PDA
View Full Version : 1st Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43
  1. 98 neon dohc problem help!
  2. Racing Seats
  3. problems
  4. help: stratus/neon PCM infor
  5. sputters and dies
  6. Engine Damper???
  7. prefomance chip???
  8. need quick help on non-working gauges
  9. engine stutters at low idle
  10. Ignition code PO 351
  11. How Reliable Are 98' Neons??
  12. Cruise Control 1998 neon
  13. Camber adjustment on 95 acr
  14. Brake squeels..
  15. gas guage stopped workin
  16. Dumb question, but i gotta ask...
  17. SHIFT INDICATOR
  18. FSM
  19. Window thingy's
  20. Coolant boiling HELP!
  21. Swapping out GSX cams for turbo'd engine
  22. Tranny help!
  23. Underdrive Pulley???
  24. Shudders after 2+miles.... need help
  25. Few Problems! Need Help! 97 Neon DOHC!
  26. 98 neon Fuel pump question
  27. 98 neon sunroof question
  28. Codes 32 and 47
  29. Electrical Question
  30. help please fast
  31. Handling?
  32. clear 3rd brake light
  33. PLugged muffler?? Possible?
  34. 1995 clutch replacement ALL BY MYSELF
  35. Is 3700 rpm to high for a 9 hour road trip.
  36. super charged neon stock????
  37. CAI for a 16V DOHC
  38. Car died. Codes 14, 22, 23, 25 & 33
  39. check engine codes
  40. Alternator question
  41. CLunking
  42. New member-? for all
  43. My 95 Neon sounds like a go kart.....
  44. FUEL PUMP PROBLEM??
  45. rims
  46. recharging a/c
  47. FMM Q's
  48. over heating
  49. Is it bad brakes
  50. HELP MY 96 NEON WONT START
  51. P0300 ENGINE MISFIRE CODE
  52. 96 SOHC removal
  53. Thinking about ripping off a/c and power steering?
  54. check engine light
  55. R/T??
  56. water on the back floorboards
  57. blown 96 neon
  58. Rear Strut
  59. spark plug tubes??????????
  60. wtf lug nuts
  61. E.M.S.??
  62. more power
  63. 96 neon stalling
  64. intake manafold
  65. drive axel???
  66. HELP!! NEON NOT STARTING STILL!!!
  67. 1995 Dodge Neon Sport Issues
  68. rear wheel drvive neon
  69. engine problems still
  70. 95 neon help
  71. help 95 neon
  72. Help!!
  73. Need some horsepower ideas
  74. Turn signles and such don't work
  75. Car Shakes
  76. neon intermittent overheat
  77. Will SRT-4 RIMS FIT ON FIRST GEN NEON?
  78. sensor??????
  79. 5.75" round e-code headlights swap pics
  80. questions about a tranny swap
  81. new camshaft position sensor??????
  82. a/c removal
  83. wont start need help
  84. Replaced fuse..then...
  85. 95 Neon - Alternator belt jumping off
  86. turbo neon HELP
  87. HAHN turbo kit?
  88. battery sensor?
  89. neon-weight?
  90. EGR valve
  91. cam shafts?
  92. 3.0 CAI
  93. Safe Without Intercooler???
  94. rev limiter???
  95. 98 Neon, clanging noise on start-up
  96. Engine fan coming on unexpectadly
  97. 1996 Neon
  98. need help with some electronics
  99. Cam Timing Info???
  100. SOHC to a DOHC
  101. gauges for a 95 neon
  102. Headgasket
  103. Poor running
  104. 95 Neon Turbo Kits.
  105. 96 neon throwing CEL's
  106. camshaft sensor??????
  107. Have to manually disengage turn signal!
  108. ICEMAN BATTERY TRAY????
  109. Dies in hot wether
  110. 98 Neon code 37
  111. Will Not Start Need Help
  112. lost in Vin # for my 95
  113. A/C Compressor suddenly wont engage
  114. Code Readers....??
  115. engin
  116. Steering wheel- need help!!
  117. Turn signals
  118. A Mystery.. 98 Neon
  119. Help
  120. timing on a 95 neon
  121. need help
  122. Coilovers
  123. Disc Brake Conversion Difficulty?
  124. VENOM PCM????
  125. New member here....
  126. my 1996 Neon MPI?
