durango GT Plus
- Excessive Cranking 2021-2025 Dodge Durango
- 3rd gen key fob
- Real 4WD or AWD
- Front End Conversion Stories
- 2015 Durango loose front end?
- 2020 Durango GT Plus 3.6L Engine Locked Up
- "2021 dodge roll away risk"
- 2011 Durango RT AWD Hemi Swap.
- 2022 Durango r/t
- Boomerang Durango
- 2025 R/T Plus
- Engine light blinking
- Stuck in Low Range
- Dodge Factory Contact?
- 2018 dodge durango v6 3.6
- Cylinder 1 & 5 misfire
- Flashing CEL
- 2013 dodge durango
- Rear signal flashing hazards in turn
- Help at a loss
- Durango 2021, Trunk Lid won't close!
- dragging brakes
- Cast number
- 2017 durango rt wiper in rear
- 2015 Citadel Headlight Options
- Wiring harness disintegrating?
- SERVICE AWD, ABS and Traction control off lights all came on
- For the life of me I can’t get Valve cover off
- 2012 dodge durango 5.7 crew AWD light
- Brake Light Comes On
- Won't move while gears still engage
- Battery voltage at alternator
- Mechanic Help: Proper Automatic Transmission Fluid for 2015 Dodge Durango 8 Speed AWD
- Rear view mirror parts.
- Wheel Well Liner
- Reading Transmission Fluid Level
- Water Trapped Inside Tail Light
- Radiator Thermostat Replacement
- Rear Liftgate Latch
- Fan Belt Replacment
- 2017 GT: Lukewarm at best air from Driver's side only?
- Dash warning lights after changing auxiliary battery
- No heat in rear.2013 Dodge Durango.
- 2016 tips new install
- 2020 sxt no start
- 2021 DD Driverside Headlight
- 2017 dodge durango citadel
- Stalling at idle, 2013 Durango 3.6L
- 2021 Durango SXT Washer Fluid Low/Light
- 2015 to 2021 SRT Front End Conversion/Wide Body
- front windows role down by themselves
- Headlight Alignment
- Cheap Durangos coming on the market.
- 2021 Washer Reservoir Sensor Part #
- Cabin Air Filter 2021 Durango SXT
- blue smoke at start up
- stolen durango returned no fob no insurance, please help!
- Stellantis Creates Another Special Edition Durango Hellcat Because They Can
- 15 Durango Key FOBs do not work
- [Limited Time] Unlock Your Car’s Potential with AutoPro X: The Ultimate Experience
- 2021 Durango SXT Washer Sensor
- SRT vs TNG
- 2021 SXT Sudden Death
- Dodge Celebrates 20 Years of HEMI Powered Durangos With Special Edition Models
- 2024 R/T TNG digital speedometer
- Replacement radiator 68232591AB
- Canadian car in the USA
- Front Differential Bushings
- 2018 Dodge Durango radio screen is delaminating
- Camshaft spins freely from gear
- Just would not start.
- 3-ports catalytic converters
- 2013 Durango liftgate wiring
- Dodge Durango 2014 R/T - Service AWD, ABS, ParkingSensor, and other lights on (Stutte
- Brake/Rotor Set 2015 Durango R/T - best/value
- 2021 dodge durnago RT
- Redeye Durnago
- SRT wheels on the RT.
- Blind spot alert unavailable.
- P0171, p0174, p0133, p0153
- Leaking power steering
- Nav is flashing on and off.
- 2018 dodge durango 3.6 penstar p0300 p0301
- Uconnect not working after replacement
- Does this mean I have a transmission cooler?
- 2019 gt foglight issue
- Valve Compression Test 2013 Durango Hemi
- 2012 Durango RT Coolant Problems
- 2015 Durango R/T Valve tap
- Audio question
- LOW light Flashing....
- 2013 RT Hood swap/wheel upgrade
- 2014 v6 engine jumping poor acceleration. Misfire code
- 2015 Durango R/T Starts and dies immediately
- Missing steering assist sensitivity options post repair
- 5.7 pre eagle engine cam
- Durango motor dead
- 2015 3.6L Random Misfire/Rough Running
- Parking light indicator
- New App for Dodge, Jeep, Chrysler, Ram
- Durango SRT 392 is the Next V8 Model to Receive Farewell Tour
- 2013 Durango R/T HID headlights.
- 2012 Durango check engine light
- '12 Durango 5.7 545RFE 5th gear won't engage.
- 2015 liftgate lights out
- 2008 4.7 engine noises
- 2012 R/T rear blower issues
- Bad Steering Column Module?
- Heater Core
- Squirely ateering
- PCM bad?
