PDA
View Full Version : 2nd Gen Intrepid
Pages : 1 [2] 3 4 5 6
  1. 3.2 exhaust
  2. Engine Emblem
  3. my 2000 Dodge intrepid 3.2 will not start it just clicks
  4. cooling problems
  5. 04 to 01 engine ??
  6. 2003 interpid over heating problem
  7. 04 ticking dash
  8. Amplifier went out on my 2004 Intrepid
  9. 1st gen 2nd gen overlap date
  10. Hose Assembly
  11. Same old stoy, squeaky noise.
  12. OIL pump on 99 2.7
  13. 1998 Dodge Intrepid 3.2 L P0700 code
  14. mechanic fixed waterpump, timing problem now
  15. Motor Purr Tune-up
  16. Replacing headunit in 2000 rt premium sound
  17. 1998 dodge intrepid throwing p0205 and p0305
  18. Dodge intrepid throwing p0205 and o0305 codes
  19. Question Replacing Intrepid Drive Axle
  20. 2000 dodge intrepid
  21. 2000 Intrepid Won't start
  22. 2002 dodge intrepid se 2.7 I keep getting cam and crank sensor codes plus knocksensor
  23. 1999 Intrepid Wont Start... Please Help
  24. switch engines, or rebuild, a 99 2.7
  25. AHHHH help!
  26. Dodge Intrepid Noise
  27. 2002 Intrepid Running weird
  28. 1998 intrepid se key fob help needed
  29. 2.7L - R Parts for sale
  30. Exploded views of EGR valve 2000 Intrepid
  31. 03 Intrepid 2.7 overheating
  32. P1391 Going throu the motions.
  33. New (Used) 04 Intrepid..but needs a few things...help?
  34. Totally out of ideas
  35. 2002 Dodge Intrepid ongoing charging issues
  36. 3rd brake light
  37. Help!!! install go wrong.
  38. New to Intrepid. Cooling leak? extra condensation out exhaust.
  39. 2.7L bad piston rod
  40. Damn!!!!!!!
  41. 2000, 2.7L starting problem
  42. Transmission shifter cable
  43. Camshaft position sensor 3.2L help
  44. 2002 Intrepid auto trans. gearshift hard to move
  45. 2000 Intrepid lock stuck
  46. is there some way to program a keyless entry remote without haveing one? 2001
  47. 1999 Intrepid radiator fan problem
  48. Door mouldings?
  49. 98 2.7 with p1391 troublecode
  50. -Fixing to buy a 1999, but the fuel pump has went out-
  51. 2000 Intrepid takes on fuel slooowly!
  52. Front door speakers
  53. 2000 chrysler intrepid won,t shift or hard into park
  54. 99 intredpid, a few problems
  55. No dash light after 2 seconds
  56. 99 Intrepid - Black fluid under rear of car
  57. EVIC Question some functions not working right.
  58. 2000 intriepid 2.7l vin u swap with 2002 vin r
  59. Battery terminal sparks
  60. Ambient Air Temp Sensor 04 intrpid.
  61. 2001 Intrepid R/T ID#'s
  62. power door locks won't work
  63. Intrepid Transmission help
  64. wont start
  65. 04 Intrepid Codes p1776 p0700
  66. please advise, stall
  67. oil in plenum
  68. Heater control actuator 2000 dodge intrepid. 3.2
  69. Replacement wheels for 04 Intrepid RT
  70. My mom's 2002 3.5L Intrepid - Keep or Junk?
  71. 2003 Intrepid 2.7 O2 sensor replacement help
  72. Alternator location and removal
  73. '00 dodge intrepid engine problems pleaseee helpp!
  74. 2000 Intrepid 2.7 "almost starts" but doesn't
  75. System problems
  76. Electric problems
  77. Spark Plug Coil Threaded Insert
  78. 1998 Intrepid Wheel Hub Nut Size
  79. Steering noise diagnosis - bad springs?
  80. Transmission Issues
  81. 2000 intrepid -- where is the ignition module located?
