PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43
  1. wandering really bad
  2. fuel pump fuse
  3. What Cam you running?
  4. what u think just got done with it old pics
  5. I need some help and suggestions
  6. mtx atx ?
  7. Synthetic oil
  8. CODES!?!?!?!?
  9. help
  10. Lower Temp Thermostat
  11. voltige stablizer
  12. tranny slip
  13. new guy
  14. help please neon idle is surging
  15. car won't shut off
  16. need a crankshaft
  17. gasket kits
  18. motor question
  19. how about some specs??
  20. Auto to 5 speed swap
  21. turbo
  22. Dodge to Plymouth
  23. Runs like poot
  24. 2003 SOHC in a 1995 SOHC neon; possible?
  25. crankshaft timing gear how do i get it off!!
  26. M3 Mirror Wiring Question
  27. MY neon just wont start?!?!?!?!?
  28. No spark on spark plugs HELP!!
  29. engine problems
  30. i want to get a mid 14 sec car all motor...
  31. Fuel Pump Goes bad after 1 mile?
  32. Borla exhaust
  33. CAMS
  34. 96 crankshaft sensor wiring kit instructions?
  35. Poor Gas Mileage 1999 Dodge Neon RT DOHC
  36. new to the forums
  37. break stand
  38. What Fluid for transmission. Auto and Manual.
  39. Speedometer not working
  40. transmission prob
  41. Engine Flush?
  42. dead wet neon
  43. water pump
  44. need help on motors
  45. APEXI s-afc II
  46. will i blow my motor
  47. 99 neon body mods
  48. Need help with Diagnosis!!
  49. hey does anyone have a manuel rack and pinion i think they coem off of the 95 base neons
  50. 97 neon- rough idle then stalls
  51. timing broke on highway, my luck engines shot
  52. moon roof
  53. heater problem
  54. oil in the intake
  55. Problems
  56. ceramic, push button clutch?
  57. 2 Questions
  58. Head Gasket + Timing Belt = Running, but with a couple problems...
  59. My first post and a doosie
  60. 96 Dodge Neon Won't start !!!help
  61. Cold start help 95 neon
  62. what could i use the 2.4l out of for my dohc neon
  63. still dont believe me???
  64. question about pics
  65. help me on this code p0101
  66. Some Newb questions
  67. Stock Exhaust?
  68. Timing belt and bENT vALVES
  69. clutch problem
  70. I need help with my neon it doesn't start right!!!
  71. Throttle body
  72. idle in my dohc changed with my new TB
  73. Why the ATX's blow up?
  74. low gas milage
  75. Tire sizing
  76. would a non-turbo eclipse motor fit in a DOHC neon
  77. why is my DOHC slower then most SOHC
  78. Spark Plug/Check Engine Light
  79. oil leak and gas leak when fueling
  80. 6 speed?
  81. Speed question....
  82. Help
  83. differential pin?
  84. New to neon and question...
  85. weed whacker sounding exhaust
  86. why???
  87. i need lowering springs for a 95-99 neon
  88. i need new clutch. usa or mex?
  89. Timing
  90. oil
  91. New Neon... Problems..
  92. question about headers
  93. whats r/t?
  94. 02 sensor removal
  95. Projectors :-/
  96. Throttle body swap
  97. Remote Starter Question
  98. something i dont understand???
  99. Injectors
  100. turbo
  101. Info needed for a 2.4l DOHC Stratus Swap
  102. engine problems...still
  103. improper tach reading
  104. need motor mount for 2.4 into 2.0 anybody got one?
  105. engines
  106. Need Part Numbers
  107. Fuel management
  108. new to the site
  109. limited slip?
  110. Snapped off a tranny bolt!
  111. Cabin / pollen air filter
  112. polyurethane
  113. 95 auto no reverse
  114. 5 spd tranny questions
  115. Stalling - hesitation - stuttering !!! SOLVED!!!!!
  116. Quikpipe Cold Air Intake
  117. will a sohc motor fit my dohc
  118. Code...1491???wont start.
  119. o-60
  120. tach problems
  121. speedometer questions
  122. neon throttle body
  123. MTX question
  124. lookin to do some head work
  125. are clusters interchangeable
  126. 1998 Dodge Neon questions
  127. mounts
  128. Wheel sizing
  129. Cylinder Misfire?! Help!!
  130. Emissions
  131. neon is shakeing
  132. exttra fuse box
  133. Ignition problem?
  134. Neon Help!
  135. Gas problem
  136. neon to dirt race track
  137. 98 neon 4dr sport
  138. which engine oil?
