PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. My new European Chrysler Neon CS :)
  2. 98 Neon 2.0 SOHC wont start
  3. How should I build a NA race motor
  4. Odd hesitation problems.
  5. auto tranny prob/question
  6. idle up switch
  7. Looking for a source for my dask defog vent covers
  8. Transmission question
  9. '95 SOHC power specs?
  10. '95 Ball joints
  11. Gas Gauge and speedometer was stuck
  12. Car wont stay running
  13. how many bulbs in the instrument cluster of a 1995 Dodge Neon Highline
  14. 98 dodge neon doors
  15. wire through Firewall neon 97
  16. Fog light Bypass? possible?
  17. security pad?
  18. 98 Neon no power
  19. Which wires are which?
  20. 2003 neon
  21. what next?
  22. random start up trouble
  23. Both rear turn signals/brake/flashers won't light
  24. What carbureted motor will fit in a '95 Plymouth Neon
  25. car wont start with starter
  26. Neon will not start
  27. How Do I Change The Tcc Selenoid In A 95 Neon Sport?
  28. lock tumbler assembly falls out...
  29. 95 neon spits sputters then dies when warm
  30. 95 neon hesitates at take-off
  31. 98 Neon Issue replaced fuel pump, now issue
  32. fan problem i hope@$%#
  33. Won't start, 98 Dodge Neon
  34. Belt Squeals With AC On
  35. Removal of Water Inlet Tube
  36. Changing timing belt and water pump, What else to do?
  37. need some advice on a motor swap (its not what you think)
  38. car is not shifting out of park.
  39. Power door locks?
  40. 95 Neon instrument cluster
  41. Won't start
  42. 2.0 sohc (automatic transmission issues)
  43. '98 Neon, DOHC...may the force be with you!
  44. 97 Neon Sport won't pass DEQ smoke+Repeat O2 sensor failure
  45. all motor?
  46. crank sensor
  47. 98 Neon Engine Noise
  48. Urban myth busted (dont need a thermostat)
  49. 99 DOHC - Power Steering Pressure Hose
  50. 97 SOHC Dodge Neon won't start when cold
  51. Urban myth busted - dont need rad pressure
  52. Head Question
  53. Help! Quick plz clutch issues
  54. cam sensor wiring
  55. Got a 1996 neon and i'm trying to get it started. PLEASE HELP, LEAVING FOR COLLEGE!
  56. Clutch issues
  57. Cold Air Intake
  58. Cracked oil pan
  59. removing control arm
  60. Neon Dies Going Down The Highway
  61. removing intake manifold
  62. 2.0 sohc check engine code p0304 trouble
  63. my 98 r/t turbo is leanen out i think
  64. park neutral switch
  65. Official DodgeForum.com decals...
  66. oil pan help
  67. Intake Manifold, and header
  68. Engine is Programmed to Stall
  69. Misfires,
  70. 2.4l swap, worth it?
  71. 1999 1st Gen Neon surges when air conditioner is on.
  72. 99 neon dohc issues
  73. Temperature gage problems
  74. 1999 Neon A/C Problem
  75. 98 dohc waterpump/timing
  76. Service Engine Soon/ Code 43
  77. paint
  78. 1997 neon
  79. 99 Neon R/T starting problems
  80. motor problems
  81. Rear Trailing Arms
  82. overheating and no a/c
  83. Help
  84. Brake problem
  85. turbo on a 96 sohc
  86. steering
  87. camshaft sensor
  88. 96 2door plymouth neon SOHC w/ sunroof partout
  89. overheating
  90. Rough Idle/hesitation on acceleration
  91. SRT 4 Sway bar
  92. Neon with no power after lightning storm
  93. Should i srt swap
  94. coilover sleeve Kit?
  95. OBD II Scanner for '99 Dodge Neon
  96. lowering the neon
  97. my 96 neon just stopped working on me while i was driving it. It was running smoothly
  98. Help what steering rack do i have ?
  99. Starter Relay Ground
  100. Serious but intermittent problem
  101. EGR Valve problems....i think
  102. 1996 dodge neon electrical problems... really need help
  103. swapping parts from 4 door - 2 door.. (PLEASE RESPOND ASAP)
  104. 97 SOHC M/T Can't Select Reverse
  105. Having A/C issues HELP?
  106. Dash Wire Harness
  107. Overheating Woes
  108. Problem with passenger front tire.
  109. 1997 Neon Need New Power Steering Gear for RHD
  110. Security System (Immobilizer?)
  111. '99 Neon Gas Cover/Check Engine Light
  112. electical problem on 1999 dodge neon
  113. Rear Suspension Noise
  114. transmission swap
  115. Strange electrical Problems
  116. brakes
  117. 1999 neon sunroof help
  118. Acceleration Problem
  119. Keep or Trade?
  120. I need to know....
  121. 1996 neon sport
  122. Throttle hesitation only when raining
  123. HELP with 99 neon R/T
  124. VSS problem, perhaps?
  125. 99 DOHC Coupe with O2 headache
  126. 1998 Neon, 2.0 SOHC Timing ?
