PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. ebrake
  2. knocking from real wheel
  3. Looking for junkyards in VA
  4. fuel pump assembly!!!!
  5. Turn Signal
  6. need some help
  7. Listen to this!!!!
  8. needed TB
  9. where can i get a......?
  10. Next mod?
  11. RICE TALK!!!!!
  12. Front End Shaking **Update**
  13. oil leak...
  14. SOHC to DOHC Swap
  15. Radio wiring
  16. question
  17. check them out
  18. wheel bearing how to
  19. Wanna trade?
  20. Wheel bearing Quick questions
  21. pictures
  22. speedometer is jumping
  23. cheap koni's
  24. where can i get steel mesh for cheap?
  25. help!!!
  26. Macromedia Fireworks Paint Job, Paint Scheme
  27. 96 neon sport DOHC oil/missfire and speedo problem
  28. pistons for a 2.4 non turbo
  29. new neon n already probs plzzz help
  30. hows my neon so far
  31. what kind of muffler do i get?!?!?!?!
  32. My car is NOT pink!!
  33. turbo a sohc? or just swap
  34. 98 RT DOHC for sale
  35. rebuild kits
  36. Internal wiring harness?
  37. Mopar High Rate & X-High Rate Replacements
  38. LOW RPM PROBLEM THIS TIME WITH VIDEO
  39. Un-Official Head Gasket and Timing Belt Replacement, How To...
  40. automatic to manual.......need info
  41. i want a CAI
  42. will these fit a 99 neon?!?!?
  43. need some info
  44. EGR valve
  45. reverse lights not workin????
  46. P1491 OBD Code and fans are running
  47. anyone ever heard of RMMS
  48. would this be bad
  49. Rear Light problem
  50. Frozen brake caliper-any way to fix?
  51. Need some radio help
  52. Wheel bearing
  53. Weight
  54. thanks all
  55. I need help
  56. blacked taillights
  57. what else do i fix???????
  58. srt engine with 1st gen trans
  59. radiator overflow boils after shutoff, i keep loosing water and overheating, help!!
  60. belt replacement!!!!!!!!
  61. Water temp getting hot
  62. switching wiring harness sohc to dohc
  63. What does das stand for?
  64. high flow cat or no cat
  65. What happen to the Royal Purple Thread?
  66. fuel rails?
  67. Crank sensor for sale?
  68. Thermostat replacment...
  69. intercooler
  70. pcv valve
  71. Misfire code P0340... where to start!!!
  72. trany swap
  73. I gotta get rid of the Neon!
  74. Live webcam *Nurburgring* Germany
  75. Any way to make IAT sensor read cooler?
  76. Getting Parking Indicator While Driving?
  77. stock speakers
  78. new r/t
  79. SRT coils!!!??!!!
  80. engine rebuilding questions
  81. im excited for no particular reason...
  82. neon vs. mustang cobra guess who won????????
  83. ca state legal...
  84. front bumper
  85. Help?!
  86. Amp mounting
  87. Alternator got wet yesterday, Battery Light now on today
  88. A bit over priced??
  89. Fuel filter
  90. DIY rear window tint
  91. Tach not working
  92. TB spacer install HELP!!!!!!! ASAP!!!!!
  93. Break fluid
  94. is this bad?
  95. need a spoiler for a resonable price
  96. Crossover cable and other transmission questions
  97. Experimenting with Video Streaming & Compression
  98. biggest cam
  99. Alignment woes
  100. exhaust reccomendations
  101. Radiator - please recommend a product/vendor !
  102. Neon vs Flash Flood
  103. 12.5 to 1 build
  104. camshaft position sensor problem
  105. Quaker State Motor Oil - Any one have problem?
  106. Clunk on take off ...any ideas
  107. what engines fit????????
  108. Prothane Motor Mount Inserts
  109. I SMELL GAS
  110. Lights
  111. 1st gen neon down the street sits in aggonizing pain..
  112. Mopar Performance Motor Mount.. bushings needed??
  113. fuel mixture
  114. welding front motor mount
  115. DOHC HEAD TO SOHC BLOCK?
  116. My Neon
  117. How much you offer 4 a gen1 w/ a srt4 swap
  118. rimz...
  119. swap?PLZ look
  120. OMFG ***Comeon, I could Really, Really use some help***
  121. am i not supposed to drive this car????
  122. where can i get Headlight Film in the colors blue and yellow?
  123. SeaFoam
  124. possible to put a muffler on backwards??
