View Full Version : 2nd Gen Intrepid
- Engine Codes p0132 and p0152
- Voting is going on now!
- water pump
- 2001 onboard diagnostic light
- 2001 Intrepid needs engine
- Whirring sound, bearing of some sort?
- Intermitent Engine Light
- Where is the camshaft sensor located?
- engine removal
- replaced spark plugs, now check engine lite
- Error Code P0152
- Diagnostic Monitor Test question
- can somebady help me
- blower location?
- 2000 ES 3.2 engine code P3054
- Realistic Bluebook value of 2000 Intrepid - good shape
- 02 intrepid sxt 3.5 trouble codes
- 98 Concorde 3.2 Part Out
- 2002 Dodge Intrepid 2.7l engine noise
- Tranny issue
- oil pressure light flickers at idle
- code p0441 and flags unsetting
- Rumble noise on cold engine?
- 2000 intrepid 2.7 issue
- 2001 intrepid stalling
- blower motor resistor
- Parting out 2001 intrepid
- 99 INTREPID WON'T SHUT OFF
- ------> VERY VERY Weird Headlight Problem!! <------
- 2001 trans questions
- I hate modern cars.
- Installing 2003 2.7 engine into 2000
- 98 intrepid
- Heater fan resistor, 99 Intrepid
- 99 Intrepid commentary
- 2002 rough ride. tires? cv's?
- p1495 code (leak detection pump)
- Thank you for the enlightenment...
- 2000 2.7 smoking
- 2000 2.7 asd relay always off
- 1999 Option Question
- 99 3.2 Timing Belt
- 2001 2.7L engine burning oil
- 2000 2.7 starting problem
- Parents 01 intrepid Heater Smell
- ALARM KILL SWITCH (HELP)
- 96 intrepid no start
- Coolant leak saga
- Help!!! code 0700
- Smelling hot
- 99 INTREPID,DRIVER DOOR WON'T OPEN
- Code P0441
- Leaky power steering hose
- transaxle problem
- Alternator replacement
- Install CD-Changer
- 2.7 stopped working
- electrical problems - HELP!!
- P0344 and P0340 Codes
- Engine flashes while driving
- oil light comes on..
- '99 ES Fog lamps
- 2001 Intrepid SE will only start on Sundays
- What front blinker bulb do I need?
- REPLACED PARTS MILEAGE CHANGED
- '02 w/3.5 Transmission question
- How do I reset the "Check Engine" light??
- Dealer cost: change inner tie rod ends
- battery relocation@2000 intrepid
- 2k Intrepid coolant leak
- new used intrepid
- Radiator Fan issue
- Recharging A/C
- Help with V belt & serpentine belt on 2001
- 2003 Dodge Intrepid Camshaft Position Sensor Error Code P-0340
- 99 concord -No HEAT!
- Computer Hook ups
- Questions about the Sepertine Belt
- A day at the dealer
- INTREPID Head Gasket
- starting problems
- ERROR CODES-2002 INTREP
- trans
- RESETTING THE TIMING
- 98 intrepid 2.7 pcm
- my intrepid is jerking while i drive it
- 2.7 engine stops while moving
- 99 intrepid will not start sometimes
- Get out and Vote
- PO300
- 01 2.7 Coolant Leak into Crankcase
- Body Control Module
- tranny
- Intermittent starting problem???
- Engine light
- Help changing starter
- Power steering pump help, 00' 3.2
- air bag light!
- 0172, 0175 codes -leaky injectors?
- 2001 Intrepid SE Trouble Codes
- '98 Intrepid steering problem!!! HELP!
- rear speakers
- Hiccup at idle and acceleration
- how come
- 01 problems in-law car
- intrepid 98 low oil pressure
- 2.7 Help me please our livelyhood depends
- 99 intrepid sits for a day wont start
- Help! Inside door hadle does not work! How do i fix it?
- Do I have a Problem ?
- steering rack
- 2.7 stalling problem,,,,help
- Fan assembly
- 2002 Dodge Intrepid Manual
- 98 with a 3.2
- Are these mechanics right?
- any clue?
- dreaming of what could've been.
- 98' Intrepid hiccupping when accel. fast and driving at high speeds...
- new to the forum
- pcm or not to pcm?
