PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Strange fuel problems 95 neon
  2. Re painting stock color
  3. 1998 neon SRT4
  4. please help
  5. 95 neon overheating
  6. Dies when shifting from first to second...
  7. Difference between a 97 neon and 98 neon starter?
  8. dohc engine questions
  9. 95 neon sunroof insert
  10. 95 Neon automatic no revese when cold.
  11. Central Florida Neons ??????
  12. how much horse power
  13. Oil Leak Problem
  14. suspension. whats best
  15. jumping gauges
  16. transfer gears
  17. I don't know what to do
  18. Where do I get stiffer motor mount inserts/ New thrust strut
  19. Control Arm Bushings
  20. Looking for a Mopar Perfomance Computer
  21. 1st gen 95 dodge neon running problems!
  22. Tire size and gas mileage question
  23. experimenting with engines
  24. computer reset for 98 plymouth neon
  25. Heater Core
  26. Im back after almost a year with some questions!!!
  27. 17s
  28. Radio Problems!
  29. Stock Stereo Problem
  30. Corbeau seat
  31. Rough Idle in Drive and Reverse
  32. Odd trouble with mom's car....
  33. License Plate Bulb Socket
  34. Ignition coil / crank sensor
  35. engine swap
  36. 1998 neon fuel pump wont turn on
  37. please help with 95 neon problem
  38. help 95 neon sport 5 speed issues
  39. 1995 neon sport
  40. New Struts/Suspension parts
  41. Tach Help
  42. 97 neon wont start.
  43. New here and looking for some help
  44. Need help!
  45. need 98 neon parts
  46. Battery light, interior questions
  47. Computer
  48. water pump kit
  49. cruise control not working
  50. whine near crankshaft
  51. Pics of my 98 Neon drag project
  52. Anybody selling an R/T?
  53. 98 Neon starting issues.
  54. Cam seal leak help
  55. aftermarket fuel parts?
  56. colored dash lights
  57. need breakline size
  58. High beams wont turn off on a '98
  59. Is this a good buy?
  60. help me please
  61. 96 SOHC will not pass smog, high HC's any ideas?
  62. problems
  63. a crazy 95 never seen b4
  64. 98 neon 2.4 DOHC head to 2.0 DOHC block
  65. Sunroof Removal
  66. Lots of issues
  67. 1998 Cluster or board
  68. Dash Lights wont light up.
  69. 1998 Neon electrical issue
  70. radiator problems.
  71. 2.4 swap rear timing cover
  72. nno fuel in the lines but i hear it hum
  73. 1996 Dodge neon motor swap
  74. 99 neon wont start
  75. 2.4 swap question
  76. Transmission front seal
  77. front mount alternator
  78. what to do when removing powersteering for good?
  79. code 12 and 54 help
  80. *&^#@* neon
  81. check engine light
  82. Picked up a neon..got a few questions for you guys
  83. 97 wont start
  84. kinda new
  85. Help .
  86. Need 98 neon gear shifter
  87. 2.4 swap list
  88. kickdown shaft return spring
  89. 96 auto for sale cheap with pics. make offer, i need it gone
  90. 2.4L swap question
  91. Engine bolts
  92. 96 sohc auto for sale $600 (oklahoma city)
  93. can i hire someone around okc to fix/replace my transmission (auto)?
  94. leaky transmission
  95. favorite mods
  96. speedometer jumps / engine cuts out
  97. Used car idle issue
  98. Sudden and bizzar electrical problem.
  99. 1998 Dodge Neon, cuts out when fuel drops to 3/4 tank
  100. R.I.P. My 1997 Neon. (Progression/Showoff Thread)
  101. Fog Light Conversion
  102. timing belt replacement
  103. Odd idling problem
  104. first time with neon need some help
  105. Still overheating..
  106. Piston to valve clearance
  107. Code 11 !
  108. Noise when turning
  109. Noise when turning
  110. loud squeaking noise
  111. MegaSquirt tables
  112. 2.4 engine swap?
  113. Wtb
  114. Looking to Buy Neon Injectors PN#0280155784
  115. done with neons
  116. Popping sound near right front tire
  117. Minor mods I think I want to do - need advice
  118. coil pack
  119. 98 neon fuel gauge ??'s
  120. Getting Frustrated
  121. Rear Bumper falling off?
  122. dodge neon overflow tank
  123. coil pack types?
