PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. need help/advice thanks
  2. TB Spacer whine
  3. i got a question and some cool ass pics!
  4. short shifter finished
  5. what style fender?
  6. Turbo Time
  7. Fuel Relay
  8. starting problem, 99 neon
  9. MOPAR PCM ECU FOR SALE??SORRY DAS????
  10. got bored today
  11. What do I need for a sohc to dohc swap?
  12. what do u think 1gen drivers....
  13. whistleling noise!
  14. What Does it take For Our Ponies To Keep Up With The Real Pony..neon vs mustang?
  15. Can you bypass the Neutral Safety Switch?
  16. **Transmission Update**
  17. spring bushing
  18. trans
  19. Circle Track questions part 2
  20. crank, crank, crank, crank, crank, crank, crank, crank, crank, crank
  21. Intake
  22. Car shuts off while driving about 5mph
  23. Problems with car
  24. frankinmotor need help
  25. sohc valves in dohc
  26. AEM CAI
  27. new bushings??
  28. your opinion is appreciated
  29. Gauge Failure in A 95 Neon
  30. i don't know what to invest in
  31. 2.4 Engine sawp
  32. about how hard
  33. Oil Indicator
  34. upgrades
  35. 4 door into a 2 door window track.
  36. neon stalled in traffic
  37. 98 sohc starting problem
  38. my fault of the shops fault??????
  39. cluster/climate control bulbs
  40. 98 Neon 2.0L Thermostat
  41. pacesetter or hedman
  42. 2nd Gear porblem! Auto Trans
  43. oil leak
  44. T3 or 16gs the question?
  45. projector headlights
  46. Quick Question
  47. hope you guys know
  48. flip flop trunk
  49. speaking of power gains?
  50. power gains?????????/
  51. new car
  52. sunroof works, but clicks bad when i shut it
  53. 1996 sohc coupe for salein PA
  54. drivers power window gets jammed
  55. some kida leak....
  56. UDP questions? bout to buy, so help asap!
  57. F/S: aftermarket parts
  58. motor
  59. vibrates @65
  60. Little help please?
  61. BA TB
  62. anyone with a stock trunklight!
  63. Window Problem.
  64. Wont start after I change alternator WTF!
  65. what do you think?
  66. Code 32
  67. *FREE* Carfax!
  68. tweeters in dash-installation
  69. Rev'ing too High
  70. Quick Help! (wiring)
  71. Sport hood on non-sport Neon
  72. turbo pistons
  73. Questions
  74. starter and battery question
  75. need help. dohc running bad
  76. I can never win
  77. Hit the Neon Jack Pot Today!
  78. very very very disappointing day
  79. clutch cable
  80. 4.3 to 2.0
  81. tranny swap help..
  82. 97 neon 5-speed, keeps popping out of fifth gear, any ideas????
  83. Neon F/S 800
  84. rooling toPulling
  85. struts?
  86. ignition problem??
  87. engine and tranny lifts and engine upgrades
  88. v6 swap?
  89. is this swap possible?
  90. Tranny Question! 95 trans vs 98 trans
  91. best clutch
  92. Engine or Tranny?
  93. quickest way to remove head
  94. electric superchargers
  95. FS: '95 Dodge Neon 2.0 5-speed | RUNNING PARTS CAR
  96. 98 Neon R/t won't start... Bout to scrap it...
  97. Flame Throwing
  98. lowering with rims
  99. About how long does it take to change Auto trans?
  100. Neon stalls no ck/engine light NEED HELP!!!
  101. power steering switch?
  102. Auto. tranny problems.
  103. header question
  104. 96 Neon Engine Troubles
  105. 1999 fog lights
  106. timing and hp
  107. 1998 Neon power hiccup
  108. Engine troubles with 96 Neon.
  109. speed limiter
  110. I know this is gonna sound stupid But.....
  111. ok, i officially am checking everything
  112. power loss with new gasket
  113. did the search and no results.....
  114. 99 Radiator
  115. New Guy.....Of Course Questions That Have Been Asked Before!
  116. GROUND WIRES
  117. Purple Ronnie dies again!!
  118. 1997 dodge neon map sensor
  119. Got my baby back
  120. My srt
  121. where can i find a cheeper turbo kit?
  122. in need of some creative critisism.
  123. New motor??
  124. overheating..HG/head? SOLVED
  125. srt turbo kit for sell
  126. o2 sensors
  127. motor....
