PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43
  1. turn signal problem
  2. suspension question
  3. PCM Question? ACR-AF/X-Mopar Performance??
  4. ATL IN SEPT.
  5. clunk
  6. This makes me SAD!!!!
  7. new headlight install
  8. 99 Neon 2.0L I-4 SFI DOHC
  9. OMG EVERYONE HAS TO SEE THIS!
  10. I am not understanding this car at all lol
  11. im tired of speeding tickets.!! how bout you
  12. i need parts! clutch, crankshaft, 5 speed, and turbo
  13. fuel pressure regulator
  14. Battery Tray......
  15. '96 neon #4 cyl missing
  16. would 6 3/4inch speakers fit?
  17. where is this?
  18. Fuel Pump
  19. Heatrer core help
  20. can someone explain.......
  21. FOR THE LOVE OF GOD......
  22. wiring question
  23. clutch recommendations
  24. water pump
  25. 95 Neon Problems
  26. anyone have any videos?
  27. srt4 swap 98 neon
  28. Brand NEW LeBra front end nose cover on Ebay--$1 w/ no reserve!
  29. i have a ?
  30. how do you take out the rear deck carpet?
  31. 97' Dodge Neon Speed Sensor
  32. repair manual
  33. SRT-4 Rims?????
  34. Headlights
  35. Timeing Belt
  36. RIMSSSSSS....
  37. Mike vs. the Crank Pulley: the final episode.
  38. co2 purge into c.a.i
  39. getting a code # without a computer
  40. still having problems HELP!
  41. Help with starting, Code 42
  42. Starting problems
  43. Compression
  44. rod berrings
  45. fuel pump pressure
  46. performance pcm question
  47. SOHC Block?
  48. How should i go about removing the Cat.?
  49. temperature???
  50. newb here
  51. Dynomax Cat Back
  52. 97 sohc problem
  53. engine clean
  54. A/C Problem....Help!
  55. MAP sensor location
  56. EGR Valve
  57. anyone from Toronto area can give a hand with tranny swap?
  58. RTV sealant set up time
  59. Sohc 2 Dohc
  60. strange idle??
  61. car parts?
  62. whats this?
  63. dash wiring
  64. Adding More Gauges
  65. tranny stuck in 1st
  66. succesful battery relocation to the trunk
  67. succesful battery relocation to the trunk
  68. where to find 5speed kit on the net
  69. knocking noise from bottom end.
  70. Transmissons
  71. reverse lights
  72. Turbo 2 or 3 on 1997 DOHC
  73. window shake
  74. HELP! ASAP!!!!
  75. Fuel Injector o-rings?
  76. Mobil 1 Fully Synthetic oil ?
  77. what happens when too much oil is added? PROBLEM?
  78. Map sensor
  79. Check out this New Neon Computer
  80. bobble strut? where to buy?
  81. o2 sensor question
  82. Interior light
  83. gauges......I know
  84. overheating, have read through post history and need opinions
  85. Valve cover gasket, spark plug tube seals
  86. ThrottleBody
  87. timing belt cover
  88. Fuel Problem
  89. 95 SOC. Help please
  90. now i have a big problem
  91. losing milage
  92. be gone check engine light!!!
  93. rear breaks & strouts
  94. What to do When you get codes of P118 & P420
  95. Code 64
  96. Starter
  97. stumble pop miss
  98. Neon power problems (electrical)
  99. seatbelts
  100. Automatic Transmission Issues
  101. manual transmission conversion HELP!!!
  102. Buying a 95 Neon but have some questions first
  103. IM NEW TO THE FORUM
  104. check it out..this is pimp
  105. what motor did the acr come with
  106. First Gen neon overheating
  107. aftermarket cd player problems
  108. fenders
  109. WIDEBODY
  110. Left
  111. FOR SALE!
  112. speaker question sry
  113. speaker question sry
  114. Now it wont start....
  115. Alternator Light blinking
  116. Help with 95
  117. Light knocking noise when cold?
  118. Speed Sensor Q
  119. SRT-4 engine swap
  120. Latest mod that gained the most HP
  121. overheating
  122. WILL RIMS FIT???
  123. Engine Internals
  124. 1996 dodge neon
  125. TB spacer
  126. looking for a srt4 motor
  127. losing power after warmed up
  128. Fuel pressure regulator
  129. fuel rail
  130. eyelid
  131. adding HP?
