View Full Version : 2nd Gen Intrepid
- Question
- Immobilzer problems...Pleeez HELP!!!
- stop light anomaly
- Loud Engine Noise
- 2000 Dodge Intrepid knock on startup
- '00 3.2l tranny issues
- Major problem with my friends intrepid
- 2001 Intrepid help
- stumped
- 2004 INTREPID-Check enging light
- New Member
- Oil in front of manifold?
- Help Please.
- noise caused by pulleys.
- 2001 Intrepid stalls when braking from high speeds
- Will a Concorde 2.7 interchange with an Intrepid 2.7?
- Intrepid 2004 2.7L hose/tube broken, help!
- question on 1999 Dodge Intrepid. 3.2 v6
- Electrical issue involving new aftermarkert radio
- torque converter
- 2000 intrepid sunroof
- Newbie- Questions
- Rough starting 3.2
- hey all including kurt2
- 99 dodge intrepid 3.5l For Sale/Part Out
- 3.5l
- 3.5l 215ci intrepid motor problems
- please help ASAP
- A/C control head fuse
- 99 Dodge Intrepid Misfire Problem
- Misfire at Idle
- 04 sxt sluggish engine
- 99' intrepid check engine light
- Jack on Crossmember? Also, Jackstand Locations?
- anyone i need help!!!
- parking lights not going off
- 98 3.2 wont start
- trailer Hitch wires
- 99 Dodge intrepid questions
- Oil Filter Trouble
- 97 - 2000 motor swap
- front speakers
- Power off, whirring sound
- problem removing valve body
- oil leak on 02
- replace 98 intrepid 3.2 waterpump help
- 2003 intrepid power steering problem
- Bypass amp
- 2.7L Oil light flickering
- Oil questions
- Carpart4u.com Projector Headlight Sale!
- electrical problem
- 99 3.2l interpid HELP PLEASE!!
- 1998 Dodge 2.7 Intrepid
- 97 3.5L Intrepid - Starting Problems
- Timing Chain or Tensioner/Guides?
- Will Chevrolet Lumina rims fit Dodge Intrepid bolt pattern?
- 2002 Intrepid transmission problem
- Electrical Problem
- error code P1864
- engine swap..possible? [kind of long]
- 2003 intrepid 2.7 interchange question
- 2000 2.7 electrical problems, HELP!!
- Heat is on or off
- 04 2.7L timing problems
- 2003 intrepid code p0058
- ATC Display; Troubleshooting
- 2.7 Timing tentioner easy change?
- new name same old guy
- 2004 dodge intrepid
- 2000 Dodge Intrepid Problems
- trans wiring harness
- Headrest Removal Help
- change plugs?
- 03 Intrepid SE 3.5L with 3 codes!
- ('02 2.7) Knock sensor
- Water puddle on drivers side floorboard
- Cluster Mileage Question
- 2004 intrepid
- 2.7 p0068
- Door Cupholders?
- 2.7 to 3.2 swap help
- Car and truck of the year voting NOW
- 2000 dodge intrepid
- Oil light??
- Shift Solenoid
- 1999 dodge intrepid rear driver side door panel
- 1998 Intrepid Speedometer Tachometer and Odometer
- concorde/intrepid torque converter lockup switch
- 3.2L Nightmere Help!
- Drive cycle
- performance parts
- your cars broke
- 2004 Intrepid- 2.7 rebuild
- Bleeding the ABS
- Please help! buddy's 00 Intrepid won't start
- We need an Intrepid Section Moderator
- 2001 intrepid stall
- Just braggin a bit on my Intrepid...
- Oil Sending Unit....
- 2.7 litre replacement
- Fuel filter is?
- 2004 2.7 litre Intrepid Shift Detent Cable Problem Can anyone tell me how to adjust
- Camshaft Sensor problem.
- 2000 interior lights
- Please help...again
- Which grade of gas to use
- p1684 and p0456 codes in a 01 3.2 trep??
- forgot to remove neg from battery
- limp mode & fuse problem
- need help
- Forged Rods and Pistons
- Won't start...
- stock head unit removal
- 96 intrepid error code p1296
- Security System Problems?
- 2002 intrepid 2.7 engine cost?
- Need 3.2L Rebuilt engine 2000 Intrepid-Recommendations?
- Oil Light Blinks :(
- What is this plate?
- EGR valve
- re use or not the accessories from 2.7 to 3.2 swap conversion 2001 dodge intrepid
- Inside door handle removal
- power window issues
- dead dodge
- spedomoter/mileage meter flameout, check engine light ON...
