View Full Version : 1st Gen Neon
- Repairs for high fuel pressure (check engine light)
- need advice about my neon
- Weird light on dash?!?
- Leaking tranny????
- center cap problem
- Wheels/ head info!!!!!!!!!!!!!!!!!!!!!!!!!
- location of o2 sensor
- Oil in plug holes???
- d i y motor mounts....
- New Engine Time?
- looking for throttle body...
- spark plugs
- 95 Neon Engine Swap NEED HELP!
- back seats
- sensor diaghram
- high idle
- Mtx swap issue, Cruise Control
- dumby lights don't always come on when engine is started.
- 96 neon DEAD
- witch block
- Question about springs/camber....
- 98 Neon stalling/not starting
- Intake on Automatic?
- Spark on only two cylinders.
- need help
- alarm
- neon problems help!!
- mani adapter for srt...
- + 20HP performance chip
- head light covers
- Gauge Cluster Swap
- LED bulbs
- tire size and clearance
- underdrive pulleys ?!
- ?s about putting srt4 parts on 98 neon
- Vacumm line maze
- throttle body help...
- what do i have?
- i hate my clutch
- Engine computer???
- just got me neon
- You know you are addicted to 1st gen neons when....
- 96 SOHC 2.0 Crank Shaft sensor
- radio problem
- Has Anyone rebuilt their engine?
- If you have stalling problems, LOOK HERE FIRST!!
- Head Problems or What?
- disc brakes
- Codes
- shaved neon
- Good Strut and Spring Setup??
- replacing speakers in back
- entering into the neon world
- Fuel Filter Replacement
- DON'T GET CAUGHT SPEEDING
- Door panel
- newbie needs help
- Blinkers, Fan, Radio don't come one!
- cams and gears
- header and intake
- Gasket question...system too lean(Bank1)
- 2.2 stroker kit?
- Ok got one for ya (crank pulley alignment)
- SMOKING NEON
- Stalling Problems
- ecu
- headers
- after market cruise control
- Used turbo
- racing advice
- Slight miss.
- mattdog 2.0 sohc to srt4 adapter
- which pcm
- Shifter Diagram
- 2.0 intake
- intercooler kit
- 95 neon fan stays on
- 1999 Dodge R/T - what's the red light under the climate controls?
- so i decided to...
- need wire help - installing starter/alarm
- magnum head on a 1996 dodge neon sohc
- No heat on 95 neon
- Donate PCM
- 1998 Neon Diagnostic codes Help!
- What Can I do with $2000?
- who has a 95 sohc??
- car misses no trouble code but egr suspect
- problems with the neon
- K&N filter
- 95 sohc engine in a 96 sohc
- throttlebody spacer?
- remote starter
- No power and slight hesitation
- New guy here
- srt 4 head on 1st gen sohc motor?
- differnt modles
- POWER PROGRAMMERS?????
- 1998 Neon starter
- weak heat 1g
- Locked steering
- Fixing Breaks
- Valve cover gasket.
- Throwing Codes
- Threads on Studs??
- wanna race SCCA
- Fuel filter replacement
- Engine Control Module
- dohc head on sohc
- where to find new headlights
- Reading Trouble codes
- Hesitation Problem
- Timing Cover......
- Quick Question
- miss after egr vacuum hose repair
- I have a couple questions
- I didnt realize there was a difference
- 2.4 swap?
- Stripped plug
- critque my build ideas PLZ!!
- Thinking about getting a neon, any thoughts?
- 98 neon stalling.
- got a Q, would a motor from a daytona fit in my 95 neon
- help 95 neon speakers not working
- ok what to do
- 1996 neon
- poor running
- starter
- squeeking noise when i shift gears
- poor dead neon (estimates?)
- 98 neon not starting.
- DOHC, SOHC? whats what
- Alternator Replacement Please Help
- head lights r backwards
- Mopar performance PCM
- code 11 on 1999 neon pls help
- MOPAR ECU
- Fan goes on and off ??
- 2.4L 1st gen?
- Engine randomly shutting down - Help!!
- New Neon owner here !
- Aftermarket Tach
- 18' wheel questions...
- Question About Screamin' Demon Coil Pack/Plugs/Wires
- 95 Neon RPM JUMPSwhen switching gearswith A/C on.
- oil on plug tubes??
- i dig the car but....overheating
- Headlight help
- Looking for 2.0L SOHC intake manifold.....
- Headlight Conversion Help
- code 42
- 98 2 Door Speaker Wiring
- jeep Tb swap?
- Aftermarket Valve Cover for 98 SOHC
- 98 TYC Diamond Clear Headlights.?.?
- DAWGIN' on my 96'
- sputtering neon, anyone have an idea?
- My Neon's new sound of the month :(
- How do i remove the door panel covers
- 9596979899 DODGE NEON FRONT LIPS**
- need body kit for 4 door neon
- New Owner
- Window rattle
- fuel delivery problems.....still, any help?
- 2.4 turbo engine buildup
- Help - Random Miscellaneous Part
- Buying cold air, asking advice.
- supercharger
- 95 Neon Power Issue??? Help!!!
- Info on this header?
- Alarm problem
- Turn signal problem
- need help to build a 98 r/t for dirt track
- EGR solenoid
- please help
- Civics taught all about 2.0s
- How to beat a 6 Mustang
- Where to find it?
- COLD AIR
- Door disassembly
- cylinder head problems....need help ASAP
- fuel pump
- Neon Pinging
- Speedometer and Odometer not working.
- 99 Neon Sport code reader can't link with
- Rad cap blew off?
- Help 98 neon R/t
- A/C Compresser????
- storing ... i guess not
- Mopar Springs
- ecu up grade?
- nightshades
- rims and tires
- Auto to Manual Trans Swap Questions
- neon motors???????
- FAN HELP, UDP for sale
- 97 Plymouth neon not starting
- engine and tranny replacement
- 3rd Gear.......... WTF ??
- BYPASS A/C COMPRESSOR
- dodge neon tansmission into a 420a eclipse
- tranny swap help!
- axles, transmission problem
- CUSTOM TURBO FOR 95 SOHC
- srt-4 turbo and manifold on 2.0 dohc?
- The Springs?
- 1997 Neon I need some help
- 95 neon sohc to newer dohc motor
- codes 23, 25
- Need Help With 96 SOHC
- NGC SRT4 swap into 1st gen Parts list
- buying a '98 neon what to check and expect!!!
- engine life of a 1997 dodge neon
- New Clutch
- Help
- Water Leaking Inside Help!!!
- what is code 42
- interchangeability. 95 97
- #2 misfire
- Finally Turboed
- Different cool air intake
- head gasket replacement
- Power window motors are getting pretty slugish.
- Code 32 EGR system failure
- radio problems
- Compression ratio???
- Need help with my steering colum
- Double clutching....
- 95 neon stalling
- 2.4 swap walkthru?
- Fuel tank neck filler?
- can you get a turbo on a 95 neon sports
- How do I make my 1st Gen neon faster.
- Nos for the ride!!!
- need a new alternator
- My Fuel Pump?
- e-brake ????
- headers
- Cylinder #1 MISFIRE
- Clutch cable maybe?
- Neon engine
- Tranny help!!!!!!
- rim questions
- 99 DOHC tranny problems SOLVED!!
- do I have a bad fuel pump or somthin else?
- Bored TB
- BOUGHT A NEON
- 97 neon sport 16v dohc
- big changeover questions
- Wheel questions???
- eclipse rims on a 98 plymouth neon
