View Full Version : 3rd Gen Durango
Pages :
1
2]
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
- Underground Lighting for 2014 Citadel
- Temp guage reading hot
- 2018 Durango smoked 2 starters
- Quick Question - OEM Install Garmin Mini Dash Cam
- Spare tire woes
- Just joined...need help
- 2012 Durango RT AWD Low light in Dash
- Truck will not crank
- ECT locations 2013 Durango V6
- 2013 Crew V6 Coolant issue
- Technical Support | Dodge Durango SRT (2019) Instrument Panel Cluster MpH to KmH
- Coolant leak at rear heat supply line
- 2021 lift gate
- parking senser
- After Market Hid kit
- Window/lock issues
- Driveling noise
- Harman Kardon 19 speaker system
- Weird Outside Temp Readings
- V8 going away?
- Can I drive to shop without power steering?
- Expensive bulb!
- 8.4 Uconnect changing source
- Tire letters for the Durango
- 2012 Durango no power to TIPM
- Oh Deer, is that antifreeze?
- P0430 diagnostic reading
- 2014 lower grill
- Random Cylinder Misfire (and more)
- Coolant Loss
- 2013 V8 Strut assembly front suspension
- Heater Supply and Return
- 2017 Dodge Durango GT OP302 code, starts running very rough
- New To Forum
- Engine tick
- 21 SRT/Hellcat Paddle Shift Faster Or Auto?...
- Lock Out Low Range on Full Time 4WD
- English vs. metric
- 2015 Durango Rear Heat
- 2019 gt shifter service
- Coolant loss
- Misfire
- trailer hitch
- Any soundproofing experts here?
- Use a USB drive for music
- Rattle Noise - 2021 Durango R/T
- 2018 DD 3.6 running issue...
- Red lighting bolt
- Wheel size
- Rattling on idle - repeatable scheme
- Two questions about my new to me 2019 Citadel
- Stop phone syncing
- Drivers Ovhd Console Lights Stays On??
- Annoying Transmission lockout When Drivers Door is Open>
- Re-Programming Key Fob?
- No Power for Trailer Brakes
- Check Engine Light NOT Coming on During Startup
- 2013 Durango Crew; 60,000 miles’ severe tick developing
- Instrument Cluster Swap
- 2021 Dodge Durango Door Lock
- Misfire at idle
- Durango languishing, no parts. Really?
- Over 200k 2nd generation Pentastar 2016 Durango Citadel
- Lug nuts
- Brake lights and 4 way flashers
- 2021 SRT Durango hard downshifting
- 2018 GT AWD and Rocky Road RRO 2.5" lift questions
- Uconnect 5.0 Green Screen
- Tranny Leak
- Thoughts on the Durango Hellcat
- click click click shifting from Park to neutral or drive
- How to Use Launch Control in the 2021 Dodge Durango SRT Hellcat
- 2021 Dodge Durango SRT Hellcat Interior
- 2015 Durango R/T leaking rad @ 41k miles
- GPS always recording?
- 2021 Durango and Android Auto
- Removing Durango AC vents
- Help!!!! Transmission fluid level
- Dash center left side AC vent
- Codes:7E8 Engine and 7E9 AT 2015 Durango
- Passenger window only goes up or down a few inches at a time!
- Haven't posted in a while, little update...
- Power liftgate slams violently
- Blown away!
- Remote start
- Wont Start
- Durango 2011 Headlight 2014 retrofit
- 2018 srt bcm
- 2018 Durango GT
- 2011 Durango Citadel
- Humming noise.
- 2020 dodge durango gt
- Right front blinker issue
- SRT8 wheels
- Air suspension
- Overheating
- 2020 Durango SRT drive modes
- 2014 limited Off-road project
- Cat-back: curious
- Additional wiring from cabin to motorarea
- Traded up to a 2019 have question re MDS
- 2019 gt long crank
- AWD vs RWD
- Help me diagnose possible trans problem
- V62 Fuel Pump Relay current recall
- New Member...bit of a rant
- Compass
- 2021 Dodge Durango SRT Hellcat AWD: A POV Look
- Replaced Headlight bulbs, Lights still dont work. (Dodge durango 2013)
- 2014 Dodge Durango seatbelt.
- 5.7 Removal - Exhaust Manifold to Exhaust Pipe bolt removal access.
- 2015 Durango R/T fog light upgrade
- Decel howl
- Any Orange County,CA 2021 Durango Owners?
- 2013 durango electrical nightmare
- HVAC blend doors/mode doors...
