PDA
View Full Version : 3rd Gen Durango
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Owners Manuals
  2. *IMPORTANT* @Dodge Durango SRT Mopar 18' Edition Owners
  3. 2016 Durango USB Port
  4. TPMS message
  5. Burn smell when hard acceleration for 2 minutes
  6. 285/50/20
  7. 2013 AWD transfer case problems
  8. 2017 R/T turn signal
  9. General reliability of more recent GEN 3's
  10. Good Price 2020 DD RT AWD?
  11. Front sway bar bushing
  12. slight clunking in drivetrain in middle of 1st gear
  13. Wind Sound
  14. Hard shift from 1st to 2nd and from 2nd to 1st Durango 2019 GT
  15. Check Engine Light - P0128
  16. Moaning sounds?
  17. 2015 Citadel NEEDS BRAKES AND ROTORS
  18. Windows quit working.
  19. Clicking While Driving
  20. Tire Talk SUV or Light Truck?
  21. 3rd Gen SRT Offroad Check List
  22. RT 16 way power memory seat wiring schematic needed
  23. 2011 Dodge Durango Amp
  24. Steering Wheel Extension Mod
  25. 2013 Dodge Durango Crew acting carzy
  26. Citadel rocker molding chrome
  27. When do you need to replace spark plugs
  28. 2018 SXT AWD - Beach driving
  29. TIPM Recall - Failing again (2012 Durango)
  30. starter want disengage
  31. 2017 Durango SXT AWD 3.6 - #2 Cyl Misfire
  32. Wanting to lift 2018 Durango
  33. Rear view mirror button
  34. 2012 Citadel - Hi Beams stay on while driving, and even after the engine is cut.
  35. Installed Tow Harness: Service AWD light on. HVAC behaves weird.
  36. 2013 3.6 oil look by radiator?
  37. alternator fix
  38. oil pressure durango ?
  39. Acceleration
  40. uconnect headphones for DVD entertainment
  41. 2011 Dodge Durango Multiple Issues
  42. Humming sound from front air vents in like new 2013 Dodge Durango Citadel
  43. 2018 Durango Rt tunner
  44. 2015 Durango SXT Readlight Alignment Screw
  45. tire and wheel ideas
  46. Is "tuning" worth it?
  47. 2011 Durango heat, p0732,p0730
  48. minor problem but still a problem (to me)
  49. Interior Lights
  50. 3rd Gen Fender Flares
  51. Downshifting when stopping
  52. SRT power add ons
  53. Ac not working
  54. Please hel!!2011 Durango won’t start!!
  55. Starting issue
  56. Add-on Towing Mirrors
  57. Drivers side actuator
  58. Traded 12 Durango R/T for 19 Durango SRT
  59. Bumper Scratch
  60. Temperature gauge not working on dash
  61. Liftgate opens and closes but wont latch..
  62. Liftgate problems
  63. Logo Splash Screen Gone After Detailing
  64. Towing car hauler with 2014 R/T
  65. Transmission Issues?
  66. 2018 GT..CAI..Magnaflow Catback..22x10.5...Asanti on Toyo
  67. 2011 DD cidadel towing
  68. Finally done?
  69. Can’t activate WiFi Hotspot. Anyone have it working?
  70. New member
  71. 15 citadel, buzzing humming driving in wind
  72. 200k mile club
  73. Who tuned the audio system?
  74. I'm Back! New 2019 R/T
  75. 14 R/T engine upgrades questions
  76. 95K maintenance items for towing
  77. Front Tow Hooks
  78. Fluctuating idle/skipping after long shutdown periods
  79. Ambient Temperature Sensor
  80. 2013 Dodge Durango SXT
  81. 2015 Durango Sloshing Sounds Driver Side
  82. OEM roof bar or rack replacement help
  83. Hello have a great Deal. 2018 Durango GT
  84. Any issues with SRT Durangos?
  85. 2016 citadel Dash message lights up when you touch outside door handles
  86. Radio display
  87. SRT Hood on 2013 R/T
  88. Engine completely loses electrical power while driving
  89. Bad engine ?
  90. 2 batteries in newer Durangos ?
  91. 2 batteries in newer Durangos ?
  92. 2014 8.4 Uconnect Broken
  93. Nothing But Issues...
  94. No “Horn with remote lock”
  95. Tech issues
  96. 2015 Durango Citidel trans/drivetrain issues
  97. Help: Evap leak p0455, dodge durango 2014 r/t
  98. Keyfob issues
  99. Power steering leaked (fixed maybe)
  100. Add third row to 5-seater?
  101. Seatbelt is stuck
  102. Damaged key message
  103. Reliability
  104. 2013 Durango - Rear rotor stuck, suspect parking brake
  105. 2018 DURANGO srt active dampening issue
  106. Performance chip for the 3.6L?
  107. SP Performance Rotors & Pads
  108. New Member
  109. OBD Port Doesn’t Work
  110. Doors intermittently unlock when locked indoor button
  111. Aftermarket or factory tow hooks?
  112. Uconnect 8.4 no Apps menu
  113. TPMS Sensor Compatability
  114. Sticky switch in Maryland
  115. 2017 Durango Front End Noise
  116. HELP!! Black Wheels on a 2014 Citadel (Durango)
  117. SiriusXM Guardian remote commands now working
  118. 2018 Durango GT rear defrost button issue
  119. USB Charging Ports not working
  120. 2015 Dodge Durango Fuel Door Wont Open
  121. Windshield Fogs up on inside
  122. Captains Chair Console Install and Arm Rest Available
  123. Whats your experience towing an RV (Trailer)?
  124. Northeast Dealer Discounts
  125. Starter inop
  126. can bus problem
  127. Red lightning bolt and power loss
  128. 2015 Durango fuel door not opening
  129. Removal of door panel 2015 Durango
  130. 2015 Dodge Durango - headlight condensation
  131. auto start heated/vented seats
  132. 2018 Durango SRT - Lift Kit?
