View Full Version : 1st Gen Neon
- Question to my Neon Experts
- Calling All DOHC Experts
- which one?
- random missfire
- 95 neon fuel filter leak
- which cam should i get?
- headlight adjustment?
- srt4 seats
- afr's and boost prob
- Shopping for a Neon.
- 2nd gen center console- will it work?
- Sohc, He351cw, 1000cc, got boost?
- Lip kit
- question?
- should i ?
- code=random missfire and car stalls
- head bolts
- Not familar with dodges.
- Oil Pressure Light
- tranny swap(updated)
- Im ****ing done with neons...
- Need help ASAP please!!!!
- battery fuse
- I need help with my Neon money pit.
- 2.4 engine swap
- DOHC swap to SOHC
- Got my neon running again!!!!!!!!!!
- question
- urgent help please..
- tech
- Intermittant speedometer
- gas milage ques.
- I need an engine
- '96 Neon charging light and battery discharge
- Back brakes creak no matter WHAT I do, help...
- dohc tranny swap
- radiator fans
- 99 r/t engine swap
- i am in need of
- Horn won't blow
- chrome grille for 95 neon
- Interior painting...?
- 95 Neon Speedo Trouble!?!? HELP HELP HELP!!!
- any 1 know y?
- steering/signal issue!
- Failed inspection
- Silent engine
- Please someone help me out
- how are you...
- overhead monitor
- does any1 know
- Short Throw Shifter
- Bad Rings @ 104K?? Is this common?
- Turbo Installation
- depos
- yellow shtuff
- Dodge neon '99
- what should i do?
- Dad in need of some help
- Need some input
- stock fuel regulator and begi rrfpr
- racing seats
- 99 dodge neon
- fan problems
- opinions please
- need some help on finding somethings
- 95 head fit a 96?
- for sale make offer+ shipping and its yours...
- parts wanted for 98 neon
- alternator woes
- all motor setup questions
- Problem wiyh my 97 neon
- Struts and stuff
- Highway hesitation
- 98 ACR Won't start...It's complicated please help!
- does anyone know anything about NINJA style body kits?
- radiator part numbers! ATX and MTX
- junkyard radiators.
- Selling:98 Dohc Mopar Performance Pcm
- Connecting rods
- this is getting annoying
- Driver side door latch is stuck
- 1st gen turbo or SRT swap-I need one
- rear brake self adjusters
- headlights
- Question
- how to run powerwire
- my car $400
- Radiator Fan Not Working
- any 1
- Fuel Pump Fuse/ piston rings
- Camshaft installation
- neon atx vs. caravan atx
- just to be clear??
- wheels
- Turbo Question, need answer asap
- think it will fit?
- replacement engine
- blowing ignition feed fuse neon number 10
- unanswerable or what
- how hard is it to..
- tranny question
- brake lock up
- need a photo
- some one help me
- Not ready for Mass. inspection
- parts needed
- Turn Signal Issues - 1996 Neon
- wheells
- GRRRRRR Fuel problems
- Fuel pump/Fuel gauge
- ugh....
- tranny/mounts
- need help-installing udp
- fuel pump over heating?
- ? on advancing timing with comp cam stage 2
- F***ed speaker wires-explane
- need help with my 95 dodge neon ???
- Shifts Into Neutral when going into overdrive
- need help with fuel gauge
- '96 Neon SOHC performance suggestions
- Won't go past 5 1/2 grand
- ok WTF
- oil light
- Hood Emblem needed for '98
- super 16 g turbo question
- neon rt clutch cable
- Front Speakers
- Trunk Spare Tire Holder
- Info on cat relocation/removal, tranny swaps, engine swaps
- broken dip stick
- white plugs
- radiator and fan issues
- Bad piston rings?
- Burning Oil
- 98 Dodge neon DOHC ticking problem
- ghost we need to talk still
- smoking!!!
- new problem
- look at this
- Check Engine Light Help
- need help finding parts
- for SPUD or anybody else with srt turbo
- cd player question
- New for sale post. I am done with the neons.
- lip kit
- lip kit
- drive to reverce
- Update
- exhaust hangers
- Manual Or Auto
- Got her started, now she wont re-start.
- 1st startup, fine, 2nd, car dies?
- 98 Neon DOHC Over heating - updated
- cold air intake
- header/egr
- ignition coils
- 1997 Plymouth Neon P0743 code???
- code 31
- toggle switch
- Short Shifter
- need advice on my n/a
- Finaly finished with the update?
- Auto Door Lock Issue
- Battery relocation write up.
- After market headlight fitment
- overheating
- Air conditioning question
- Posting problem.
- I NEED HELP
- WooHoo! Look what I got!
- Overheating, Or is it?
- Performance Chip
- Whats kind of car should I get?
- 96 dodge neon running too rich
- 98 neon intermittantly wont start
- trying to setup 95 sohc for dirt circle track
- Exhaust
- looking to buy a computer
- p0137
- poly bushings
- Neon SOHC N/A
- hey guys its a fast question
- what fmu?
- noob needs help.
- posts
- cams and retainers and springs
- New Rims!!
- Clutch cable replacement
- unknown sensor
- auto trans
- Neon SOHC TURBO
- speedo not workn
- HELP SENSORS OR NOT???
- HERE WE GO AGAIN
- tore out the trans,
- fuel pump
- I put my parts on ebay.
- racing automatic transmission?
- How is the neon coming?
- Starter question
- after a year...
- rims are rubbing!!!
- painted the car :)
- car audio section sucks
- Fuel pump?
- LMAO
- has anyone ever used these?
- changing an altenator in an 95
- Anyone know how much to torque a rod cap?
- I am new here! 97 SOHC 2.0L CAI help!
- wats da recommendation of timing belt change on 97
- 03 dodge neon cluster swap
- atx vs. mtx axles.
- You guys ever see this?
- performance talk
- atx problems
- need to change front brake caliper
- wheel question
- Getting ready to swap a 2.4
- Suspension Techniques #55335
- Instrument Cluster Pinout
- would this work?
- 1st Gen Air Struts into my 2001. Yay or Nay?
- Cleaning enigne..
- New Engine, honestly how much?
- 2.4 tb question
- dont know what this means please help
- Amp troubleshooting
- crazy idea for crankshaft...
- flamethrower...
- Looking for a crackshaft and a piston rod for a sohc
- NO DRAIN PORTS AHHH!!!!
- 1997 ACR Neon for sale
- mopar egr block off plate
- 03' 2.4 1st gen?
- -HELP- Grinding/Rattling Noise -HELP-
- 5 spd swap.
- Battery relocation kits
- 2nd gen interior in first gen
- New muffler
- just saying hello and needing info.
- Engine Computer
- throttle body
- valve gasket
- ATX to MTX Swap, What do I need?
- wtb working gauges
- wtb radiator
