PDA
View Full Version : 1st Gen Neon
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Help!! I should be runnin faster than 17sec
  2. I NEED a mopar pcm dohc
  3. Fan relay help
  4. Rough Idle Mystery solved!!!
  5. error code 31
  6. megasquirt
  7. intake manifold???
  8. sohc wont start below 1/4 tank
  9. 96 Dodge Neon Brake Issues Please Help
  10. 98 Neon rough idle
  11. 95 wont start
  12. Indy intake
  13. 420a head
  14. starter issues
  15. head problems changing head but not sure what head to use
  16. Serious Issue ~ single mom needs HELP please
  17. Sohc crane 12 1/4 mile times?
  18. 1998 neon clicks but wont start
  19. Replacing Front end Damage? Anyone?
  20. tire size conundrum
  21. Rear parking lights don't work.
  22. Anyone sellin speakers?
  23. Sprocket question
  24. Neon Headlights
  25. Oil leak?
  26. looking for specific parts
  27. 95 Neon Knock/tick noise?
  28. clutch and ecm info
  29. wierd clutch noise
  30. 2.0 to 2.4 Differences
  31. 98 neon fuel pump fuse blowing out?
  32. temp guage reading hot for no reason
  33. mileage
  34. mileage
  35. Instrument Cluster fine, but still not working.
  36. Tire question.
  37. Original Neon video owner's manual
  38. dome light!
  39. Losing Power when Turning with Low Fuel
  40. timing problem plz help fast i need this car for work and cant figure out whats wrong
  41. New Member of the 200K Club!
  42. factory tweeter!!
  43. adjustable strutt
  44. newbe 1999 neon rt
  45. Sunroof Repair Links for Neon
  46. Smoking PCM
  47. cylinder head
  48. 98 neon wont start
  49. 96 Neon PDC rewiring
  50. Subwoofer enclosure?
  51. 96 SOHC Neon Struggles Uphill/Slow Acceleration
  52. 1996 Neon ?
  53. More stupid problems.
  54. Stinky A/C
  55. Illumination Light Fuse Issues.
  56. 98 Neon SOHC Camshaft Postion Sensor
  57. 96 Neon Wont Start
  58. Speedo is off?
  59. Speedometer problem with a 1996 Dodge Neon
  60. 2.0l to 2.4l head swap?
  61. POS neon serious misfire/oily spark plug problem
  62. Overheated coil packs
  63. alignment
  64. bought new wheels, need opinion!
  65. scrappin noise from where???? and grounding problems
  66. Will these rims fit my car?
  67. when lowering
  68. Black turn signals
  69. Tach help please!!!!
  70. Transmission kickdown cable
  71. 99 Dodge Neon DOHC
  72. overheating, kinda
  73. 95 sohc dodge neon
  74. which lowering springs?
  75. Lifting a Neon
  76. Stalling...sometimes!!??
  77. Need support for my 1995 neon highline -- read...
  78. mufflers
  79. no reverse
  80. 95 SOHC Acceleration Problem
  81. check engine light
  82. New to the Neon world
  83. Clutch Cable???
  84. Fuel sender ?
  85. Weird overheating when ac is on???
  86. Under construction...
  87. How hard is a swap?
  88. 95 Neon, Hot afternoons, AC on, slow crawl to overtemp
  89. 96 Radio not working
  90. My 95 backfired and would not move...
  91. new to forum w/96 neon.
  92. Swapping 96 sohc ecu with 97 dohc ecu MT
  93. just wont start. it should ?
  94. 97 Highline Sohc surging issues
  95. Weatherstripping
  96. wtb: 97-99 mopar pcm
  97. Bad acceleration once warm
  98. turbo 420a neon??
  99. crank sensor problem?
  100. 99 front end rattle
  101. Ignition Coil Connector
  102. 99 dodge neon sport r/t 4 door sedan
  103. 1999 Neon/E10
  104. Engine fans don't want to come on, 95 Neon
  105. I am looking for help to figure out right gear for a 3/8 mile dirt track.
  106. 98 Dodge Neon Clutch Pedal Ignition Lock Switch
  107. 98 Neon Purchase next weekend
  108. Check Engine Light
  109. Electrical frustrations
  110. Cluster lights won't work, need help.
  111. 98 Special Edition???
  112. HELP! 95 neon misfiring under acceleration
  113. New guy from indiana needing help desperately.
  114. 1997 Dodge Neon speedometer/odometer not working
  115. Looking for general advice and help on some information
  116. VA Military Member needs assistance.
  117. Whp with this setup?
  118. 1995 neon questions and problems
  119. Is it possible to swap 2ng gen lights into my 1st gen?
  120. newbie questions
  121. 98 Neon DOHC problem
  122. Ac / fan / idle problem HELP!
  123. Help!! P1491 code
  124. darrie
  125. RIP My Neon
  126. Neon Engine Work/Upgrades NEED ADVICE!
  127. 96 Dodge Neon Running Problems
  128. 98 neon stalling problem
  129. Exhaust donut leak
  130. Transmission drain/fill photo guide
  131. manual rack help!!
