- Clear Bumber Lenses
- Electrical problem - any ideas?
- Parting out 95 Neon
- Cracked tranny case
- Transmission problem
- battery/ voltage problems
- neon doors haha
- 2.0L dohc
- Tan Interior?
- Car Overheats
- What color rally stripes should I put on my Red neon?
- Rear Strut Tower?
- Heat Shield
- code 25 help
- AHH My fog lamp is out!
- diamond clears
- Possible to get a 97 neon sohc? to bout 160hp with out alotta big addons?
- car doesnt start! HELP!
- Projector Headlights
- HELP!!!!!!!!!! Clutch problem?????
- thinking of swaping engin and transmssion
- Leaking Gear Lubricant
- WATER PUMP vs Timing Belt/Tensioner!
- AAAHHH! WATER IN MY CAR!!
- Exhaust System
- blown head gasket?
- Wiring up amp and sub
- body kit question
- Horn No Work
- '98 Plymouth Neon EX
- wiring problem
- Valve Cover Gasket
- Check Engine code 51 Fuel Sys Lean
- Emmisons sucks
- alternator belt adjustment
- sohc question
- faulty gauges
- More Car Trouble =(
- loss of engine oil
- door ajar light
- MULTIPLE THROTTLE BODIES
- BAD NEWS
- Code 11, OBD questions
- sohc
- Torque setting for DOHC camshaft caps
- Clear Tails Lights
- 4g63 swap???
- car sputtering when accelerating
- Clicking noise
- Light bulb for neon 9007...what is the best ...
- factory coil springs
- 1/4 Times please
- 95 water pump help????
- rims
- code 17 help
- Targa Top Neon
- MY CAI
- Hedman/Chikara Header
- Engine misbehaves in reverse
- 95 water pump, timing belt
- compreser
- 1997 Help
- Coolant leak from head gasket
- 1995 Neon Interior Door Panel
- 10 grand and what to buy...
- new guage cluster
- rad fan problem
- EVAP System?
- N2O
- Pacesetter Header install ?'s
- Removing Side Mirrors?
- 97 Neon Radiator Fan not working
- 2.0 DOHC 13g turbo project
- MSD?
- Car Won't Start??
- Water in carpet driver side
- gauge help
- '96 DOHC sputtering
- CAI?
- time to just get a new engine?
- Need a new engine
- line locks
- gasket
- Miss My baby =(
- Turbo anyone?
- mtx? atx?
- advice needed, car losing power and going into security mode
- 95 neon loses power
- sunroof
- rough idle right after starting
- oil on spark plugs
- Sunroofs
- oil light
- Catalytic Converter
- New to forum.... Question on locks:
- neon horsepower
- Tail lights......Breaks, blinkers dont work??
- Radiator Fans
- Headers..... How hard..?..,.
- Does this do nething positive?
- All Carbon Fiber Neon?
- Colour Scheme? honest input
- Installin a Tachometer hard?
- the stock pipe..GOTTA GO!!!!
- Cold Air pipe only 1 way?
- super or turbo??
- need a idea on performance
- 95 Plymouth Neon compression probs?!!!
- Fuel/ air ratio gauge
- 97 Neon Sport Loose Spark Plugs
- Most interior lights won't work
- dead car
- '98 Neon Blinkers stopped working
- change tranny fluid?
- wheel "shakes"
- fuel cutoff
- Question about wiring
- code 35
- Ebay Rim
- turbo question
- Headlight Replacement
- 1st gen gauge cluster repair
- Gauge stoped working
- My first car!
- any ideas
- Neon 96, 2 doors: windows ajustment
- Trim question
- SRT-4 engine swap...what's exactly involved???
- check engine light
- 95 sport vs. 95 regular
- fog lights
- passing gear
- Ideas/Thoughts on Coil-Over sleeve kits?
- Harmonic Balancer Puller & Crank Pulley Tool?
- OOPS!!!!!!!!!
- SPEED CHIP DODGE NEON
- Opinons on Sportline springs
- Moving the Cat w/short tube header??
- New scenario
- Small problem
- cv shaft replacement questions
- What/How to clean my pistons
- Hmmm - what a mess
- electrical problems
- painting question
- SSB and SBA steering
- muffler?
- Throttle Body changing
- Fuel system cleaner
- Cigarette Lighter
- 97 Neon head light stay on
- gauge question
- wiper arm how to change it.
- Whats your opinions
- Engine loading up on fuel...
- Got some where
- so um yea....
- Head Gasket Change
- Motor Mount Inserts
- Lets try this again...
- New member with Neon 96
- motor swap
- Auto Paint
- How much HP....
- tech help
- runs rough
- 95 Neon SOHC, interference motor??
- stupid question
- ACR or aftermarket
- Help please
- Synthetic gear lubricant for manual trans?
- Driver's side window problems
- engine swap question
- Little help please
- SOHC head to DOHC head swap?
- Oil restrictor question
- need help on code32
- Oil Sending Unit
- racing stripes
- I want this one-->
- System dont work?
- Fuel injector question
- sleeper neon?
- Dodge Neon Heating Problem
- Where can I find a...
- What's Wrong with this Picture
- 95 fabrication and paint question
- Gauge installation question
- strut problem
- I have melted my egr valve
- 97 neon engine
- Problem with some part....
- squealing sound
- Jeep Grand Cherokee stereo swap to my Neon?
- Turbo AT/MT ??
- Header 95-99
- Oil still leaking
- weird happening
- 98 neon tranny issue?
- Used Rims..
- P&P/exaust/suspention
- srt4 for regular neon?
- trunk
- finally my 1st gen neon is in the shop
- Engine Problems. Please help!
- pcm or header
- SOCH and DOHC Manual Transmission, bolt up the same?
- is it hard to install a fuel pump?
- 5 speed or auto
- why i cant reach the 5000 rpm ....
- Nitro Yellow Green Sport Coupe 4 Sale
- NE1 WANT a NEON?
- Door
- couple questions
- headers
- Speedometer?!
- Aut. Transmission for Neon `96
- Motor Stops without warning
- Oil leak please help
- What's that wire for?
- starter?
- throttle body
- Manual won't shift into 1st!!!
- No starting condition need help
- neon codes help
- 2nd Gen Valve Cover on a 1st Gen?
- boiling coolant
- Just a couple Q's
- automatic iceman
- 2-3 sluggish shift
- question
- front disc brakes
- fog lights
- Valve Cover
- iceman intake
- Automatic
- Aluminum radiator
- ATX Upgrade
- Replacing Head Gasket
- TB before or after CAI
- duel exhaust question
- 98 Neon alternator
- 60mm or 55mm
- prototype neon (1991)
- Ran a GTI last night.
- Trunk lid?
- 95 4 dr neon vs grand prix gt
- Bored Throttle Body
- new parts?
