PDA
View Full Version : 2nd Gen Intrepid
Pages : 1 2 [3] 4 5 6
  1. No start
  2. 3.2 Heating Issue Diagnosis
  3. Cruise Control Issues
  4. Engine miss with air on
  5. 12v amp wire cut
  6. I need to know what is name of this part
  7. I need to know what is name of this part
  8. 99 dodge intrepid es cooling fan issues
  9. low idle help please
  10. A P1776 CEL that went all bad and is still bad...
  11. intrepid problem
  12. Help 04 intrepid overheating.
  13. 02 Intrepid 3.5L Throwing Multiple OBD Codes
  14. 1999 dodge intrepid major alignment issue
  15. map sensor problems
  16. 2003 Intrepid ABS Module
  17. 1999 Dodge intrepid 2.7L best car made, I like my car
  18. 99, heater fan issue
  19. what kind of oil should i use????
  20. Help????
  21. Help PLEASE!!!
  22. irritating whining noise
  23. Aftermarket Front Bumpers?
  24. need help bad
  25. Sporty and Luxury...possible?
  26. 2000 Intrepid problems
  27. Squeak, squeak I can't believe I'm one of those!
  28. 02 Intrepid AC leaking water into car
  29. 2000 Dodge Intrepid 3.2 turns over, yet won't start
  30. code p0420 help plz
  31. How can I reset the check engine light?
  32. AC re-charge help
  33. 2.7 intrepid 2 issues
  34. Interior Lights
  35. 1999 Dodge Intrepid Check Engine Light came on with a DTC P1391
  36. ecm on 01 2.7
  37. Amplifier problem
  38. 2002 random stalling???
  39. 1999 2.7 Liter Engine Stops Running while Driving! HELP HELP HELP!!!!!
  40. 1999 Dodge Intrepid 2.7L engine code P1642
  41. 01 Intrepid Rear Tire Rubbing on strut. Can you help?
  42. 1998 Dodge Intrepid - 2 Problems (Tire related and Air conditioning related)
  43. 99 intrepid 2.7 oil light flickering
  44. Wet driver's side floor board
  45. 2.7 l 98-04 engine knocking - How did you fix it? (if you did)
  46. Really interesting 2001 Dodge Intrepid electrical problem.
  47. 2000 2.7 engine won't turn over
  48. help car stalls 97 3.5l
  49. Coolant leak :(
  50. Need help.
  51. 2.7 oil pan
  52. Alt. Brackets????
  53. Aside sludge, Smoking
  54. need help on timming 2.7l tech to tech
  55. LF tire wobble ???
  56. 2002 intrepid!! Need speaker help
  57. 99 2.7L Horrible Knocking
  58. 2000 EGR issue
  59. 2001 dodge intrepid Starting issues
  60. Can anyone help me out?
  61. R-134a amount for recharging AC
  62. 2.7
  63. Window tinting
  64. Please Help w/ swap..
  65. Engine dies on highway and oil light flickers at idle
  66. a/c & defrost
  67. Hydraulic lifters frozen
  68. An invite to 3rd Gen. TOTM!!
  69. code Po1391
  70. Fog Lamps/Bulbs
  71. More codes after fixing
  72. 01 intrepid hazards and turn indicators not working
  73. Transmission Hard to Shift
  74. Gas gauge not working?
  75. EGR or catalist problem?
  76. 2003 vs 2004 Intrepid
  77. Hydraulic Tensioner
  78. New comer
  79. Headlight adjusting and HID's
  80. Water Pump Weep Hole
  81. Help, Confused, Cylinder firing diagram 3.2L
  82. NEED Help! 04 intrepid will not start.
  83. 1999 intrepid 2.7 missfires at temp
  84. 2002 intrepid ES 3.5 - limp mode
  85. Computer question?
  86. cruise control issues
  87. Remote Starter for Dodge Intrepid Tach Wire
  88. Fuel System OL
  89. 2000 Dodge Intrepid Low side A/C port
  90. 2001 Intrepid losing coolant and slight oil usage
  91. 2002 2.7 primary timing chain tensioner
  92. R/T random miss?? Help please
  93. Ghost in 2001 ES After Shop Visit. Spooky stuff.
  94. Cam Sensor Location for 2004 SXT
  95. 1999 intrepid transmission issues
  96. 2001 Intrepid PCM
  97. cranking no start, P1391 code
  98. Is there an extra input on the back of the radio?
  99. P0172 rich code
  100. 2.7 idle messed up when warm?
  101. 2001 Intrepid Wiring diagrams
  102. it sparks but no start
  103. Cam Shaft Sensor Issues
  104. 01 intredpid no spark
  105. 1999 Intrepid SE 3.2L Knock
  106. What is need to ditch the 2.7 in a 2000
  107. Are there any known problems with switching a 2.7 engine from a 99 intrepid with a 01
  108. 2002 v6 heater not hot????
  109. 2.7 intrepid O2 sensor and akward idle
  110. electrical issues 2000 dodge intrepid(please help)
  111. cheap performance chip is messing up my engine
  112. Brake light issue might have caused car to not start?
  113. Gauging interest in RWD Intrepids...
  114. Codes P1684 & P0703
  115. 2003 intrepid prob with cruise control and engine starting
  116. Going Crazy with this no-start
  117. Differential Capacity
  118. 2000 intrepid trans promlems
  119. Factoy Amp Bypass on 2004 Intrepid
  120. 1998 Dodge Intrepid Part Out (Seized Engine)
  121. 3.5 Intrepid Charging Problem ???
