PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43
  1. neon acting like a pool
  2. TB spacer
  3. NEED INFORMATION!
  4. srt-4 rims on a 98 r/t
  5. Neon Problems again
  6. sister come from college = lots of Neon problems
  7. hahn turbo kit
  8. another question
  9. Question????? PLEASE HELP!!
  10. How to program keyless remote for `99 Ply Neon Highline?
  11. fog lights
  12. what the hell dodi do?
  13. 98 dodge neon r/t questions?
  14. catalitic converter
  15. multiple questions.... 95 neon
  16. Code 14 MAP Sensor
  17. CEL shows a .......
  18. 12 crane cam ????'s
  19. Cavalier?
  20. Swap from DOHC to SOHC?
  21. Please can you help me out?
  22. Restoring Headlights
  23. header? good oe
  24. help
  25. New Tires
  26. Newbie with cooling fan question
  27. Chrysler Radios
  28. Idle down issue, need help!!
  29. 2.2 stroker kit
  30. Coil pack
  31. bumper sticker remover
  32. Please Help - Have Barely Used Computer
  33. Windshield wiper
  34. '96 neon stalling (kinda lenghty question. sorry)
  35. New To Dodge Scene
  36. transmission trouble. PLEASE HELP!!
  37. Advice on these Service Engine Codes
  38. DOHC or SOHC?
  39. Tossing ideas
  40. 2.4 swap???
  41. O2 Sensor
  42. Turbos???
  43. mtx?
  44. race quistion
  45. Making an auto tranny fast.
  46. Best weight oil for tick?
  47. 1998 Neon parts car
  48. Replacing the mounts
  49. APEXi AVC-R Boost Controller
  50. 95 dodge neon noise
  51. It will not start....HELP!
  52. turbo hesitation?
  53. neon -> turbocharged neon
  54. Trottlebody
  55. 2nd gen. radio in 1st generation?
  56. heres my ride.
  57. Neon Won't Start...HELP
  58. Diagnosing some engine troubles
  59. Diagnosing some engine troubles
  60. Article bashes neon!!!
  61. 1995 neon fuse ? under hood
  62. tranny swap
  63. 95 Help!
  64. iceman
  65. Odometer
  66. Wrecked SRT-4 - Parts for Sale
  67. Low compression in one cylinder
  68. how do you take the stock shifter off a 99 neon thats an automatic??
  69. How much boost can a stocker handle....?
  70. Speed Sensor
  71. Throttle position sensor
  72. Need Info Neon 96
  73. Stalls after 20 minutes
  74. *Dodge Neon Pics 4/26/06*
  75. Love My Neon
  76. Throttle Body
  77. srt4 front bumper
  78. need some rod bearing help here!!!
  79. neon automatic gearbox!!!!
  80. head gasket problem!
  81. Suspension!
  82. GRRR HELP!
  83. Side ways hood?
  84. Helping a co-worker
  85. pcm question
  86. fuel in oil?
  87. compression question
  88. cam questions
  89. 2ND PLACE
  90. What is it with New Sensors for 1st Gen Neons
  91. Changing starter on 95 neon
  92. will a 99 neon starter work in a 95
  93. Help - No Spark on rebuilt Motor
  94. iddle problem
  95. Exhaust pipe
  96. starter??
  97. where is my door jamb switch?
  98. broken timing belt - bent valves?
  99. code 3-4-3-5-5? Engine pulling
  100. PCV location on 97 neon?
  101. sugjestions?
  102. mopar ecu
  103. ugly exhaust sound
  104. STUMPED AGAIN!!!
  105. 96 dodge neon 2.0 sohc fuel pump fuse is blowing
  106. how do i replace my door windows?
  107. If its not one thing its another.
  108. Dual Exhaust?
  109. 1qt oil in the intake mani?? WTF?
  110. good bottom end rebuild
  111. Where can I get a raced prepared neon?
  112. problem after problem
  113. how to port and polish
  114. Need dash panel
  115. o2 sensor
  116. egr ?
  117. new custom cold air intake pics..
