View Full Version : 3rd Gen Durango
Pages :
1
2
3
4]
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
- Full size spare
- Air bag light
- AC issues
- Rear AC vents not blowing?
- "Auto restart" PITA
- Newest FCA Recall
- UO5 "Autopark Functionality" recall/campagn
- What Trigger EVIC Battery Indicator? (After T36 Recall)
- How to fix error code p3401
- Uconnect and Map Updates?
- Heating/ Coolant Issues
- MESSAGE (Vehicle Phone Needs Service)
- Resonator delete
- Trailer lights issues
- A/C Blower or Fan Motor
- DD'12 back up camera tilted down (picture)
- Radio Swap in '15
- P0300, p0131, p0172
- 2014 Durango 2nd row seats
- 2018 Durango Black edition Tailgate
- Aftermarket Hood For Sale
- check engine light
- Cracking Shift Bezel
- Instrument cluster display screen
- Brakes
- 2011 DD map update
- HID low beams not working
- poor headlights,aiming
- '18 Durango RT
- Dodge Durango 2016 rt
- 2017 Dodge Durango peeling 3M tape
- Starting problem
- Push to start button?
- 2017 SXT Upgrades
- Leak at Tie Rod Boot
- Mopar accesories - exhaust/cold air intake
- Brush Guard
- Made the switch!
- Stereo control issue
- Converting to a shark fin antenna?
- 2017 Durango R/T shifting problems
- Dome light help.
- I need help finding a lift kit for my 2011 Durango citadel 2wd 5.7l.
- UConnect 8.4 NAV Issue
- Turn signal out message
- Cruise control button not working?
- Winshield Washer Fluid Issue
- Durango 2012 front swap
- Remote Starter for a 2018
- problem
- Speed control not working won't turn on
- Radiator removal 3rd Gen Durango
- 2012 Durango - Radio won't shut off when driver door opens
- Passive entry
- brackets for 2017 bags for a 2017 durango.
- 2017 GT rear bumper hitch cover (no hitch underneath)
- 2016 Durango SXT Change Oil message question
- Fuel door won't open
- Service Park Assist System
- Left rear door will not unlock properly
- Uconnect - Delayed Initiation
- Snow Day Snow Pics
- 2018 R/T Upgrade Questions
- Faliure AFTER Replacement?!!
- Trouble - CEL codes P0335,U1424, P1DD2, U0140,
- battery light
- HID to halogen
- Thinking if Buying a Durango
- dodge durango 2012 no bus problem
- Shifter Change in new Durangos - Comment
- Rubber Piece
- 5.7 Exhaust Manifold Bolts
- 2018 Durango Not Flex Fuel?
- Exhaust freezing up?
- Water in Rear Brake Light
- T59 Recall - Incorrectly Installed Brake Booster Shield
- Weird Issue Happened
- We're driving the 2018 Durango SRT, what do you want to know?
- 2013 Dodge Durango Hemi Hesitation
- Front washer fluid problem
- lower control arm Front Left/Right Lower Rearward bushing removal ?
- B5 blue option
- Heat/vent seat not working
- Oil pressure switch issues
- 2012 Dodge Durango Alternator now PCM?
- Tune up on a 2011 V6
- Has anyone upgraded their NON Alpine stereo system
- 2014 Durango Ralleye Bull Bar
- Its like a whole new Durango
- 2012 Dodge Durango R/T - Brake Light comes on at highway speeds, goes away engine off
- Tpms
- Caliper covers?
- Brembo brake covers
- Tuning
- 2018 Dodge Durango R/T AWD (Customized - Pics
- uconnect goes on and off
- changing Headers
- Questions regarding DD Issues?
- cruise control on 2009 caravan
- Power Brake Booster Warranty
- Wits end with 2012 Citadel
- Windshield wiper fluid reservoir wont hold liquid and hose to sprayers is split
- TPMS Sensor Won't Relearn
- 2017 Dodge Durango GT Suspension question
- Where to buy black AWD emblem online?
- Could someone that's leasing help me understand how it works
- 2016 Limitted
- oil filter compatibility
- 2011 durango
- front wheel grinding, found after market disc rotor lug holes much larger than the lu
- No Bus Dodge Durango 3.6L AWD 2012
- Advice on 2011 Hemi Citadel Durango
- Replacing left side power liftgate strut 2013 durango
- 2011 Dodge Durango driver door won't lock/un-lock
- Dodge Durango Aftermarket Hoods discussion
- Aftermarket offset
- 2012 Dodge Durango won't start
- 2015 rear lift gate won't latch
- Crankshaft sensor Location 3.6l
- Check Engine Light/Remote Start on Dodge Durang
- HID High Beams Suck: Need Bulb Replacement
- Unbiased 2014+ owners
- Adding factory cargo rails??
