- Exhaust clamps?
- 99 mtx r/t upgrades cat + intake
- 19lbs accel injectors
- speeding ticket today
- turbo W.I.P. pics
- cv joints
- this was the only message from the CEL
- engine Code
- Under drive pulley?
- head unit
- 97 sohc 2.0 2door ATX $1000
- new motor
- engineProblems
- bad clutch?? bad tranny??.....
- re: carpute spex thread closed?
- tinted windows
- Things happen in threes...
- HELP!!! I need help to go to work tomorrow!
- Ebay Gauges
- 2.0 SOHC head on a 2.4 block
- lol dont freak out...
- Shifting.
- Computers
- have a serious problem now
- aeromotive fpr
- Clear Coat
- how fast?
- Window regulator
- Can someone tell me whats wrong?!?!
- I think I have a problem....
- How to take off the letters on the back of a neon
- Neon Header
- Torque
- Head Gasket?
- DOHC
- bigger brakes
- tranny shot?!
- Is It true???
- damn...
- lambo / vert conversions?
- turbo test fitment pics
- New to Neons
- Neon dies out
- Injured my baby...
- clutches
- solinode clicking thing? lol
- puzzled electrical mess
- Is it a Blown headgasket?
- JET Power Control Unit
- body kit???
- couple minor porblems now....
- head replacment question.
- turbo fuel return line question
- question
- Fuel injectors
- times
- my car lunges
- Please HELP!!!
- Compounds?
- EGR
- SOHC Turbo/NOS
- Headlight switch not engaging the headlights
- Rear Disc brake conversion
- DOHC
- was is the difference between neons?
- Power motors
- Enigine moves a lot.
- well, i sold my r/t
- my staHELP!!
- tires
- srt turbo question
- Swapping Oil Pans
- Cold air intake
- sorry but i had to share
- Looking for....
- Bobble Strut Construction
- Is this an E Z fix?
- No hissing on the gas cap?
- Brand New here
- port match plastic manifold
- Did any first Gen come with a CD player as a optional extra?
- hahahaha look what i found
- Overheating
- Maybe Leaving :(
- Pic of my Australian Right Hand Drive Neon if your intrested.
- squealing belts...
- now no spark ..1995 neon sohc
- Big bang, then the motor dies
- changing tire size
- headers
- E test
- UDP and Header question
- SRT Turbo Checklist
- out my exhaustwhite smoke
- 2.4 head
- Side Markers
- painted the beater car
- Oil light
- terrible miss of motor
- water in trunk and rear floor
- shifter
- advice on some 95 SOHC problems
- t the front do the lowering springs
- Need a fast reply to question
- Brake Pads
- Whats The Problem??? 1996 Neon
- electril oil pressure gauge....???
- Neon Magazines Apart from Mopar now
- Need to dbl check my EGR connections
- Throttle Bodies?
- my exhaust
- Engine removal 2.0 SOHC quickest way
- Cool New Gauges
- Ahoy!
- CAI on 99 neon
- ?-Best Car-?
- Shift speed?
- Direct port NOS on SOHC plastic intake whos done it?
- update on my dead engine
- Mystery hose connected to air intake duct
- What my neon is worth
- code errors, what to do?
- For Sale List
- The two wires and connector at the brake master resevoir?
- Iceman Question
- DOHC Head on a SOHC Block
- What do you guys think
- wheel bearings
- running or not
- question about my dead engine
- Window alignment
- Help. soemthing wrong with my neon
- My car needs a tune up
- SOHC to DOHC Question
- we have 2 new family members...
- 97 Dodge neon Died
- belt alignment
- Looked at a 98 Neon came with a free bonus pic included
- 1995 dodge neon automatic transmission problem
- 97 neon vs 97 vw golf
- Turbo pistons question
- PDC cap replacement?
- MSD ignition leads will these fit a 2.0 SOHC?
- Bellhousing bolt up 2.0 SOHC
- Check This Pic
- MTX Swap Question...mounts?
- Jeep TB??
- Hotchkis SwayBar
- RT/ACR?
- Decode this Vin :D
- Engine smells?
- don't remember...sorry!
- 1st Gen. DOHC to the Calibers DOHC
- srt 4 swap in my 99 rt
- cylinder head removal
- Oil on spark plug threads
- hydraulic lash noise
- Auto Trans problem: Valve Body
- Body damage question
- evaporation system & Defrost
- Shifter cable bushings
- Clogged PVC valve?
- Code 52...Help Needed
- Is it the Timing Belt????
- Code 34?!?!?! WTF IS THAT!
- Why are Neons constantly underestimated?
- 96 neon stall
- Rough idle on 97 with DOHC
- That "breather" hose that connects to the factory intake
- Code 25 Please Help!!!
- Dying and Oil Light
- i didn't think it would happen so fast...
- next performance mod to look for?
- take off...
- 98 Neon won't turn over after DIY work
- he asked...who wants it?
- power steering/ a/c issue in the wet?
- 95 cam
- Tranny is pissed
- turbo/supercharger
- HELP!!! Dead Neon
- thought this was funny and had to share
- is it just me...
- 70 bucks or should i get it from some where elseheadgasket
- FINALLY!!!
- EGR block off kits
- funny story happened last night
- engine swap question
- engine question!!
- 99 dohc engine put into a 98 dodge neon r/t overheating
- votland lowering springs
- Speedo Needle....
- Front bar removal on 97 neon
- tire size
- 1st gen Sohc 2.0 $2600 waste? HEEELLLPP!!!
- My carputer specs
- DIY Reverse Gauges :D done w/ pics
- Sound/Clunk Question!
- Wants to start
- bolt pattern
- Those little HVAC lights.... they get 12V?
- Better Tools
- wires
- yall should remember my high idle problem, well I fixed it
- Good Deals on Ebay
- Cheap Headers....worth it?
- 1997 2.0 SOHC neon automatic car weight?
- speed...
- '96 Neon 2.4L Stratus Motor Swap
- oil pan removal
- De-badge
- engine swap gen1 to gen2
- Money making to pay for car part/mods
- I'M SO FED UP WITH THIS THING!
- 1996 Neon head gasket question.
- Photo Gallery
- stereo idiots
- Airbag Control Unit
- mtx trans
- idle problems
- neon drawings
- what is your opinion
- suspension questions
- Throttle pressure cable
- Oil catch can?
- FPR...?
- i think i found my exhaust =]
- New Interior Pics opinions please
- Projector headlights
- engine trouble
- Plastic seals on hyd lifters on SOHC neon
- mufflers
- 1995 neon error codes 11 and 43
- Help, my 4x100 honda wheels are on, but now it knocks when I brake
- tranny swap
- might be getting another r/t
- What do you 1st gen guys get for mileage? Tuned or not
- neon using oil
- cleaning headlight lens/covers
- Rebuild questions
- caravan intake??
- ARGH! Alternator
- codes 43, 12...HELP!
- ARG!
- 95 dohc w\ m-trans into 96 sohc w\a trans car
- paint
- door ajar
- TRIPPIN OUT
- Cleaning TB.......