  124. triangle
  125. Trying to get info on a srt swap
  126. 95 dodge neon tranny and motor mounts. location
  127. Need help with front end
  128. loose motor, and oil in the spark plugs
  129. shifter spring
  130. srt-4 piston questions
  131. 1995 dodge neon motor and trany
  132. Check engine Light Question
  133. 98 Neon No Spark
  134. Issues
  135. Crossover Starter
  136. How many problems here
  137. First car
  138. need a source for new 2-door belt moldings
  139. 1996 Dodge Neon Fuel Pump Problems - Please Help!
  140. Electrical Problem?
  141. MoonRoof Drain Holes
  142. project car needs new engine and transmission
  143. 96 neon help!
  144. Headlight Gasket/Seal Installation
  145. noise inside transmission help
  146. Chilton Or Hayes Manual
  147. Engine fan won't shut off
  148. Engine Heat Problem
  149. 1999 Neon Brake noises
  150. Cluster Problems...
  151. sohc on adoh block
  152. Whining noise during sharp turns with A/C on??
  153. skipping on acceleration
  154. 1998 Dodge Neon 2.0 DOHC Starting Problems
  155. 1995 Neon Gauge Cluster Swap
  156. Street sertifed car show wisconsin state fair
  157. Street sertifed car shower wisconsin state fair
  158. mivec
  159. SRT Radiator?
  160. quick question about turbos... maybe dumb but idk so.
  161. HeadLights/Brights don't work
  162. check engine light question
  163. 2dr 96 dohc neon
  164. throttle sticks help!
  165. 96 neon gauges messed up?
  166. water pump
  167. looking for sohc engine
  168. right turning fuel hesitation/miss? HELP
  169. charging system
  170. check engine 02 sensors
  171. Can someone explain the Gas tank vents
  172. Rough Starting... Any ideas?
  173. 95 SOHC "overheating" EGR system failure code
  174. sohc to dohc
  175. Gas filler vent problem
  176. help with A/C
  177. can u put an 2 gen Cluster in a 1 gen neon
  178. Mystery Diagnosis
  179. Help! DOHC to SOHC
  180. Electrical prob after head unit install
  181. kyb gr-2
  182. Looking for 3.94 in ohio area
  183. FREE PB hood and incomplete DOHC head
  184. Battery ?
  185. ECM going bad? what to look for?
  186. 1995 base and sport differences
  187. 1995 base and sport differences
  188. HELP!!! before I pull my hair out!!
  189. 98' Neon Drive Cycle
  190. Best way to accelerate fast?
  191. Can someone please help me?
  192. 97 DOHC Wont idle
  193. I dont know what to do...
  194. Desperately need info!!!
  195. 1996 neon 4 sale
  196. 1999 neon p0171 problems!
  197. Fuel pump fuse keeps blowing !!
  198. please help
  199. SOHC Head Replacement
  200. 1996 neon part out
  201. ground wire
  202. Stratus 2.4l engine
  203. starts and everthing workz ,but won't shift from park..Help..
  204. Got some Q's about a 1997 neon
  205. Neon Drifter
  206. neon upgrades
  207. Pcm
  208. '98 Neon
  209. can i make my 2.0 a 2.4?
  210. Shifting
  211. 1st gen engine parts needed
  212. Heater/AC Vent problem
  213. unusual request... Neon trunk emblem?
  214. "R-Speaker" message on Radio
  215. Vibration issues
  216. noooo my neon dieing looks like it ? can it be saved ?
  217. Starter Issues
  218. 96 Dodge neon no spark
  219. 96 neon no start
  220. POOF! OMG, what was that???!!
  221. Forgot which is the Low Pressure valve on a/c
  222. 96 Neon Hard To Fill Gas Tank/ Nozzle Keeps Shutting Off
  223. Please help! Neon bogs!
  224. '98 neon multiple motor issues cant decide best fix
  225. I need a 95 neon clutch cable
  226. Neon wont start help asap plz!
  227. 95 neon engine stalls at 20miles
  228. Error Code.How to Solve it?
  229. Big Brakes?
  230. Banshee whistle, please help
  231. 97 neon fuel problem
  232. Help!!!
  233. air conditioning not working, recharged but still nothing
  234. 95 neon idles up high when push clutch in to shift?
  235. Personal Invitation for 2nd gen TOTM voting!
  236. Engine knock
  237. #3 Cylinder Misfiring.
  238. 95 neon NO SPARK!!!! plz help
  239. Engine questions!
  240. catylic converter
  241. Noise
  242. 1st Gen Racecar...kinda
  243. transmission re-installed
  244. 96 Neon Revs High When I Clutch to Slow Down
  245. Transmission Oil Pump
  246. Mis fire codes
  247. Blown Head Gasket 1996 Neon
  248. dirt track help
  249. Quick question
  250. Aftermarket heads??
