View Full Version : General Tech
Pages :
1
2
3]
4
5
6
7
8
9
10
11
12
13
- What general things to do on a recently purchased high-mileage car?
- 87 dodge colt engine miss
- How to check codes on 01 Stratus
- 96 RAM 6 CYL Skipping/Surging Fuel Mix
- Bunch of problems, trying to narrow it down.
- wrong tranny fluid... OOPS!
- Custom serpentine belt size (123 - 127")? Please Help!
- will not idle
- 95 1 tond dually
- Another speed sensor question
- Need help identifying AC Compressor part
- speedo not working
- 3.9 coolant leak
- New lift pump, cam/crank sensor...same problem.
- Need help diagnosing knocking/ticking in 5.9 Dakota
- help id my gears and put a value on them
- PO441
- Headlights: High beams work great, low beams not so much
- how to time a dakota 5.9
- P0551 Problem
- Check Engine Light Mystery
- TPS and throttle screw adjustment help
- Overdrive lockout Solonoid replacment
- #11 Fuse Ignition FD
- 78 POWERWAGON NO START
- Help, Help, shift lever struck in park
- tranny troubleshoot
- Baffling mechanics and me...
- 94 Dodge Ram Engine Code
- either starting
- Installed K&N - 30 min later - Running bad ?
- Gas ?
- 02 Ram 4.7l Surges at idle?
- Will not start
- Keep hearing this clicking noise
- lost reverse gear, and possibly 1st, in 46re.
- Won't start... Valet problem or Starter/Ignition?
- need help brake lights stay on
- Durango Idle misfire
- 92 Ram Problem
- 6.7 liter diesel break in
- Problems with my Neon
- Odometer not working
- Column Shifter stuck in Drive. Linkage broken?
- rear end noise
- Chevy question
- "Ten Steps to better Torque" by David Vizard
- 2005 Dodge 2500 Hemi
- what causes PZM Serial Data Loss
- Turn Signal Issue
- Overdrive trouble in 97 ram 1500
- Power Wagon electric lockers
- oil filters,5.9 cummins
- RWAL Speed Sensor fixed ABS, etc problems
- New spark plugs for 99 dakota 5.2 V8
- no power steering/brakes
- 2000 5.9L Diesel Power Loss
- code P1610
- 2005 Dodge Dakota Cutting Off
- Camshaft Position Sensor Indexing
- Outside Temp Guage (Overhead console)
- Transmission Issues 92 dodge dynasty
- CB Radio?
- overbore headgasket
- Huge Electrical Problem!!!
- 2001 Dodge Intrepid A/C & Fan Problem
- Looking for colorado members
- swapping out the 318 for the 360
- First Power Loss, Then Stall, Now It Wont Start!
- Paint for '94
- Headlights on a 1990 Grand Caravam
- Starter relay location for a 89 dodge colt vista
- 1996 Dodge Viper RT10 50000 miles
- transmission
- power steering
- VERY low RPM on idle and almost dies..
- ON-OFF-ON-OFF-ON produces... nothing....
- 95 ram 1500 with bad heat
- smartflix rental DVD on Differential Rebuilding
- 1969 383 Timing chain Install Question
- inept carb man.
- 99 ram conversion van ac not cooling
- Front differential noise
- Dash/Console light problem!
- Troubleshooting Horn 95 Stratus - Details Inside
- dtcs
- Carroll Smith on "The Warped Brake Disc"
- 440ci. Timing question
- 1992 w150 wiring harness help
- I don't see an engine forum so I'll post here. 4.7 Q
- 4.7L rocker arm problem (wierd)
- CHECK ENGINE CODE P0404
- P0441 engine code
- PCM lettter to Chrysler Customer Service can anyone help?
- EVAP!!!!
- Head swap
- Trouble code P0404
- Dodge Ram Accelarator Pedal
- Fuel leak
- Loseing Power
- mopar trans
- Axles
- Need Help Please!
- Speedometer
- 2000 dodge stratus flasher problems
- magnum with sr-10
- Miss
- removing my a/c.. HELP???
- turbo'd omni
- 1986 Dodge Ram 50
- PLEASE READ AND RESPOND
- 1991 Spirit leaks from under dash?
- For whom who is new to the auto world
- 95 5.2 Ram just wont run well....
- bad engine stumble in first mile or so
- 01 Dakota Drum Brakes
- side skirt lancer shelby
- a/c problems
- Removing Gravel Guard ??
