- New Exhaust New Sound Suggestions
- Oil seepage from Camshaft position sensor area.
- for sale..
- To do the struts now or not?
- Brake parts compatibility?
- heater hoses
- Wired buzzing noise coming from inside the dash ( interior lights relay? )
- couple problems
- Timing issues
- problems again
- cranking but wont start
- Burnt????
- Water intrusion
- torque wrench + extension formula
- Oil light at idle
- 1995 plymouth neon 4 sale
- Left turn signal problem
- sparkplug?
- new here and bad news.....
- Question Throttle Body / Intake Manifold 99RT
- Wierd EGR problem
- anyone want to trade a atx car for a mtx car
- Introduction and a question
- strong smell?
- Cranks for a while before starting
- fuel pump
- can't sell my neon
- Clutch question
- How to replace alternator belt and P.S. & A/C belt
- head gasket sealant?
- 96 into 95 swap
- timing question
- Removing window crank
- Car almost stalls out when at a stop?
- removing of the cat?
- Shift light on 98 R/T
- timing belt removal
- help wit findin cams and pistons
- Car stalls for no reason
- 97 SOHC rad. fans not working
- 96 ecu mtx and a 96 wire harnes
- radiator fans not working
- crank pulley bolt broke
- Need help passing emissions...96 Neon O2 and EGR not ready
- speedo not working.. please help!
- Car too low, raise height?
- Anyone want to trade from Konis & Mopars?
- 95 engine going into a 96
- belt for ac and power steering
- FS:95 dodge neon
- Squeeking and creaking front end
- Anyone know about these?
- I dont want to leave the neon world
- Coilover Problems
- 97 SOHC trans problems
- 2.4 2.0 head question.
- Help please? 1995 neon
- lol....
- headgasket?
- my 99 neon wont start
- will these?
- Interior Lighting Issue
- motor swap done runs great but now it wont start
- Any one know how to take the A/C out of a 97 coupe neon?
- misfiring?
- Turbo Installation
- parting out a 1g dodge neon
- 2.0 DOHC engine
- dtc po140
- clutch for 1997 dodge neon
- power steering bypass?
- FS: 98 ACR $1200 (read description please!)
- Bad Idle
- harmonic balancer removal
- Dies at random
- 2nd Gen SOHC Header on 1st gen?
- srt swap
- DOHC 2.0 with ATX
- my fuse pump fuse keeps blowing i need help bad
- Looking for Upgrades Under $100 (Please Post Reply)
- Parting out a 99 dodge neon sport dohc car
- Update on the engine problem.
- tap knocking noise
- '95 Neon - way to test ECM?
- noise in front end?
- 95 in a 96 engine swap
- Does anyone have a spare starter laying around?
- car throwing new codes
- finally cai ordered
- blinker light on dash
- 95 Plymouth Neon vs 95 Plymouth Neon Highline
- 1996 neon help
- Please need help, car wont drive anymore after 3 miles !!
- 95 neon window clips
- tell me if you guys think its worth it?
- Head Question???
- 96 to 99
- My 1st Gen work log. The rebuild!
- will a dohc fuel rail fit a sohc engine
- misfiring issues...its somethin simple
- best battery/hookups to buy for a neon?
- Need Engine Wiring Harness for 95 Neon DOHC
- blew a timing belt
- asking before paying for it
- Window
- Heater Cores are...
- New to me 99 expresso, mods?
- trans problems
- Radio--Electronics
- any ideas? on cruise control
- 225/50/17 work?
- painting
- Keyless entry on neon
- horn help
- has any one ever?
- buildin a stroker could use some advice
- parting out the neon
- where can i mount my 3.5" speakers
- found a
- small problem....help me out
- VSS swapping???
- Possible problem?
- know what is wrong?
- Extremists Anyone?
- Painted intake manifold
- think i found the problem
- header
- Clutch question
- battery relocation question
- does any one on here ...
- kickdown switch
- Anyone?
- I can't believe it's this hard
- lifting my neon
- torque converter circuit
- im looking for a set of 2 or 4
- oil/fuel mix in intake
- does any 1?
- would a fuse pump relay
- Throw-Out Bearing
- burnt hose problem
- Maybe Clutch, Not sure!!! :(
- how i made my short shift
- anyone know where i can find this?
- Help ASAP!!!
- any one have a 3.0 intake?
- Where do i find?
- downstream O2 sensor
- 3.0 intake!!!!
- fuse problems maybe
- should i pick it up?
- carbon-fiber hood for sale
- Clutch cable help
- any one have a?
- Dodge neon vs Plymouth Neon?
- how much?
- Seafoam help please
- Help?
- Struts?
- Interior design 4 dr
- Change from 4 bolt to 5 bolt tire pattern
- Clutch Question
- regular neon tranny with srt engine
- Ode to Neon
- '98 Tail Light Socket
- new fuel rail
- Car Overheats When On Hills
- Anyone have a...
- steering wheel swap
- How to turbo your neon....
- I want a 13 sec neon
- Wire unplug
- gas mpg
- Intake and exhaust cam?
- whats different?
- Running into probs....
- Yay!!!
- Got it running!
- Help, I'm an idiot :)
- 1995 sohc to dohc questions. please read
- Engine Swap ?
- what size ?
- a little help?
- pcm plugs
- where can i find this?
- Persistant break squeek
- neon camshaft
- $600...to much?
- 1995 Automatic to Manual Swap
- Got a lil problem (hard to explain)
- finally !fixed?
- high volume oil pump?
- 95 dodge neon 2.0 engine swap help
- Getting a neon again! (I hope)
- Quick question
- sohc to dohc
- Another A/C Blower Motor Problem
- Crazy Idle
- Been a While...decided to bring her back to life :)
- Bottom End Specs?
- Troubleshooting my idle problem
- Need Help with Tach Instalation
- 1000cc injectors...only 3 work?!?!Help
- question?
- Idle is all messed up
- could a bad wheel bearing...
- gauge clustor problem
- Damit!!! Exploded axle
- Timing Belt Intimidation
- anyone have a udp forsale cheap?!
- is this normal???
- 2.4 last minute questions.
- Back fires when starting out in 1st
- Rough Idle & Hard to Start? HELP!!!!!
- DOHC swap
- 2.4 egr with or without
- MTX Redux Part II
- #3 cylinder lean condition.
- Road Race cam timing suggestions
- more details on tranny swap...
- Need 99 R/T door panel blue driver side
- got bored this evening
- egr blocked off
- misfire
- cam question.
- Proper oil....
- 1999 Neon grinds in second gear....
- Emergency Fuel Cut Off Switch
- lifter tick
- EGR Valve
- How to paint a car...
- sucked up some water.....
- iat sensor
- just got a 95 neon SOHC need some advise
- paint job questions
- 97 & newer connector pinouts
- compression?
- another question
- 98 2dr Door Panels
- Clutch Help ASAP Please
- PT Cruiser to neon swap
- need advice
- Blowin' fuel pump fuses
- question
- Code 51 woes-96 Neon 2.0 SOHC ATX
- 5-Speed Cables
- 1st gen valve cover
- when you turn your key off ,what shuts the engine off?
- Body questions
- Dodge Neon 98 SOHC
