View Full Version : 1st Gen Neon
- well guys
- srt4 compatability
- Vacuum problems
- MSD
- what is the Point?
- New pics of my 95 all cleaned up!
- Turbo setup questions!
- piston question
- Anyone going to the Carlisle All Chrysler Nationals!!!!
- atx throttle body?
- Possible multiple sensor issues?
- ACR for sale
- Blowed
- turbo kit on ebay
- sway bar?
- oil psi?!?
- Dodge Neon Transmission Problem
- Me revving my neon video
- Neon Facts
- Anyone heard / use this product to fix head gasket?
- 95 Neon trunk leak...
- gas question
- aftermarket gauge install
- 97 motor in a 95 car ???????
- 1999 Neon- car shuts off, comes right back on while driving
- Question about atx to mtx swap
- over charging
- 2.0L head vs 2.2L / 2.4L
- help! i dont know jack about clutches...yet
- 5.0 mustang injectors?
- Searched Searched And Searched Some More
- Need a Primary Proportioning Valve, or Prop Valve help...
- Neburon on ebay...ew
- Remove rear rotor (E-brake is NOT on)
- Gonna Need Alot Of It
- 2.4 Swap...need some helpful advice
- Special valve spring compressor??
- Need help bad on My dohc turbo project
- Header Trouble
- Ok heres what the hurculiner looks like
- Help Neon is dead!!!
- Cam gears
- Please HELP!!!
- alternator bolt
- Going turbo question
- tranny and pcm
- SRT-4 Swap DONE
- Question about TB
- My rear brakes (PICS)
- MSD coil packs
- plugs & wires
- R/T sways Vs. Base Sways
- FS: 56mm tb, vc's, gauges/pod, more
- I wanna Glare at you
- Cut The Rice Let It Rumble
- FIIIIIIIIIRE!!!!!
- is this bad?
- wire shorted
- Code 43
- where do u get an iceman
- car possessed
- Head spacer??
- headlights
- Moving Sale - 1st gen parts
- Gas Guage Dosent Work
- steering wheel
- DODGE R/T
- check out this catback
- Head gasket adhesive
- I can tell it's above 90 degrees!!
- Code 31
- i thought i remember seeing someone somewhere...
- Exhausting Sound.. lol
- 95 neon engine wireing harness
- 18's
- Spray paint update
- exhaust
- throttle body question
- clear headlights
- Missfire and my dohc is now dead!
- Supercharger is this possable???
- diagnosing the alternator
- R/T or NO r/t? that is the question
- 95 neon check engine
- Brought her home. She needs some help.
- well i wont be working on my car for awhile now
- car dies
- update and ??
- Selector cable
- Faulty Gas Gauge?
- 1995 neon dead
- ebay blow off valve
- ? for turbo neon owners
- Oil Leaking
- Having trouble with SOHC engine, Need Help
- Sellin the neon
- WAT RIMZ!!!!!
- Over heating
- hmmm it broke.
- PO351...
- Turbo Manifold
- i got my turbo!
- Timing belt cover
- Lifters?
- Been a while.....
- Rice me Baby
- SOrry
- sohc turbo manifold
- ecm anyone?
- painting outside
- anyone got a gas tank filler neck?
- Gas mileage
- my tranny is finally back in, but
- pacesetter header install
- possible parting out a 99 dodge neon dohc
- Indy Head Vs. Stage 6 Head
- head bolts
- My Neon!!
- help car won't spark
- Changing front Break pads?
- Air Conditioner
- 1st gen trailer hitch
- p0140
- coolant problem
- more problems
- valve cover
- Paint Question
- over heating problem
- Body Kit and Headlight Covers
- spark plug gap
- easy way to get the adhesive off the trim.
- need help
- VSS Question
- 96 Neon 5spd Tranny Questions.
- Holy Neon
- oil viscosity for a turbo neon? and timing as well
- 3 inch exhaust
- How To: Custom 3.0L Cold-Air Intake Mod
- Throttle/ATX Question 95 SOHC - Dirt Racer
- any one here use or heard of megan header
- GOT 2 PROBLEMS HELP!!!!
- '99 Plymouth Neon for sale in classifieds. Look!!!
- weird alternator
- Rad Hose..
- '95 to '97 steering wheel swap.
- 99 dodge neon
- A Big Thanks to spudsterier ..........
- Couple Problems.
- speedo?
- kind of tranny fluid do i need
- 98 neon died.
- Bumped my head and bought a Neon...
- top starter bolt
- ORANGE WIRE
- Door speakers Don't work..
- windows
- HELP...98 neon oil sludge?
- New story about 2.4
- fuel for mopar pcm
- some people are stupid.
- NO START
- SRT-4 UPDATE!
- EGR Tube
- any srt swap success stories???
- gauge cluster fails in front of my eyes
- Best way to find out if you need new shocks/struts?
- lowering spring
- how much paint?
- need help choosing
- anybody happen to have these...
- burning oil???
- turbo neon AWD
- throttle body spacer
- My green Neon hates me i think.
- belt slipping off
- alternator ground
- need information please
- oil in my t/b
- Need MTX
- skunk 2s
- sohc redline
- excited for tomorrow
- turbo with semi-stock motor?
- 95 sohc neon code 22 need help
- Quick question about rear suspension bars
- NEW HERE CAN ANYONE HELP!!!
- anyone selling there 1st gen front springs?
- anyone got parts for sale
- wastegate
- Parts for my car
- SRT-4 Exhaust
- 99 dodge neon dohc transmission
- Problems to expect?
- rear motor mount (spud Das racerx?)
- Turbo Setup
- Brakes...
- car running real slow
- NEED ac COMPRESSOR
- 99' lost timing belt, are the valves toast ?
- ? for ya all
- pcm noise car wont stay running
- WTF WAI????????
- my A/C breathes fire
- Looking for ideas
- car alarm
- Its dieing!
- SOHC Manifold
- Want more Power From a SOHC '96 Neon
- question about fusable link
- bad night...
- CODE P1492
- road time
- havin clutch cable problems!!!!!
- depo projectors
- hp gains
- GAS TANK
- engine or trans
- SRT-4 swap??????????
- HELP! did a tranny swap car wont start????
- Service Engine Code 72
- might be crazy but...
- cleaning valves and pistons.
- proper way to P&P the head.
- where do u put the gear oil in a 5 spd?
- springs
- SOHC worth Performing??
- Spark Plugs
- oh no, is the head of my engine no good? (Pics)
- my car sounds like a bus
- srt 4 engine or car
- NEED HELP ON THROWOUT BEARING ASAP
- Plymouth Neon Rotten Rear Brake Lines
- Window track
- New here, got a couple questions
- lmao check out this pic!!!
- my first and LAST head job.
- Factory options
- brake line??
- Revs to the moon when I start engine.
- can crank pulley be removed by hand?
- mopar pcm
- f**king alternator!!!!!!
- need help fast
- HID Help!!
- alternator bolt spinning in place?
- 95 dodge neon dead
- replacing steering knuckle
- cam gear
- Car just dies
