PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Turbo for dummies
  2. Engine hybrid questions
  3. Looking for turbo parts.
  4. Pcm ???
  5. (((trans cable broke)))
  6. dodge neon a/c blower out
  7. 99 DOHC Starting Poorly
  8. Wiper linkage bushing,not available.
  9. 98 dodge neon fuel pump install
  10. always cold engine
  11. 98 neon problem
  12. 1995 neon
  13. Broken timing belt after 10K?
  14. question
  15. 2g engine in a 1g neon
  16. just looking to get pointed in the right direction
  17. 1999 r/t wont start/fire
  18. code 54
  19. Do Not Do Business W/ GhostNeon2!!!!!Be For Warned!!!!!
  20. auto shifter sticking
  21. noisy 96
  22. 96 neon 2.0L tranny
  23. 97dohc running/starting issues
  24. power rack to manual
  25. Dash lights not working *please help*
  26. pcm swap
  27. f/s 1996 mopc pcm and misc
  28. Blower Motor???????
  29. lowering springs
  30. 17in tires
  31. 10.5:1 pistons
  32. Black truck poll
  33. 95 neon performance
  34. Oil Pressure Wire
  35. Stuck in 1st gear...
  36. Dohc aftermarket 10:5.1 Pistons in Sohc
  37. Lookin for 2 door
  38. Rolling Chassis
  39. Atx to Mtx swap help
  40. Gas guages not working
  41. 96 Neon - Instrument panel not working
  42. Fog Light How-To Redo
  43. SOHC Turbo Manifold
  44. engine stutters/hesitates at steady throttle only
  45. 95 Not Charging
  46. Oil Leak.....
  47. timing problem
  48. 1995 neon emc
  49. need a video of your wideband in boost
  50. got her runnin. turbo oil seals are blown tho.
  51. Need camshaft help
  52. 1997 Neon will not fire!!!
  53. turbo build
  54. ebay springs
  55. Why must some people Rice out their neons?
  56. put my neon up for sale
  57. 10.5:1 comp with nitrous
  58. Shift limits?
  59. FYI on water leaking into a trunk of a Neon
  60. Adding a rear sway bar
  61. Adding a Cruise Control to my car
  62. Rebuilding my 2.0
  63. Car Alarm
  64. Front End Issues
  65. 96 dodge neon wont start - need help!
  66. trans cooler?
  67. throttle swap
  68. 96 Dodge neon Project
  69. car is for sale!
  70. Fuel fillter neck issues
  71. Dohc Cam Id Question
  72. 99 plymouth cranks but wont start
  73. rough idle sometimes
  74. Megasquirt wire harness
  75. Help - 95 neon sohc idle RPM
  76. extra fuel injector in egr inlet hole??
  77. Rhd
  78. Want to buy clutch
  79. Just great!
  80. top End Swap Questions-Dohc back to Sohc
  81. needed fuel filler tube
  82. Finally some pics of my car
  83. Larger cam/Injectors?
  84. Turbo questons
  85. How can I tell if a car has the "Competition" package?
  86. Dodge Neon PCM
  87. My Neon
  88. Water/methanol injection!
  89. Post your pic/mods
  90. ohio
  91. Car dies when I press in cluch over 2k RPM
  92. Fuel-rail thread size?
  93. Auto transmission linkage problems. Shifter won't shift
  94. Sitting in there running one minute, dead the next!!
  95. still idleing high
  96. 97 neon is it my Engine or Tranny going???
  97. anyone selling lowering springs?
  98. Huge dilema
  99. 2.4 top to 2.0 bottom?
  100. CEL codes 12, and 37
  101. Coal Canister is making the engine lighit
  102. transmission shift cable.
  103. dohc header on sohc?
  104. Purge valve solenoid and park neutral switch help
  105. OBX-R Exhaust ?
  106. Cranks but won't start and a code 54!!
  107. 4 lug to 5 lug?
