View Full Version : 1st Gen Neon
- will 00-02 headlights fit right into a 1st gen?
- Will 2.0 SOHC head work on 2.4 DOHC block?
- Code 37 and possible automatic/manual trans pcm
- ? on runnin seafoam
- Pos
- wiring harness removal
- power steering question.... delete?? or not?
- well.......its for sale<-----UPDATED!!!!!!!!
- head tick
- WTB TRANNY
- 97 neon radio problem
- FS: low mielage engine block. *pics*
- Crane #18 cams
- I need....
- WTB 96 dohc wiring harness... or sohc wiring harness
- needed: stock 97 MTX computer
- week #1 at alleghany mountain raceway
- Bobble strut
- officially for sale
- torque wrench for head change
- header with cat or not?
- piston removal
- anybody else hate drum brakes
- picked up a scoop today 10 bucks
- well i totalled my car...parts 4 sale
- Dodge neon lower end
- i hate cooling problems!!!!
- Things are finally looking up
- need help !!!! bad !!
- 2.4 SWAP HOW TO... NOT DONE 56K Take a nap...
- Broke as A Joke... and need gas money
- 200hp!!
- sad sad day today
- DONT LOOK IN HERE... LOL
- well...............i got something completly unexpected today.
- Auto tranny
- Morse Brake Pads?
- my junkyard visit.
- pcm and steering wheel help !!!!
- atx tb with or without c/control
- code check with key
- exhuast problem
- need to buy a tranny
- windshield replacement
- alternator overcharging
- 2.4 Sap Info
- Parts For Sale from 95 DOHC neon M/T(Prices Updated)
- Car will start but battery light comes on,, code 41
- Parts for sale. Lowered prices. Make offer.
- reverse hood???
- got her washed...and some new pics....well links...
- After Reading Vote.. does he not realize what 1/4 is..
- no reverse in mtx
- FOAM IN THE COOLANT
- Short Shift Install
- intake manifold clean-up?
- DOHC MTX lots of upgrades - $950
- i need quiet exhaust for a day!!!
- need a front lip
- Radiator Fan Fuse Keeps Blowing
- Vehicule Speed Sensor question
- gauge cluster..please help
- WTB: CAMGEAR
- Head GAsket replacement( 95-96 & Spudster if you're there
- so what would be .. 2.4 to 2.0
- WTB:95 dodge neon engine
- ok...got a ?....
- Codes 12 and 43 after seafoam?
- egr removal
- tb swap
- Speedometer / Odometer Not Working Correctly
- TACHOMETER PROBLEM
- 98 Neon w/sohc no spark after cransk sensor change
- car is down (again) any thoughts?
- The writings on the Wall: Compression Test Results
- Valve Seal question
- no top end?
- FUEL PROBLEMS
- srt-4 turbo/manifold on 2.0?
- header
- Took Her for A Quik Spin Today
- New engine build n/a
- another computer Q
- What to buy next I wonder.
- something wrong with tranny
- oil pump!
- Ebay pistons?
- Computer swap info?
- 98 Neon - overheating, leaking HELP!
- Code P1404 ?
- NEW NEON!!!
- And so begins the project.....any tips and suggestions?
- setting in the new clutch
- How to adjust cam??
- Sensor under battery to what?
- ohoh help fast?
- Aftermarket Clutch
- COLD AIR INTAKE
- engine troubles
- FOR SALE post. Taking offers.
- How fast are you at pulling a stock sohc out?
- For sale... stock and other fun stuff...
- Got the new atx tb on!!!!!!!!!
- Need Help CEL
- FOGLIGHTS
- Need sound advice on brakes..PLEASE
- any strong radiators out there that are cheap.. JEREMY HELP
- GOD HATES ME
- Overheating...new HG
- atx tb
- mysterious electrical problem
- passenger window
- anyone have HIDs?
- got a steal on a cd player at the junk yard today
- Found the problem!
- fuel rail
- 4g63 or 420a
- 97 neon wont start, no power at all
- oxygen sensor! PLEASE HELP!
- Gas mileage suck
- custom exhaust
- Exhaust leak?