  132. Lights and Intake for 96 DOHC Sport 4Dr
  133. 96 dodge neon cant get torque converter bolts to align with fly wheel
  134. 1999 dodge neon overheating problem
  135. 1995 possible wheel upgrade - hub info
  136. How do i make my tires not rub?
  137. fuel pressure reg questions/rough idle
  138. Engine turns over but wont fire.
  139. air intake temp sensor?
  140. Engine Compatibility
  141. 97 neon serious issues
  142. Help!!!!!!!Trying to install aftermarket radio in 96 neon
  143. '95 Neon WONT..
  144. 1996 neon
  145. Mystery oil leak, or newbie DIY?
  146. 96 Neon Rodent repair
  147. What is the best color for my rims?
  148. water on driverside
  149. 97 Neon Hard Start
  150. I need help with my car
  151. Transmission Fluid
  152. Electrical... issues.
  153. broken timing belt
  154. grinding or bottoming out
  155. stock car racing
  156. aftermarket tach need help!!
  157. bent engine mount or bracket?
  158. 1998 Neon with a flowmaster 44???
  159. Unique timing issue
  160. Fairly new DOHC PCM on SOHC
  161. Help !!! Crankshaft Dampner Pulley.
  162. 97 Dodge neon o2 sensor help please
  163. Monroe Quick-Struts for Plymouth Neon - Compatible with Breeze?
  164. NA Tuning E85 questions.
  165. DOHC Gear Identification
  166. remote keyless entry module
  167. Timing, camshaft and crankshaft question.
  168. plugs for a DOHC
  169. What the heck happened to my car?!?!
  170. 1998 dodge neon sohc won't start
  171. Engine runs - no gauges
  172. 97 SOHC dead! Fuel Pump, Or?
  173. Tranny issue
  174. new to this web site looking for a mopar performance pcm for a dohc
  175. 98 dodge neon looses power
  176. ground locations
  177. 1998 Dodge Neon R/T 2.0L turbo help
  178. Radiator Fans On and Off Constantly
  179. 2005 tranny Guts swap?
  180. 1997 dodge neon fully built, trying to find/ install a wot box-launch control??help
  181. obx 6.25qt wet sump oil pan.
  182. 98 5speed continual problems with shift cable/bushings
  183. 98 neon sport dome light dont work
  184. 1996 Dodge Neon
  185. Will a 05 tranny work in my 99 Neon???
  186. 95 cam?
  187. fresh battery, no start.
  188. transmission/headlights issue
  189. Cat removal - MPG gain?
  190. 99 Neon, Buzzing noise in the dash
  191. trans help
  192. 97 2.0 sohc driving me crazy
  193. 1. gen Sratus 2.5l brakes on 1. gen Neon?
  194. 97 neon bogging after new head gasket
  195. pcm questions.
  196. Whining belt
  197. Help!
  198. Obd-II tool OT-2 wifi connection problem
  199. bottom end rpm good, high end rpm weak
  200. Code 72 and EVAP solenoid
  201. 96 Neon Starter Wiring diagram or pics needed
  202. '96 Starting Problem
  203. 96 highline starting problem
  204. Motor mount bolts on a 99 sport
  205. header bolts size and length?
  206. Neon 95 Manual Tranny
  207. instrument cluster help
  208. Is engine Damaged ? or Just some Pump broke ?
  209. 1998 neon RT. Delayed Start/ Fuel Pump fuse
  210. Dash gage
  211. Dodge neon heating problems
  212. 96 neon brake lock up
  213. !97Neon No light, cranks but won't start, OBDII scanner will not read.
  214. 95 Neon Sport dying!!
  215. Backseat swap?
  216. rear wheel noise
  217. turn signal question
  218. Performace timing with stock cam gears
  219. Strange sound from gearbox when cold. (3,94 mtx)
  220. what kind of trans should i use?
  221. 97 dodge neon
  222. Fuel Pump 98 Neon Coup
  223. Shifter cable quandry
  224. How do i repair a dented rocker panel?
  225. No spark
  226. electrial problems
  227. Bad oil leak, i need direction
  228. electrical probelms with 96 sohc dodge neon
  229. Starter isnt engaging...Help ASAP
  230. Car won't start...Help needed ASAP!
  231. Two problems
  232. looking to buy another neon need help
  233. Little help please....
  234. 98 neon brake pedal is rock hard and the car is hard to stop!
  235. i need some help asap
  236. Acceleration Lag...any ideas?
  237. Push Button Start...Help Needed
  238. 1997 DOHC Neon died while driving
  239. Dieing after warming up
  240. Tranny issue
  241. oil light issues
  242. 96 DOHC ACR Part Out - $1 CLEARANCE SELL!!!
  243. not starting
  244. sensor problem
  245. Struts or Strut Assemblies?
  246. how to tell the difference by looking at 2.0 /2.4cams
  247. 2.4 swap
  248. bunch of 1st gen neon parts
  249. 1998 DOHC timing belt replacement
  250. code 43 help