  82. 2003 Intrepid overheating
  83. 2000 3.2 top end noise - sounds like diesel
  84. 99 Intrepid doesnt like water
  85. 2000 intrepid runs then dies
  86. My solution to Oil light flickers, P0172/5 and rpm hesitation
  87. wont start
  88. 2000 Dodge Intrepid temp control problem
  89. 98 Intrepid Electircal Issue (its a GOOD ONE)
  90. Cigarette Lighter Replace 98 Intrepid
  91. 2002 intrepid engine lite comes on and rpm spikes
  92. lighting behind A/C Heater controls
  93. New to Dodge Forum and need some help
  94. catalytic convertor
  95. cleaning batt cables fixed ac, ck eng lite, HP
  96. 2004 3.5 SXT High output making knocking sound
  97. help please
  98. O2 Sensor problems 2002 Intrepid
  99. asd relay coil hot at all times
  100. 2000 2.7 ticking, what is it
  101. 2002 intrepid rear end height
  102. 2004 Intrepid with a surge (video)
  103. 2000 Intrepid problems - advice please???
  104. 2000 2.7L - 4K Idle
  105. 2002 Intrepid problems.. need help
  106. 2001 Intrepid A/C clutch won't engage (Error P0645)
  107. O2 sensor
  108. 2002 Intrepid ES shimmying
  109. cylinder 4 misfire
  110. 2002 3.5 coolant leak
  111. ABS and Trac light on
  112. Ignition Problem?????
  113. Help!! 04 SXT
  114. 2000 intrepid electrical issues please help
  115. 2000 Chrysler Intrepid 2.7l won't start
  116. 2002 Dodge intrepid Bogging down
  117. 02 Intrepid 2.7 Overheating Mystery
  118. 2003 Dodge Intrepid 2.7L P0700 Trans pulls:(
  119. 2000 Intrepid ES 3.2 Gas Gauge Needle Issues
  120. 1998 dodge intrepid engine light dtc p1687 p1695
  121. ecu
  122. 1998 Intrepid ES Platinum Metallic Paint Code?
  123. Help!!!
  124. TIming Chain Tensioner
  125. 2003 Intrepid P0300
  126. 2.7 Sludge - Cam Section
  127. 2003 Water pump gear and Primary Chain
  128. ABS and Brake light on...Does not have ABS!
  129. 2002 2.7L No Spark After Rebuild
  130. Any advice on the Drive Belt replacement?
  131. 2.7L 2000 dodge intrepid
  132. Stalling problem solved
  133. 02 Intrepid heater control not working
  134. Lost Climate Control Display
  135. Installing a Fuel Pressure Gauge
  136. oil pan dip stick tube removal
  137. 2002 Intrepid transmission problems
  138. crank no start condition
  139. Car is stalling and having issues P0129 Help
  140. P0340/300/132
  141. CV joint question
  142. Stuck Tranny Solenoid - 04 Intrepid
  143. 2002 Intrepid 2.7L Rebuild
  144. Dashboard brake light won't go out.
  145. 2.7 liter oil sending unit
  146. Dodge intrepid 2003 to 2000 2.7 engine swap
  147. 2000 to 2003 engine swap
  148. 2004 Intrepid SXT 3.5L In Limp Mode
  149. Please help with the charging system
  150. 2002 Intrepid V6 2.7 Timing Issue
  151. Help with 01 2.7
  152. Have codes P0068 and P0108
  153. Question about Transmission Solenoid 02' 2.7 engine
  154. 2001 SE 2.7 front end growling and howling
  155. Engine will not beyond 3000 RPM sometimes!
  156. alternator
  157. 2002 2.7L Dreaded Spun Bearing
  158. 3.2 Timing Belt Installation
  159. intrepid ac problem
  160. 02 blower run at high and won't stop
  161. intrepid engine swap?
