View Full Version : 3rd Gen Durango
Pages :
1
2
3
4
5
6]
7
8
9
10
11
12
13
14
15
16
17
18
19
20
- Fishhook/Stutter Issue
- 2011 Durango Citadel Key Fob Issues
- Nav update
- 2016 Tail light assembly
- Tie down hooks in trunk and driving with trunk open
- Keyless Entry Not Working ??
- Anyone use airbag spring helpers?
- Evap Leak
- Cleaned my key fob
- 2011 and Up, Upper Radiator Hose *WARNING*
- Help! Check engine light won't stay off
- Center console under dash light
- I want one...
- Gave my Blacktop a Black Top
- New App to text license plate owners
- To Dodge Cares - Spark Plugs
- 2013/2014 Hemi Spark Plug Replacement Cycle Differences
- My thoughts about my new/used 2015 R/T Durango
- Rubber Mat Wind Deflector question????
- Lug nut key!?!?!
- Little plastic bag in glove compartment - empty????
- 30K mile service on '14 Durango, AWD transfer case service
- OEM Roof Rack Question
- Uconnect Issue/Questions
- LED signal side mirror on a 2015 Durango
- Driver and Passenger window controls not working
- Seat removal on '14 Durango R/T
- ID which cylinder P0304
- MDS(ECO) viberation
- Head rests srs
- ?s for 2014-16 owners
- Audio Player Does Not Display MP3 Artwork
- April Rebates
- Tranny flush or standard fluid change?
- Long term test/RT towing review
- Blue Tooth Ringer Adjustment
- CEL, FCW error
- Firestone Destination LE2
- Proscpective 2014 DD buyer...What to look for?
- 2011 Dodge Durango Power Window
- looking to buy a durango
- VIN Check Please
- V6/8speed vs V8/6speed
- Radio & Dash Upgrade
- Windshield vibration
- Swap rear wheel drive xmission for awd
- Parts for 2015 rear floor console swap?
- LED Bar
- Loose gas cap
- hvac no heat
- Small oil leak
- Got backed into today....
- Sun visor recall (part deux)
- Passenger's side heat blows cold
- Brake Rotor / Pad Replacement - Recommendations?
- Brass Monkey
- Leaking front driver side strut
- Where did all the Hemi's go?
- 2016 Durango Build is finally Live
- 2011 3.6L Oil Filter Spring
- This HEMI-Powered Dodge Durango Rocks, Then Rolls Through the Snow
- Can you reset the GPS?
- P0520 code.
- I'm going to kill her
- 2016: New Pentastar / 27 MPG Hwy
- High pitch low frequency noise when air on ???
- Lack of heat coming from roof vents.
- 2012 rt awd no gears
- P0456-evap purge system small leak
- Any reason not to get a Durango?
- Stabilus Powerise
- No power to rear view mirror
- 2013 with Aftermarket Head-unit installed
- '13 R/T RHB camera hack
- Radio and Nav dead
- 2011 durango key not working
- 2013 Stalling After Start - Pt. 2
- 2015 R/T - Lemon, not lemonade.
- Blind Spot Monitoring Light
- Strut Replacement
- Srt 10 ram rims
- Cel p2096
- Interior Colors of Durango
- New to me 2011 Citadel
- Another pass side vanity mirror recall?
- Heated Steering Wheel is the Only Auto-On Option?
- 2014 Dodge Durango 110v power inverter replacement instructions
- License Plate Lights
- Engine Cradle Bracket and Creaky Bushing
- Power Steering Fluid
- 430n RHB won't read any discs
- AWD LOW indicator
- can 2011-13 headlamps replaced with new 2014+ models
- 2015 Dual Zone Climate Control
- Recalls
- Can I get error codes in the EVIC?
- 2013 Citadel - Stalling on Start
- Dodge Durango Remote Start: engine turns off after a few seconds
- Aux lights
- no horn..
- Tailgate Rattle - 7 Times at Dealership
- Mismatched tires
- New Remote Start question
- charging issues
- MVP extended warranty plans
- Uconnect Sys. 2.600 & Nav. Updates available RHR
- Issue Pumping Gas
- Passenger heat and AC not blowing hot or cold
- 17 Inch wheels for winter
- My Durango with a Cargo Rack
- Oil Leak - Timing Cover
- 20" Hyper Black wheels
- Information: Dodge Durango NavTool Navigation Video Interface
- no tow/haul button on 2105 r/t ???
- 2016 Durango Update
- Sunroof and seat frame rust
- Lifter noise - ticking
- Class Action Settlement on TIPM recall
- Magnaflow 2014er RT
- Who has high mileage 3G?
