PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. run fuel return line through the evap hard line?
  2. run fuel return line through the evap hard line?
  3. run fuel return line through the evap hard line?
  4. rear lip
  5. what cars come stock with a 58 psi fpr
  6. compression
  7. Interior lights
  8. Sticking Calipers - Melting pistons
  9. Getting to expander rings from the bottom?
  10. megasquirt
  11. lot o miles minor problems what should i do
  12. part out or sell whole?
  13. p0743 & p1899
  14. 1998 plymouth neon s.o.h.c need help badd
  15. 98 Neon - Replace or not replace
  16. Code 31
  17. overheat?
  18. Radiator Help!!!
  19. anyone have a wiring diagram for the alternator
  20. Used parts
  21. everyone should switch to the srt oil filter
  22. i made my own solid bobble strut
  23. 97 neon sport issue with guages and belt squeeling with a/c
  24. 1st gen neon collector wheels
  25. odd question!!
  26. a lil off topic
  27. FandSfab.com NOW OPEN. 2.4 power steering brackets!
  28. Low spark on #3....
  29. 98 neon, pinging
  30. I need help with my Dodge Neon
  31. EGR question
  32. fuel pump fuse keeps blowing
  33. 3.55 vs 3.94
  34. Saying hi and showing the new car 56k warning
  35. turbo parts have started comming in
  36. Got a purple 98 sohc
  37. '96 engine rebuild
  38. Question???
  39. Question on diagnosing Knocking
  40. Anyone want a free Mishimoto thermostat?
  41. please help!!!!!!!!!!
  42. *!!! Nightmare OVER !!!*
  43. FS: srt turbo
  44. Wierd idea.
  45. built 2.4L turbo wont run right at all
  46. Daytime Lights Dont Work
  47. 2nd gen short throw shifter in a 1st gen?
  48. 97 Neon sohc Squeeling belt! cant figure out
  49. Fuel filter..
  50. Rotate cam magnet 90 or 180 deg?!?!?!?
  51. bobster
  52. E-Brake problem
  53. built turbo 2.4 wont spool
  54. Engine Bog
  55. remove balance shafts in 2.4 and set screw for pickup tube?
  56. My Neon engine shakes and revs itself or doesn't rev at all.
  57. Problem With Electrical...
  58. anyone have any use for these?
  59. want to buy a turbo!!!
  60. fuel injectors
  61. itb
  62. rear brakes
  63. Running too lean CEL
  64. 97 DOHC Neon Problem...
  65. wtb dohc
  66. 1997 neon highline question
  67. modify stock clutch to 550hp???
  68. Problems with alt plug
  69. My Neon my be dying at an early (mileage) age
  70. Turbo neon running like crap
  71. Cams removal with valve seal replacement?
  72. Tightening Balancer..
  73. Getting A/C to work??
  74. socket for Oil pressure switch?
  75. k can someone explain these codes?
  76. For Sale: ATX throttle bodies
  77. won't run
  78. Suspension?
  79. Engine Swap Question
  80. Stalling when hot
  81. Anything Useful?
  82. Back tire alignment?
  83. Quick tire size question?
  84. Parking lights w/ Fog Lights
  85. F/S high compression motor
  86. Lack of RPM gauge
  87. QUIK question
  88. wiring issues
  89. battery Problems Anyt one with same problem.
  90. turbo!!!!
  91. Hello
  92. I beat a srt-4?
  93. tranny help ASAP
  94. Auto Trans Problems
  95. I have to SELL
  96. Need a Experts Help. HELP!!
  97. Im back
  98. High Rev Problem
  99. p1491 code
  100. Race motor NIGHTMARE !
  101. boggs out when it wrams up
  102. Neon DOHC 2.0 & 2.4 camshaft difference
  103. Is it possible...
  104. air filter help!!!!
  105. strange noise in the front end.
  106. Help Please
  107. How to adjust tranny belts???
  108. looking for catalytic converter
  109. f21 fuse blows with key not on
  110. lowering springs
  111. help with 1st gen turbo piping
  112. Wiring harness diagrams
  113. Transmission Shift lag
  114. A/C Compressor problems
  115. Transmission slipping Question
  116. Aftermarket Steering wheel adapter!!
  117. hooking up aftermarket tach
  118. lots of extra neon parts
  119. Steering wheel emblem removal
  120. SOHC to DOHC swap
  121. finally- for sale :/
  122. Weird sound(maybe bearing noise)
  123. can any one help
  124. Removing shifter knob?
  125. Hesitation
  126. got me a 2.4! how should i build it exactly for turbo?