  128. problems...
  129. lowering springs.....
  130. i have no idea y its over heatin
  131. i feel like a huge dumb ass
  132. expresso
  133. crane 14 cam upgrade? Certain extra parts?
  134. another question..camshaft bolt
  135. THESE PARTS MUST GO!!
  136. OMG Please buy a hanes or chilton manual lazy gen1 owners
  137. brake pads !!!!!
  138. dohc and sohc ratings?
  139. stripping a 95 neon
  140. Circle Track questions
  141. I appreciate the help w/ the water pump info. One more dumb question though.
  142. turbo oil pan
  143. well crap
  144. An Englishman into Neon 1st gen
  145. massive oil spill
  146. possibly a feeler post
  147. tb diffrence
  148. How do you tell???
  149. Changing out 97' NEON SOHC water pump and could use some advice.
  150. sunroof
  151. Dodge Neon Rims
  152. turbo...
  153. My alternator SCREAMING at me???
  154. egr block off
  155. which ecu should i go with
  156. !!unoridox pulleys!!!
  157. 350 dollars
  158. this shiv anygood, ima buy some if i get god reviews
  159. Charging System drain & difficult codes
  160. SRT-4 Swap..Questions About Motor and Trans'
  161. 95 Neon loss of power SOLVED
  162. Bolt Ons...
  163. Need picture of EGR Block Off plates so I can make my own!! Thnx
  164. NEED HELP!! CANT FIND A PART??!
  165. Confused
  166. how fast after these parts are installed
  167. obx brand performance parts?
  168. sohc- dohc switch over
  169. srt-4 swap....
  170. ground wire
  171. battery plugs question!!?
  172. 45 psi?
  173. for sale post
  174. SOHC to DOHC convertion plate???
  175. Got my brakes done!
  176. How To Install Crank Pully ?
  177. Is this any good?
  178. 2nd gen speedometer
  179. How long.....
  180. i have tail lights but no brake lights.. i searched forum with no luck DAS SPUD ???
  181. Heres a CAI for ya...
  182. Airbags???????
  183. Is there a way to get the rear windows all the way down?
  184. More or Less back pressure
  185. Air filter
  186. neons...got new pics...
  187. how good is the stock alternator
  188. another problem HELP!!!!!!!! lol
  189. hard starting
  190. speakin of door panels and manual windows
  191. antenna...
  192. I am still looking guys!
  193. dohc ecu vs. sohc ecu
  194. Fantasy Football
  195. engine block problems
  196. belt
  197. trans gears
  198. Exhaust
  199. door panel trouble HELP!!!!!!!!!!!!!!
  200. battery to trunk
  201. Switching from dinosaur oil to Synthetic??
  202. Car isn't shutting off?!
  203. interchangability question
  204. tach
  205. cold air intake
  206. fuel pressure
  207. only heard but is it possible? 2.2L
  208. srt4 instrument panel
  209. Any interest in my Neon as a parts car in VA?
  210. Fuel Delivery Problems
  211. rt swapped
  212. Spitting and Sputtering
  213. Code 65?
  214. Indy Intake Manifold
  215. got my cd player...got some pics(ov my subs)...
  216. what size tires can i tuck??
  217. Alot of questions. Think you can help??
  218. WON'T START!!!!
  219. wtf is going on with my shifter
  220. cd player?
  221. grinding sound when turning left.
  222. got lucky.
  223. Little help with breaks
  224. still selling some parts
  225. Fog Light Button Wiring
  226. Best bang for my buck
  227. O2 sensor question
  228. still have the iceman for sale
  229. How hard is it to remove Bottum part of Dash with Vents?
  230. What is the best neon?
  231. How much can I get for this stuff?
  232. injector leak
  233. Automatic Transmission Question
  234. Turbo Configuration for SOHC Engine
  235. I have a plan!
  236. 1995 Dohc Neon sports
  237. 2 questions
  238. possible drag racing.
  239. Removing Oil pan in 95 Neon 2.0
  240. What exactly makes this high-peformance?
  241. woohoo
  242. neons vs. civics-dispute
  243. Black Smoke
  244. Anti freeze leak!
  245. Oil Leak dripping from Transmission Transaxle case
  246. Ebay Turbo Kit...worth it or not?
  247. Car runs like a raped ape on rainy days..
  248. well...
  249. put this in your neon
  250. how hard is it to instal the UDP