  118. Motor suppplier
  119. steering wheel
  120. more vroom vroom
  121. Help Help Help!
  122. where is a good cai
  123. need pics of cold air intakes
  124. New Battery Needed...
  125. Roaring sound coming from front end?
  126. weird spark on cylinder 4
  127. Stage 2 Clutch and aftermarket flywheel
  128. AFTERMARKET RADIO
  129. zo6 and mustang gt
  130. fans?
  131. dodge neon indy intake manifold
  132. Expresso
  133. another wiring problem: dead battery
  134. Oil in 4th spark plug well
  135. bad clutch??
  136. Its all making sence
  137. turbonator quistion
  138. r/t neons and 1/4 mile times
  139. good speed/performance mods
  140. 98 Neon overheating
  141. 95 neon VS 94 civic hatch
  142. New Neon owner
  143. Where do you connect a scanner
  144. Sea foam
  145. runs like poot again
  146. cam gears
  147. spark plugs
  148. smoke ?
  149. code 37!!!!!
  150. more suspension
  151. 2.2
  152. 2002 2.0L SOHC into a 1995 Neon No Spark
  153. LEAKING ANTIFREEZE? WATER PUMP?
  154. cat question
  155. Xenon Bulbs
  156. momo Steering wheel
  157. it doesnt start 2.0 dohc
  158. Questions...
  159. CAI Question
  160. is it legal
  161. Neon weird problem
  162. guage cluster problem (yes i read the faq)
  163. CAI
  164. pls help
  165. A way to fix side piston rod play?
  166. check this out
  167. turbo
  168. tranny swap question
  169. putting a neon tranny in a eclipse
  170. oil in tranny fluid
  171. oil in tranny fluid
  172. topped out
  173. Hooking up neon to laptop
  174. compressoin?
  175. ATX fluid drip in 96 SOHC
  176. screeching sound
  177. True or False
  178. race qustions?
  179. my turbo
  180. Tach hookup
  181. 0-60 IN LIKE 18 SECONDS
  182. code 11
  183. air filter
  184. N20!!!!!!!!!!!!!!!!!
  185. Catalytic Converter
  186. questions
  187. Bumper Covers
  188. engine swap
  189. PROBLEM AFTER UPGRADING MY THROTTLE BODY
  190. Issues when off the gas...
  191. turbo from eclipse
  192. horse power
  193. rpm's
  194. no reverse lights
  195. blew my neon
  196. my car
  197. Cruise Control Vacuum Accumulator
  198. car wont start
  199. a lot of noise
  200. need to know what apart is called
  201. rough idle
  202. certian type of switch
  203. turning signals on mirriors
  204. 97 Neon Doggy off the line
  205. curious
  206. why why why what is it
  207. Running car just off battery?
  208. Idle Gremlins
  209. Twin turbo neon????
  210. carefull with ur 5-speed
  211. Should i get new rims or a new body kit?
  212. Power problems....
  213. my 96 dodge neon
  214. low end power
  215. thumping in rear
  216. blowing brake light fuse
  217. where can i find
  218. CAM SENSOR?
  219. Oil Leak Help
  220. Here is my ride what do you think?
  221. taking engine out problems
  222. repair manuals
  223. 99 suspension mods
  224. what to do next
  225. window crank
  226. Turbo Oil Line
  227. Problem with Neon
  228. squeak coming from wheel well
  229. cam timing gear question
  230. water in spark plugz?!?!?!?
  231. Something to think about or do? conterversal
  232. vacuum leak code
  233. Running like poo
  234. Timing marks
  235. Another bad find. Low compression
  236. 95 NEON FRONT BRAKES
  237. 98 dohc neon to a 2.4
  238. Bottom end
  239. Help! Starter changed, still won't work!
  240. KNockin NOise?!?!?!?!?
  241. Manual transmisson noise
  242. rear disk???
  243. Weird spark after timing adjustment
  244. Gas Mileage
  245. How to time DOHC motor?
  246. 96& 95 neon parts
  247. 95 cam in a 98 will it work?
  248. srt-4 rims
  249. low fuel pressure?
  250. seat covers?
