PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. check engine light on
  2. Tranny swap????
  3. lip kit
  4. lowering
  5. Might be leaving the family
  6. new neon puller
  7. Clutch install???
  8. Jet Chip
  9. Cracked Head Performance
  10. Aftermarket Filter Problem
  11. Clutch?
  12. need fault code help
  13. RIP Neon
  14. just excited
  15. door panel removal
  16. 1997 Dodge hood emblem
  17. 99 neon r/t with srt4 swap 4 sale
  18. Fart can
  19. help - the engine is shaking
  20. Drop A Bead
  21. smokin neon,,
  22. Neon Problem :(
  23. HELP!!!
  24. I need a UDP
  25. obx camgears
  26. My neon gauge lights and shifter lights
  27. booger bushings...or lack there of
  28. short shifter?
  29. ebay hid kit
  30. ecu question
  31. 99 neon wont start
  32. auto differential trouble
  33. Big chunk of metal/concrete/steal???
  34. e brake handle
  35. need more noise
  36. cross bars in back and info on strut tower bars
  37. New neon today
  38. tint
  39. srt4 spoiler
  40. tire size and chassis ajustment
  41. white face guages
  42. TYC headlights
  43. srt seats needed
  44. pics from the race track
  45. Hi Flow Cat
  46. Cooling problems, possibly gauge??
  47. the best sparkplug wire
  48. Cam change for years?
  49. strut braces
  50. 0-60 times
  51. timing
  52. skunk 2 lowering springs
  53. Don't expect a solution but eh
  54. Tire width
  55. pic of my 95 acr sedan dirt track car in action
  56. Amp Problem
  57. engine bay
  58. need a photo...
  59. shifter
  60. cigarette lighter
  61. getting rid of Neon...
  62. Ebay intake check it
  63. auto trans 97 plymouth neon
  64. 2 Questions ??
  65. new tranny help
  66. OMFG, IT STILL WONT START
  67. Crank Censor?
  68. runs like azz
  69. lowering springs
  70. goin racin
  71. smog
  72. No spark
  73. 97 Neon bucking on freeway, stalling. HELP?
  74. essential tools needed for enginetranny removal?
  75. cam posistion sensor
  76. PCM code 42???
  77. Coolant Bubbling?
  78. Adding Fog Lights to Neon 97 ?
  79. STOMP IT
  80. gallery
  81. ATX removal
  82. anyone selling headlights?
  83. UHHHHHHHHHHHHHHH, HELP!!
  84. short shifter question
  85. help with hose
  86. 3.0L CAI
  87. 95 Neon won't turn over
  88. window tint
  89. 1st gen gauge clusters
  90. sensor location
  91. paint
  92. '95 Neon SOHC engine died while driving
  93. car won't start
  94. Gas Tank Problem
  95. SRT4
  96. FUSE BOX
  97. Help?!
  98. IS IT WORTH IT?
  99. after seafoam...
  100. dit is full but now when i put my car in nuetral and park it makes a loudtransmission
  101. crash boom bang
  102. crazy radiator fan
  103. bobble noise in rear of car
  104. gauge faces
  105. 2edGEN SOHC in a 1stGEN
  106. Seafoam!
  107. 96' stereo wiring question
  108. turbo swap
  109. clock stuck under dash!
  110. Is this piece important? o.0
  111. ATX kickdown lever frozen
  112. shift kit
  113. Engine Swap?
  114. Underdrive problems!!!!
  115. HELP!! Please..buzzing sound..
  116. stalled and wont start!!
  117. srt-4 swap really worth it???
  118. MTX axle seals?
  119. dodge neon parts
  120. nasty headlights
  121. power distribution center
  122. DIY 3.0 intake
  123. What would my car be worth?
  124. check engine light
  125. honestly
  126. spark plugs
  127. springsfactory springs
  128. WTB: Looking for a 4 door, 5sp, Dohc
  129. Dies in reverse
  130. Stratus Engine Parts MIA?
  131. TB
  132. Finally got a wiring harness!!!!!!!!!!!!!!!!!!!!
  133. tb backfires??
