PDA
View Full Version : Dodge Caliber
Pages : 1 2 [3] 4 5 6
  1. 07 Caliber Overheating and shuts down...Help please
  2. Help, no turn signals or wipers!
  3. Broken trunk lid
  4. 2007 Caliber, Need Help!!
  5. Help Please!!
  6. Dodge 2007 Caliber- Code P2017(Chrylser code) Check Engine Light On
  7. 2009 Caliber Knocking/Rattling Noise
  8. So not happy!
  9. Front End Work On 2007 Caliber
  10. Check engine light on 2008 Dodge Caliber
  11. 2006 caliber wiring diagram please help
  12. Making my Caliber pretty!
  13. Is it common to replace a clutch at 138,000 miles
  14. Opinions on Alternator Brands for Caliber
  15. Dodge Caliber Alternator Concern
  16. Caliber Dead, Electric Throttle Control On
  17. Simple questions (maybe)
  18. 2012 Cali Bumper Color Issue
  19. reconnect airbag wire in driver headrest
  20. Camshaft sensor on 07 Caliber
  21. Dodge Caliber seat height
  22. 2.4 conversion
  23. Towing a Caliber
  24. P0445 and P0446 code help
  25. CVT fluid change.
  26. 84000 km Service
  27. Caliber problems
  28. 2007 Caliber Electronic Throttle Control Light
  29. 2011 Caliber SXT stick
  30. back windshield wiper
  31. Leaking, bad rods and break pads...oh my!
  32. Headlight goes out when turning 2008 Caliber SXT
  33. 07 Caliber shaking at stop light.
  34. Mileage drop over 6 months
  35. 2007 caliber rt awd 2.4
  36. 2007 SXT w/error codes P0700 and P0730
  37. 07 Dodge Caliber rear strut replacement
  38. oil change interval - - 4400 Kms ??
  39. Seat Heaters
  40. Evaporative Emissions System - Large leak detected
  41. What are the best replacement wiper blades for our vehicles?
  42. driver heated seat problem
  43. shortage in Dashboard lights
  44. please help in Canada....
  45. Calibre tail/brake light
  46. Whining noise
  47. red flashinf light
  48. engine light, no code, 5 beeps ?
  49. 08 Caliber SXT with 18" rims, will 17" fit ?
  50. U1146 Lost Communication with External Memory
  51. moon roof leaking?
  52. 2007 Caliber timing belt
  53. Caliber replacement spied
  54. Body rust on brand new Caliber (at dealer)??
  55. Cargo screen
  56. problems with my HID kit on my Caliber
  57. HELP!!! 2009 CVT Tranny from hell
  58. 55K miles - small issues, questions!
  59. Bluetooth
  60. Clicking noise in front driver's side of 2011 Caliber
  61. Front End Issues 2007 Caliber
  62. Power Transfer Unit
  63. Dodge-Chrysler REALLY dropping the ball on a transmission issue...
  64. i need advice on my caliber, PLEASE HELP!
  65. My sick caliber :(
  66. K11 recall problem?
  67. 2007 Dodge Caliber whining.
  68. break light on dashboard issue.
  69. Question about tires
  70. p1607 code on 2007 dodge calibur rt
  71. a/c compresser issues..
  72. Dealer-only transmission can be serviced by 'little shop!'
  73. Carlisle Chrysler nationals
  74. fill tube filter?
  75. Replace spark plugs at 30K?
  76. Considering 2007/08 Used - Would you buy?
  77. 2012/2013 Dodge Caliber Speculation & Rumors
  78. Just purchased a 2011 Dodge Caliber RUSH
  79. HELP!! Where is the crankshaft position sensor
  80. Rad Fans
  81. dash dead
  82. How to access UCI mode in 2010 RES radio
  83. Rattling noise in engine as if something is about to fall off :(
  84. 07 Caliber won't start. ODB2 code P0522
  85. Anyone know what this noise is..?
  86. Flash Light Draining the Battery????could it be
  87. All My instruments just died !!!!!
  88. anyway to disable the sentry key system
  89. uconnect
  90. 2011 Caliber SXT stick
  91. door hinge problem
  92. AC Valves
  93. Timing Belt
  94. 2007 caliber ... Limp Mode..errr....
  95. Cruise Control Not Working
  96. Satellite Radio
  97. New to forum from South Carolina
  98. Headlights
  99. 2008 Caliber SXT ~ Brakes
  100. Caliber 2008 whining noise
  101. Front end clunking.....again!
  102. Mysterious location green fluid
  103. Could a new fuse box cause the car to throw errors?
  104. Bull Bar For 2006 Caliber
  105. 2007 Caliber srt
  106. Problems with Caliber fuse box
  107. 2007 Dodge Caliber Dies at Idle
  108. heater fan stopping
  109. More Detroit auto show pics
  110. 2011 Detroit Auto Show
  111. Cruise control
  112. how to remove the Alternator
  113. There is "oil" all over my Caliber- help!
  114. Speaker wire Diagram 2007 Caliber
  115. Having Problems with my 07 Caliber!! Help
  116. Temp gauge
  117. Caliber AWD conversion?
  118. T-stat
  119. Merry Christmas
  120. Headlight replacement
  121. Headlights and Wipers
  122. Headlight Issue
  123. Thanks Quickie Lube
  124. Some pictures and a video (from Spain)
  125. 2011 Hemi Tour
  126. New 2011 Dodge pictures
  127. Just bought a 2010 Blackberry Pearl Mainstreet
  128. when to change the coolant - trans service ??