  127. How much would you pay for....
  128. Radiator replacement question.
  129. vacume gauge
  130. Question about ATX tranny's
  131. F/S 1998 dodge neon highline
  132. oil leakk
  133. Rear main seal
  134. trouble keeping my dohc running..
  135. What have you done for your neon today? *POST PICS*
  136. Neon will not start - I need some help
  137. couple of performance questions
  138. srt4 exhaust on 1g
  139. Tach signal
  140. Battery relocation problems
  141. How to remove rear seat?
  142. OBD Code 12,1,1,1,1,55
  143. Is it okay if there is a little air in the
  144. adjusting the timing
  145. Timing question
  146. 1st gen turbo help please..new guy
  147. Radio
  148. timing question
  149. Neon starts and dies..
  150. Crane cams idling?
  151. 2001 magnum head
  152. Broken MSD Coil Pack
  153. 2.0 stroker??
  154. What does stock SOHC run?
  155. WHAT NOW SUCKA, project log
  156. Iginiton Fuse blows! Tried everything!!!
  157. Looking for some parts
  158. 97 neon acr for sale
  159. 95 noen help needed
  160. clutch 4 neon
  161. 97 DODGE NEON battery charging problems...
  162. low oil presure
  163. a wtf thread
  164. Oil Pump!
  165. ac compressor continuously on?
  166. anyone lookin for rims?
  167. tach problem not the usual problem
  168. Dying at idle, need some ideas!
  169. How long does it take...
  170. ****y 420a overheating (junk)
  171. Neon 2 Liter
  172. 1996 Neon wont start???!!!
  173. Can a chipped piston cause...
  174. squealing when shifting 98 neon
  175. Hey guys
  176. VOTM go vote
  177. Old fuel filter??
  178. Replacing the oxygen sensor
  179. Re-adjusting trunk lid?
  180. Selling my turbo neon.
  181. universal coil overs?
  182. 95 Dodge Neon Starter issue
  183. Exhaust manifold on 97 neon
  184. Gripping tires
  185. Neon Master Cylinder
  186. Neons for sale! 2 1996 SOHC 5sp Man.
  187. underdrive puley
  188. Paint Codes
  189. ignition lock cylinder
  190. 2dr. door panel
  191. Reverse lights won't work....
  192. rt tb
  193. 97 neon dohc runs great till warm
  194. indy inatke manifold
  195. New muffler, $40 rebate!!!
  196. Opinions on head lights.
  197. 96 plymouth neon sohc atx
  198. SOHC - DOHC Computer
  199. 95 Neon DOHC 2.0 Shaking and Power loss
  200. Cutting tie rod nut?
  201. Out of options....
  202. how do i fix my tach???
  203. 99' Neon R/T Strut Mounts
  204. what gives?!
  205. Do bigger wheels...
  206. 5spd trans swap problems
  207. Great MPG!!!!
  208. Parting out 97 Plymouth Neon Expresso DOHC
  209. New Old Car 1995 Neon....
  210. TPS Signal!
  211. 97 Neon dohc NO START
  212. I need help with my brake line
  213. Throttle body broke?
  214. Fixing scratches,rust spots,etc..
  215. Broke H Balancer pulling it....
  216. PCM conector repair help!!
  217. Won't shift into 4th or high gear ?
  218. Glasspack/Muffler from summitracing.com?
  219. '98 sohc
  220. my first neon..need some help
  221. automatic trans serous problems
  222. 96 SOHC A/C problems........help
  223. Cleaning HL's?
  224. map sensor question?
  225. 1995 Neon and 1999 neon
  226. i have a 97 sohc and 5 speed tranny for sale. 96k mi.
  227. i want a 2.4 so bad
  228. ? about a tranny
  229. wont stay running runs VERY poorly
  230. 95 nyg neon for sale
  231. Neon now undriveable - potentially BIG problems...
  232. Compatibility?
  233. looking for a srt-4 engine, & 2nd gen seats.
  234. Tie rod end removal?
  235. goin turbo...got some questions
  236. 96 Neon stalls after running
  237. head light removal (not the bulb)
  238. wheel bearing
  239. new vibration from steering wheel/all over...
  240. sumthing i found online thought you might like it
  241. Cheap source of fuel filler neck FOUND!!! Replace yours!!
  242. oil cooler?
  243. 99 R/T driver door panel
  244. Problem scanning OBD for inspection....
  245. air conditioner blower not working?
  246. pistons
  247. 95 nyg sport coupe
  248. Track day line-up
  249. stripped oil plug what are my options?
  250. emissions controller code