  134. Oil PSI
  135. evap valves
  136. ? stock crank pully weight?
  137. Read The Codes Now What To Do To Fix
  138. ITS NOT THE CLUSTER
  139. Length Difference???
  140. Help!! Center Console Removal - 1995 Neon automatic
  141. Cooling fan problem or not
  142. centerforce clutch
  143. Headlights
  144. alot of play in my clutch pedal
  145. Steering wheel?
  146. Hubcaps....
  147. Howell what going on?
  148. 95 cam
  149. lowering
  150. big problem
  151. list to get
  152. mtx swap
  153. wheel bearings???!!!
  154. Help! Oil in the plugs..
  155. rear seat thing??
  156. Replacing Neon Alternator
  157. LOUD steering
  158. New speakers?
  159. HYDRAULIC TIMING BELT TENSIONER BOLT
  160. Shift Knob
  161. Turbo question
  162. Dohc or Sohc
  163. Problems
  164. My plymouth neon project: first car
  165. heads?
  166. My car is afraid! HELP!!!! ASAP!
  167. turbo question
  168. problem fuel line
  169. electric supercharger
  170. mopar pcm with turbo??
  171. trans rebuild info
  172. sohc rebuild
  173. evap pressure
  174. A few Questions about my mtx swap
  175. brakes
  176. transmission case swap???
  177. 96' Neon wont start up! help
  178. Speakers
  179. Blown Fuel Pump Fuse
  180. how much boost
  181. o2 sensor
  182. EGR valve
  183. front lower motor mount
  184. cracked block??!?!?!?
  185. Spark plugs 96'
  186. SOHC & DOHC wiring
  187. specs?
  188. SOHC pistons
  189. bad trans?
  190. engine code
  191. just an idea....
  192. dohc swap questions
  193. Progress and pictures of 95 sport coupe
  194. PCV
  195. faster than 120mph
  196. valve cover?
  197. nos with stock internals?
  198. Neon Weight
  199. 95 neon ports- 96 neon ports
  200. wow i haven't been here in a while...
  201. uh oh another one
  202. turbo help!!!
  203. what head fits where?????
  204. FIANLY HOME
  205. Fiberglass fenders
  206. cams and stuff
  207. 2.0 to 2.4 engine swap newbee!!
  208. crank/cam re-learn question
  209. question??
  210. is number one comapny good?
  211. charge light
  212. 3.0 intake???
  213. pcv hose
  214. What I have decided.
  215. Fender and Door Problem
  216. I'm ready,
  217. help with audio wiring
  218. 2.4 VEHICLES?
  219. how do u remove the headlights?
  220. Bad Fuel Efficiency? 1997 Neon
  221. 2.4 Stratus w/ Turbo
  222. 2.4L engine swap
  223. airbags
  224. TDC question
  225. NEED YOUR HELP
  226. WOW...R/T w/11,000 miles on ebay
  227. sohc engine with dohc head??
  228. welding
  229. broken
  230. For sale !997 DOHC Plymouth Neon Expresso
  231. Tach problems
  232. Crunching sound in Transmission??
  233. 1997 Neon Front Bumper Replacement?
  234. 1997 neon EGR Valve- Where?
  235. fuel filter question
  236. how long can the fuel pump fuse be out?
  237. UDP ??????
  238. intake
  239. pics
  240. fuel pump
  241. what injectors??
  242. My new side turn signals what u think?
  243. code 63
  244. mopar PCM help
  245. 1997 neon SRT 4 swap!!!HELP
  246. Some pics of my Neon..fresh from the car wash
  247. Engine restricted??
  248. ADDING CRUSE CONTROL
  249. oil cooler
  250. r/t progress pics