- P0456 EVAP Emission Control System Leak Very Small
- Rocker panel removal
- 04 durango 5.7 sounds rough
- Strange issue while coasting on freeway... NEED IDEAS PLEASE!!
- Max Tire Pressure vs. Door Sticker
- misfire keeps getting worse
- Hacker Recall
- New Member
- car's remote
- Brake upgrade
- Seat Covers with Heated/Cooled seats
- Tire buying time
- Fuel relay?
- Brake Controller
- Pulley noise
- Evaporator Seal Replacement
- Fuel pump relay
- Message on radio
- Airbag Light/Connector
- 2015 Durango RT Sema Build
- Front Center Console removal
- Warranty with miles on purchase
- Recalls and warranty repairs....
- New 3rd Gen owner with questions.
- 22" OE Performance Wheels?
- 2015 2 wheel drive in snow
- PCM on Backorder
- Dashboard power cutting out while driving
- "FOB has left the vehicle"
- More Shock talk
- Warranty Question In Regards to Towing
- Alignment issue 2015 Citadel
- 2011 Durango Citadel radiator fan/ac warm at idle
- Quick fix/bypass Anti-theft code for 8.4 RA3/RA4 radio use
- Front Park - 2015 Durango Citadel
- 2015 Limited Blacktop Edition
- Just picked up my 2015 RT
- 2014 V6 transfer case fluid level conundrum
- "Pinch Weld" DIY...
- Replace fog light reflectors 2012
- Rough Shfiting
- Write up for replacing emergency brake pads?
- Oil change surprise.
- No more AUX option on touch screen
- When is the last model year for the Durango?
- 2012 Durango V8- Hissing Noise- Could it be the TIPM?
- spuddering problem
- Headlight & Fog light bulbs
- Leveling Kit
- 5.7 Oil Change Question
- 2012 5.7 Plugs
- TIPM R09 repaired..but
- Antenna base on roof
- DiabloSport inTune-DCX
- Eco-Diesel any chance in Durango
- Fuse/relay layout on 2012 Durango
- Aftermarket receiver...
- just ordered flowmaster force...
- $110 for an owner's manual!?
- Memory settings
- Passengers Side Floor Wetness...
- Air Filter
- MOPAR Performance Intake - Check Engine Light...
- FS: 22x9 Gloss Black Viper Repro's & RK Sports Carbon Fiber Hood
- New Border Patrol Durango
- UConnect Updates - Dodge Cares
- Cuban Chrome
- Fluid Questions
- Brake light on - intermittently
- 2016 Rumors?
- Driver's side windshield washer nozzle
- GPS map keeps indicating there is an update - garmin
- Antennas: Fin vs. post
- UConnect Upgraded
- UConnect Vulnerability on Jeep Cherokee
- Park Assist Guides
- Yep, Parse Error on the Parse Error thread.
- Twice this week...
- AWD issues....
- Just added a 2015 Summit to our garage.
- Map Update Worth it?
- Second row center console rattle
- Rear shocks on backorder, dealer has no estimate of time
- Contest!
- Spark Plugs?
- Chatter/shudder in reverse
- Software Updates
- Mild hesitation under mild load between 1500-2000 RPM? Recall issue?
- HID Headlight Already Out?
- Loud Noise when switching into Drive/Park
- Aussie Durango dead pedal
- the screen name applies again 22" SRT Reps
- Serious recall on 2015s for suspension issues
- air bag recall
- Uconnect remote access failure
- Electrical glitch -- again . . and again . . .
- HELP, 2011 R/T ACC Sensor Cover Gone!!!
- Burning smell after a long hill climb while towing.
- Where are the production codes on my 14 RT?
- Help! Air soft Pellets under the seats
- Question for those who drive a police package DD
- Fuel Injector leak, anyone?
- SRT8 Springs on Durango
- Travel Trailer towing
- new member
- replacement windshield with tinted strip?
- Fog light fuse location 2012 Durango
- Warped Rotors
- Latest Lockpick for '14 -'15
- New durango
- 2015 RT, grinding in manual mode
- XM radio
- Endless cranking
- Selling stock rims and tires
- Install 2014 Durango halogen headlights on 2012 Crew
- Climate control temp setting issue
- What are the current offers from Chrysler for
- Can You Disable Uconnect on 2015?
- Cute ad
- Key Not Detected Message-Car Won't Crank
- FCA cutting powertrain warranties beginning in 2016 to 60,000 miles
- 430N Media Center Software Update
- carbon fiber
- 430N RHB Software Updates?
- Front rotor size...
- Should I build another R/T?
- 2013 r/t weird gas cap problem
- 2013 AWD 3.6 Replacement Tires
- 2013 AWD 3.6 Towing