- How often to change the timing belt and water pump
- Help: Can't remove speaker in middle of dashboard
- Please help!!
- 3.2?
- 2002 intrepid se check engine codes
- lots of transmission code Help!
- p0700 & p0740 help
- Error codes P1684 and P0700
- DF Video!
- New to Dodge
- Poor mpg's & 3 codes!! Help!
- Impact wrench
- 2001 Intrepid Starting Problem. Can it be a switch in the steering column
- Fan settings aren't working anymore
- 2.7 water outlet
- 1999 2.7 timing problem?
- 01 Intrepid: Transmission or Sensor??
- Harmonic balancer removing
- 2002 Intrepid conversion donors
- Location of Midline Amplifier?
- Should I buy?
- 2000 Intrepid
- error codes
- Hard start when hot
- HVAC blows through top vents only
- Motor Over Heats But Not Always
- 99 INTREPID ES Interior Lights
- 2001 Air Intake question - HHO
- 2.7L V6 Sludge Problem
- No Fire
- 2000 3.2 ltr drive belt replacement
- 1998 Dodge Intrepid .. no Speedometer ...
- P 1684?
- stereo system 99 intrepid
- trunk lock cylinder!
- In Search Of.....
- blower wheel removal
- cruise control and lighted window switches
- Three malfunctioning codes
- CODE P0622 and VOLTAGE LIGHT ON
- CRANKSHAFT DAMPER PULLEY VIBRATION?
- Ignition Key
- 2000 Intrepid 2.7L troubles ?
- Who would win???
- 99' 3.2 Intrepid ES RAD. Drain Help
- Brake lights problem
- Mufler
- Battery and starter changed - Intrepid won't start!
- Front End Shake
- vents in trunk?
- Gauges
- Rebuilt 2.7 Oil light problem
- whew, what a ride
- 99 Intrepid, 2.7l..Stalls after highway driving, EGR code..need some help guys
- 99 intrepid questions
- whir when cold.
- Timing Belt
- That dastardly "no bus" again
- P0108 stall until warms up
- Intrepid 99 stereo removal
- engine swap
- Shimmies and Shakes
- 2.7 to 3.2 Swap--No Start
- my new car 2000 dodge Intrepid
- Learned my lesson on changing coolant!
- Horsepower rating
- Driverside window
- codes
- 02 " no bus" on odometer.
- 100% electrical loss
- owner's manual
- Whats the engine interchange for a 01 Intrepid R/T?
- LIMP MODE! PLEASE HELP!
- Engine Question
- Removing 04 intrepid stock radio
- 2.7L Intrepid, blown at 20,000
- 2000 Dodge Intrepid 2.7 won't start
- CODES P0104 and P1683 ???
- 2000 Intrepid 2.7 blew up!
- 2002 Intrepid with wet drivers side floor
- 2000 dodge intrepid 2.7! engine open need a better diagnosis
- my water pump blow after enigine fire, I NEED HELP!!
- 1999 Concorder v6 3.2 starting issues
- Airbag Light
- AC blower
- 2001 intrepid interior trim
- 01' Neon sparke plug tubes
- I will miss him
- Clock Spring Recall?
- ENGINE HAS BLOWN 2.7 54,000 MILES!
- engine not turning
- Planning to swap out intrepid 2.7
- dodge intrepid shutting down
- Engine shuts off after highway speeds/ and cruze control is also shutting off after 20mins use
- bad engine knocking all of a sudden
- 2003 dodge interpid engin light
- dodge intrepid engin light
- 2.7L 1999 Model Problem
- 2.7 liter problems
- common steering failure?
- Common issues to look for?
- timng issues
- 02 Intrepid code )0440
- Running ruff
- 2000 dodge intrepid 3.2 engine firing order?
- 02 intrepid trans - help
- please help
- Performance
- Transmission Swap
- I'm thinking about buying a 98 3.2 ES....
- COTM
- 99 Intepid...key won't turn after battery replacement
- Transmission valve body
- Stuck in 2nd
- I seemed to have fixed the codes P0132/0152/0441
- Starting Problems
- transmission question
- stuck in park
- Please help I have power steering problems
- HELP ME PLEASE
- 1998 doge intrepid engine noise.
- Hvac fan problem
- 2000 Intrepid Stereo problem HELP !!!
- I have Problem after I Change engine intrepid 2002 2.7 with engine 2.7 1999 HELPPPPPP
