PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43]
  1. Aftermarket tail lights and bulbs
  2. Torque
  3. Leaking
  4. Service Engine Soon Light
  5. Wide Body Kits
  6. cowl hood?
  7. Huge 1996 Dodge Neon Problem
  8. cat removal
  9. will this really work?
  10. Neon Diffrences
  11. weight redux
  12. Locking fuel cap
  13. Wiring Diagram 98 neon Sport
  14. help me win a 50$ bet?
  15. Nitrous
  16. Civic vs Neon
  17. throwing codes... damnit
  18. 550 HP Neon!!!!!!!!!!!!!!!!!
  19. Exaust
  20. Step by step
  21. What do you think of this??
  22. valve lash?
  23. Custom Dooor handles?
  24. '97 Sohc, is the starter really this bad to replace?
  25. My ideas
  26. hey i got a problem :(
  27. what it tha weight size for tha 98 rt
  28. what it tha weight size for tha 98 rt
  29. oooooooh nooo !
  30. 96 Neon
  31. A few Questions
  32. I need to know what size a stock 95-99 neon fuel door cover is?
  33. side moldings
  34. Headwork anyone?
  35. 99 Neon Relay question
  36. Transmission is rough, speedo cuts out
  37. Evap canister?-code 31
  38. 96 neon won't start
  39. Parts please...
  40. Gauges
  41. 1997 neon fans not coming on, need fan module advice.
  42. My NEON is possessed! Flashing lights, dies
  43. Brakes
  44. Interesting question
  45. what would you do next?
  46. sucked some H2O!
  47. New Seats!
  48. Motor mount
  49. gas gauge question
  50. intake/throttle body question
  51. loose windows
  52. vacum line
  53. Relocate Battery to trunk
  54. chikara vs pacesetter
  55. el glow guages/aluminum guage overlays
  56. 96 Sputtering problem
  57. engine for my 96
  58. I need help on changing a starter!
  59. Pre-Orders for new LSD
  60. car won't start
  61. Leaking
  62. fog light fuse
  63. My 96 is in the repair shop
  64. Studdering '95 neon
  65. Oil drain plug location?
  66. Oil in coolant
  67. yellow lights
  68. The gods of irony!
  69. DOHC cold air intake questions
  70. Projector Headlights.....
  71. 1st gen exhaust system
  72. Head Gasket advice
  73. cold weather tick
  74. Mitsu turbo?
  75. underdrive-overdrive
  76. e.t.s.... my first run
  77. Motor mount question
  78. iceman CAI
  79. wat type of engines can i swap into my 95 neon
  80. SOHC/DOHC COMPATABILITY
  81. Pullin some codes
  82. Change the mileage on new headunit???
  83. Neon body kit recommendations
  84. tell me about your neon
  85. Reset PCM= Horrible Mileage
  86. rpm problem
  87. dragging noise
  88. passenger mirror help
  89. 96 neon speedo quits intermittently
  90. I REALLY need some help here guys...
  91. exhaust manifold
  92. Neon no start problem...
  93. Cruise control problem...
  94. Wheels and Tires
  95. Intake scoop
  96. changing engines
  97. Squeeekin on down the road...
  98. rough idle when cold
  99. turbo
  100. auto trans to manual.
  101. Stumped
  102. 2-Door New Neon?
  103. ACR v.s. New style
  104. My Neon Is running badly
  105. Hey yall, new member w/ 97 probs
  106. More HP
  107. neon worth
  108. Reverse Lights! Help!!
  109. 97 Neon, 4th injector wide open full time
  110. I NEED HELP
  111. How should I fix this?
  112. 95 neon speedometer
  113. aem intake
  114. got a new (old) neon and have some problems with it...
  115. Front Wheel "Clicking"
  116. Running rich, WHY! and high pitched noise and mod question :D.
  117. DTC P0172= Fuel rich problems