  132. fuel and injector question
  133. '99 R/T Head questions
  134. valve cover paint question
  135. scissor doors
  136. mopar ECU plus mods HP guess?
  137. where to sell?
  138. tips on engine reinstall
  139. 2 questions
  140. Overheating 95 Neon
  141. Wrecked my Neon......Accelerator sticks?
  142. 96 neon runs badly (42/43 error codes)
  143. Hahaha..
  144. i want new seats....
  145. BACK BRK. LTS. STAY ON WHEN CAR OFF
  146. back seat removal....
  147. !!Neon Engine Swap Troubles!!
  148. P0138...replaced sensor, light still on..what now?
  149. dang it more chugging
  150. My new wing
  151. UDP?
  152. Cam gear
  153. HEADS
  154. Water on back floor
  155. Neon Gauges
  156. Headlights?
  157. what year should i get?
  158. mitsu engine
  159. transmission question
  160. fuel filter.....
  161. Buying a Neon
  162. mitsubishi eclpse won't crank
  163. Custom Interior Painting
  164. Window Regulator installation?
  165. HG Confusion?
  166. Painting
  167. 0-60 and 1/4 mile question
  168. Electrical?
  169. Window Clips
  170. Anyone want an Iceman?
  171. Overheating..
  172. Well I finally Ran it!
  173. Newbie with Starting question
  174. Camgear pull
  175. cam(s)
  176. neon motor (engine) change
  177. Ram Air on eBay
  178. tips for getting crank pulley off
  179. my car squels like a mofo
  180. 97 dohc neon, install 2.4, is it worth it?
  181. Got a new alternator and the belt is still pulling hero..
  182. So..
  183. Doing 60.....Dome Light Flickers On/Off
  184. quick little fuel filter question
  185. machined or new block?
  186. Odometer Mileage??
  187. silly ? spark Plugs
  188. Need Help Plz
  189. Better Gas Mileage?
  190. Antenna wire???
  191. neon ACR/ PT2.4 swap help
  192. 8K Cluster Tach w/Indiglo Gauges-SOLD!
  193. oh shoot
  194. 2.4L question sry
  195. it has been brought to my attention
  196. possible starter or Battery problem? please help!!!
  197. A/C Sqeals
  198. 1995 left turn signal issue
  199. Anti-Sway Bar Question
  200. all thats left of my baby r/t
  201. Replacing the instrument panel with another
  202. Tire question
  203. Ha oooo plz
  204. Smoke?
  205. Venom 400
  206. Could this be a $50 nitrious system?
  207. Srt-4 trans in 98 dohc Will it work?
  208. The Iceman LIVES!!!!!
  209. Question for spudsterier
  210. Tips about Driving a Standard Neon
  211. 2.4 conversion? Opinions and pictures
  212. Hey all
  213. ABS
  214. Drag Racing
  215. my ride by the way
  216. What is this piece called?
  217. HELP ME PLEAZE~GIRL IN DESTRESS!!
  218. y won't my car go faster?
  219. Question about Disapearing oil
  220. My bros new ride
  221. Dodge Neon 97 DOHC won't start.
  222. How to replace ignition lock / tumblers?
  223. AAH my Ac is Dead. Help PLZ
  224. factory 97 Stereo -- any inputs?
  225. 1 A/C ? 1 General ?
  226. PCM part# P04874164??
  227. Gas mileage
  228. My friends neon low compression
  229. fuel pump fuse blown
  230. 18 inch rims
  231. Before I go and buy the gauges....
  232. Noob here needs help plz.
  233. mopar drop springs
  234. Udp question?
  235. '98 neon center dash panel needed
  236. Difference from Sohc to Dohc
  237. kinda dumb throttle cable question
  238. transmission - squeal ???
  239. A few questions from a Neon nOOb
  240. What would my 1/4 mile times be? Your guesses are highly apprieciated!!!
  241. Heat Shields
  242. doing a mtx swap
  243. engine removal problem
  244. 96 Neon head gasket replacement ballpark $
  245. 97 Neon vs 97 Talon
  246. Help!!
  247. CV joints?
  248. Air bag problem
  249. Swap
  250. this might be a dumb question
