View Full Version : Dodge Intrepid
  1. 97 rarely starts, and likes to stall out
  2. wiring/sensor schematic
  3. Cruise Control not working.
  4. Need Help Connecting Throttle Cable
  5. Manually Open Blend Door
  6. 99 3.2 Intrepid Need Help ASAP!!!!
  7. 98 concorde 3.2L
  8. AIRBAG Light on Intrepid 2003
  9. 1999 3.2 intrepid
  10. My powersteering is making loud noise still?
  11. o2 Sensor problem. Please help!!
  12. Turn Signals Problems
  13. Need a Fuse box diagram
  14. Sometimes starts / Sometimes doesn't!
  15. Air bag sensors
  16. Intrepid Not Starting
  17. Brake lights
  18. intrepid is stammers at 100-120 km
  19. 2002 intrepid
  20. Map Sensor Issue
  21. Fixing Sunburned Headlights
  22. 2.7 Water pump failure
  23. Twin Halo LED Projector Headlights for 98-04 Dodge Intrepid
  24. Question
  25. 1996 3.3L intrepid transmission replacement HELP.
  26. 96 Intrepid Gauges not working
  27. obd 2 codes
  28. Dodge Intrepid Parts
  29. 2.7 to 3.2/3.5 conversion
  30. Coolant leak from under the engine!!!
  31. Power Steering Noise When Cold
  32. Bypass amp
  33. 2002 Intrepid Passenger window will not go up
  34. Tranny issues
  35. Car won't start....help
  36. Strange Power Steering Problem
  37. Just bought a used Intrepid 2000 and worried now
  38. Spark Plugs
  39. Faulty blinkers
  40. How to disconnect A/C compressor
  41. 2.7 rebuilt and purring like a kitten
  42. 2.7 to 3.5 or 3.2 swap
  43. Would flushing help?
  44. Should my daughter buy it?
  45. strange dragging noise when i hit the breaks
  46. 2.7L V6 Sludge Problem
  47. 95 Intrepid coolant issue
  48. 2002 2.7 Stalled @ Red light, won't start - oil light problem
  49. intrepid 2002 2.7l
  50. Cigarette power shuts off when ignition off
  51. virbration (no noise) during high speeds
  52. Changed Battery Now Car Wont Start
  53. 2.7L Hysteria?
  54. Engine Code 45
  55. Help with 3.5 HO
  56. starter replacement
  57. rear door panel-drivers side
  58. floorboard full of water
  59. Why is the Intrepid gone?
  60. Any Engine Removal Install Write ups for 98 and up?
  61. 2.7 to 3.2 Swap--No Start--Need Help!
  62. voltage spike
  63. 2001 Intrepid with DTC P0432
  64. Shopping for 98-02 Intrepid, what to check?
  65. starting problem
  66. Help with 95 intrepid engine trouble
  67. 1999 Concorde
  68. sudden engine knocking pretty bad
  69. New member with question
  70. Chicago Intrepid Meet
  71. 1999 Intrepid 2.7L wont start after a cold snap of -50c
  72. COTM
  73. In great need of help!!!!
  74. NEED HELP QUICK
  75. advices on buying a 2002 Intrepid
  76. Regional Sections!!
  77. Whirring sound, bearing of some sort?
  78. 2004 Dodge Intrepid electrical help please!
  79. electrical arcing coming thru speakers
  80. 1997 Intrepid gas leak
  81. Noisy power outlet in my '01...
  82. Swapping Autostick
  83. inprove the speed
  84. hood opening problems
  85. 96 dodge intrepid
  86. 3.3 to 3.5 engine swap........
  87. "travel information center module " Intrepid '95
  88. front end alignment???
  89. Need a 3.5L engine for 02 Intrepid
  90. Changing Alternator.
  91. bucking while coasting at any speed
  92. 94 INTREPID SHUT'S OFF ON TURNS ???
  93. Connecting Rod Replacement
  94. Get out and Vote
  95. 99' Intrepid Problems...
  96. shifting is so damn hard!!!
  97. How to open hood with busted cable ???
  98. 01 Intrepid ES - P0340 Camshaft Position Sensor Circuit Malfunction
  99. Yet another Oxygen sensor question
  100. Need 2000 Intrepid Manual, please help me!
  101. 2002 Intrepid w/ Speed Sensor Problems?
  102. 04 intrepid on 22s
  103. 2001 Intrepid Ignition Switch Problem
  104. 96 Intrepid 3.3 engine P0154 O2 Sensor Circuit No Activity Detected
  105. 2001 intrepid es
  106. 1995 Intrepid Electrical - Cruise & Air Bag?
  107. Electrical Problems?
  108. I want to convert my 3.5 to 3.5 ho
  109. Do I replace the thermostat?
  110. Looking into info on how easy or hard is to fix an issue with my car suspension.
  111. P0138 code on 2002 Dodge Intrepid
  112. Cooling fan
  113. need nominations for car of the month
  114. 03 Intrepid, broken line.
  115. Need help with my Intrepid
  116. 2002 Intrepid with no spark
  117. HELP NO BRAKES! STRANDED!!!
  118. im trying to fix up this beast
  119. 2002 Dodge Intrepid Transmission Problems
  120. 95 water pump help change PLEASE HELP ME !!!!
  121. 95 dodge intrepid water pump change ! help !
  122. FS 98-04 intrepid smoked headlight cover
  123. REPLACING STEREO NO SOUND HELP!!
  124. i need help with my 1996 dodge intrepid fast please
  125. 1997 Dodge Intrepid Keyless Entry
  126. 1995 Intrepid Cruise Control & Air Bag Light
  127. 1999 Intrepid spark plug coil removal
  128. Location of the PCM ('96)
  129. beeping noise
  130. Spring rubbing against tire
  131. What's going on??
  132. Mutifunction Switch
  133. Auxilary Fan....melted off!?
  134. is there a forum thats actually active???
  135. weird engine or tranny noises on 95 3.3l
  136. 99 SE Engine Trouble
  137. i want sum 20's but.......
  138. 2000 Dodge Intrepid Wont START!!!! HELP
  139. Help - girl friend's 2000 ES - high beams won't turn off!
  140. Bumper Repair
  141. hot rodding the 3.5
  142. low beams headlights will not come on
  143. 93 Intrepid will not start...Please Help
  144. 95 intrepid
  145. August Car & Truck of the Month!!!!!
  146. 96 A/C Belt?
  147. Intrepid Comming Back?!
  148. Purchasing an Intrepid
  149. July Ride of the Month Voting!!!
  150. Transmission, Dash Gauges
  151. MOVED: Tweeter is going out.
  152. YOUR ATTENTION PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!
  153. Gas Mileage
  154. Which generation do you have?
  155. Service Engine Codes For OBD II Engines