  122. Newbie - Fuel Filter Question
  123. 2001 Intrepid R/T gas filling issue
  124. How to check Engine Lockup
  125. 2001 ES 3.2 Cuts off at low RPMS
  126. Newbie having big Trans problems in 03 Intrepid
  127. Blower Motor Resistor
  128. Problem after 2.7 to 3.5 swap
  129. heater blowing cold air please help
  130. Just baffold and going crazy
  131. 2000 Intrepid - Loud Engine Knocking
  132. 2001 Intrepid 2.7 Stalls
  133. Its Cold out :(
  134. 01 2.7 water pump replacement
  135. 1999 intrepid tie rod question
  136. Radiator Fan Runs Continuously
  137. 03 sxt 3.5 tick to knock
  138. 02 Intrepid SXT spoiler delete
  139. Rear tire wear
  140. Slow to get heat
  141. Battery Charging problem
  142. to anyone parting out your trep
  143. FRUSTERATED stalling
  144. 98 concorde 3.2
  145. Should I get new tires or just wait
  146. P0121
  147. 2001 intrepid alt. regulator.
  148. BAD Engine Knock
  149. intrepidtrouble
  150. code 301?
  151. 99 3.2 No Fire
  152. Abused Ram 4x4s
  153. 02 Radiator Fan Replacement
  154. How to get the spark plugs out of a 2.7
  155. Performance Parts for my 04
  156. 2.7 cranks but won't start
  157. Catalytic Converter Discrepency
  158. 2002 Dodge Intrepid Short Wiring Diagram Help...
  159. Hepa Filters on a 2000 Dodge Intrepid?
  160. Gear shifter will not shift into gears, please HELP!
  161. 2000 dodge intrepid
  162. Power Steering Fluid Leak
  163. amplifier problem
  164. runs sometimes
  165. headlight adjusting
  166. starter on a 1998
  167. Need help 2001 Intrepid
  168. Sticky shiffter
  169. P1684?
  170. NEED HELP!!! New to this forum
  171. 2000 Intrepid Battery
  172. 2002 Intrpid: Ignition switch problem?
  173. Foot brake is stuck! Help!
  174. My power steering is making loude noise?
  175. 2000 intrepid blowing fuse
  176. Rod Bearing Replacement
  177. 05 stratus
  178. Radiator Cooling Fans--When do they kick on?
  179. 98 Intrepid Thermostat
  180. Code P0138 2004 intrepid
  181. Body Control Module/Aspirator Motor
  182. Ford Ranger 16" wheels on Intrepid
  183. Squealing sound
  184. 2000 intrepid problem
  185. antifreeze leak from weep hole at thermostat housing
  186. Clicking noise during starting?
  187. What is this crazy sound?
  188. Blown Head Gasket
  189. Swapping a 3.2/3.5 inplace of 2.7 ?s.
  190. 98 Intrepid w/ 3.2 oil leak???
  191. Question on a Driveline Swap
  192. just installed new pads and rotors
  193. 04 Intrepid Rpms fluctuate over 2700 rpm??
  194. the 2nd gen intrepid dodge should have built!
  195. 98 Dodge Intrpied Wiring Issues
  196. P0160 code
  197. Fan Problem 2002 ES
  198. Squealing...Please Help!
  199. air directional/ac-rear defrost buttons
  200. Changing 98 intrepid driver's side headlight bulb
  201. 2.7L Turns but won't start...
  202. Knowledge of Dodge vehicles
  203. 2.7 alternator and power steering pump can be used on 3.5
  204. Interior Lights Flashing
  205. 2002 intrepid turn signal intermittant
  206. '04 Intrepid antifreeze leak problem
  207. squeak problem
  208. Codes and stalling
  209. Cranks but won't fire
  210. Electric window switch from driver's door, 2000 Intrepid
  211. best seal for tranny pan
  212. 98 Intrepid won't start after rebuild
  213. Swapped '98 3.2 for '02 2.7... Help!!!
  214. Are these tries to big??
  215. 1999 2.7L transmission question
  216. 3.5l exhaust removal
  217. Interior light bulb change
  218. Used parts
  219. 01 Intrepid Engine Swap
  220. 04 Intrepid SE, Oil in Cylinder
  221. Help Please my car has no power
  222. '00 Intrepid 2.7. ATF Flush?
  223. dodge intrepid
  224. How to check codes?
  225. 2000 Intrepid with bad alternator
  226. Engine oil smells like gas...
  227. Need some advice
  228. any comments on 04 3.5l intrepids?
  229. 98 Intepid part out
  230. replacing valve body in dodge intrepid
  231. Power window
  232. 99 dodge intrepid programmer
  233. 99 dodge intrepid programmer
  234. Sound System Stumper 2
  235. BCM Question
  236. 04 3.5 autostick questions
  237. 1999 Dodge Intrepid for parts!
  238. 2004 Intrepid - Over Heating
  239. Replacing 2.7 with a 3.2
  240. 04 intrepid stalling
  241. Sound System Stumper
  242. puzzled
  243. Climate Control display wont stay lit up
  244. Gasoline smell
  245. 98 Intrepid Power Issue
  246. Is it dead?
  247. 99 intrepid tranny problem
  248. Frustrated with my '01 2.7
  249. I've been gone
  250. Black Housing Twin Halo LED Projector Headlights for 98-04 Dodge Intrepid
