View Full Version : 1st Gen Neon
- Power Steering
- Question
- Engine Oil Cooler
- Shift Cable bushings
- chopped shifter????
- Neon Sensor and Part Locations
- Severe Hesitation - no CEL codes
- PCMs: SOHC to DOHC? Worth it?
- Scan code P0601???
- -Head & Tranny Q-
- spark timing and cam timing
- Brake problem
- oil puddle under my car
- Question
- My 97 Dodge Neon Tie Rod
- piston question
- dohc engine
- And that was it...
- 1996 Dodge Neon Problems
- Plymouth Vs. Dodge width...
- bigger brakes
- throttle body Q
- got my turbo today!!!
- kyb gr2
- Help! Something is Wrong!
- two disapointments
- help please....
- cam sensor code problem please help!!!!
- short shifter
- o2 Sensor
- bolt-ons????
- turbo help
- Howell Automotive
- Power Lock Question
- Help!
- 3.0l intake filter
- o2 and Converter
- O2 Sensor
- Brake Master Cyl.
- Interior Part Interchangeability
- 98 ACR racing SRT-10
- would this be a quick temp. fix?
- door fixin question????
- The Tao of the Neon
- srt-4 seats
- Couple questions??? please help!?!?!?
- got a new toy today!!!!
- lash adjusters
- i think i know the answer to this question....
- Horn
- Rear Seats
- driving slow, motor dies
- Dynomax Exhaust
- AC
- Motor mount issue
- in my 99 r/tsrt-4 swap ??????????
- 98 neon, EGR problems
- motor mounts
- Random Vacuum line on passenger side...
- rim question
- Overheated and then ??
- Code 45????
- another engine question sry...
- cam question
- guage instalation problems
- Wheel Noise
- o2 sensor question
- head gasket
- V8
- 3.8 from a windstar..hmm...
- cluster problems
- Tachometer Install Problem...
- TB at last
- '97 Neon cooling fan problems
- Which fuse/relay
- NOS
- Is This Safe (or Practical)?
- 96 Plymouth Neon FS
- Can u swap...
- Sad day on wednesday...
- AIT sensor
- the unthinkable happend
- old turbos
- Tranny????????
- Needing help
- need some info
- popping in exhaust
- supercharge quiston
- engine noise??
- 97 dohc for sale
- trouble shoot
- Leaking
- My new whip!
- 96 neon trans
- fuel and rpms
- Engine Rebuild question...
- 98 R/T wont start on its own.
- question and a lesson
- click, click, click ... and nothing
- Header
- euros vs. altezza
- shifter
- had some fun this morning
- flowmaster exhaust question
- cool cluster
- Front end bushings and Tie rod ends
- difference of udp
- cam gears???
- Fuel System Problems on a 95
- sway bar?
- custom,diy, ghetto
- anyone ever DIY P&P intake manifold??
- just wandering
- 1995 Dodge Neon With Mods
- engine sound??
- Throttle Body Question
- exhaust
- A Few Budget Modification Questions
- Some performance Q's....
- 1995 Neon Overheating & No Flow Through System & code 22
- starter? or what?????
- Brake Noise
- Can anyone give me some links and suggestions?
- short shifter
- Need a new engine
- engin swap and etc
- -Dirt Track Racing-
- which is faster?
- camshaft
- cheap turbo setup
- Exhaust System Suggestions
- srt-4 shift set up
- fan issues
- 95 NEON WON'T START NO SPARK HELP!!!!
- installing an amp onto a stock deck
- Anyone a turbo expert?
- hard into reverse
- DOHC issues
- lowering car
- Rear View Mirror
- update on mods!
- Dodge Neon Performance Book
- Recommendations Needed!
- A/T to M/T swap
- 97 Neon with a 3.0L V-6?
- 1995 neon shifter cable
- brakes from hell...
- TB ?????
- Me back, some problems with my neon :(. Helpy.
- Timing belt broke........
- shift knob
- What yrs will interchange on 96 Neon ac compressor?
- turbo???
- Help!!! No horn
- 1996 neon frequent stalling
- New custom cia pics
- cia
- Extra Lighting brainstorming session
- Custom Center Console Speaker Install
- yes, finally!!!!
- Is there a way to reset the trunk lock?
- quick questoin about DIY CAI
- UDP
- SOHC or DOHC muffler?
- Struts/Shocks?
- Spark Knock Evident While Turning Slowly or When Idle
- Wheel Hop?
- i know i asked about this before, but...
- Misfire after 3000rpm
- crappy reception
- Trunk Release
- RPM running low... new spark plugs
- Question about my Neon
- pics?
- lowering springs
- 98 neon code 6c (PO302)
- common sources of coolant leak?
- fuel/speed mixture
- ok, here are the new pics
- new neon, pulled codes, help?
- luggage rack?
- check engine light codes
- rims???
- IceMan Again??
- FS: Stage 1 SRT injectors w/rail
- shift question
- sweet deal
- getting my rims on today
- BRAKES
- back seat covers..
- needed badly
- Fuel filter
- motor problems!!!!!!!!
- 1st gen faq's up top
- 1st Gen FAQ's
- custom
- auto shut down relay
- MTX Fluid
- intake
- auto to manual
- Interior Piece needed
- auto trans fluid?
- neon misfiring...NEED HELP!
- msd dis-2
- quick question
- bulb change...
- roll cage
- sucked up some water
- random gauge failure...
- code 37?????
- EGR Silonoid/EET ???? Where to buy?
- UDP Question Again.....I'm Sorry
- fog lamp replacement
- Engine Swapping and Service Manuals
- 97 neon auto
- streetrace
- Alternator tensioner
- i have a qusiton
- torque steps
- v-afc for the magnum intake
- WOW!!! check this out
- code 0171
- Opinions on Chill Factory with stock motor
- 98 Neon DOHC quitting????
- Tips for Drag Racing?
- smoking
- weird issues, and error codes. 97 sohc auto.
- IN NEED OF
- '96 Neon misses in hot weather
- dome light cover?
- Shift Kit
- UDP belts
- Battery relocate ?????
- AC in hot weather
- lotsa performance questions
- 90 K miles on our 98 Neon!!!!!
- headliner... rear deck question
- Pealing Out
- Stumble when starting
- srt-4
- HEADERS
- Redline..SOHC
- timing
- whats this code actually mean???
- Pullin Hondas
- aye aye aye
- Underdrive Pulley?
- wheel studs
- noob Question
- '95 Neon cruise control probs