  129. media radio
  130. Saw some of the new revamped Calibers today.
  131. Retrofit EVIC?
  132. P161b-battery disconnect / tcm internal
  133. 2007 Caliber Loss of Power
  134. 08 Caliber Rear Shocks Replacement
  135. doors wont unlock from the inside
  136. No EVIC button, but is there a code to ...
  137. Caliber AWD?
  138. Caliber Performance/Fuel saver chip installation
  139. CEL flashing
  140. 2008 2.0l Tenison pulley assy
  141. P2017 check engine code ... HELP
  142. Show off your Calibers!
  143. Inner Tie Rod Ends - 07 SXT Check Procedure
  144. Caliber service manual
  145. Needing Help P0700, P0730, P0777
  146. Sunroof issue, any ideas?
  147. problem with 2007 dodge caliber
  148. 2007 Caliber/Compass Recall info
  149. 2007 Caliber CEL and Park lock
  150. two things, any ideas for roof rack, and i think it's a motor mount
  151. does your left tail light look like a fish tank?
  152. New Caliber owner
  153. Windshield Wipers Ghost in the machine
  154. 2010 OBD-II Caliber codes
  155. Blinking ETC Light = No Power
  156. Warranty void?
  157. '10 caliber mygig questions
  158. ETC problem
  159. Whining sound in transmission when you press the gas.
  160. HELP! TIPM-Alarm Problem
  161. ABS light and no Cruise control
  162. Engine Question
  163. P2005 Intake Manif Runner Ctrl Stuck Open Bank2
  164. First Problem Cannot get out of park. Fixed. Now, Brake light problems!
  165. Headliner Help..
  166. 07 dodge caliber sterring rack sounds
  167. Summer tires for caliber sxt ??
  168. Aftermarket Stereo install help
  169. Cooling fans not running
  170. Seat Belt alarm
  171. 2007 Total Mileage
  172. 2007 dodge Cailber check engine light.
  173. Metric or SAE
  174. Turbo
  175. Caliber Towed to the Dealer today! WTF!!?
  176. Cold Air intake
  177. How do I program a key for 2009 Caliber
  178. subwoofer box help me pls?
  179. Front control arms
  180. What tires?
  181. Peformance
  182. Lighter accessorie
  183. flickering hid lights
  184. OBD2 Codes
  185. Performance air intake?
  186. Leaving my Dodge Caliber in Garage for 5 months?!
  187. Heated seats...
  188. Dim high beams?
  189. No traction control
  190. Lights going out in cup holders
  191. unbelieveable... 2009 caliber..
  192. 2007 Caliber Aluminum Wheels corroding
  193. 07 caliber heater does't work
  194. Turn Signal Light replacement
  195. Messed up need help
  196. Dings and whistles..
  197. Spark plug and lug question
  198. TPS sensors
  199. 30k checkup
  200. Improve MPG even more?
  201. Might buy a Caliber on Saturday!
  202. Notice a shortage of Calibers on the dealer lots?
  203. reverse light condensation, seemingly common?
  204. 08 Caliber starting to surge
  205. Any alternator problems?
  206. Odometer readout stuck on temperature.........
  207. Instrument Panel Lights
  208. P0304 p0204 & p0420
  209. Help!! P000B Where is the sensor
  210. Headlight Assembly
  211. Winter Tires for 2007 Caliber SXT
  212. need some help!!!
  213. 07 Caliber Stalling Problem
  214. Six times to two dealers and they are clueless
  215. Also check engine light problems...
  216. 2007 Caliber sunroof problem
  217. My Ex-wife cracked my rim...finally ordered a new one!
  218. caliber engine light
  219. Lights on heater controls
  220. Locating front control module
  221. Lower Class Club
  222. vibrations
  223. Srt 4
  224. Alarm Horn
  225. its been a while...
  226. Caliber news for 2010
  227. Transmission help
  228. Calling all Caliber owners
  229. Getting the right exhaust parts for SXT tip
  230. uconnect studio - why doesnt this have the phone option
  231. Bike carrier for Caliber?
  232. Brakes
  233. Brakes
  234. popping/knocking noise
  235. Finnally got the windows tinted
  236. Electronic Throttle Control System
  237. Side Mirror Part #
  238. 2009 Caliber SXT new to the family!
  239. Calibers must be excellent cars!!!
  240. need help
  241. Last chance to get in on group t-shirt buy!
  242. Sunroof stuck!!
  243. Overdrive
  244. Trailer wiring
  245. Factory Radio Power Specs
  246. 2007 SXT Wiring Diagram
  247. Setting Clock
  248. key, chips and fobs
  249. Caliber Beverage Cooler
  250. This should be a good weekend.
