- 2000 Dodge Stratus CV Joints
- Detonation on 2,4 Engine...
- 03 Stratus, a few questions
- 95 Stratus Transmission Problem HELP
- Engine Noise
- 2.7 swap
- 97 stratus lost keyless remote weird problem help
- 97 dodge stratus head rests are stuck
- 97 dodge stratus 6cyl. oil light on help
- Looking for 2001 R/T body parts
- Compatable Engines
- New Used '05 Dodge Stratus ... 2 new problems
- NEW TO THE STRATUS STEREO QUESTIONS PLEASE HELP
- Rotor Replacement
- 1996 stratus keyless remote
- '98 Stratus, few problems
- Valve Cover gasket question
- which O2 sensor is it?
- oil pump
- I NEED HELP FINDING WIRES, STRATUS ...
- air filter on 2006 stratus
- light lens
- possible lead in to stalling?
- engine issues on a 2001 dodge strattus.... NEED HELP ASAP
- '97 won't shft out of second
- '02 RPMs?
- 2006 Eclipse Swap??
- HELP PLEASE
- Timing belt...
- Lowering Springs help...
- spark plug change?
- R/T for sale??
- Help with air bag light
- Anyone with a repair manual?
- where do i ground the stereo?
- 2.4l auto to 5 spd conversion??? What should I get?
- 02 stratus infinite system questions
- help! thinking of buying 01 stratus r/t
- Hey everyone Could use some help with a power steering issue.
- 18" Spinners
- 98 Stratus Transmission problem
- 97 strat Head gasket frequency of failure
- Oil pooling up in spark plug holes
- Stratus keyless entry remote question
- Drop?
- 02 Stratus R/T Suspension compatibility
- Peeling paint?
- Spark plugs
- just wondering
- '99 Stratus to '97 Sebring Rag-Top Engine Swap?
- Stratus spoiler
- Rough Idle, P0352 Code 2k Stratus 2L
- A few 2000 Stratus 2.0L questions...
- timing belt for '99 stratus 2.4L
- 99 DODGE STRATUS SUDDENLY STOPPED AND WILL NOT RESTART
- having ignition problems
- Tranny Swap...
- Stratus 98 2.0 lts rough idle
- 2003 Stratus RT Sound System Question
- 03 Stratus Rough Idle?
- Intermittent brakes question
- Engine leak problems with Plymouth Breeze (same as Dodge Stratus)
- 1999 Stratus ES - newbie question
- 2001 Strarus R/T fan relay
- won't stay running
- 2003 Dodge Stratus RT
- 99 Dodge Stratus ES V-6 : Mod help
- Serpentine Belt 97 Stratus
- 2001 Stratus Humming Noise
- Stock speakers for 7 Speaker infinity system
- power steering
- CarFax Check...
- Power steering belt tension 95 Stratus 2.4
- I have a brake problem
- `01 Stratus HeadLight Assembly
- Changed Battery, now NO radio!!
- Dodge Stratus 2001 V6 2.7 Heater problem
- 3.0 Liter Specs...
- carbon fiber
- 01 Dodge Stratus R/T headlamps
- Stratus Brake Life
- Selling My R/T
- exhaust
- New CF Hood
- Car and truck of the month, vote now!!
- Digital Instrumentation - Whats on the lower left?
- dash help
- venom 400
- 2000 status rough running and dies
- stratus running problem
- 2001 R/T - Eclipse performance parts...
- brake pads
- PT cruiser 2.4L turbo engine swap
- Emblems...
- How Many Miles On Your Stratus???
- cant find my oil filter!
- 01 R/T Coupe timing belt location
- 2000 stratus 2.4l question
- Stratus'03, with some electrical systems dead. Please help!!
- No sound from rear-left speaker
- oil pressure light
- Stratus RT 02 Front Bumper
- Two more questions about my 01 R/T
- Center Dash Clock out
- rattling noise on 2000 stratus
- 2004 stratus speaker question
- car hesitating during acceleration
- Shifter question
- 2001 Stratus Transmission leak and Overheating?
- Why do my lights start flashing when I unlock & open my door?
- Do I have ABS?
- '04 stratus r/t RKE
- '01 R/T overdrive? or RPMs
- Stuck in PARK, HELP!!
- R/T Owners: Question about fob (remote)
- 96 dodge stratus
- instrument panel?
- 04 stratus r/tcoupe body kit
- Passenger door not unlocking with double key turn?
