View Full Version : Neon SRT-4
- what does a map clamp do and how does it work
- srt4 seats wanted.....
- reflash
- Help! Trouble with gears
- exhaust sound
- Best way to clean engine bay for the SRT-4?
- Voting is going on now!
- stage 1 comp
- stage 2 toys question
- S3 turbo
- tuned
- knocking noise coming out of my engine
- Insurance
- Trouble at 2700 RPM?
- oil light on dash??
- Regional Sections!!
- top srt4 site
- New to the boards
- srt-4 swap specialists??
- suspension, exhaust,and electronics
- I want more power....
- Update on my car...
- How many miles on your SRT-4?
- trans question
- TEIN SPRINGS FOR SRT-4 With ACR Handling
- Short Throw Shifters
- Interesting ebay item...
- Vacuum
- oil pressure
- SRT MEET ANYONE?
- 4 Year Old SRT-4....All Detailed
- Parking brake light
- help new srt-4 owner needs help with getting his srt-4 hp up
- plugs and wired
- problems with my srt-4
- i need help installing new boost guage
- Upgrades
- max boost??
- Maddog STS
- mopar stage 2 wastegate
- 3 inch down pipe
- noob
- fuel question
- red light on dash
- Stage 1 Installation
- AEM UEGO
- AGP Trans. Mount
- battery light on dash is on!!!! help pls
- Cardone Performance Calipers
- anyone use synthetic dot 3?
- Which return line kit??
- Forward Motion???
- Turbo timer
- FS: JT Autostyle Lambo/vertical doors
- Best Rims to Buy?
- ignition coil
- Looking into buying a SRT 4, have some ?
- Actron Scan Tool
- Another Return Line Question...
- boost problem help me
- Turbo XS type -H RFL bov
- Normal Boost in 1st
- QUESTIONS TO BE ANSWERED
- new spoiler and turbo timer
- SRT Calipers
- WANTED: Stage 2 SRT-4
- what is a wideband
- Mopar Stage 2 upgrade VS. Boost Controller?
- 2 step
- FS: Mopar Borla Exhaust, ATP 3in Downpipe, etc.
- NEw Car
- bigger injecters
- RT EARNEY EXHAUST MANIFOLD FOR SALE!!!!
- FS: Stage 2 PCM
- DTEC controllers
- Happy Holidays
- I think I need parts
- Different Vin ok??
- ngk irridium spark plugs
- leaking oil UHP
- What's done?
- HELP!!
- HELP!!
- My impression on Caliber SRT-4 test drive!
- Max Boost Stock?
- Oil Pressure gauge
- are eibach springs good?
- What Stage?
- Is my fuel pump giving out or what?
- Weapon R Oil Catch Can
- O2 sensor bad already?!?!?
- Tires
- catch can not catching.
- front emblem
- Help me make my decision on selling my stang for a srt4
- Just installed the AGP bones
- rims...
- rpms acting wierd??
- Selling Dtec FC Packages .
- need help on deciding on getting stage 2...
- NEED HELP WITH CODES...
- 3 inch TB system
- flamingpinhead offline for a bit
- fuel return line
- Help with AFR's
- Catch can
- What car soap do you like!
- Your duel Exhaust!
- MIL Eliminator/Exhaust
- can you put a external wastegate on a stock ported turbo?
- Any SRT-4 clubs near Corona CA
- been stock long enough
- OT: Caliber SRT-4
- Blue 04 SRT-4 for sale!
- New website
- Check Engine light
- Need a little advice
- Please help
- boost guage
- BOV's
- Apexi AFC Neo
- alternator amps
- 6 Disc Changer
- Hint Hint
- help wit ma stage 2 wastegate on how to adjust it
- NEED SOME SERIOUS HELP
- Cold Air Intakes
- Flamingpinhead Will Be Out For A Short Time.....
- About Darrell Cox Racing
- battery help???
- wondering what Exhaust to get I NEED HELP!!!
- STS info
- high strength lugs
- race gas
- some srt4 advice
- New Maxxfab Items=Funny AFR?
- WHAT SHOULD I SHIFT AT (RPM)
- E-Brake
- Mystery Chime?
- About FC
- ma check engine light is on
- Any one have a boost/vac gauge for sale!?
- Benefits of 91 thru 94 octane?
- THREW A CODE P0038
- Can you have something in common with a service manager?
- normal or not
- Any one have a wga for sale?
- need help
- Boost Gauge Problems
- Exhaust Opinions
- Warranty
- srt swap
- Correct SRT-4 Winter Startup and Shutdown
- srt-4
- Took delivery,then BAAAAMMM
- new stage 2 ecu
- the dashboard
- grrrr
- I WENT TO THE TRACK
- NEED HELP BAD!!!!!!!!!
- Water/Meth or Intercooler?
- GReddy Profec B Spec II Boost Controller
- FS: Mopar STS
- Thanksgiving
- Hardpipes
- Please check my shopping cart.
- Car and Truck of the Month, Get Involved!!!
- ENERGY SUPENSION LOWER CONTROL ARM BUSHINGS
- Uncooperative 2nd gear
- *Emptying Oil Catch Can*
- wideness of tiredd!!!
- FROUNT MOUNT!!!!
- pros and cons to wheel spacers
- Motor Mounts
- Getting an srt-4!
- SRT-ford
- wild graphist wanted $$$
- PNW people
- help please
- help please
- Inner Tie rod Please help
- Ride Quality Question
- boost leak help please
- what should my car be hitting at the track
- Love my SRT so much that....
- Fuel pump Question!
- BONZ SRT-4 COLD AIR INTAKE
- FS: Mopar Short Throw Shifter Neon/SRT-4
- satge 2 or fuel mods
- I just beat a BMW 335 twin turbo off the line
- srt-4
- My New 415whp 50 Trim SRT-4
- Need help, sputter, oil leak, brake pad fluid reservoir
- transmision????
- need help with wastegate
- holding off rust
- srt-4 insurance costs
- Tires
- stutter while accelerating
- My car??
- Question about stage 2
- four point harness f/s
- S1
- bov kit?
- Need Help--Fuel Issue
- p 1188 code.
- i went to the track last night
- FS. Mopar exhaust and BOV
- Sound heard while in higher boost
- Gas Mileage?!
- looking for a stock ic
- MOPAR BOV!!!!!!!!!
- AGP Doggy Bone
- Apexi turbo timer
- U110C-NO FUEL LEVEL BUS MESSAGE
- Boost
- srt spoiler!!
- anybody have a front srt4 axle for sale
- for sale
- Kaminari Carbon fiber hoods
- About turbo Kits
- need a little helo
- srt4 sound
- HELP!
- where to get the car tuned...... finally..lol
- P1188 TIP SENSOR PERFORMANCE
- MOVED: Interesting read???
- mopar bov and ptp wastegate
- caliber srt-4
- tranny fluid change
- FOR SALE 2003 SRT-4
- trans problem, anyone else?
- Custom badge F/s!
- help P0234 overboost performance
- new injectors
- stage 2 map and tip sensors
- What happened?
- Wastegate or boost controller or both
- TUNING METHODS
- HOW TO: Oil and transmission fluid change
- OCC setup
- p0420
- stage 2 help
- NEW in box Turbo and Manifold for a 2.4 L SRT4 Engine
- stiff gears
- How much is my SRT-4 worth?
- price too high???
- Want SPOILER