- What suspension parts causes the Stupid clunking noise
- Auto highbeams with light bar
- Dashboard removal Durango 2017 5.7
- 3.6 2011 durango starting issues
- 3.6 durango a/c compressor
- Service Repair Manual
- Loss of power steering and brake assist with engine running
- Driverside master control
- Rough idle
- Oil Temperature Question/Issue
- ABS/FCW/Traction Control/Park Sense Idiot lights
- Power steering fluid
- 2017 v6 trailer issue
- Highspeed Fan Relay Location
- rear power actuator strut
- 2015 Durango Will Not Start
- 2013 Crew, tailgate won't latch even when manually closing
- New member looking to upgrade my Citadel
- Blower randomly shut off and turns on
- 2013 Durango R/T
- Towing capacity?
- Sharp eyes and advanced knowledge...
- 2014 headrests
- 2019 RT Throttle Hesitation
- Lowering a 2012 AWD Crew
- Limited Slip
- Customer Complaints/Screen Delamination
- 2014 Durango AC Issue - "Hissing" not blowing very cold air
- Auto-Lock after left alone...
- Transmission keeps going to slip and grind mode .
- 2016 Durango Rear Center Taillights LED
- accidental starting.
- New Order 2023 Dodge Durango Blacktop PKG GT
- Oil coolant leak
- Front CV replaced at dealer, now steering pulls right.
- Bad oil leak
- Towing - Length/Weight of Trailer - Braking
- 2018 Dodge Durango GT RWD
- Dodge Durango 2015 V6 3.6L : performance
- A/C and Heat Issues That Don't Make Sense
- Xenon to halogen conversion
- oil temp to high
- Towing and Tongue Weight 2023 Durango RT Plus
- Performance Exhaust
- Question regarding MDS
- Favorite artist/song
- 2019 Dodge Durango extended crank
- ODB2 scanner not working with my vehicle
- 2013 durango cam position fault
- 14 durango 3.6L stuck in 3rd CEL and Stabilitrak HELP!!
- Performance hood
- 2013 Durango ABS Module availability
- Uconnect/HDD issues
- Start/Stop issues and Random misfires 1,3,5
- Partial Cold Air Intake CAI ??
- Brakes
- Part warranty?
- Clunking, thud sound please help
- 2022 Durango R/T Hemi Transmission problem
- Map lights burned out??
- 2012 R/T 5.7 cam wiped?
- 2018 GT HIDs housing switched with 2021+ LED housing
- Rear wheel bearing replacement
- 2012 rt passenger Hid headlight
- 2014 Dies while driving - PCM replaced
- Blend door actuator not actuating?
- No Spare with Tow n Go pkg?
- Fuel filler tube replacement how to
- Durango passenger window switch not working
- 2013 Rear end Fade or Bad Tires?
- Steering Pump Wiring
- #2
- Temperature Gauge
- Need Help!!! Transmission issue
- 2013 Durango Auto-Lock issue
- New R/T
- Front Strut Replacement
- knock senser
- 2021 Durango Subwoofer Wire Input +/- ?
- 2016 Durango - TIPM issues
- 2017 Durango gt 3.6L p0302
- No radio signal, also no wireless uconnect operation
- New Member & issue with durango.
- SRT vs. R/T
- knock senser
- 2006 dodge durango 5.7L hemi neutral safety switch
- Complete rear brake job - rotors still extremely hot
- 2015 v6 torque specs
- Durango problems
- Durango III seats swap from Grand Cherokee WK2
- Engines 2x4 vs 4x4
- Passive Entry
- 2014 Durango shifting problems
- 2022 Durango GT Plus AWD Shifter Lever - Clicky Noise / Slack in the Thumb Button
- 2018 Durango - How to reset anti Theft / Security (blinking red light)
- DiabloSport Tune or HP Tuners
- Stumble
- Add Bluetooth audio streaming
- LED Headlight Upgrade
- looking for some help. 2000 Durango
- 2013 HID Headlight Assembly - Cheaper replacement Option
- XM won't work. No signal Contact dealer.
- bypass rear heater core?
- 2014 dodge durango won't start after driving for a while
- 2012 crew ETC light
- Durango 845RE Transmission Acting Wierd
- 2011 Hemi Crew Intermittent No crank No start … help!
- 8 Speed Transmission Question
- Flickering gauge screen
- 2011DurangoETC??WHATS WRONG!?!
- Anyone have a recommended exhaust shop in Monmouth County, NJ? Need H pipe done.
- Oil life reset
- Key Fob isn’t working correctly, help?
- Front seat relay unplugged
- 22" Wheels installed!