- exhaut manifold
- Cold Air Intake Question
- 2001 R/T Bad paint!
- Parking Light Wire Location
- engine whine
- engine whine
- My 2004 SXT 2.7L experience so far
- 2.7 problems only up to 2002 ???
- Selling my 04 Stratus
- Squeaky struts or steering component?
- Half Shaft Mod
- dodge stratus r/t cooling fan not running properly.
- Sylvania SilverStar headlights dimming?
- light help
- crank pulley removal 2.4
- does any one know?
- Hi, I am new here, have a question
- instrument cluster removal
- wiper removal
- 98 Stratus leaks alot of oil... any idea where from? cylinder head?
- Window Washer Pump 2002
- 2004 Dodge Stratus SE
- SRT Rims
- Headlight bulb replacement
- NO HEAT!
- Help Please!! P0141
- No sound from front door speakers
- What do you think...
- cylinder numbers
- '01 R/T Questions..
- No wipers or turn signals, what to replace?
- Exhaust manifold to downpipe
- 2.7 to 3.2 or 3.5 swap/engine differences?
- 2005 Dodge Stratus SXT Sedan
- Squeelllingg Tires (not the good squeeeel)
- coolant bleed valve?
- cold air
- I Broke My Power Locks!!
- Strange Problems with My 98 ES
- 97 2.4L rough idle
- sister got in a wreck...
- tranny
- Stratus Do It Yourself information
- 2002 stratus leaking transmission fluid
- 2000 dodge stratus running lights problem
- thermostat
- Filling gas tank
- New Member....What am I getting into?
- How Durable is a 2.7 ?
- 03 SXT headlights
- Half Shaft replacement
- 98 with 2.4 litre motor - DO I NEED TO CHANGE THE TIMING BELT?
- 2004 Stratus Speed
- 2002 Dodge Stratus humming from the front
- Lack of temperature control.
- Brakes, Something wrong?
- 2002 Dodge Stratus SE Coupe for sale
- Help on first upgrades
- 2000 Dodge Stratus engine tranny problems
- Steering wheel sticks when turning left
- Lada-Zhiguli or Niva
- Transmission failure at 46,000 mi?
- TIMING BELT
- Looking for R/T EGR Vacuum Solenoid
- what is this vacuum box below driver side headlight?
- Thinking of getting a Stratus
- Body Questions
- 96 Stratus Blows cold air
- incorect RPM reading
- help please!! won't start????????????
- Timing Belt Change - When
- Burnt Electrical Smell
- Borla Exhaust...Please Look!
- Stratus SE Engine Swap
- 95 dodge stratus 4 door sedan help
- Will these rims fit?
- 2001 Stratus r/t compass temp display mirrors
- Where does the oil come from?
- New Pics Finally...
- Speed Limiter?
- Wheel and Tire Options?
- Update on Stratus bucking after fuel up
- cigarette lighter dead...no fuse???
- 01 Stratus won't start, dash lights and radio dont light up
- Squeaking in steering on L side; '02 with 70Kmiles Help!
- 2002 resistor please help
- Growling
- rear suspension 2002 dodge stratus sxt shocks or stuts?
- 3.0L engine coolant...
- 2001 Stratus R/T Alternator problems
- heat and oil light issues
- Weird stalling problem
- 2001 Dodge Stratus RT - AIS Motor
- finding what cam on the car
- 04 headlight replacement
- Touble code question
- Coilovers...
- How much power can you get from the 3.0?
- Wheel Info
- Stratus Sedan SE 2.4L
- front end squeeking
- looking to get an 04 sxt coupe...
- Some help please!
- 02 R/T amp wire
- Forced Interior Face lift..
- power steering tensioner removal
- selling my new apexi safc2
- Air horns
- how much abuse?
- WHERE IS THE CRANK POSITION SENSOR??!!!
- Intake Mod Question
- Door Noises on my 98
- Tach ODO and Gages dead after installing aftermarket Stereo
- opinion on wheels
- engine problem
- HAS ANYONE DONE THIS?
- Violent shaking... please help!
- O2 sensors and replacement
- 1999 Stratus NO START - Electrical
- ATF leak
- 18" rims or lowering springs?
- 2000 Stratus Power window issue...Help Please!!!
- eclipse spoiler on '02 r/t
- Engine Swap Help
- annoying sound coming from front tire area
- changing front wheel bearing
- headlight bulb replacement '02 Stratus
- anybody know about this
- Alarm
- HID Kit for a 03 RT
