PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. piston ?
  2. wat do u think
  3. Bent Valves on $50 engine, now with pics
  4. what cams for 2.4l swap
  5. Question
  6. Got my indy intake manifold on. Pics. And maybe trading my car.
  7. exshaust leak again
  8. cant go right
  9. Mitsi/Neon
  10. help me. itll only take a minute and it'll be fun
  11. wheel stud threads
  12. Replacing a Serpentine Belt
  13. help
  14. wtb: 95 dohc atx pcm
  15. New car, new engine, new clutch...
  16. Accident...never believe it
  17. 1996 Neon Coupe New Owner
  18. Overheating
  19. buying another neon......again
  20. to buy a track or not to...
  21. Help! Electrical Problems!
  22. ATX TB on MTX Question
  23. 98 Neon is home, has problems (of course)
  24. 1995 Neon 37000
  25. motor ? stratus motor
  26. Tired of this thing sitting here...
  27. Rear blinker and brake light out?
  28. New front hub rebuild kits if anyone is interested??
  29. Transmission slipping?
  30. exshaust leak &break problems
  31. Underdrive Pully Question
  32. Great news. I am back in the neon. Pics.
  33. i need a....
  34. I'm Buying a 97 DOHC ATX White Neon
  35. fuel regulator
  36. engine out... sohc in....
  37. Turbo
  38. Jeremy?
  39. Engine removal
  40. Kirk Racing header from Modern Perf., what about O2 sensors?
  41. Need help :(
  42. Need tranny :(
  43. God could I get any luckyer...
  44. r/t stripes
  45. WTF Please help
  46. Wheel Lug problem!
  47. What about nitrous?
  48. vacumn lines on a stock SRT4
  49. Trunk leak, 98 Neon
  50. i got a indy intake manifold
  51. Big problems.....
  52. What was the Highline package?
  53. '95 Neon Woes
  54. Why does 95sohc seem to have significantly more Power than 96-99 SOHC?
  55. finally race the Crx check it out
  56. Diff Tabs
  57. Valve spring comparison
  58. **EDIT** Extra Ground Straps: DO IT
  59. Forward Motion
  60. Intake
  61. Another Neon
  62. 2.4 transplant or complete 2.0l build up
  63. go figure
  64. Oh Wow!
  65. well!!!!
  66. What Codes ID a 1999 Neon R/T RT
  67. advice for deck
  68. New R/T bent valves
  69. Wheel Bearing
  70. need help! 98 neon idle stalling
  71. in 4th today at 108 mph
  72. Want to hear your Opinions. on a New Car
  73. Odd Oil Leak Somewhere???
  74. OMG!
  75. ATTENTION NEON OWNERS:
  76. Creaky clutch!
  77. 95 SOHC Crank Case Breather Delete, Possible?
  78. WTB-DOHC Bottom end
  79. So whats gonna go wrong next
  80. 1997 neon?
  81. buying a neon
  82. sway bar questions!
  83. ohhhhhhh mullatman11!!!
  84. disk brakes and wing help?
  85. $1,500 to spend on 1st gen parts
  86. doors for 4dr neon
  87. odd problem
  88. Drop springs
  89. were can i get a guage cluster like this
  90. non modular to modular and wat gear ratio
  91. magnum cam
  92. turbo install questions!
  93. 2nd gen tb in 1st gen
  94. putting 95 sohc motor in 98 sohc car...
  95. dohc head on sohc block
  96. Battery relocation
  97. Brakes
  98. of all things...
  99. 97 Neon Help needed
  100. 2.4 compression reading
  101. injector cleaning
  102. Injector Flow rate
  103. how do i tell if i got a highline or a base
  104. sohc to dohc wat parts can i use
  105. 97 neon ground wire for stereo
  106. Increasing MPG through head work...
  107. 95 dies after warm
  108. anybody see the def of Neon???
  109. E brake cables???
  110. pulled it
  111. 1995 Dodge Neon SOHC
  112. Installing Valves In A DOHC: What to use?
  113. just throwing this out there but what if
  114. FNG with intake questions regarding DOHC AEM cold air on SOHC engine
  115. Complete Prothane bushing kit!
  116. GRRR DAMMIT! (alternator is still good, must be the computer?)
  117. turbo...fuel???
