View Full Version : Dodge Journey
- Dodge Journey 2009 problems.
- Dodge Journey SXT 2010 2.0 CRD Diesel - DMF
- No heat on passenger or rear of vehicle, warm air on driver side
- Navigation no detailed map
- Changing Subframe
- Dodge journey vacuum line
- No Rear heat air blowing
- battery
- 2011 dodge Journey no heat on passenger side
- 2012 journey crew fwd rear rotor size???
- 2010 Dodge Journey Blend Door Actuator
- 2017 Dodge Journey Headlights
- rough idle
- Uconnect, USB and rear camera faulty on 2013 R/T rallye
- Hello dears!!! help out-can who faced? DODGE NITRO when turning,, even at low speeds,
- Dip stick for transmision
- Passenger and rear door locks not responding to unlock
- Rear upper control arm bushing.
- Moonroof drains
- Journey Battery drain
- Won't start - Key Undetected
- Change in tire size
- 2011 Dash removal
- Uconnect - heat issue/screen glitches
- Had cabin filter changed & now heat blowing cold on pass side, are these connected
- Fog Lights Relay supply from ignition wire
- 2017 Journey Fog Lights
- Drumming noise at highway speed
- Heat
- 2011 Journey instrument panel freakish behavior.
- Oil pressure sensor location 3.5
- 2012 dodge journey 3.6 l, high temp readings
- Engine Shuts Off
- 19" wheels to 17" wheels
- Dodge Journey - Misfire and Parasatic Battery Drain
- Dodge Journey 2010 Diesel A/T, Cruise software updates?
- body control module
- Running wires through Firewall
- p0456
- my said is not ucnnect available
- Dodge Journey 2010 Diesel - Parking heater installation
- Uconnect stopped working
- AC condensate dripping from bottom of blower housing.
- ETC Light
- Does anyone have a CTP11, CTP12, or CTP12.5 firmware
- 2010 Dodge Journey rear air issues
- Uconnect won't connect
- Intermittent backup Camera
- 2011 3.6l cranks but won't fire
- horn going off by itself
- Neutral Safety Switch
- Air is stuck on floor vents
- Journey DEad Battery Syndrome
- Dodge Journey 2009 Diagnostic Starter
- Interior lights
- dome light stays on while driving
- Horn beeping randomly
- my car is actually posessed
- Battery Drain 2015 Journey
- which panel closeout
- Can you take an RB5 unit from any FCA
- Cranks but no start
- Rear wiper stopped working
- Preferred option group 28X and 2DX
- 2009 Dodge Journey 3.5 FWD break caliper issue
- Horn and emergency lights acting crazy
- Rear view camera
- why is my horn honking
- Fuel gauge not moving
- 2009 Journey Radio issues
- 2012 dodge journey 3.6 sxt
- remote keyless entry with remote start
- I believe dealer ripped me off
- 2012 journey
- Help my journey on it's journey
- Wierd location to find brake fluid.
- 2012 Journey RT
- 2012 journey
- Ladder racks
- 2018 Journey Crossroad
- tail lights 2015 journey
- 2010 journey
- Help!! Anyone know the axle nut size
- Bad Transmission Pump
- Overheating
- Journey
- 2013 Journey Uconnect update hell
- Front breaks locking on
- Wiper switch on 2009 Journey
- My engine problems still not solved
- Back up Cam
- 2012 Journey not shifting out of first
- upgraded 2011 journey radio to a 2017 RB5 navigation
- Back up camera
- Back up camera
- Fel-Pro or Evergreen gaskets kit?
- Negative Battery Terminal Temperature Sensor
- Whats my missing piece called?
- Radio problems on 2015 Dodge Journey
- responding to Julie Dodge Social Care Specialist
- 2011 Mainstream Need a new motor but trying to figure something out.
- 2013 Dodge Journey SE 3rd brake light not working even after replacing LED unit
- Wheel bearing sounds - not a wheel bearing
- Coolant temp sensor
- Dodge Journey 2.0 crd diesel Fuel Gauge Stuck On Empty
- 2009 Transmission
- No VOLUME AM/FM Radio
- Install mygig reu/rex
- 2014 Dodge Journey
- Wiringharness problems
- 2012 Journey - OBDII code P0520 (Oil Pressure Switch)
- Royal Purple Review
- HID anyone?
- how many spark plugs does in 2015 dodge journey
- 2012 Journey Defroster
- 2010 Journey Random Horn Honks
- Buying Advice Please
- 2012 Dodge Journey Issues
- Brake light replace/removal
- 8.4 uconnect Nav?
- 8.4 uconnect
- 2012 Dodge Journey Code 0430
- bank 1 sensor 1 code 0032 3.6
- 2009 Dodge Journey SXT Compressor Relay Location?