- 2000 dodge intrepid wont start
- Low Oil Pressure
- 2001 2.7 oil light
- clicking sound on right front wheel
- P01391 and P01490
- Timing chain 2001 2.7
- Map sensor
- A/C Not working 2002 intrep
- Heater blower motor resistor
- 98 2.7 Won't start
- Radiator fan assembly
- Bosch platinum 4+
- 2000 intrepid oil light
- WHEELS FOR A 1999 INTREPID HELP!!!!!
- 02 INTREPID
- 1998 Intrepid
- New to Forum, Intrepid help
- Squeak coming from steering column
- 2000 2.7L V6 Engine Q. HELP PLEASE
- Rear Lights
- Philladelphia area dodge owners
- NEW PURCHASE
- Flapping noise during engine warm-up.
- Intrepid Door Seals, locks, headlights, etc.
- window actuator 4 sale
- P0132 & P0152 error codes
- code 0160 98 2.7 motor
- C/s pulley wobbling
- PCM location troubles
- Advice Please
- Head gasket change for a shade tree mech.
- transmission output sensor 2001 intrepid
- 2002 Dodge Intrepid Transmission Problems
- won't start
- 3.2 Converted
- 00 Intrepid with 2.7 won't stay started
- '01 Intrepid sat for a few months, now it won't start
- can i swap out the 2.7 for something else?
- 2.7 Upper Coolant Housing??
- Tranny stuck in gear
- HELP PLEASE
- 1999 Intrepid 2.7L shutting off.
- Strut replacement questions
- camshaft positioning sensor
- 2003 Intrepid has water sound from HACV system
- 2000 Intrepid Front End Clunk
- 3.2 broken Tim belt issues
- dropping rpm
- NEED HELP PLEASE!!!!!
- anyone got crashed intrepid for me
- Dodge 02 Trep won't start
- 2000 intrepid stopped running
- Cheap 17's?
- airbag issue 2000 intrepid
- airbags didnt deploy
- OBD II help
- Car and Truck of the Month, get involved!!
- Obsolete - Intrepid 2nd Gen Do It Yourself information
- 2004 intrepid codes p0700 & p0580
- 99 Intrepid Antenna (?)
- Help on removing alternator
- 01 intrepid se speedo not working???help
- 1998 intrepid
- 2001 Intrepid 2.7L idles at 4K p601 code
- Love/Hate Poll
- Trep engines
- new car
- 99 intrepid blower motor
- Hood Emblem
- struts
- Front brakes squeak
- water outlet
- dodge intrepid viper rt
- 2.7
- An important question
- Too Much Oil
- 01 intrepid trunk release
- Multi-Faceted Electrical Problems
- True clear tails. Street legal.
- 2000 Dodge Intrepid Wont Start! 2.7 Liter/Help!
- I WANT SUM 20" RIMS BUT....
- 0113 and 0172 computer codes
- 2000 model 2.7 r and u (unreal)
- Taking apart the instrument cluster???
- delete this
- Lights get brighter upon braking
- OBD codes 420,432
- Speaker wiring problem
- Need help with 2.7 motor
- eclipse stereo problems
- intrepid 04
- OBD2 module wiring diagram for 2000 Intrepid.
- Headlights Dim upon Braking
- Buildup of oil
- 99 Intrepid ATC problem - no heat
- Timing Belt on 99 Intrepid
- Turn signals / hazard flashers busted
- Starting problems
- Evaporative system leak
- DODGE INTREPID DOOR PROBLEMS!!!! HELP!!!
- 2000 R/T wheel info
- Leaking on driver side floorboard on a 99
- 99 miss...help pplease
- 1998 intrepid just stopped help
- 2002 2.7L Engine Waterpump
- Looking for a front license plate bracket for a 2003 Intrepid
- Intrepid reliablity...
- 2.7l to a 3.5litre swap
- Sludge
- Bumper repair
- Tune-Up
- 99 intrepid headlights flicker
- Spark Plugs
- 99 Intrepid Front End clunks& AC problems
- BROKEN TENSIONER PULLY,2000 INTREPID
- Intermittent Problem with A/C Blower
- Car dies at hi rev
- 2.7 engine
- timing chain thoughts on 99 intrepid
- foggy headlamps on 99 Intrepid
- engine oil light... please help
- Seating Track
- Speakers
- Help on deciding to buy 98 Intrepid
- 98 intripid code P0700,P0731
- CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
- P0016