  162. Setting Timing On 3.2 Intrepid
  163. time for change
  164. How To Replace Radiator Cooling Fan Dodge Intrepid 1998-04
  165. Oil sending switch
  166. Leak detector pump, Purge control solenoid
  167. Cracked dash 03 Intrepid
  168. 3.2 Head Removal Misc Questions
  169. 2002 dodge intrepid
  170. 3.2 OHC Head Gasket Replacement
  171. Trans problems.
  172. 2000 Intrepid 3.2L A/C Help
  173. Hazard 20A Fuse Blowing
  174. How To Remove the taillights on your 98-04 Dodge Intrepid
  175. fuel line through the firewall.
  176. 2001 Intrepid Idle and Code Problems
  177. Engine issue
  178. p0700???????
  179. Camshaft Position Sensor Help!
  180. P0700 and P0888 Codes
  181. 04 Intrepid transmission
  182. Harsh Downshift and startup...
  183. 1999 Intrepid 2.7 won't start from key, but will if I bump it.
  184. More Intrepid problems
  185. 01 Intrepid P/S hose..are they kidding me ?
  186. 1999 Intrepid Transmission problems
  187. 1999 2.7 intrepid problem
  188. HELP - My Heat/AC Fan Wont Shut Off - Stuck on HIGH
  189. 2.7 knock sensor replacement
  190. 2004 Engine Blown, What engine will fit
  191. p0750 problems
  192. 98 dodge intrepde 2.2 3cyliner misfire
  193. 2000 intrepid
  194. 2002 intrepid wont stay running
  195. 2.7 engine removal
  196. Security System Lock Out
  197. 2002 Intrepid heater problem
  198. Overheating issues!!!!
  199. My project
  200. help with p0171 po174 keeps coming back.
  201. 2001 SE Interior Lights Out.
  202. Trouble cyl 6 missfire and 2nd gear sticking
  203. Intrepid problem
  204. 01 2.7 squeaking on slow left turns and also straight
  205. I wanna ditch the 2.7!
  206. Transmission not engaging when cold
  207. Stopped running while driving. Wont start.
  208. Miller tool 6195
  209. Thermostat Change
  210. 2.7L Rebuild
  211. 2004 intrepid shifting problems
  212. `98 Intrepid ES .... Please Help!
  213. 98 intrepid 2.7 motor
  214. 98 3.2 How to change the serpentine - AC belts
  215. 2000 oil pressure issue
  216. 2000 Intrepid tranny problem
  217. 2000 Intrepid tranny problem
  218. 2000 Intrepid 2.7L hard starting when first started cold
  219. I have a P0432 Bank 2 below eficiency
  220. 2002 check engine light
  221. 2002 3.5L V6 Dodge Intrepid, Evansville IN, Expressway
  222. how to remove driver side cv joint
  223. low speed shaking
  224. 99 3.2L Runs only w/cam sensor unplugged help!!!
  225. 3.5 Intrepid Injectors...
  226. Oil Coolant Lines to Radiator?
  227. May buy an intrepid - Things to look for?
  228. 1999 dodge intrepid Exhaust problem / Y pipe
  229. 2002 Dodge Intrepid Freeze Plugs
  230. 2002 Dodge Intrepid Water Leak
  231. 3.5 HO quit running. HELP!
  232. i need help
  233. Wipers gone crazy
  234. Headlights flicker on and off
  235. 2.7 to 3.5 swap
  236. ignition switch line fuse?
  237. crank sensor problem
  238. should i change to valvoline oil?
  239. Fuel Problem
  240. 2000 intrepid 3.2L starter not spinning or engaging
  241. Changing Radiator Hoses
  242. Fuel pump bad or something else?
  243. Another No Start Problem
  244. i have a relay question
  245. 2002 intrepid ignition switch
  246. 04 Intrepid Dashboard
  247. rattling noise help????
  248. 01 2.7 intrepid into 98 intrepid with dead 2.7
  249. Replace 3.2 with 2.7?
  250. Transmission Problem