- Downpipe's
- removing the bumper thingy
- 1 second faster how noticable
- 97 sohc into 95 sohc neon
- PAINT CODE???
- Question About Repair
- Update!!
- Pistons???
- headlights
- mtx...info...
- WTB headlights
- my 99 neon wont start
- Which should i buy first?
- installing air/fuel gauge?
- Can't remove ignition key
- i need some help.
- WHERE DOES THE TACH WIRE GO????????
- WHY THE FLANGE DOESNT WORK!!!
- will a 2nd gen STS fit a 1st gen?
- might be selling some parts
- Changing the Oil to much
- lets see your neon's
- just wondering if someone would be interested?
- Fuel gage trouble
- battery to trunk
- Engine won't turn on
- timing!!!!
- Wheel Sizes
- White Smoke coming out of Wifes Valve Cover..
- My weekend... 2.4 swap included...
- Important Note on the mtx to atx throttle body switch, all california cars have the funneled mtx TB
- Whats a turbo setup worth?
- fuel psi
- help plz !!!!!!!!
- transmision help
- F Alaska
- broken horn?
- High idle issue... STUMPED!
- Advice Please, Cause of my neon burning oil..
- SRT Tranny!
- clutch for sale
- WTB: stock DOHC pistons
- [Problem Solved!!] 97 neon won't turnover, but clicks..
- no pcv valve (problem solved: new gasket and pcv valve)
- How do I pull off cam gear?
- My 99 R/T *forsale*
- cruise control
- Alternator Got Wet Not Charging Now...
- 2nd Gen steering column.
- lsd vs quaife
- Alternator belt... again!
- twin turboing my 2.4
- I have the worst luck with my car
- help fast!!!
- Help finding oversized valve cover bolts?
- 1995 Neon shakes on takeoff
- Bought atx driveplate/F1 clutch, bolts???
- okay getting P/O radio wiring
- Off I go...
- 2.4 confusion
- no power at 1200 rpm
- MTx ECU in an ATx
- o2 or cat
- want to buy ecuand other advice
- Stuck with motor mount now!!![progess, stuck on one bolt now]
- Battery temp sensor volts out of range
- Supercharger
- Acr ecu in plymouth coffee
- wats better springs or coils?
- battery light
- What ECU?
- ....wow
- 95 neon acr or 98 expresso
- my tachs wrong.... help
- its letterd
- to quote MPX
- just got home from autozone
- aftermarket parts
- gas milage
- swap
- Getting the AC back up.
- project thread
- Turbo 2.0L or naturally aspirated 2.4L???
- Can't Figure out whats wrong
- a/c bypass pulley
- 4g63 will it fit
- headlamp switch problem
- HOW DO U INSTALL A CLUTCH???
- dohc turbo build vs srt build
- fuel mileage dont seem right
- started a parts list what am i missing???
- you know you are a 1st gen owner when...
- projector headlights
- 2.4L installation
- Cam options for 2.4 turbo
- Manual Transmission
- upgraded cam parts
- Check engine light on solid but car runs fine
- want to buy rear sway bar mounts
- source for turbos
- WTB: 2.4 and intercooler piping.
- Light bulbs or the Overlay..
- Is 9:47 a good 1/8th mile time ?
- **Important Notice** Missing Link Reminder.
- HAVE 15 ATX TBS NEED TO SELL
- Water deposit boiling, HELP!
- 95to96transplantneon
- bleeding coolant system
- MPx Rebuild Kits
- Problem: Reverse lights stay on even out of reverse?
- DIY custom gauge
- Code 43
- went to the bone yard today...
- 95 master cylinder Q
- Head Gasket Sealant?
- anyone selling bored throttle body
- transmision overhaul
- Bigger injectors
- project turbo DOHC! pt2
- HELP! Brakes. ASAP Please.
- what year ford or exclipse has compatable bigger fuel injectors with the Neon?
- how much hp after these mods
- lowering springs
- 97 neon with 2004 sebring 2.4 motor swap
- sry to ask
- From SRT4 to R/T
- Delux $1,000 Ebay turbo kit
