PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. air intake
  2. lug nut size
  3. water pump leaking???
  4. 99 parts
  5. Name this injector
  6. Modern Performance's SUGGESTED BUILD STAGES for the 1st gen's??
  7. acr
  8. in your opinion should i get the parts or the engine first
  9. koni struts
  10. Steering Wheel locking up
  11. Is this a UDP or stock???
  12. Turbo fuel rail Q
  13. quick car alarm question????
  14. Parts for sale.
  15. lost key
  16. want to buy a neon
  17. 98 Neon Died and wont start
  18. Hydraulic vs spring tensioner
  19. HomeMade Turbo Manifold Pic + a Few pics of my Car
  20. smell oil
  21. check out the evolution of my car(its not much)
  22. looking for a couple parts for the 2.4 swap
  23. would anybody suggest
  24. EGR valve replacement
  25. the beauty of computers
  26. Turbo room
  27. Starter Bolts
  28. Automatic Transmission is not gearing down from 2nd to 1st
  29. sohc 2 dohc swap
  30. Can I put this turbo on my car??? lol
  31. Vacuum
  32. speaker question (powered sub)
  33. will this set of cams
  34. anyone have 12 grand i can barrow???
  35. FOR SALE
  36. Turbo the MTX or ATX?
  37. Used engine trouble
  38. Right hand drive
  39. should a mtx be rolling in neutral
  40. ok im retarded
  41. HELP! oil light
  42. wiring harness disassembly
  43. modern performance driving lights
  44. well i got another r/t
  45. Is there......
  46. oval asphault track tire?
  47. Auto trans problem
  48. axle question
  49. Great, what the hell is this leak????
  50. Differential Mod
  51. theoreticly, how much room....
  52. MTX Gearing
  53. afc-neo wiring
  54. Can Anyone Help?????
  55. Turbo gastket
  56. 1995 neon no power to coil pack
  57. 250in lbs?
  58. water pump and timing belt
  59. trunk flop problem
  60. rear main seal
  61. grease and so on...
  62. wing...
  63. any ideas on clutch
  64. sticking a v6 into a 1996 neon?
  65. fuel cell
  66. What do you guys suggest (exhasut)
  67. car shuting something to do wit battery
  68. boost gauge
  69. fpr and rrfpr
  70. Shifter?
  71. ATX TB & CEL
  72. Question about codes
  73. EGR, block off...question...
  74. Battery light going on, but battery is new
  75. Map clamp
  76. ASD realy , 95 neon not starting
  77. possable group buy....lsd....
  78. antifreeze
  79. diagnostic tests
  80. drive axles
  81. Need some ideas
  82. blowing fuses need help
  83. Plymouth Neon
  84. got my 95 cam!!!!!!
  85. wheels?
  86. how hard
  87. Intermittent grinding noise.
  88. I need some advice
  89. 95 Neon only revving to 4000rpm????
  90. alt question
  91. Clutch brake in???
  92. Stock air intake part?
  93. ATX TB question...
  94. 2.4 swap
  95. exhaust is on
  96. ~$1700+/-
  97. Good interior pic and contemplating
  98. UDP installation
  99. New owner
  100. 96 auto neon no reverse
  101. difference in highline and lowline
  102. exhaust leak cant get fixed
  103. srt swap
  104. better plug wires?
  105. dropped the clutch dang it.
  106. SCCA & R/T Wheels, SRT Injectors, TB f/s/t
  107. High Flow Cat
  108. intake
  109. air fuel imbalance help
  110. What MTX to use
  111. Buying another neon
  112. Where to get info on Trans swap
  113. timing belt broke wat u think happened to the valves
  114. NAME THIS CLUTCH!!!!
  115. Ignition Key switch problem!
  116. Nitrous
  117. Christmas Ideas
  118. someone chime in please
  119. neon
  120. rods and pistons
  121. exhaust
  122. motor mounts
  123. Neon engine for sale SOHC, other parts too
  124. Swapping 1st gen Gauges
  125. how to fix a power moonroof
  126. Spoilers/Wings
  127. need help car not starting! need help bad!!!!