  127. What would you get????
  128. mini van ecu?
  129. Dodge / Plymouth ???
  130. 1997 Sport.
  131. engine swap
  132. head swap
  133. Need Help Bad!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  134. Sound System Diagram.....
  135. cooling fan problem.
  136. ECU
  137. 2001 motor in a 95 body
  138. Replacing wheel studs?
  139. spark plugs
  140. front skirt
  141. Over heating!!!!
  142. What do you think of my car?
  143. Burning tranny Fluid ???
  144. 95 SOHC vacuum and driveability porb.
  145. 98 AC/Heat Issue!!! HELP PLEASE!!!
  146. just got a 95 Dodge neon... need sum help
  147. Is this supposed to happen???
  148. Reliability?
  149. lower springs
  150. Headlight Replacment Question
  151. 95 neon spark plug help!
  152. Jeep Throttle Body
  153. TPS Sensor?
  154. 3.0l intake
  155. gauges 97 neon
  156. headlight bulbs
  157. Rims... how big can i go
  158. '97 DOHC mysterious overheating episode
  159. need more speed
  160. 95 neon problem
  161. Custom Strut Bar
  162. Possible Air Leak?
  163. damn egr code
  164. AMAZING RESULTS
  165. 96 neon help!
  166. sohc intake manifold
  167. Modular clutch?
  168. Problems at 1500/1700 RPM
  169. 1997 neon help
  170. TURBO NEON NOT STARTING!
  171. need to understand what he means
  172. 400hp turbo 420A Problem
  173. question
  174. SOHC NEON TROUBLE
  175. Stroke the 2.0?
  176. Rattle
  177. Startting again
  178. Neon problems
  179. need some quick help
  180. NEED SOME HELP!!
  181. what the hell does this wire do?
  182. Turbo neon oil leak!
  183. spark plug popped out.
  184. Factory Amp?
  185. rocker arm installation
  186. New Brakes
  187. check out the transmission
  188. Thinking of purchasing 95' Dodge Neon... need input.
  189. Indy/Howell SOHC Intake Manifold 2.0
  190. Power Steering and AC
  191. im new with a 95neon
  192. the block
  193. Clearance at Bodykits.com
  194. What would you do???
  195. oil on plugs
  196. clutch fork ball?
  197. 1997 MTX Bucking
  198. performance computer
  199. the infamous 'ghetto intake'
  200. Looking for upper Grill mesh insert for 1st Gen
  201. FUEL PUMP FUSE KEEPS BLOWING????
  202. Weather Strip Performance????
  203. Speakers
  204. Linkage Arm
  205. supercharger question?
  206. Little more power
  207. Keyed My Car
  208. Iceman Intake
  209. Quarter Mile Times?
  210. new car
  211. gremlins in my car
  212. 97 2.0 DHC 4dr Battery Light not going off?
  213. Automatic Throtlle Body
  214. Duel Exhaust Performance?
  215. Best Upgrade for $300
  216. Fuel Tank Question
  217. 96 neon
  218. Dohc swap??
  219. 1Gn Computer Codes
  220. Interior Painting?
  221. woohoo. the rebuild
  222. Neon Instrument Cluster
  223. HeadGasket Set For a 1998 Dodge Neon
  224. electrical problem??? WTF
  225. AIR INTAKE SYSTEM!!!
  226. A/C Problems
  227. Gooey Pan Of Sorts?
  228. will an eclipse GS-T engine fit in a 96 neon
  229. oil pressure gauge
  230. won't start
  231. Window regulator removal
  232. big rock+low car=new oil pan
  233. any body got a 95 2 door for sale
  234. Seat help?!?!
  235. Rocker Arms
  236. new or rebuilt engine
  237. full of crap...
  238. My 95 Neon
  239. Wipers Don't Work
  240. running rich in first cylinder please help!!
  241. compression problem?
  242. Neon won't start... any ideas
  243. Looking to buy my first car...95 Neon Sport
  244. Lookin for ideas for my 96
  245. dimension question
  246. Cold Air Intake
  247. Front Door Panel removal on '98?
  248. My '95 Neon
  249. 98' Neon starter question
  250. Dash help?!
