View Full Version : 1st Gen Neon
- iceman or battery tray
- Strange current drain
- 2.4 swap
- Leaking radiator fluid
- 99 dodge neon sounds weak when cranking
- slow n/a sohc crane 12. Please helpe :)
- ABS Light on no code
- Coil Pack Bad?
- new motor. Turbo? tuning
- 97 neon crank sensor wiring
- 1996 Dodge Neon Problem Please help *Video Included*
- 99 R/T for Sale
- Rear sway bar bracket
- 1999 r/t
- Seat Belts Have No Retract Power
- Why doesn't anybody get or answer my questions!!!!
- Help me please anyone!!!!!
- boise, id. new club
- 1999 Plymouth/Dodge Highline Coupe 2.0 SOHC
- 98' neon DOHC, several problems...
- 99 dodge neon over heating
- 1999 Plymouth Neon Highline Coupe SOHC
- 98 neon skyline qiestions
- pcm help plz no start
- question
- 2.4 swap
- Cam Shaft Position Sensor for 2005 Neon
- speedometer and odometer stopped working
- 98 neon hesitation
- engine and tranny questions
- 99 dodge neon. turn key and nothing
- 1995 neon....nothing at start
- Weird clicking noise from front drivers side tire.
- Over heating 99' Neon, Can't figure out why?
- brakes! how does this look...
- igniton and exhaust
- Weird electrical problem
- engine swap 95 dohc avenger in a 98 neon dohc??
- DOHC head
- doesn't start all the time anymore
- onboard rally video, 1G Neon
- Clunking sound
- high mileage dohc head?
- 98 neon electrical question
- just inherited a 95 4dr auto
- Miss fire saga continues
- 98 neon sohc a/c help
- Head lights out, left brake turn signal out.
- 98 dodge neon
- Aftermarket stero wiring problem
- First time a/c help
- LED problems
- 97 Neon Rear Brake Shoes
- Instrument Cluster Swap
- 97 Neon bucks then dies
- What's a better set up?
- can i turbo or supercharge my 1 gen
- Is this a good deal on a 1998 SOHC Neon?
- 98 neon has an a/c refrigerant leak.
- 1996 Dodge Neon
- How do you turn up or elimanate revlimiter HELP ASAP
- 97 neon no spark
- Multiple problems, help?
- Just bought a 98 coupe r/t
- Ran out of gas and needle still reads 1/8 of a tank.
- Just bought a 96 neon need some help with some issues it has.
- 95 Neon attempting to stall at speed?
- new rebuild oil leak ?????
- 98 Dodge Neon has surging issues.
- 99 R/T Mutliple misfire codes
- fuel injectors
- 1995 dodge neon 4 door sohc for sale
- removing the turbo???
- Best AFR for 1st gen neon
- cooling fans not working
- 95 dodge neon
- Urgent!!! No fuel to engine!!! Need help!!!
- Sputters Then Dies
- aftermarket radio no illumation lights
- Cam help urgent!
- ecu compatability on a 2.4 swap
- ecu
- egr vaver help?
- So, who's active around here?
- 95 Neon injectors
- Str. T koni and bump stops
- 98 Accelerates on Own
- stalls when warmed up...why
- Phantom Grip LSD
- 1998 Dodge neon, cant find part, help
- Stock to Aftermarket Stereo Help
- 1995 neon wont start need help!!!
- WTB Needed: '95 DOHC Wiring Harness & ECU
- Throttle / shifting problem?????
- P R N D 2 1 Label
- 3.3 swap
- Pcm help
- stock flywheel weight in a 99 neon sport?
- Neon Throwing code 51
- need info on replacing axle seals on a 1995 neon
- Need some speed!
- Digital tach reading low
- Loud bang when backing up
- Neon Leaks Fuel
- 1998 neon 2.4 sebring engine swap
- the dreaded p0300 code
- 1998 neon highline sohc electrical problem...
- '99 R/T Clutch noises and other minor worries
- Part numbers old visual parts Ventshade & Tail covers? pics
- no spark i give up well almost...
- how do i connect 95 fuel pump/taillight harness to99 dash harness
- Unerdrive Pulleys and Racing Ecm
- 1999 to 2001 shocks and clutch kit
- Heater core repair
- Custom tuned factory computers. Finally?
- Somethings wrong with my headlights/wiring
- Front control arm bolts
- Missfire Issues, Runs rough at Idle
- 1998 dodge neon rpm range
- 97' Neon for sale rebuilt and no rust!