- Making the Case for Upgrading Lubricants, Just the facts, no friction
- interchange
- 04 Ram front Brakes
- 01 dakota electrical problem
- torque converter clutch solenoid circuit? #37
- 02 Stratus coupe spits out coolant going uphill
- 1989 Dodge Dynasty
- trans light
- Rochester Carb
- Need help on electrical problem maybe?
- where is transmission output sensor
- Hard to diagnose 2.7 overheating problem.
- Torque Converter Clutch Solenoid
- '90 Ramcharger 5.2 TBI idle/smog problems
- EGR valve
- 99 Intrepid 2.7L A/C and heater problem (AC46)
- windsheild
- 318 ENGINE
- Corvette Starter Problem
- atf 4 trans fluid
- no spark no fuel on a 92 dakota 5.2l auto
- 440 TRANS. QUESTION
- never mind, thanks
- MAJOR idling problem
- Over filling fuel tank
- cloudy headlights
- 2002 durango...4.7L
- SRT-4 engine/pcm problem
- Oil?
- O2 sensor help with 06 Dakota with 4.7L V8
- 4.56 gears
- What does this mean??
- Code 891 what to do???
- couple of q
- Need Some Help!!!
- Balancing a 360...?
- blue print
- Looking for Serpentine Belt Diagram on 1992 Shadow 3.0 - V6
- 1997 Ram Wagon 3500 a/c ?
- v8 engine swap
- water pump/intake fitting
- 99 DURANGO CHOCKING
- trailer wire harness 2k7 Ram
- Dash lights
- Flushing oil
- gear ratio
- BCM
- Water pump replace...trouble with fan
- 89 RAIDER WON'T START
- 86 ramcharger problems
- 2000 dakota...throwing black smoke...help
- ! what is it
- lights wont shut off
- dodge durango
- 10 psi studder!!
- Need New PCM?
- Key won't turn in ignition
- Air Conditioning
- Blower Settings
- Battery Drain on 04 Ram 1500
- Scramble eggs
- wont pass deq
- 1998 Dodge 2500 is clanking?!
- 545RFE Transmission Temperature Gauge Install
- 96 voyager 3.3 random cyl misfire and stalls
- 2001 Durango ABS problem
- PCM connector help
- dodge Caravan Evaporator Issue!!!please help
- 318/727 driveline vibration, converter?
- AC wiring
- E85 Conversion Kit
- Cooling System Q's
- Drawing 1200 watts from car's electric
- 1987 Ram 50 problems
- 98 Ram 3500 24 valve deisel Auto Trans
- 1991 PLYMOUTH ACCLAIM
- Subs and wiring
- 4x4 question
- speed sensor tests?
- Quad Cab Latch
- 2004 Stratus 4 Disc CD Changer (Help)
- opinons on my a/c compressor, and what the damage will be
- Multiple Misfire Problem
- NEED HELP! I have tranny issues
- speed sensors
- Need Advice On Fluid Leak
- speed sensor problum ????
- check engine codes
- Speed Sensor bad??
- removing windshield
- 2001 4.7 overheated and now doesn't start
- Timing belt broke at 60mph Any Hope 4 me?
- Dodge Spirit Trunk problem
- 2.7 needs rebuild? New engine?
- brake lights don't work
- turn key motors
- 2 good camshaft articles
- egr valve 05 ram 1500 hemi
- Electical Problem on the 2000 Intrepid, wont start once warm
- Viper electrical problem
- 1999 Durango won't restart after tune-up!
- 5w30 or 10w30 in my dakota??? please help!
- Changing fluids...
- Reset Duct Doors on 97 Intrepid
- a/c vent switching
- throttle body spacer
- 6.1 Cam
- Temp gauge reading question.
- Grand Caravan 3.3 Rocker Oil Starvation/Cam Bearing Replacement
- OVERHEAD CONSOLE
- POWER STEERING LEAK
- No steering!.. bolts sheered
- A/C ON BUT NOT SELECTED?
- alarm system
- lamp out problem
- Air Conditioner problem
- 92 dodge stealth fuel problems
- Quality Parts!!!
- Auto to manual
- Fuel Pump Fuse Blowing
- Help bad brakes maybe???
- 4.7 into the place where a 5.9 use to be?
- 01 neon
- Valves
- blowing frost from vents
- Pinging?
- Stuck in a second maybe?
- RPM's raise when i hit a bump but only when warm!
- 1996 dodge ram v6
- How to bypass!!!!
- whining noise at idle & gets louder on acceleration