  118. Oil Pump Question
  119. help bad oil leak
  120. Balanced Crank?
  121. missing problems
  122. fastest 1/4 mile time in a 1st Gen
  123. crank size? need info to replace rod bearings
  124. Air Conditioning Part
  125. Engine block difference.
  126. 3.5" speaker location advice
  127. Cruise Control Question
  128. turboing
  129. Question about Radio
  130. mopar/borla exhaust
  131. Timing belt interference? Need advise
  132. any one ever hook up there radio in the house
  133. AOL/MSN Names...
  134. New Vid
  135. my poor babys
  136. kind of an odd topic.
  137. Latest mods
  138. mopar and o2 sensors >?<
  139. My car got keyed.....
  140. turbo kit
  141. MOPAR
  142. intake manifold? exhaust manifold?
  143. 1ST GEN PARTS,TYPE(S)SHIFT KNOB,SPOILER,custom seat covers..
  144. Did some raceing over the weeknd!!!!
  145. IF ITS NOT ONE THING THEN ITS A FREEKEN NOTHER!~!!!!!!
  146. Manual Tranny
  147. for sell post
  148. MLS Head Gasket : Needs Modification
  149. fuel pressure low...
  150. Have a cam question
  151. anyone iterested?
  152. running your car on water.. whats up with it
  153. smog testing what will affect it...
  154. Turboing a 99 SOHC MTX
  155. broken exshaust bolt iin block
  156. plz help
  157. Engine Problem...Help
  158. my trip to Wal Mart in Anchorage Alaska
  159. between rattle can and 4k paint job
  160. headlight ?
  161. carfax please
  162. starting problem
  163. Racing Ford Probe Gt And Acura Legend (rematch) after my 2.4 swap
  164. Turbo-pro?
  165. exhaust manifold
  166. Oops. Any ideas.
  167. accident
  168. I'll bet...
  169. POWER LAG
  170. turbo help
  171. will this work???
  172. need a clutch
  173. Alternator and a leak?
  174. Newbie
  175. check engine codes
  176. egr block-off valve question
  177. Got some bad news...
  178. engine problem
  179. 98 SOHC Toasted Water Pump
  180. Wet nos setup
  181. Brakes... clutch maybe?
  182. mustang injectors
  183. head work?
  184. Replacing Valve Seals on a SOHC
  185. grinds into second
  186. cleanin....again...
  187. fan problem
  188. Almost dying
  189. Need help with a trouble code!!!!
  190. 95 neon with code 25 and wont idle cold
  191. CHANGED MY MIND! (damaged piston pics pg3)
  192. 2.4 motor mounts
  193. how to check tranny fluid
  194. Stock dohc piston Question
  195. FOR SALE: Nos kit
  196. e brake
  197. need ur pics
  198. o2 after cat
  199. Was gonna Go NA,,, BUT....
  200. now im getting mad...
  201. SOHC OR DOHC HEADER
  202. quick question needs a quick answer
  203. Putting 1995 SOHC head on a 2.4 Block What should I know?
  204. wheels from differnt makes?
  205. bypassing radiator fan Relay,,,, code 35
  206. Got myself a New R/t today
  207. Name this header
  208. Tail Light Gaskets
  209. update and question
  210. jeremy, 95to96
  211. spittin sputtering high revving etc. HELP
  212. does anybody know if
  213. NVG T-350
  214. nvm that post
  215. Miss fire in Cylinder 2
  216. could the sohc trans be making my 2.4 slow
  217. max power for srt4 motor
  218. 2.4
  219. New head bolts
  220. spill on my altenator
  221. Need cheap DIY ideas
  222. stupid new headunit
  223. rear drum brakes..
  224. Selling friends Sohc Mitsubishi Turbo set up
  225. new wiring harness...
  226. love it
  227. just seeing what you guys think of the new interior
  228. rough idle
  229. AIR INTAKES
  230. Need Help! Car died!
  231. so i swapped the altenator,, hlep please
  232. door hinge ?
  233. 99 with 2.4 stratus NEED TURBO
  234. Has anyone ever used both the 3.94 and the 3.55????
  235. engine removal
  236. Paint Code Help?
  237. anybody ever see this???
  238. underdrive pulley question
  239. carfax favor
  240. 96 Neon A/C Heater Blower motor
  241. question on motor swap
  242. WHERE OH WHERE ARE THESE SENSORS LOCATED PLEEEEASE
  243. Weirdest tickets
  244. Performance Spark Wires
  245. Rear Sway Bar
  246. 2nd gen center consoul swap???
  247. way way way off topic not even chrysler related
  248. My governor is actually around 120mph...
  249. Hey, I'm new and have a few perf. ?'s about my 95....
  250. also did the 1st gen DOHC sport come with a metal intake manifold?
