View Full Version : Dodge Journey
- New to me 2011 SXT AWD with questions
- major car trouble
- Code:P2002
- 2012 Dodge Journey SXT howls when starting in cold weather
- Strange problem
- Signal light won't work with lights on
- 2009 Journey MYGIG update
- Adding GPS to my new Journey??
- Journey 2012 battery saver mode.
- Rear VES will not turn on
- New 2013 Journey R/T with issues!
- 2013 Auto Locks Issue?
- 2010 Journey overheating issues...
- 2012 Journey
- My New 2013 Journey now for mods
- A/C compress don't clutch fans don't work
- Worst vehicle I have ever owned
- Connect Rear Camera to Factory Radio LCD
- RockAuto Parts has any 1 used them
- New Journey!!
- FOB With Integrated Key -Help Pz
- Transmission Fluid Leak
- Heater hose fittings
- 2011 Blank Uconnect screen
- 2013 Journey SXT "Poof/crunch" noise when backing
- Trading a ram for a journey
- Bluetooth/Intermittent Connection Drops
- Dodge Journey gezocht voor opnames
- Frustrated!
- Why are the 16" hub caps so expensive???
- Transmission stumble?
- Help! 2012 journey interior lights flashing
- 2009 Dodge Journey overheating
- how do I get Navigation in my 2011 Mainstreet Journey
- Appearance of faded black plastics
- Uconnect - SD Card Issue & Brightness Issue
- 2013 Journey Oil Change Light
- Upgrading to heated seats? New owner as of tomorrow!
- Journeyitis
- Help wanted on Dodge Journey SE 2012 Block Heater
- Over heating
- bluetooth
- Garage Door Opener
- UK 2.0 Diesel RT Fuel Consumption
- Drivers door failing to open
- Drivers door weather seal
- 2012 Dodge Journey - 3.6l motor making hollow out noise at idle
- 2009 Journey P108 & P109
- '12 Journey Lug Nut Torque Spec
- Journey or Durango - That is the Question
- 2011 Dodge Journey
- dodge journey 4 cyl starter
- Journey Front Rotor change
- 2013 journey camshaft sensor problems
- Grinding noise when wheels turned completely left or right
- Dodge Journey Center Mount Brake LightDodge Journey, 2010. Center Mounted Brake Light
- 3.6 Journey consuming fuel during braking with engien
- Wheel size
- 2009 journey V6 3.5 SXT FWD will not move foward, only reverse
- key being stuck in ACC position when turning car off
- Uconnect voice command not working
- Code P060
- No sound from radio on 2012 Dodge Journey
- 2010 Dodge Journey Fuel filter
- cooling fan not working
- Eliminating the panic button
- Electrical problems
- Sirius XM "acquiring signal" message
- Bluetooth problem, Dodge Journey SXT 2013
- 2013 Journey Rust on Door Hinge
- juddery automatic gear box
- 2009 Journey Rear VES Screen
- Towing a 2011 Dodge Journey behind motorhome
- Locking/key fob issue 2010
- New to Dodge . . . advice?
- Noise Issue
- Wiper Washer ?
- 2012 Dodge Journey battery/charging issues..
- 2009 journey tranny fluid
- spark plugs replacement
- Passive Remote Key (Not safe when you can drive without it in the car after starting)
- 2009 journey traction control light
- Gas Tank Issue
- journey 09 power window panel
- online oem parts retail
- Issue with 2009 Dodge Journey not starting
- Bluetooth addition?
- Where is the thermostat on the 2009 dodge journey with 3.5L engine?
- Journey 2008 CRD crusie control
- Towing with 2010 Dodge Journey
- no cost maintenance plan
- 13 Journey SE
- AC not efficient. 09 journey sxt, help
- 2011 journey rt abs/traction control
- Tires/Rims - Will 225/75R16 Work on my 2009 Journey?
- Third Row Seating
- 2009 Rear differential leak
- Loss of power/pickup.. anything to look into?
- 09 Dodge Journey - Uconnect Kit 82212159
- Fuel Tank/Gas Gauge
- 2009 Journey power window's stopped working
- Ba tires or bad Journey?
- Seat covers for Journey
- New Journey Owner
- 13 Journey add bluetooth
- dodge jounery side rails
- Key fob 2010 journey
- Should I sell it or keep it ? SE+ 2009/80 000km
- 2013 Journey Crew - Heavy Gas Pedal
- Crankshaft position sensor
- High idol and stalling
- Windows Fogging
- 2009 Dodge Journey - Driver door wont open
- Who's the best Dodge Ram dealer in miami?
- 2010 journey tpm
- Move radio position
- Crazy Cold Weather problem - 2010 Journey
- 06 chrysler pacifica tune-up
- Changing plugs in 4cyl. journey
- 2011 Dodge Journey Problems
- Dodge Journey Key Fob
- 2012 Dodge Journey SE/AVP that I am going to have to ask
- Vents blow cold air on passenger side and in rear
- My Dodge Journey 3.5l V6 6 speed auto - Engine Noise with Drone noise
- 2010 Journey silver colored panel on dash
- Painted Calipers
- 2009 Dodge Journey Door Panel Removal
- heated seats
- 2012 Journey Radio question
- Gas Mileage Drop - '09
- 2012 Journey Avp + Sub-woofer help!
