View Full Version : 1st Gen Neon
- back seat?
- fan relay
- PCM issues after disconnecting
- Neon Coupe Window Parts, Need Help!
- First Gen Neon / Pt cruiser wheel back spacing
- somebody please help me before i trash the car
- Installed the rear main, no problems.
- 95 power steering leak
- Intake/ TB
- Drivers side window crank does not work
- transmission 3rd gear
- turbo exhaust
- srt-4 rims on 1st gen
- sohc pcm on a dohc
- i think these people are inasne
- Engine randomly does when driving
- what does this go to
- Rear main oil seal..With no pre lube?
- turbo?
- long rods vs stock rods
- mopar performance pcm question..??
- i need help!
- Hey guys new to forum (pics of car included)
- trans leak
- Neon EGR System
- turbo kits!!!!
- speedo gauge info
- Tranny question.
- stroker ?
- wierd overheating issues in both my neon's
- Possible Part-Out
- T9 Allen Wrench
- Help me out fellow neon owners
- Few random questions.
- Hot temp gauge, cool engine?
- Stalling on right turn?
- Weee!!!!
- msd
- silverstar vs PIAA
- keypad
- question about k member frame bolts
- whats going on?
- Normal highway RPMs?
- Running bad, Sputtering. NEON F*****!
- regulator
- 130hp at the wheels or cranks??
- timing belt?
- crash boom bang
- Need opinions
- reverse lights
- magnum
- Fuel pump ????????
- Emissions exempt PCM?
- parts list for a 98 neon dohc
- Question on Transmission
- Wiper Question
- turbo help
- Thanks For Helping Observations and Some More Questions
- PCM Help
- Info Appreciated!
- What ya got?
- oil sending unit?
- Sell the Shell or Fix it? (Pics)
- How hard is it to rebuild a motor?
- FREE parts for the taking!!! FREE FREE!!!!
- rim color
- NEED SOME HELP ON BRAZING MY EXHAUST MANIFOLD!
- arg its back.
- glow gauges help
- what do door ajar & dome have in common??
- RPM drop???
- Srt4 turbo on 2.0 dohc motor
- sensor?
- anyone around ohio need a 95 neon? PIX ADDED!!
- Dash Cluster differences
- Swap Update! MORE PICS!
- best long tube header???
- torque specs on the block?
- what kind
- I searched...can't find a straight answer
- Rims
- Where did you buy your head gasket?
- Looking for performance parts
- wiring
- 2.4 question
- in a word motec
- SOHC to DOHC!?!?!
- Brake Light Wiring Issue
- WTB NEON
- Megan Header
- still lost
- need the atx to mtx swap how to
- snowflake wheels
- Royal Purple
- TB swap.
- Installing a 3.0L CAI
- Timing belt reinstallation
- headlights
- massive oil leak from behind engine?
- clutch/brake assembly removal?
- Bearings
- Dammit Man
- Neon looses battery connection
- lights
- Drivers side brake caliper
- Actron CP9135 have worked perfectly with my Dodge Neon 1995!!
- Pacesetter Headers
- 1st gen SRT swap how to; using ngc and the nv-t350
- fuel filter replacement
- Mopar PCM
- what makes a neon a highline?
- vacuum lines
- wiring
- transmission bolts
- Please hurry I need help
- help please!!
- Big Problems....
- Exhaust
- radiator fan wire colors?
- P and P head work on 95 SOHC
- ksport lowering springs
- Dont you just looove tickets
- shifter and coilover
- p1899
- evap purge canister/selonoid
- coilovers
- brake upgrade
- depo headlights ebay
- Wind noise
- brake issue
- 1st gen PCM interoperability
- Well I still have no luck Please help
- heater core and fans
- Headlight bulbs
- A/C Compressor bearing.....
- stuff for autocross
- NEO-ohio
- still not right
- need help
- Car dies when cold
- neon won't start
- I need to replace the PCM
- My bottom end budget build PIX ADDED!
- Location
- Car won't Start with Key Please Help!!!
- wheel hop problem
- Where can I find a 2.4L engine??
- Turboing a 97 DOHC??
- R/T squiggle seats, Dynomax exhaust, '95 cams, dohc muffler, and taillights F/S
- acceleration problems
- Dipstick
- indiglow gauges
- 96 Neon wires broken front under radiator
- 96 neon speedometer
- some parts fs
- 98 neon r/t
- Why do my fans turn on with a cold engine?
- code 35??
- CEL + err code makes no sense
- Replacing EGR VAlve
- EGR Valve
- This cars startin to cost me
- Short Shifter
- KYB GR-2 struts
- wrong trouble code!?
- Rota Wheels
- Raining Neons : )
- clutch?!?
- Rear door handles
- Auto Trans id question
- My teacher wants to race me
- Picked this up from a junkyard
- Southern California tuners
- What the heck do voltage and power steering fluid have in common?!!
- Air intake question
- sohc engine buy
- swap by year
- removing headlights
- O2 Sensor question
- camshaft
- 1995 Neon Paint Colors
- FS: 2.0L DOHC Race Short Block w/ Stand Alone EMS
- head gasket
- srt-4 wheels on lowered 97
- metal gas tank pump/filter problems
- Forging rods
- timing belt
- 99 neon wont start
- Overheating but not really overheating.
- LOOSE MANUAL SHIFTER
- A Little Help
- QUESTION???!!!
- rising rate fuel regulator
- 2 more questions
- TB
- Body Parts
- I believe I solved the idle problem!
- car shudders, need help to fix
- 1997 dohc head reinstallation help
- udp
- udp
- whole swap
- confusing new neon
- DOHC harness
- Where are you from?
- help...
- How do you install new rear struts?
- Dash Cluster.
- srt-4 wheels on a neon?
- whats the difference?
- need help, idle
- Going turbo... HELP!!!
- tranny swap
- codes
- stage 2 axles?
- Neon Questions
- Spark plug tube seals
- engine surging at wot
- catch can
- engine chugs on startup and runs like ****!
- No Engine Spark
- Really Stupid Exhaust Question
- Any Trick For That Lower Motor Mount?
- engine struggles to stay running
- cylinder head wont come off
- 98 Neon sunroof
- Idle Stall (I didnt see it in other threads)
- MPG
- Cleaning Head Gasketing Surface
- i failed smog
- Valve cover removal question.
- Performance computer question.
- wtf is wrong
- Where to buy a front lip..?
- Engine Swap Possibilities
- PCV valve
- PCM pinout
- Does anyone have a 1998 Neon service/repair manual PDF??
- head gasket removal
- Muffler shops?
- Window Crank
- 4k rev limit????
- supercharger??
- adjustable cam gear ?
- two stage turbo
- Dear God, Let It Be Easy.........
- Code 51
- newbie
- battery light ON
- eBay short shifter