  127. 95 Plymouth/Dodge Neon Sport Electrical issues
  128. Tranny Swap
  129. 1st Gen SOHC parts and 98 R/T Part out
  130. Pcm help
  131. Losing Power & Long Start up issues
  132. Confused. Picture Identification
  133. SOHC motor
  134. changing rear brake shoes, Help
  135. 98 rt fs
  136. 99 Dodge Neon SOHC
  137. neon not starting - click noise
  138. Please post pics of your 1st Gen's with aftermarket rims...
  139. '99 Dodge Neon Rear Wheels locked Up
  140. Project X Carnage ( Jordans neon )
  141. Been having some fun....
  142. Help!!!
  143. Cat Covertor is toast
  144. Want to join the Neon world
  145. 96 neon a/c blowing hot
  146. bogging..
  147. Need help Neon oval track car
  148. looking to buy a neon, but...
  149. 95 dodge neon
  150. Click....No Start :( smoke from starter
  151. 1995 Dodge Neon SOHC swap to 1996 Dodge Stratus 2.4 engine
  152. 97 neon auto turbo build?
  153. Troubleshooting No Start- No Spark
  154. Power Locks
  155. Neon Reborn
  156. 1996 Neon DOHC P0304
  157. 98 Gas Filler Neck Replace
  158. 1998 Plymouth Neon No reverse
  159. Alright guys, I need some help.
  160. 95-99 sohc computer
  161. head?s part 2
  162. hesitation and chugging upon acceleration
  163. no spark no fire
  164. 99 neon with anti-theft problem?
  165. carbon fiber roof
  166. engine spools like it has turbo when a/c is on
  167. Coolant Temperature Sensor Location (SOHC)
  168. SRT-4 front clip?
  169. power steering
  170. engine and other parts for sale or trade
  171. Where can I get?
  172. ? no clue wat this is or were it goes
  173. 95 2.0 sohc auto
  174. 95 Neon ?'s. Help Needed
  175. Neon Lift?
  176. 98 Neon Starter removal
  177. Exhaust Donut
  178. Idle question
  179. spud...
  180. head ?s
  181. head ?s
  182. 99 Neon Alternator belt problems
  183. Coolant loss
  184. lookin for more motor power.
  185. need motor help.
  186. 97 2.0 sohc wont start
  187. 96 neon no start
  188. 97 Neon (Automatic) - Jerking / lurching at 60mph
  189. Wheel Noise
  190. clutch problems
  191. A/C / Heater lights wont work.
  192. '95 oil cap gone! What others will fit?
  193. 98 5spd stuck in 5th
  194. Harmonic Balancer bolt size..
  195. 97 high beam light on dash
  196. Hello all
  197. 96 to 95 sohc engine swap
  198. Is there an eletric thermostat for the radiator fan?
  199. Overheating fans don't run
  200. power steering rack removal
  201. Broken Motor Mount and Weird Axle...
  202. oxygen sensor or some vaccum hose problem ? Stalling when very little throttle applie
  203. Cannot fill gas tank?
  204. 96 Neon battery dead
  205. 1995-1999 Instrument Cluster with 7K Tach - fully functional
  206. 1995 neon turns over wont start
  207. 1995 neon
  208. 95 neon cranks but no power to fuel pump or coil
  209. Stalling when turning
  210. 95 neon highline issues
  211. 95 crankshaft sensor replacement problem....
  212. Granatelli vs. MSD
  213. Where can I find a front timing cover?
  214. hard shifts
  215. 97 neon dies when driving
  216. 99 Neon Dash and Running Lights Work Intermittently
  217. Error Code 44
  218. dodge neon shutt off
  219. Random stalling issue?
  220. Tank swap
  221. 98 Neon Interior Lights
  222. 95-99 Neon parts manuals
  223. 95 neon head gasket
  224. 95 neon sport
  225. weird revving problem
  226. debating whether to get these or not whats yalls opinion????
  227. Cam question
  228. Installing Passenger Side Motor Mount
  229. cant get right
  230. interior lights
  231. 1996 plymouth 2.0 SOHC want to put 2.4 dohc out of dodge Stratus 1998
  232. rpm question?
  233. Clogged Catalytic Converter
  234. rebuild 2.0 need advice
  235. 98 neon will not start
  236. Swap SOHC Head to DOHC Head on SOHC Motor?
  237. FS: Megasquirt with custom harness
  238. Changed the rad now the engine light is on and code is 1899
  239. Coolant Leak
  240. 99 neon with 97 motor
  241. 1998 2.0 sohc 5 speed timing off please help
  242. my 1998 neon 2.0 sohc
  243. stops turned "foggy"
  244. 1996 dodge neon cigarette lighter wont work..
  245. Help..Remove 95 Neon dome..
  246. want to turbo my neon
  247. Using Seafoam Through a Vacuum Line... Which One Should Be Used?
  248. 1997 dodge neon fuel problem
  249. catastrophic failure?
  250. Head Work...