- Better Throttle Response
- Coolant Gone within 5 minutes of Filling
- how do you remove and replace backup camera
- bluetooth
- Ambient Temperature sensor
- 2018 Durango back upcamera
- uconnect
- 2010 Journey, failing to start
- 2015 dodge journey Reverse light is ON and Radio/touch screen is black
- 2015 Journey OBD2 no power
- Dodge Journey 2014 back up camera
- 2010 Journey - intermittent start fault
- Can I programing a new key by myself?
- Dodge Journey 2.7 rt 2009 low beam problem
- 2009 Dodge journey SXT cont. starter issue
- Knocking noise in engine
- How long will my 2009 Dodge Journey last me? How many maximum miles will it get?
- Need Help with my dodge journey
- Master power window switches and bezel part #?
- 09 dodge journey window issue
- 2010 Journey SXT random misfire
- 2012 journey starts by itself
- Reverse Camera
- 2013 Journey - UConnect/Bluetooth HELP!!!!!
- lift gate issue
- 2017 DJ Bluetooth issue
- Android stereo
- Misfire issue, at a TOTAL LOSS!! Help please!
- 2009 Journey SXT multiple error codes
- torque specs
- No overdrive, band adjustment?
- Blows smoke from exhaust
- Loose battery connection???
- How do you reset and update
- Rear Suspension Torque Specs (2012 Journey SXT)
- Typical shift rpms?
- what is 2009 dodge journey (CAN BUS)
- Radio Wiring Diagram for 2013 Dodge Journey SXT FWD
- rear struts 2015 journey
- 2010 Journey no heat?
- 2011 Mainstreet
- 2016 Dodge Journey ABS/Traction Light
- Help locating ACC internal fuse
- wind noise from driver side mirrors
- Manual to Power Drivers Seat Conversion
- Good idea? 17" Winter tires and rims? Stock are 19"...
- 2012 Dodge Journey - rear outer CV boot torn? advice?
- Heat controls
- My daughter's 2013 Journey's seat bely continually chiming!
- 2012 Journey serpentine belt replacement
- 09 dodge journey brake light flashing
- 2009 Dodge Journey SXT Overheating
- Dodge Journey 2012 Heater controls
- Aftermarket head unit wiring
- AC only blowing cold air on low
- 275/55r20
- Block Heater
- 2013 dodge journey UConnect
- 2009 Dodge Journey Defrost
- Severe brake fluid/dust stains on rims
- ambient air tempt
- brake light dont work
- help naming and finding this part
- 6DCT450 MPS6 transmission
- Front wheel bearing
- 2010 Journey R/T with 219,000 miles for $4000?
- 2009 JOURNEY Hot start issues
- 09 Dodge Journey LIGHTNING BOLT FLASHING(undrivable)
- Parking brake light goes on and off while driving
- heater
- 2010 Journey FOB part needs gluing to the silicon
- "life time warrenty" catch 22
- Dodge Journey R/T 2010 Battery Drain Issues, please read all.
- Ignition Switch
- Radiator fan won't stop running not the relay
- starter wiring
- Radio Issues in 2012 Dodge Journey
- No Heat passenger side, little heat drivers side.
- 2013 Dodge journey SXT Bluetooth parts ?
- Chmls light 3rd brake light not working
- 2015 Dodge Journey Radio changes channels by itself
- 2012 Dodge Journey overheating
- 2011 Journey locked key fob inside
- 2010 Dodge Journey key Fob oem replacement
- Journey Oil Pressure Light
- passenger side no heat
- UConnect
- What can be wrong now
- 2014 Dodge Journey Front License Plate
- 2017 jOURNEY TRANSMISSION
- 08-10 Dodge Journey torque steer video
- 2009 Dodge Journey.
- paint chips on 2016 journey
- 2010 journey key fob programming
- Heater problems
- Heater core picture
- power steering leak
- manual
- Heater core flush Due no pass Heat
- Dodge Journey 2012 RT
- 2017/2018 Dodge Journey Tow Package
- 2010 journey hard start
- Journey 2009 2.7V6 RT Transmission noise
- 2012 Journey wipers won't turn off
- diagram
- will E15 gas hurt my 2011 dodge journey?
- Top glove box/cooler removal?
- power door locks
- Journey wont start
- 2015 Journey SXT - Check Engine Light
- am i getting the run around
- 2012 jouney 3rd brake light
- Dodge Journey heater core/hose routing/flushing question
- Messaging issue
- Tire pressure system changes which tire is low
- Dodge Journey 2008 2.4l transaxle capacity
- 2013 dodge journey r/t
- Rear Climate Control
- 2012 Dodge Journey my interior lights stay on while driving.
- Key fob not detected
- dust leaks in 2009 FWD dodge journey
- 2009 Dodge Journey power window problem
- No temp control for passenger