- where is the computer located
- Possible substitute to the famous Iceman!
- Alternator question
- under drive crank pulley
- ecm/pcm
- Tranny shifting problem
- 1998 Dodge Neon Blower Motor..help..have video
- 99 plymouth 2.0 dohc...oil leak and engine light
- Neon won't start in the cold!
- 96 neon blower motor squirrel cage
- looking for a flame red trunk lid
- 1998 2.0 DOHC bent valves
- No power to lights, dash, or radio
- Reverse lights not working / fuel gauge not working
- Headlight adjustment
- Clutchs
- 1997 neon sport coupe drivers side door window off track (broken)
- 99 Neon, 2.0, DOHC
- 96 neon drive cycle
- fuel gauge works backwards
- Crane 12 vs Comp 400 or Crane 14???
- New Piston recomendations
- short tracked down to interior lights fuse in the pdc
- Motor shoots up to 8,000 Rpm with no warning by itself stumped!
- 96 neon emissions again
- Engine swap DOHC to SOHC
- Headlight Options
- 96 neon thats confusing me...maybe electrical
- Neon Series 1 1996 economy issue
- Rough idle and tries to die
- 98 Neon front clip diagram
- rides like i have fat ppl in the trunk
- is there a way to test the computer
- cheapest place to get a good port and polish job
- opinions on my new neon
- Rough Idle when in gear or neutral
- hey everybody I'm new here and could use some help
- HELP past time limit Emissions Test Failure
- Fuel pump woes...
- dodge neon r/t?
- Selling my 1995 Neon
- ice man intake
- Rust in gas tank 96 neon
- ?????neon no start do to gauges?????
- neon wont start did start before getting fire
- 1997 dodge neon vibarting problem
- Oil Pressure problems after head swap..stumped!
- Am I able to reuse Felpro Head bolts?
- 1999 Neon battry drain
- are DOHC and SOHC Head bolts interchangable?
- Gauge cluster problem
- rough idle in cold weather
- Help with high ideling.
- Headlight issue
- 95 sohc rev limiter porblem
- '96 Neon with knock - code 43
- 96 neon base: fuel or something problem
- differences in a 1999 2.0 and 2003 2.0
- go euro?
- Fuel gauge problems.
- Dash lights/ taillights
- sohc 30-70 in 6 sec
- 97 sohc, milky coolant clean oil?
- Need emissions help
- 1998 Dodge Neon Questions
- How do i do an EGR block off?
- Rough idle/Stalling
- Cigarette Lighter???
- 96 dodge neon running problems
- power steering
- 1996 Neon Stop problem
- 96 Dodge Neon Door Won't stay open
- 2.4 swap?
- Neon rough running
- trouble with 98 dohc shifting
- 1996 dodge neon wont start, turns over only once
- 96 dohc leaking oil pretty diecent
- 97 neon highline sport dohc help plz
- interior ideas?
- dohc bolt ons?
- Just Sayin', Neon Engines are......
- 95 SOHC, slow creep up to overtemp
- best ecu for the power
- 1995 Dodge Neon PLEASE HELP
- spoolboy>fmu?
- 98 neon sohc #1 no spark
- DOHC ecu?
- 95 Neon, no fuel will not start
- 99 Dodge Neon - Multiple 43's
- Car not starting
- boosting my dohc
- srt turbo sohc?
- Rusted oil pan
- Glasspack with muffler?
- Rack and pinion leak
- Long our short intake tube?
- Exhaust leak help
- 95 neon electrical problem
- Radio wiring issue + HVAC bulb number?
- Help
- swapping a sohc head to a 2.4 head
- Check Engine Codes
- Trying to put in a trunk light - having issues.
- Other good bolt-ons for a DOHC
- help with 2.0 to 2.4
- turbo stuff for sale
- p0441 1995 dodge neon
- 1998 Neon MPG increase
- SOHC milled head clerance question.
- Broken Shifter
- Turbo my dohc
- What belt with udp and no a/c?
- 97 dohc atx shifting weird
- Need some help
- Hey Everyone. Newbie here. Looking to learn some things!
- Is my fuel pump going bad?
- New neon woes
- 1995 Neon Head Gasket
- 96 Neon SOHC Hard Start After Sitting
- Crazy Radio.
- Radio and dome light !!
- weather strip
- 2001 Engine in a 1998 Neon
- SRT-4 rims
- Sohc muffler on my dohc!!
- Crane Cam And Valvesprings For Sale!!!
- 98 Neon Rt Power Window Issues
- 98 Neon power window issue.