  139. quick fuel question
  140. What's going on with the Neon?
  141. low cost ems
  142. Got me a another Neon...
  143. Need some help with a couple question.
  144. help with gauges
  145. E-Brake problem!
  146. enging code P0422
  147. does anyone have a dohc motor they want to sell
  148. converting a neon to rear wheel drive
  149. carbon fiber
  150. oil leak
  151. low rpm miss
  152. Code 65 neon 1996 problem
  153. Anyone thinking about a front end conversion...
  154. taillight fillers
  155. Front Backfire????
  156. Engine Help needed
  157. 95-99 neon front lip anyone have them
  158. How do I remove these spark plug tube seals?
  159. DOHC valve cover
  160. LOOKING FOR 96 NEON WIDE BODY KIT
  161. polyurathane motor mounts
  162. Help: Installing Glow Gauges
  163. will an 03 sxt motor fit in my 98 dohc
  164. Can you clean a catalytic converter?!
  165. Trouble Code #64!
  166. 1998 Neon SOHC Bucking.....
  167. Clearance Problem
  168. Rust on the vavles...
  169. installed tranny, nothing turns, HELP!
  170. lights
  171. 1st gen front end swap
  172. tail lights leaking?? and my truck will not open?
  173. False Temperature Indication
  174. 99 r/t turbo install
  175. i want to rebuild my engine for racing what all should i get?
  176. Stereo Wiring Issue
  177. top speed
  178. Tie rod
  179. Engine
  180. Put put putting
  181. Rear Brake Conversion Help
  182. rear main seal
  183. apexi grounding system
  184. Yet another dumb quiestion!
  185. Fuel Problems/ HELP!
  186. '95 Neon losing fuel pressure
  187. Just wonderin......
  188. chocolate milk for oil, blown head gasket
  189. When is the starter finished?
  190. Throttle Body Interchange
  191. Rumbling sound coming from rear
  192. Exhaust?
  193. something new from the rust belt!
  194. downshifting...pop...clutch pedal has NO pressure
  195. Transaxle fluid
  196. Help with new Gauge face
  197. '95 Neon Highline, 87,000 miles. Fuel leak help.
  198. Turbo compatibility
  199. Is it worth saving?
  200. No electrical power, zip, zero, nada
  201. 5 to 4 lug pattern
  202. Hey its been a while!!!!
  203. 96 neon...dropzone lowering springs.
  204. Massive Oil leak
  205. smoke....ONLY at idle???
  206. 1998 Dodge Neon
  207. Newbie with a question
  208. Figured out how to post my pictures muaha
  209. help
  210. I want this to be an R/T
  211. body kit non ricer
  212. help converting an automatic to standard?
  213. Painting the interior of my neon.
  214. stupid question
  215. Hi all! New owner here. 98 Neon transmission question
  216. Radio Issue????
  217. New Plugs
  218. new to the world
  219. 96 sohc milage down to 10-15mpg ?????Help
  220. v6 motor swap in a neon
  221. need help on turbo
  222. Fog Lights on a 95
  223. compression results.....?
  224. Newbie needs help
  225. transmission fluid
  226. AFTERMARKET TACHOMETER INSTALLATION
  227. fiberglass hood?
  228. *^$#&*(!^%^%$#!*(*()$@&*()!@Headlights
  229. Shifter all kinds of F&*KED UP
  230. us vs. mexico ecu
  231. MAP SENSOR HELP!!!!PLEASE!!!
  232. motor swap
  233. sohc to a dohc
  234. sooooo lost am i...
  235. Exhaust kit
  236. My 97dohc dead...again.
  237. speakers out
  238. overheating
  239. catback
  240. new member - need some direction
  241. The nice P0171 (Running lean) code
  242. smog
  243. 98 neon auto tranny
  244. 98 neon auto tranny
  245. diagnostic codes...
  246. Which muffler do you recommend?
  247. 1998 Neon SOHC
  248. lubricating gauges
  249. torque converter clutch solenoid ckt
  250. blown head gasket