  125. Any gen1 drivers out there with a myspace
  126. Aftermarket water temp gauge
  127. Best time to shift in a race
  128. Does the Stock PCM Record Mileage?
  129. ok Whats going to Help Low End power I need it bad!!!
  130. steering wheel removal gone bad?
  131. Idle speed 98 neon
  132. muffler tips
  133. air filter right off TB
  134. HELP ASAP!! Gear Selection**fixed**
  135. overheating
  136. motor fell out!!!!
  137. will SRT rims mess up my speedo?
  138. 99neon wont start
  139. sway bars
  140. door panels part 2
  141. need more power
  142. code problem
  143. wanna start colecting up parts for the 100k tune up
  144. Mopar better the Tb Spacer + DOHC Pcm
  145. To sell a neon, the greatest quest of all...
  146. stupid thieves
  147. Mirrors
  148. "To Each His Own" Tired Of This BS
  149. why does my gas milage suck
  150. here is finally a video of the r/t running
  151. What battery?
  152. clutch swap POSSABLE??
  153. help me with my swap,1st gen neon
  154. well... runs on 3 cylinders still
  155. cylinder head?
  156. Neon Wont Start
  157. cruise control
  158. Question about rad fans
  159. how much would you pay?
  160. how to recharge
  161. Honda, skoda, and renault owners are..
  162. What Is The Differance Between Tuners And Ricers IYO
  163. found a way to go straight pipe..But DYNOMAX MUFFLER video is now up!
  164. Need a header!!!
  165. Calibers
  166. 2.4 oil filter question
  167. guage trim
  168. Mopar Combustion Cleaner
  169. power window switch removal
  170. Checking valves, etc... Pics included
  171. ok so what should i get
  172. struts/coil overs
  173. mesh grill kits i know i know
  174. wiring harness
  175. 2.2 Impreza AWD Engine in a Neon??!?! Look Inside
  176. about how much whp sohc
  177. fuel question
  178. spoolboy mod filter?
  179. anyone have the sigle into dual exhaust for sale?
  180. 2.4L pistons
  181. 12.5 to 1 pistons???
  182. 96 Neon Stalls after some time....
  183. Wire diagram
  184. Engine removal w/o tranny
  185. 95 trans fit on a 98? Racer let me know if you still interested
  186. People Are REALLY STUPID!!!
  187. 1996 Neon Sport Battery Light???
  188. any suggestions for a hesitation?
  189. 95 neon burns too gas. Help me Please!
  190. cost of the srt4 swap???
  191. selling 96 plymouth neon dohc
  192. strange overheating issue
  193. Lets hear them stories, 1st Gen Neons
  194. code 65
  195. MTX Swap done!!!!
  196. exhuast help
  197. Door panels
  198. smoking... not overheating... wtf!!!!!!
  199. would 1stgensrt4 beat an srt 4
  200. newbie help
  201. bov
  202. The Screamin' Demon needs a radiator.
  203. catch can
  204. Anybody have any extra DOHC Pistons?
  205. 95 dodge neon weird problem
  206. neoneros
  207. Battery/ the biggest one I can?!
  208. well my other post went to hell and no one helped
  209. Questions
  210. wtf...wtf....wtf...wtf...wtf...wtf!!!!!!!!!!!!
  211. Cluster Problem
  212. Mufflers???
  213. Help! Loosing water! ACK!
  214. to pay.. or not to pay...
  215. Help with a friends neon
  216. snowflakes
  217. Quiet Exhaust...
  218. roof fabric
  219. headlight switch shuts car off!!! help!
  220. Broke connecter thing
  221. the question no one has the answer too
  222. Acceleration trouble!!!
  223. lots of parts, new parts added!
  224. High Mileage
  225. What causes this
  226. new clutch wat should i get
  227. '98 NEON radiator
  228. 98 ATX Expresso Issues PLZ Read
  229. Condenser problems
  230. look good?
  231. 2.4L year?
  232. Can I change water pump with motor still in car?
  233. no spark....wtf??!!!
  234. OBX LSD issues
  235. Troubleshooting P1491
  236. anybody know stuff on plymouth laser
  237. shifter bushings...
  238. neon haters
  239. major gas leak
  240. any idea?
  241. venom feul injectors????
  242. spudsterier or those wih srt4 turbo
  243. headlight gasket
  244. Brake Booster help please
  245. Haii guys i nned some help desiding what to do.
  246. cv joint or clutch
  247. symptoms of bad shifter linkage
  248. acr sway bars 4 sale!
  249. Front Wheel Bearing Replacement
  250. brakes help?