- 2009 HVAC Inoperable and Auto Headlamps stay on in daytime
- Active Headrest
- Dodge Journey Group in Facebook for Ontario Members
- 2010 Journey 6 cylinder 6 speed - Droan noise, engine noise, rattling, vibrations
- Error Code P0344
- dvd entertainment evolution
- 2009 journey starter.
- Wiring in Steering column haywire
- Airbag light is always burning
- Happy Thanksgiving
- Spark knock and Droan and low Idle when trying to speed up on 2010 Dodge Journey SXT
- Anti theft system
- Pentastar V6 head issues- all models
- dodge journey 2012 - odb2 to monitor awd on android
- 2009 dodge journey drivers door control
- 2010 Journey making a noise when slowing down
- Detailed maps on journey sd card
- Overheating
- Garmin Navigation System 2012 Journey
- Electronic Throttle Control issue
- Journey vs Snow
- Remove rear rotors on 2010 Dodge Journey SXT
- Dodge Journey SXT 2012 help- VR problems
- 2009 journey sxt window/hood deflectors
- Driveline issues??
- 2012 Journey - Can't hear anything on incoming calls
- Electronic Display-Fuel Economy
- '09 Media Center 430REN-Sirius TV ?
- dosge journey will not pair with new phome
- 2011 Journey Issues
- 2012 Journey - Transmission Shudder
- 2012 Dodge Journey R/T keyfob/windows
- 09 Journey outside mirror
- Backup Camera Problem on 2012 Journey R/T
- Dodge Journey / Fiat Freemont 2012 for european buyer
- Dodge Journey Performance Modification
- 1/4 Mile on 2012 Journey R/T
- exhaust diameter
- Great Dodge Journey Review
- 2010 Journey knocking
- 2010 Journey CRD 2.0L chugging
- Keyless remote battery replacement 2011 Dodge Journey
- exhaust mods?
- Poor Gas Mileage
- DRL Issue
- Back up camera + navigation on factory screen
- Brand new Journeys
- DIY High-Flow Air Intake
- 2009 Journey Electricial Issue
- Driver Door Problem
- 2012 Journey R/T - Possible Trans Problem?
- rear lower control arm
- New Journey owner. Love it! (HID questions involved)
- Oxygen Sensor Error P0058
- 2010 Journey trans cooler
- 2012 R/T Journey Australia
- just picked up 2012 journey crew
- Problem with radio on 2011 Journey
- Musty Smell From A/C
- Uconnect won't connect
- Considering a used 2010 SE
- NEED HELP! 09 Dodge Journey
- upgrading stock speakers
- Aux jack half volume
- replacing keyfob housing for a 2009 Journey
- Shop Manual
- 2009 Dodge Journey is going crazy!!!
- 2010 Firing order
- 2011 Mainstreet FWD
- New to Dodge and need help with Uconnect
- P0158 Code 2009 Journey
- Headrest and Center Cubby Lid removal
- 2012 Journey SXT (review)
- 2012 Journey with less than 200 miles broke down!
- 09 Journey rear LH doorlock
- seat belt chime
- 2012 Journey equalizer
- Radio console rebooting
- Dodge Journey Vs. Nissan Murano
- Projector headlight housing
- 2009 Journey Gas gauge and locks stopped working, brake light stays on
- Transmission Dipstick
- How can I do if not drive car for 2 months
- Cannot raise left-rear window
- Dead Dodge 2009
- UK/Eurpoean User Manual
- 09 journey issues
- Fahrenheit to Celsius
- 2011 Journey Transmission
- Yes or No, replace 215/65R16 for 225/55R19
- Electrical problem???
- All Season Tires
- Buttons on driver's side door trim panel not working
- Electric problems
- 2008 Journey CRD stopped during drive, repairshop claims turbo is busted
- 19 inches wheels vs 17 wheels
- Rej Lem
- 2010 Dodge Journey remote start problems in the cold
- Tpms
- 2012 Journey
- Cyl 5 misfire (P0305)
- Alarm Won't Shutoff & Doors Won't Unlock
- 2010 sxt
- 2009 Journey back antenna broke
- journey fuel guage issue
- First irritant on 2011 Journey...
- Official Dodge Journey Fuel Economy Thread...
- Coolant temperature guage problem?
- Mystery Grinding Noise - 2010 Journey
- wierd pattern displayed
- 2009 R/T Journey Sqealing from belt area
- Dodge Journey Mainstreet 2011
- how to get airbag codes?????
- Remote Start & Climate Control
- 2011 Journey Express bucking when torque converter locks
- Location of win module, please help!!!!
- Anyone have this with their Journey?
- Just finished my Garage