  128. f1 clutch from ebay
  129. Goldline Lowering Springs?
  130. white smoke
  131. recommended injectors and plug wires
  132. Alternator voltage output...
  133. Mini Viper is ALIVE
  134. wiring problems
  135. What do you guys think of these lowering Springs
  136. will a 2nd gen motor fit in my first gen
  137. got my dohc motor ideas
  138. I WANT THIS NEON BUY IT FOR ME OR DIE...
  139. Got a question about my 1997 Neon DOHC......
  140. Clutch removal.
  141. 99 R/T questions
  142. rims and tires. help with size
  143. HELP!!!! No Cold Start!
  144. Little trouble with my push button start
  145. need qs from your guys
  146. Optima Battery Problems....
  147. arent you glad you have a a neon!
  148. srt cluster on 1gen
  149. Help. My neon is eating gas more than usual!
  150. shifter cables
  151. New Modernperformance website....
  152. 96 neon..pulsing lights!!
  153. 95 Ghetto 3.0 CAI question...don't shoot me
  154. Fuel Injector Questions
  155. Is there anyway to find out what options my neon has
  156. kinda confused about oil troubles...VIDEO IS UP RIGHT NOW
  157. Alarm Problems
  158. question about what fuel to use for DOHC
  159. parts fitting questions?
  160. viper keys
  161. is this a good deal????clutch.
  162. what does it take
  163. Need help with neon!
  164. FS: 420a built part out
  165. Power Steering Noise
  166. best spark plug and cap
  167. electrical problem
  168. aftermarket oil pan
  169. Turbo people help. Garrett T3
  170. HELP! HOW DO I GET MY DASH APART (STEREO)!!!!
  171. oil feed and return line...
  172. What exhaust size/kind should i get
  173. i think i have a transmission problem
  174. 98 Neon Back-up Lights not coming on
  175. fuel pump question?
  176. had some fun with my back seat. lol
  177. just out of curiousity
  178. throttle body spacer?
  179. In Your Opinion What the Best Looking Kit ??
  180. car shutting off
  181. ITB's on 1st gen!!??
  182. Blown bulb in gear shift console
  183. HELP WITH CLUSTER!
  184. Time for a new clutch question....
  185. hood
  186. HEADLIGHTS GO OUT WHILE DRIVING
  187. problem just started to happen
  188. Fuel Pump problems!!!! HELP PLZ!!!!
  189. OBX Throttle Body Spacer 95-99 Dodge Neon 2.0L
  190. anybody know
  191. my 2nd neon
  192. Gen1 Brakes and srt 4 brakes
  193. 2 year Turbo plan.
  194. push button start and toggle on/off
  195. question
  196. 1995 Neon Clutch
  197. Cheap neon turbo kit turbonetics....grrrr
  198. Turbo set up?
  199. 97 neon leaking coolant
  200. Gas mileage and steering problem
  201. A/C oil type
  202. Neon Problems?
  203. parts fitting questions
  204. oxygen sensors
  205. Getting a '98 Neon on Monday, some questions...
  206. looking for motor
  207. are there any stronger axels for 1st gen?
  208. lol may another neon rip... lol
  209. last one for now
  210. just another pic
  211. interior pics
  212. custom cold air intake pics............
  213. Lots of carbon built up and spark plugs are ash white...
  214. Glasspack or not
  215. i wanna turbo!!
  216. b4 i buy this turbo i need some opinions
  217. cylinder head question
  218. C what ya'll think about these gen 1 coilovers
  219. parts for sale
  220. i did search...alot
  221. Is my CAI installed correctly?
  222. 98 dodge neon oil pressure switch
  223. right hand drive
  224. Damn Snow...
  225. noob question
  226. Fuel return question
  227. Window Leaking
  228. 95 neon bogging down at 40/60/80 kph
  229. timing belt and power steering pump
  230. Raising comprestion with MLS head gasket...
  231. need some help with 98 neon
  232. how much does 2.0L weigh
  233. 1997 sohc tranny problem
  234. ok I got a tire Question....
  235. Engine Stalling running like crap
  236. Which engines interchange
  237. New LSD unit found...New to me anywho.
  238. 2 questions.
  239. SCCA car
  240. someone is going to get f-ed up
  241. gears, acr, fuel, and 2.4 swap??
  242. Turbo is on and running Great!
  243. HELP! Installing White gauges. I cant drive like this!
  244. poor poor Neon
  245. window rattle
  246. This is the hottest NEON EVER in my opinion.
  247. turbo neon? or buy a turbo car?
  248. i need help installing CAI
  249. brakes and brake pads... yes i searched those terms and got nothing
  250. i got a few questions