  108. Video of Neons.
  109. please head question
  110. 95 neon motor swap need help
  111. 95 Neon driving problems
  112. 96 Neon No Start
  113. Need help reading a "bad" cluster guage.
  114. changing out heads
  115. Neon '95 Problem. Possible Coil/Fuel Pump Problem
  116. changing rear struts
  117. 99 neon overheating
  118. lambo hinges for sale
  119. auto transmission sticking in 2nd gear
  120. 98 neon rt idles funny
  121. I think it's running lean.
  122. Throttle Bodies?
  123. 95-99 front lip spoiler
  124. 1995 2.0 SOHC engine swap question
  125. Neon Transmission Help
  126. heyqwell
  127. Gauge Clusters
  128. new here, looking for some good knowledge
  129. looking for a 95-99
  130. Shifter shifts but nothing happens
  131. instrument panel problems
  132. 95 cam in a 97
  133. 96 Dodge Neon - No Spark, No Start
  134. Hit deer good idle poor acceleration 98 SOHC weird plug burn
  135. Used 1995 Instrument Guage Cluster
  136. srt 4 dash
  137. ok made up
  138. Iportant Questions please help
  139. Coil pack question...
  140. DOHC and SOHC heads
  141. 2003 neon motor
  142. no 1 would see this
  143. Will a 2.4 from a 03 pt fit in a 96 neon?
  144. Vehicle Speed Sensor - what is it good for?
  145. Fuel gauge prob.
  146. EXPORT euro tails 4 sale 1st gen
  147. 1998 dodge neon, bettery light came on
  148. engine code
  149. question about 3.0 cold air setup
  150. Neon 1998: Engine light on due to radiator fan not coming on
  151. Running hot
  152. How to replace a thermometer on a 1998 Dodge Neon with a 2.0L SOHC engine?
  153. srt-4 seats
  154. Trans question
  155. Engine Harness?
  156. 97 neon dohc overheating?
  157. Nuts to me! New Issue! Battery Temp Sensor busted!
  158. turn signal issue
  159. 97 DOHC starting issues
  160. Starter and Fuel Pump
  161. clock spring
  162. maybe water pump?
  163. 97 Neon Sport!!
  164. 95 neon ECM?
  165. <~~~help needed~~~>
  166. Battery Light is on
  167. Trouble codes
  168. No start head banging
  169. Car Will Not Start
  170. nean mud flaps
  171. 95 ATX Part out
  172. oil blowing out air filter
  173. Wiring
  174. Projector Headlights Up For Trade!!!!!!!!!
  175. Water getting on the floor
  176. Wont crank after engine install.
  177. Defroster-No air-new owner
  178. What is this?
  179. DOHC swap need help
  180. Manual Transmission + shifting problem
  181. Hard Starting Neon
  182. o2 sensor problem?
  183. shifter problems
  184. Coolant Temperature Sensor
  185. 1996 neon spring rate
  186. Engine Swap
  187. switchblade key...
  188. window motor
  189. A little info please
  190. PCM, Auto Shutdown Relay (ASD), or something else.
  191. Selling my turbo neon Dubuque Iowa
  192. 1995 pcm
  193. aNdRo_LiKe_wHoA just sayin Hello!
  194. nc neons
  195. i have a brain teazer
  196. 1996 Neon need some answers please
  197. Trouble code po122
  198. New to the Forum
  199. 98 Dodge Neon Stumbles and Surges
  200. car chuggings and stalling problems
  201. best place/price for fuel pump
  202. brakes sticking on
  203. Leaking under the dash on passenger side
  204. 99 neon dohc ticking at start up
  205. front end problems
  206. Overheating new rad?
  207. Lower Class Club
  208. Stock stereo ?'s
  209. fried wires.
  210. 3.94 trans and dohc computer
  211. Projector headlight question
  212. Thinking about changing out struts and shocks
  213. Has anyone installed Dynamat in their ride?
  214. 99neon starts then stalls in morning?
  215. Answer this please
  216. Please
  217. made the coolest exhaust
  218. Need to locate
  219. no spark, no fuel..
  220. redbook?
  221. When I brake my headlights turn on and dash lights up
  222. look what i found!!! bkr9eix's
  223. 1996 Neon Check Engine Light P0171
  224. my 2.4 is detonating (spark knock)
  225. timing and other problems
  226. body improvements
  227. Exhaust question !!
  228. would running too lean cause me to blow the head gasket
  229. 95 neon dies when braking at stop light.
  230. How to test oil switch?
  231. modded my fuel canister. lmk wat u think. pics
  232. 95 plymouth neon with just fixed now sensor trouble
  233. Part out
  234. turn signal switch
  235. Bigger Chrysler Injectors??
  236. manual trans in stratus/sebring?
  237. will this fmu work for the spool boy mod???
  238. p0203, p0132, p0134
  239. Chatroom?
  240. Swapping cams??
  241. dumb question
  242. heres a good one for you guys...
  243. tranny question
  244. i know this is the neon forum but...
  245. Odd Problem??
  246. 4sale in ATL
  247. Figuring out piston ring size..
  248. Bent rod
  249. Mattdog adapter
  250. stupid question but hard to answer
