View Full Version : Dodge Caliber
- Shuts off while driving
- New 2010 caliber CRD owner
- 09 SXT Acceleration Hiccup
- New to Dodge
- 2011 Front and Rear crossmember
- dodge caliber 2010
- 2011 Dodge Caliber Express
- dodge caliber ABS on engine off
- got 2007 dodge caliber with a POOOA code on 2.0 engine
- Check engine p0455
- Pulls to right and possible strut issue
- 2007 Dodge Caliber 4cyl "Limp Mode"
- 2009 dodge caliber -Throttle light
- Heater/AC problem
- Trouble P0198 on my Dodge caliber 2007
- Will Parking Lights Auto Shut off???? I accidentally left them on!!
- Caliber brakes
- Replace catalytic converter 07 Caliber
- Where is the MAP Sensor???
- Cross member Corrosion Extended Warranty
- Shuffle during light acceleration 20-30mph
- Clicking from HVAC by glove compartment
- 07 Caliber R/T Rear Diff
- ETC Light
- 2011 caliber mainstream radio
- Park/neutral safety switch
- 2011 Dodge Caliber - How to clean fuel injectors
- Sensors not ready
- Need an opinion aftereffects of installing new coilsprings and strut kits
- 2008 Caliber Electrical issue
- Unable to locate low pressure valve
- 2008 caliber no start
- 2007 Caliber 2.0
- 07 caliber with issues
- 2008 dodge caliber help!
- Power window problems, Please help!
- Lights control stem
- Loose cruise control stem
- 07 Caliber Complex Keyless Entry Issues
- Dodge caliber help......
- Problems with my dodge caliber sxt 2.0 - 2007
- Jerykl
- Cam Sensor and Fuel Injectors clicking when key is off!
- Looking for advice/opinions
- 2007 Dodge Caliber with codes p0746 and p0777
- Going to buy a 2012 Caliber
- modifying my 07 SXT
- Best way to use Kick down Dodge caliber-2007
- 2011 Caliber Master Switch Removal Help
- 2007 dodge cailber sxt 2.0L
- 2007 Caliber Wiring Issue
- Please Help! Clicking from passenger dash board.
- buzzing sound
- Oil sender help
- Caliber sport headlight problem. Newbie sorry
- 2007 Caliber Radio problem
- HELP! 2010 Dodge Caliber "NO BUS", no gauges, no signals, no wipers
- 2007 Caliber damper controls not working
- '07 Caliber 2.0L gas, oil leak
- 2007 Dodge Caliber AC clutch
- Power Lock Button (only the lock button) does not work
- How to fix p0010 code
- Battery or Electrical Problem?
- A case for the x files newbie help.
- 08 caliber 2.0L sxt cvt High pitched whining sound
- New member with AC issues Dodge Caliber 08
- 07 caliber sxt roof molding cracking.
- Used ECU/PCM. do part numbers have to match?
- 2009 Calibur sxt
- AC/Heat blower/fan doesn't work
- 08 caliberfwdBought used tires and car shakes hard between 65 and 90 mph on highway.
- New caliber owner check in
- Banging/popping in engine compartment when shifting
- defective thermostat gasket
- 2010 Caliber SXT overheating
- Atomatic transsmission problem
- 08 caliber 1.8 SE Misfire and TSB PCM flash cost?
- Cooling fan won't shut off
- Intake Manifold Sensor?
- 5 speed manual transmission question
- 08 Caliber Cruise Control issue.
- 08 caliber 2.0L sxt cvt electronic throttle control light flashed and now limp mode
- Can't use key to unlock drivers door....HELP?!?!
- Trunk will not open, HELP!!!
- Battery Tender ??
- Anti Theft Light/ TIPM Issue
- bought a 2011 dodge calibermainstream
- buying a battery
- Windshield fluid nozzle--only passenger side
- Sub install
- lights stay on after car turned off
- rear breaks
- Dodge caliber radio + amplifier
- Camshaft Position Sensor
- '07 Caliber No Start but will Crank
- Dodge Caliber 2010 central locking not working
- Car runs cold
- 2009 Caliber Starting issues
- ABS/break problem
- electronic throttle control ETC on dash
- Caliber -07 Headlight problem (not the ordinary one)
- Google Plus Community for Caliber owners
- Wiring for MusicGate?
- Electric windows all dead at once
- Eletric thottle body
- SRT4 v SE suspension
- Polybush kit???
- spark plugs
- 07 caliber sxt idle
- How many miles on your Caliber?
- Advice Please
- problems with vacuum line
- Engine vibration
- RPM's question
- 07 R/T 120k Fuel pump Issue
- Caliber Light Retaining Water
- limp mode pain in the butt
- Adjustable camber?
- Question on 2008 dodge caliber sxt part name
- software update
- Wont start
- WATER LEAK (passenger side)
- Dodge caliber same problems..