- Pursuit Durango
- New Dodge owner
- Side Mirror Question
- Dodge Durango Hellcat vs. Tesla Model Y in Drag Race
- Wrapping 2016 Durango hood
- 2014 Durango 3.6 w/P0394 p0345 after rocker arm replaced
- New to the thread
- Hesitation at around 1700 RPM 6 Cyl Citadel
- 2014 R/T Power locks don't work
- Settings being lost
- Help Needed: Passenger Side HID Not Working
- Blend Door Actuator
- Durango Hellcat.
- Hood rusting
- B2207?!?!
- 2016 Durango SXT AWD no electrical power
- Blacktop Touchup
- 2011 citadel
- Phoenix audio Tesla screen review and settings
- Fluid Reference
- Same Durango new color
- Wet sanding and buffing
- Auto headlight problem
- 2021 Durango r/t
- Mopar.com My Garage?
- Grinding Sound on Front Driver's Side When Turning Right
- Removing Wheel Hub
- Separating Rotor from Wheel Hub
- New ghost lights
- Oracle lighting
- Which Size Brake Discs and Rotors
- 2016-2019 fuel economy?
- armrest controls...windows/locks/mirror
- Headed to the paint shop
- Cool Durango T-shirts
- Durango Hellcat Becomes the World's Most Powerful SUV
- New member, gonna lift it.
- 12.1 Tesla style screen
- Let the customizing begin
- Durango modifications
- Dodge Ghost lights
- Tesla style screen
- DRL Flexible LED's
- Mods to my Durango
- Flexible led lights
- AC ques. -- just curious
- Durango customization
- 2014 R/T performance mods
- Liftgate problems
- Sunroof seal leaks
- Voltage drop to fuel door button
- U0170-lost communication w/up-front left satellite acceleration sensor
- Transmission quits pulling while driving
- were these a wheel option in 2017?
- Cel - p105d
- in-service date?
- R/T Fender Badges
- Lug nuts
- 2011 Durango keyless entry dead on passenger side only
- Flickering backup camera and other issues
- 2019 GT faint whine / wooing noise
- Fuel pump goes bad - 28K miles - Durango SXT
- Borla Cat back Exhaust
- Durango 2013 R/t alternator fried!
- 2011 durango A/C issue
- touch up spray paint
- sticking caliber?or brake line
- Unresponsive throttle at 60mph
- Break Manifold LLeak?
- rear hatch handle
- Mystery Part -Need Help Identifying
- UConnect Upgrade or Aftermarket
- 2020 Durango R/T
- Parts That Are Interchangeable 3rd Gen Durango
- Turn Over / No Start
- Electric Trailer Brakes and a 2015 Durango
- Shifting Issues
- Battery Saver Mode Issue
- Metal on metal sound when turning
- Need a Transfer Case Switch for a 2011 Citadel 4 Wheel Drive
- Confused
- Bought a 2012 Durango crew
- Interior lights stopped working
- Instrument panel issues
- 2013 Hemi V8 60k Spark Plug Change
- high pitch squeak/ 3rd row floor area
- 2018 set durango power loss?
- Transfer case leak
- Drive Train Control Module & Transfer Case
- defrost: mirrors and rear are not working
- heat seat module
- Durango problems. Thinking of other vehicle options after warranty?
- 2018 or 2019 Durango R/T Towing Capacity with and without towing package
- License plate lights not working
- Stuck in 4th gear
- Power outlet problem 12 volt
- 2014 Durango, R/H tail light stays on
- Water sloshing sound behind dashboard?
- Crev6 Crew RWD intermittent click sound in Park, then stuck in 3rd or maybe 2nd
- "Clunking" sound on acceleration fix...
- Rear interior leak
- Smelly heater air conditioning
- Temperature issues
- Radio troubles
- Wipers won’t shut off
- 2013 Durango SSV leveling questions
- Jeep wheels on durango
- Looong Crank before Start 2013 V6 Grand Cherokee
- Just want to know safety of Durango?
- Another Recall 2011-2013 Durangos/Jeep GC
- 2020 Durango RT blacktopor 2020 Ram 1500 Bighorn midnight edition??
- Uconnect Access
- Seatbelts all broken?
- 2015 Durango limited engine problems
- Check engine light reset.
- 2011 Durango Heat (3.6l) Tow Package Question
- headlight noise
- Not happy Durango owner, engine rattle noise+ loss of performance?
- 2011 Durango Heat, park assist system fault
- Noise From Front End
- Level/Lift Kits on 3rd Gen Durango
- AWD FCW warning on citadel
- coolant tempature at idle
- 2019 Durango RT Towing Capacity
- 2016 Durango Limited remote start not working properly.
- center console
- Power steering fluid?
- 2017 Durango GT AWD P0733
- 2020 Durango SXT
- 2015 srt hemi wiring issue
- 2014 dodge durango