- liftgate problems
- Upgraded rim/tires causing jerk/stutter/shifting problems.
- 04 durango
- 2011 DD V6 or V8?
- leveling kit
- lift gate issue
- Windshield Wiper Fluid not working
- UConnect Upgrade
- K&N for dodge durango
- Footwell Lens Cover Part #
- 2015 Dodge Durango SXT - Did not come with a Backup Camera - Need help with solution
- cost of rear brake job
- Mud flaps for RT
- Time to upgrade?
- New Member Question
- 2015 Durango Wheel Studs
- AWD won’t kick in
- I have a 2011 Dodge Durango ..3.6. P265 60r18
- 2014 DD Limited - Headlight Upgrade
- passinger seat
- Bluetooth went stupid
- USB port not working?
- Headlight question
- T75 Recall 12/14/17
- Engineering menu durango 2018
- Front Blinker Out
- Tires for 22's
- 2014 Dodge Durango Led tail light
- Transmission problem
- Remote start:heated seats/wheel
- Diagram for o2 sensors
- 2011 Durango with Charging Issue - T36 Alternator Fried
- Radio problems
- Engine stall while driving
- 2" lift 2017 dodge durango
- lifting a 2017 dodge durango with the 3.6 penestar.
- rear passenger USB Port
- Volume controls - steering wheel
- 2011 durango crew with pushbutton start malfunction
- 2012 Durango AWD crew with hemi 5.7
- Corsa Exhaust Tip Alignment
- Dim HID head lamp
- 2012 Durango heater problem in Alaska
- Replacement front bumper?!
- 2016 Durango help!
- Dodge Durango rotary knob
- Going to dealerships tomorrow. Question about 2016 Durango Models
- Parking brake cables
- 2016 R/T Oil Change
- 2017 RT Lifted 2.5" Rocky Road
- replace projector headlight with regular one?
- Detailing
- Tire pressure sensor
- 2015 security light flashing and no start?
- Multiple issues after camshaft install
- Newbie with problem on Daughters rt
- Front recovery point?
- It's only money
- DodgeCares -- not so much
- B5 Blue availability
- Replacement Headlight Bulbs
- Water sloshing under drivers seat - with skid plates
- running boards
- My new ride
- New Member
- Is it too heavy?
- New Recall?
- torque value
- 2017 Durango RT Mud Flaps
- Jeep WK2 Bilstein 5100's on a WD Durango?
- Remote start
- 2013 Durango Citadel 4 wheel Low issue
- Blue Smoke at Sartup
- Switch 12 volt for overhead console 2017 Durango
- No crank no start
- brembo brakes
- 2016 RT courtesy light won't turn off
- 2012 Dodge Durango extended Cranking times
- 2012 RT Does not want to shift at 3500RPM
- 2011 Dodge Durango Power Lift Gate Problem
- 2013 Durango Citadel Interior Lights Issue
- Electronic throttle control on Durango Citadel 2012
- Help with Electrical failure
- blilking hid headlights
- can you put diesel feul in 2011 dodge durango crew
- 14 Dodge Durango mileage
- Oil Filter Housing Adapter Spring Failure
- Engine smell in the passenger compartment
- Dodge Ram stock radio
- T36 Recall
- wheel studs
- Alternator Diode Thermal Fatigue - Safety Recall
- New tires
- 2012 Durango rear view mirror
- Transmission Overheat
- HID install
- towing
- Remote start system
- Dyno Results f/ No Suitcase??
- 2014 DD Limited airbag concern
- Anyone tow a long camper?
- 2017-18 Adaptive Cruise control in Stop and Go traffic
- Anyone switched gears on a 3rd gen?
- Full LED Bulk Kit / Information
- Apple CarPlay?
- 2014 durango key fob
- Lowered 3rd gen!! Why not the '14 & '15????
- Nav or not?
- Old news??
- First Drive Review of the 2018 Durango SRT
- Clicking sound when slowing down
- Here We Go Again..DDRT'12 not starting..
- Inverter wiring
- Capless Fuel Filler - Missing Ring around Filler
- Are the stainless kick plates standard now?
- Trailer light wiring harness
- '12 RT Passenger Side mirror replace..UGHH
- Fiat Chrysler recalls 1.33M vehicles
- The 2018 SRT Dodge Durango (Photos)
- Police package?
- Durango aggressive tread tires and black wheels
- Introducing The Brass Monkey Dodge Durango (Photos)
- For sale link?
- Cylinder Misfire on a 2016 citadel
- 2017 R/T staggered Hellcats