- 07 Caliber check engine and low gas light on
- 2008 Dodge Caliber SXT, a few questions...
- p0139 issue
- 2008 Caliber SXT power issues?
- How to remove console sides?
- more acceleration as foot is removed from the accelerator
- Broken off trunk lid
- Turn key and Car dies!
- changing oil and filter and air filter
- timming chain
- new owner of caliber
- High speed blower motor
- New Dodge Caliber Owner Few Questions?
- 07 caliber grinding + battery light
- Turn over but wont start?
- CVT Trans Issue TAKE A LOOK AT THIS!
- Bad AC bearing/bearings In a 2007 Caliber
- Dodge caliber speedo instrument cluster
- headlights
- 2011 dodge caliber stx uconnect Australia
- headlights
- wind back tools
- Caliber 1.8 SXT start and power problems
- 2007 Caliber R/T Cluster Flicker
- Damage to 07 sxt - need help (really weird)
- getting tired of problems
- CVT neutral/selector switch
- 2009 Caliber SE, 83,000 miles, idle issues in cold/wet weather
- P2017
- question about wires in headrest
- camshaft position sensor
- What engine fits my caliber
- Bumping from underneath
- strut questions
- 2007 Dodge caliber, rough idle, moves at a snails pace
- Rough idle CALIBER 2.0 SXT CVT LPG
- 07 Caliber won't go over 10mpg
- How to replace alternator for 2008 Dodge Caliber 2.0L
- 07 Caliber - Screeching when AC is on
- 2009 Caliber Rough Accel. At Low RPM After Oil Change
- Replacing a CVT
- Climate Control
- 2008 Caliber revving very high only when gas is applied.
- 2009 Caliber SXT Coolan Leak Driverside Firewall
- Bypass a/c
- Window Problem
- Blower Resistor
- 07 dodge caliber -----horn issue
- 2010 Caliber - Speedometer, Fuel Gauge & Odometer not working
- .20 cent fuse cost 1400.00
- transmission overheating
- 2010 Caliber Express performance upgrades
- 2008 Dodge Caliber SXT rear making squealing noises?
- CVT is out? P0700 and p0777
- 2009 Caliber Headlights
- 08 caliber having trouble shifting
- 07 Caliber A/C clutch relay location
- RDA fulid Change and rotor questions
- "limp" mode 2007 SE 2.0L
- P1607 O/P circuit malfuction
- 2007 dodge caliber sxt etc light
- Dodge Caliber Replace Battery
- Altenator pulley info
- bank 1 camshaft position sensor
- tires
- Rpm/tranny issue?
- 2007 no power to ecu?
- Rear Left brake/indicator/tail light not working
- Starter Issue--2007 Caliber
- Dodge Caliber, 2007, Uconnect help!
- Custom Exhaust
- ac noise
- Rear Seat Replacement
- Squeaky brakes?
- OK to swap RADIOs in Calibers?
- Oil sensor issues
- roof weight
- Stupid speedometer
- 2007 caliber "No BUS" :(
- cel still on after 2 cam sensor replacements
- 07 Dodge Caliber Horn Not Working..!
- Battery Light, No Power and EPS and ABS Lights too !!!
- Bad Rear Hub Assembly? (2007 Caliber)
- replaced engine @160k. now AC trouble
- Parking lights wont turn off
- AWD R/T Front Hubs
- 07 Caliber Window Issue
- change oil soon
- black trim fading.
- Dodge Caliber ABS/BRAKE and speedo problem,, help
- fuel door locks problem - needs the help of locksmith
- battery
- HELP! Reset Check Engine Light. No Problems Found.
- ignition module on a 08
- 07 dodge caliber stalling
- emission system code p0420
- 2.0L CRD swap for caliber
- Help with 2009 Caliber - ABS-Brake Light coming on with a hard split second braking
- Stuck anti-siphon ball?
- TPMS is confused
- Hard Start
- Gauge install
- 07 Caliber coil test
- 07 Dodge Caliber Shocks
- 07 caliber transmission problems
- A Pillar Hit My Car (Painting)
- 2008 dodge caliber electrical issue
- Oil Pressure Sensor Location
- A/C issues
- AC Compressor?
- Help!
- 2009 Dodge Caliber 2.0L
- Need to replace lower ball joint
- HELP! no lheadlights,wipers and signals
- Considering purchasing a 2008 SXT, Help Please
- 07 Caliber Overheating and shuts down...Help please
- Help, no turn signals or wipers!
- Broken trunk lid
- 2007 Caliber, Need Help!!
- Help Please!!
- Dodge 2007 Caliber- Code P2017(Chrylser code) Check Engine Light On
- 2009 Caliber Knocking/Rattling Noise
- So not happy!
- Front End Work On 2007 Caliber