  133. 2016 Dodge Durango
  134. 2015 Limited AWD...do i have Tow pkg?
  135. Door locks dont work
  136. 2012 Citadel 5.7 AWD misfire on cyl 3
  137. 2013 Crew inner backup lamps
  138. Liftgate lower trim panel retainer clips
  139. AWD Not Working
  140. Warning Lights
  141. New wheels! What should I run?
  142. buying advice.
  143. 2015 Dodge Durango Citadel Motor Mounts
  144. Transfer case issues
  145. Gen 3 Durango Nerf Bars
  146. Alternator and PCM
  147. Service Power Steering
  148. 2013 Dodge Durango Crew power liftgate wont open or close
  149. 2017 Durango 5.7 voltage
  150. durango srt oil change interval
  151. Towing
  152. MP 3023 transfer case fluid
  153. Intermittent starting issue
  154. Disable Auto Comfort
  155. Durango R/T transmission problems
  156. Auto hi-beam function
  157. 2018 Trailer lights
  158. Rear tires not spinning
  159. Heater core issues - Need Help!!
  160. ‘11 Durango Seat cover and foam swap?
  161. Issue with Bluetooth song display
  162. 2015 Dodge Durango SRT water leaking sunglass holder
  163. Used 2015 limited purchase concern
  164. Rear swing away tire carrier?
  165. What weight/type fluids recommended
  166. Glove box rattle?
  167. Brake Controller needed or already installed?
  168. Misfire on1,3 and 5
  169. 2013 instrument cluster help please!
  170. 2015 Durango Lift Kit
  171. Steering rack leaking
  172. 2014 durango key fob
  173. hazard light
  174. 3rd row seat buckle
  175. Questions about buying a demo Durango
  176. Slight burning smell when I turn on the heat
  177. How to remove rear interior panel, cargo area over heater/ac unit?
  178. is anyone else have a problem with the 2011dodge pickup TIPPM problems
  179. backup camera foggy
  180. 2016 R/T level lift
  181. Spare part for driveshaft center support
  182. Right Rear Taillight
  183. Radio
  184. 2012 Durango 5.7- Dont Buy a Dodge
  185. Keyless entry problem
  186. uconnect module - help
  187. FCW OFF sensor
  188. how do i remove 3rd row in a 2018 dodge durango
  189. Towing advice?
  190. 2017 Durango SXT Seat Issues
  191. 2015 Durango R/T - new owner
  192. Issues with Trans dropping out of Gear in Reverse
  193. musty smell inside
  194. Lift gate opens but won’t stay open
  195. New Member to the Forum
  196. Drivers Door Master Control Problems
  197. Dodge Durango R/T 2015, battery specifications
  198. High Beams not working at all
  199. Normal coolant temperature in 5.7 hemi
  200. Keyfob Battery Replacement
  201. Oil change, Do It YourSelf
  202. Acceleration Hesitation Cause
  203. How To Change oil on your DD
  204. One Week Road Test: Dodge Durango RT and SRT
  205. Shift To P
  206. Tekonsha-Durango-no lights
  207. satin or gloss black wheels
  208. Electronic Throttle Control Light
  209. Misfire on cyd one
  210. Codes
  211. Recall gone wrong! Please help!
  212. 2016 Hemi R/T Oil
  213. Battery Light on after Alternator Recall Fix
  214. 2017 SXT driver seat removal
  215. 2014 durango turn signal
  216. Bypassing adaptive cruise
  217. 2013 Dodge Durango RT
  218. 2018 R/T just stopped working!
  219. 2013 Dodge Grand Caravan
  220. Lowering springs for 2015 SXT
  221. 2015 R/T Issues - Questions?
  222. what makes the fan come on with A/c?
  223. Replacing headlights on 2011 Dodge Durango citadel
  224. Battery Life
  225. 2013 Durango BUS system
  226. Prospective R/T Buyer 2014+
  227. 2013 Crew Voltage Gauge
  228. 2013 Dodge Durango throttle position sensor
  229. Water sloshing under driver side seat - 2011 Dodge Durango - 3rd gen
  230. Lifted Durango with Bilstein shock. How to do rear?
  231. Display keeps showing FCW Failure
  232. Fumoto and 2017 RT
  233. Occasional starting issue
  234. Head rest
  235. brake controller wiring and the under dash connector
  236. Backup Sesnors
  237. 2018 Summer vacation in the books - fuel consumption
  238. 2013 Durango Citadel Power Liftgate Problems
  239. 2012 Durango Ground wire disconnected?
  240. Another thing . . .
  241. Recent Calls / View Contacts
  242. Engine fan extremely loud
  243. dodge 2010
  244. Vw Atlas vs Durango
  245. P000b 2011 v6
  246. New guy, Right mirror source
  247. recommended size for jack stands and floor jack
  248. 2012 Dodge Durango Crew AWD
  249. USB port not working
  250. '18 R/T Numerous Problems after Purchasing
