View Full Version : 1st Gen Neon
- non PB hood with 2.4L.
- I NEED A VALVE COVER! help
- little ****ers (paint tips)
- oil sensors
- building up the top end ...help
- heavier oil???
- valve specs 1st gen SOHC vs. 01+ magnum
- Pic needed...Back up sensor location
- Mopar PCM or RPM gauge off?
- H&R Lowering Springs
- Gear slop or diff pin or axels???
- eibach springs
- 98 neon
- i want ur opinions
- crane 12, 14, 16 cams.
- Made a discovery last night...
- 95 neon threw code 41 generator field not operating properly
- how necesarry are
- GO 2.4 OR GO HOME
- forum rules
- side pillar covers.. cheap?
- Did some ebay splurging this weekend
- my 96 sofhc threw a p0171 code
- car keeps hesitating
- How to install side/parking lights
- Whats my 5 Speed Neon Worth ?
- no spark at all, help engine wont start!!
- killed neon
- fuel pump fuse hates me
- squeaky motor mount
- Need help, parts, info
- dont know if i did something wrong but holy hell
- Sensors
- 99 dodge neon cuts off
- how come
- struts
- Which Clutch?
- fiberglass hood
- Dash Speakers
- Need Help buying a muffler
- turbo-charging
- projectors in...halos arent working right
- Turn signals not working correctly
- Looking for a magum cam
- Rear Trunk Speakers 4 sale
- 4dr first gen body kits
- plenum spacer
- Secondary hose to Throttle body intake???
- White, milky subsatance in oil???
- Good Reason to Keep Stock PCM..>Look Here
- Custom seat brackets aftermarket.
- heater controls
- Upgrading my 1997 neon SOHC
- Turn signal cancelation not working
- wel i think its official
- 95 neon mods or adjustments.
- computer help
- my srt 4 wing!
- Wanna Trade??
- oil light
- need some advice quick. ASAP
- ignition switch...
- I NEED ALOT OF HELP WITH MY 96 PLYMOUTH NEON PLEASE!!?
- My 1999 Dodge Neon *Pics*
- My 99 dohc just threw a P0304 code. Any thoughts?
- Emissions sucks
- next mod for my r/t
- lowering kits
- Mini Viper is down
- remote mounted turbo
- SORRY!!!!!!
- Question about tranny fluid
- backfire...code 43
- four point f/s links to pics are now included
- racing seats
- is this a good clutch choice
- broke a bolt
- starter sparking!
- HELP!!!!!!!!
- door switches
- is this a good price?
- when you think you seen it all
- 95 cam shaft
- what kind of tail lights
- air/fuel gauge????
- Battery light flashing on and off, car jerks?
- fans not working
- no fan motors
- The Little Things
- Help.
- Just Wondering...
- starter sticking
- is it too rice?
- Anyone Autocross?
- Well, I got a Mitsubishi TE3/4 Turbo!
- tempature problem
- alternator question
- new pics added,,, got tb yesterday, questions about it
- 1997 neon upgrade questions
- 1998 DOHC Neon w/temperature problems
- thank you spud
- silly question?
- heater core removal
- nology wires coil and box for cheap
- 1998 Neon with DOHC stalling starting problems (HELP)
- i need a fuel tank filler neck
- Ok noob is back, more problems with my neon ;(
- throttle body
- just proved the neons capability
- clutch cable removal and install
- Maybe looking at a cheap 97. advice?
- underdrive vs. lightweight
- SOHC head on DOHC block???
- who wants free stuff?
- update
- I need some ideas
- How Long have you owned your Neon?
- when i press in the clutch>>>HELP
- dual side exhaust
- question on lug pattern
- just bought some depos.
- failed inspection, need to fix
- buy or no
- Question on RPM's
- clean headlights
- new rims....
- ight buy thin one!!!
- will 100% plugged heater core effect engine cooling?
- what do you guys think?
- Verdict on the dyno is..................
- wheels
- just wanna make sure this is okay.
- another question
- 3 questions
- New Pics
- Problems again!
- Tranny swap question
- WHATS THE first mod you made to your neon??!!
- which hose is the inlet hose
- oil line
- clutch cable or clutch
- got my r/t!!
- This is going to sound funny..... But I need help anyway!
- Engine went pop and antifreeze everywhere!!
- HELP
- Headers
- dyno
- Overheating problem...last post...suggestions???
- Antenna
- neon cuts out during rev
- holy freaking head batman...
- soch intake???
- Feeler post..
- ok i did search
- 96 neon engine mis ideas?
- Clutch Time.
- Headlight lens hazy
- $1,700 95 SOHC 80K + Extras New Better Pictures Make an offer Must Sell
- Head Gasket mission accomplished
- now they have a book
- Facisa Fog Lights?
- ok so im confused,, well i was looking at spuds pictures and...
- what clutch
- horsepower
- im getting a turbo
- auto to 5spd....
- Throttle body spacer What to buy
- alt. belt squels when wet.
- HG wasnt leaking
- Engine Sputters and Dies, no clue. Help!
- how much horsepower??
- Fuel Tank Filler Neck
- Oil in spark plug cavities
- come on people vote
- building a srt motor
- atx trans leak
- got some new toys
- glasspack
- Interior lights stuck on
- gauge cluster ?
- urgent need some help...
- first gen srt-4 turbo tuning PLS HELP!!!!
- Clutch Cable Issue???
- Help! Please shed some light on shift linkage. Pic included.
- here we go again
- Looking for some parts
- Where did the Neon get it's looks from?
- i got hubcaps
- coolant overflow bottle
- Cooling propblem update....more help please
- Iceman intake on Ebay
- What is Code 37?............1999 2.0L SOHC
- no power to coil
- 2.0L SOHC overheating diagnosis help please
- Buying Atx TB for 1st gen, Let Me Know How Much
- code P0118 Coolant Volatge High????
- Help! I need A Head Valve Cover Gasket for an SOHC 95 Highline!
- Engine whines at startup
- trunk hard to pop.
- cracked dash
- hi, 1st gen guys... anyone have a stock CD player...
- any one want a 2.4
- i don't think it will work and a real ?
- turbo project videos!
- painting rims project
- no spark or fuel
- radio problem
- time for the painting project
- need a tach
- mopar pcm?
- Better ideas for fuel line
- pic of r/t's
- fog lights question
- Clutch Help...........
- New calipers and still the brakes drag.....
- starter
- MORE BRAKEING SH!#
- should i get it or not
- quick question
- motor choices???
- '95 Gen I Neon | Radiator | BRAND NEW | For SALE!
- torque converter solenoid problem?
- Want to be 100% sure its the TOB
- squeaking and ps/ac
- pt, or neon engine?
- TB w/ cc HELP
- fast free hp?? opinions?
- cc tb.....das???
- No fuel
- diff pin woes?
- H.I.D. Headlights
- new rotors
- Clutch Circuit/Torque Converter Trouble Code
- Replacing Brakes on a 96 Neon
- another trans problem
- ATX TB
- flashing PCM
- 4g63 to a 1gen neon
- how hard is it to put a neon srt-4 motor in my 96 neon
- on the road again!!!!
- throttle body spacer
- my poor car
- engine removal
- exhaust sucks
- Skunk2 lowering spring
- FS: 1995 NYG stage 1 SRT
- Rotor won't come off
- gear lube!
- need help/advice thanks
