- For Sale: 98 neon stock battery tray, good condition!
- For Sale: Stock intake system, take a look!
- I need a neon. Anyone got one?
- 95-99 Dodge Neon Intake J Elbow 3.0 like the Iceman CAI
- brake pedal problem
- Best CIA
- Rear sway bar??
- Boost control.
- Bobble strut, Broken?
- please help me out!!!
- Brake problem HELP!!
- preferences
- struts?
- bumper question
- Horn is stuck
- Ball Joint Bolt question.
- neon keys???
- Wtb
- Believe in your dreams
- 95 nyg neon
- neon with nos
- what would cause?
- Great bargain on Dodge/Chrysler/Plymouth (maybe mopar performance even?) parts
- srt 4 ecu
- 99 Expresso VS 03 Grand prix gt?
- Dumb question?
- got to love your neon
- Manual tranny wont shift!
- srt4 head swap on a 97 sohc!?
- stealth motor?
- SOHC pcm
- Mopar Performance PCM DOHC
- Gas Tank Removal
- boost control
- valve cover gasket
- 98 Relay circuit and wiring
- Question about Ghettoblaster/EGR heat????
- Longer throttle cable?
- custom dash/gauge cluster
- cam timing
- How to replace temp sensor
- will a 2002 cluster?
- Random turn signal speed
- 99 Neon 2.0L DOHC timing problem
- Speedometer not working
- PS pump noise
- short block question
- please help?
- checkout my ride...
- I'm Back! again lol!
- RPM gauge studder
- Code 32
- Anyone have any info on these?
- Idle overheating issue
- 3 inch exhaust
- why buy a tach driver
- heat range
- Just got a 98 neon sport, few questions
- 97 neon for sale
- a sad day
- Overheating problem
- i got a new toy tonight!!
- Your first neon.
- Camshaft Sensor
- Speaker size?
- Think with your dipstick jimmy!!!
- Couple how-to videos
- anyone have a ?
- DOHC and SOHC pcm??
- any tips on install?
- Fuse Box Mounting?
- where can i get this??
- neon ACR fuel injectors
- srt-4 turbo question again, oil feed.
- Rear disc swap??
- neon soch, pcm and piping fire!
- '96 Fuel System or Engine Problem?
- need rims
- Neon oil leak
- High Idle(not vacumm leak)
- oil pan ?
- rod knock?
- Ignition switch.
- Oil sucked into intake?
- Oil sensor????
- battery relocation
- Stock VS Megasquirt?
- Will they fit?(tires)
- Weird electrical problem(short?)
- Can pcm be damaged?
- ? about an exhaust
- 96 Neon - Odometer works part time
- Electrical Issues please help!
- my neon build up all opiouns needed please check out
- looks like im gonna be doin the 2.4L swap
- Shifting problem
- 1996 dodge neon timing marks
- 1998 sohc new fuel pump and now it bogs
- i need help on timing marks for a 1996 dodge neon
- Weather stripping for doors...
- Complete rebuild
- flush oil with diesel?
- should i trade my srt rims for these 6 stars?? pic
- lookin for a turbofold
- How to do an alignment?
- mopar computer help
- '98 neon SOHC
- Singin' the Check Engine Light Blues...Verse 2
- Dirt track cams
- radar detector to fuse box? 98 neon
- srt rims on 1st gen
- f/s 95 nyg neon
- blew the brakes lines yay
- Why does engine knock
- Piston hitting spark plug, but not valves?
- Parting out R/T
- Vote
- Srt-4 turbo oil return flange/down tube
- Oil catch can install
- oil leak......?
- No 4th Gear
- jerking problem help asap
- Neon w/ rear disks?
- '95 Neon door will not close in cold weather
- Will this fit on a 96 neon? HELP! Struts and springs
- Parting out 95 SOHC neon
- ? about a tranny
- 97 neon tricky electrical issue
- 1995 SOHC Oil light flickering
- should i raise my compression ratio?
- fuel pump? Crank but no start
- More Nitrous with Turbo Questions
- need help
- Road Atlanta Track Day
- brake probs
- hey from pa neon owner few q's
- whats your opinion of electric superchargers?
- flywheel
- Looking For AFX Race PCM
- 95-99 Dodge neon parts?!?
- Ecu decode
- Car of the month
- Can the stock engine do this
- if i put a
- will this fit ?
- indy intake manifold sucks
- need help dont no wuts wrong with my car
- afx race comp rebuild
- How hard is it 2 ?
- turbo question and oil cooler question
- srt turbo set up on a 2.0 dohc
- Rally neon!!! Questions still awaits answers!!!
- headlights
- where can i buy a dohc motor
- Cheap 14" snow tires that work great also $35 each new
- Cat cloged?
- Anyone selling a Neon??
- IC Before you Condemn it after Soldering...
- I like my exhaust crack
- No power help?
- should i turbo the neon or build a sand rail with a neon motor
- 1997 dodge neon flooding problem
- neon itb's
- need some help with engine and tranny
- Speed sensor
- I hate exhaust problems
- abnormal error code
- help with problems that im having with used engiine
- how much boost
- someone buy these
- oil pan gasket?
- i seen this on here before
- aftermarket gauge cluster
- Neon wiring harness
- Need some opinions
- question?
- problems with my car please help
- will srt-4 rotors?
- need a name help?
- 2nd interior swap.
- Im stumped...
- dohc springs
- modular and non modular
- Gotta love surprises.
- has anybody ever
- SOHC aluminum intake worth $60, NECESSARY?
- help!! Quick!!
- i want it lower
- what plugs should i use?
- pcm grounds
- gauge problem!!!
- how can i fix this i have a Wiring problem??
- look what i found for sale!!
- Mileage Club
- Scanguage
- Throttle body stuck wide open!!!
- help turbo oil feed
- need help no power to pcm
- 95 SOHC, same as 98 SOHC?
- Need some advice :)
- no spark no fuel pump going on
- Pushing Past 120MPH 2.0L SOHC
- 98 neon timing problems
- Cleaning out the parts bin
- Pics
- head gasket only
- Gravel Tires Sizes and Lift and Brakes...
- rev limiter!
- gunna b near chicago for 3 months!
- Diagnosing O2 sensor problem...
- Help Please!!!
- 420a weakness
- can anyone answer this question???
- Rims for sale
- acr for sale?
- highline sport
- DOHC Exhaust Flange
- New Dodge Neon Owner *HELP*
- rev limiter quit?
- factory tach questions.
- overheating 96 sohc atx
- sun roof not openin
- rear wheel drive neon
- ACR vs. r/t
- Battery Box
- Neon bogs down turning left...
- little help please....
- electric water pump??
- r/t questions
- hey experts - got one for you - DOHC on 2nd gen?
- Exhaust Questions
- WTB: SOHC engine in midwest
- White RT for sale
- 96 Neon Rear Strut Question
- 1998 r/t
- 8.8 wave spring performed works!
- sup gen1 fellows
- Looking for altenator for 95 Neon
- Neon Exhaust
- new motor job
- man do i miss my neon
- exhaust
- running rich
- neon 4 sale
- Quick Question
- 5 speed tranny 4 sale new clutch
- Camm quest
- mopar pcm Question.....
- help on my 95 dodge neon
