View Full Version : 2nd Gen Neon
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Ticking sound at idle..
  2. Need some help please
  3. 2005 Dodge Neon SXT Rear Suspension Part ID
  4. injectors and RRFPR
  5. crank but wont turn over?
  6. raising the car back up
  7. squealin' neon
  8. R/T Exhaust
  9. sooo... i been thinkin....
  10. Road Trip Issue...
  11. Dodge commercial
  12. 2000 Neon - Stutters when idling
  13. The Official Myspace Thread
  14. 2001 es/se difference??
  15. mopar lip kit
  16. ideas on a stalling problem?
  17. I AM PARTING OUT MY CAR..2003 SXT (neon)
  18. Heater/ac/defroster not blowing
  19. Turbo Neon
  20. Ignition Trouble???? Please Help!!!
  21. 2005 Neon turning left harder than turning right?
  22. what size are the stock rear speakers??
  23. How fast is your car???
  24. A must see neon show
  25. Speedometer and Tachometer went backwards
  26. a few 2001 neon questions
  27. Should i get a new car?????? advice please
  28. need help
  29. Whistling Belt??
  30. Shift Knob
  31. Double Tap Feedback On Brake Pedal
  32. looking for parts 00 an up
  33. Clockspring Problems
  34. 2000 Neon sticks in park - cruise
  35. looking for a lip kit for 03 sxt
  36. Need parts from a 2003 neon sxt
  37. Headlight Wiring Capability/Capacity
  38. serpentine belt pulley
  39. Where did all the coolant go story
  40. 2003 dodge neon r/t performance part help
  41. Broken reservoir top
  42. it is mine!!! all mine!!!!
  43. "Door" Indicator problem
  44. Code P0750 Shift solenoid
  45. help
  46. My winter wheels are here!
  47. What other cars do you drive?
  48. Car shuts off during idle
  49. any 2nd gen tennessee owners here?
  50. Speedometer Problem
  51. Oil Pressure Warning Light
  52. Exhaust.
  53. Wiring scematics, removal and installation, specs, and Locationing.
  54. New user please help asap!!!
  55. What battery do you guys recommend?
  56. 4-1 race header
  57. Should I trade my 2004 for a 2005?
  58. what type of engine coolant.
  59. Control Arm replacement - I need help!
  60. Lets have a poll...does your neon tick?
  61. No heat from heater!
  62. Short Throw Shifter
  63. Test Pipe Resonator
  64. Does this mean I completed a drive cycle?
  65. the new plans i have
  66. 2005 dodge neon 02 sensor
  67. CD changer help
  68. Throttle position sensor issues?
  69. Well Time to sell my baby....
  70. spark plugs
  71. '03 Neon Fuse Interior Fuse Panel Diagram
  72. Sweet smell inside cabin, but no steam on windshield?
  73. tires
  74. Body Side mouldings
  75. inside lights out...
  76. Heart tail lights for sale
  77. lower control arm makin funny noise since wreck
  78. 01 NEON RT (questions)
  79. 01 NEON RT (questions)
  80. i need help please
  81. Rack and Pinion
  82. Cruise Control help
  83. Evap Emmission Control errors on a 2003
  84. Thinking about getting Suspension Techniques Swaybar Set from MP.
  85. Cruise Control Problems
  86. 04 Oil Pressure Hookup
  87. Alarm Lights
  88. problems with 2005 dodge neon SXT
  89. Exhaust question
  90. Help
  91. SRT Bottom Door Trim
  92. vibrates and scary noises coming from the front
  93. 01 mopar lip kit (pics)
  94. tailights
  95. 2005 Neon Trans Cooler Lines Leak
  96. No Heat!!!
  97. Anyone in southern Cali
  98. turbo on SE
  99. 05 STX Knocks, Thumps, and Squeaks
  100. 05 STX Thumps, Knocks, Squeaks?????
  101. Replacing a blower motor ASAP
  102. 2000 Neon Auto trans problem.
  103. AC / Heater Question
  104. 1st gen owner looking at a 2nd gen
  105. 2.0l Motor mounts
  106. Shopping cart / Subie Neon?
  107. Junkyard Fun
  108. New job!!!!!!!!
  109. Popping Noises
  110. Please help,kirk header problems
  111. Srt4 rims on neon 2001
  112. stuff for sale
  113. injector help
  114. hey peoples whats up(N3zeroN
  115. Change to High Mileage Oil, do it or not?
  116. 2003 srt 4 struts ...for sale
  117. Any suggestions for P0441 code?
  118. whats better.. cold air intake or short rams?
  119. Suspension
  120. High-Output Alternator
  121. Eyelids, Will they fit?
  122. 2004 Dodge Neon SXT Question
  123. Anyone ever had this problem?
  124. Need to replace idler pulley
  125. Struts.
  126. What to Clean Seats With?
  127. sway bar bracket mounts....
  128. BRAKE indicator light comes on when starting in 1st gear.
  129. Port matching throttle body with intake manifold
  130. A Sad day for me today....
  131. Do you wave at fellow Neon drivers?
  132. A Little Help Please...
  133. need help
  134. san joaquin valley mopar show / cali meet (56k atomic bomb)
  135. What size for pics
  136. Engine taking a long time to turn over + p0440 and p0441
  137. pproblems with brakes
  138. Srtgtr34's Audio & lighting Thread
  139. Need to install power steering pump and Belt
  140. Getting New Tires...Why Not Some Rims?!?
  141. check out my album/looking for power
  142. Help?
  143. 2004 sxt neon
  144. help with exhaust's
  145. needing parts
  146. looking to get best sway bar kit.
  147. Halo fogs
  148. looking for the brightest and best quality H1's
  149. Im back...
  150. need info on gaskets...
  151. Installing An Aftermarket Car Head Unit
  152. hey guys !!!
  153. ebay motor mounts???
  154. Ford coming out with Speed and Stereo Volume Limiter
  155. Fuel Economy The Thread to End all other MPG threads
  156. eyelids
  157. New Headlamps
  158. Research on sound system
  159. N3on
  160. How do you guys measure your MPG?
  161. A night to remember
  162. This just brought a smile to my face
  163. Looking into a 2nd gen neon. help
  164. HELP!!! need new engine
  165. 2000 chevy venture
  166. 03 sx 2.0 starting problem
  167. fuse question
  168. New Cylinder Head Bolts - 2001 Neon ?
  169. 2001 2.0 Neon SOHC timing belt tensioner
  170. Camshaft and cranksaft sensor replacement 2005 neon
  171. TSB Question- PCM Reflash
  172. side skirt
  173. Jegs Master Engine Competion
  174. 00 light conversion to 03?
  175. Rainforest in my 2005 Neon
  176. Free 2004 Repair Manuals
  177. exhaust sound
  178. Neon started skipping very bad!
  179. The Random Noise
  180. Headlights and Tired
  181. Looks like we may be losing another member!
  182. Sentry key problems??? Please help!!
  183. Inner Tie Rods
  184. Any Murdered Neons On Here?
  185. lowered pics
  186. Passenger Window Problem
  187. One Last PhotoShoot Before Winter
  188. Dust Covers for new struts
  189. Winter Projects(2nd Gen Only)
  190. Is this 2 much for Rims?
  191. studdering like crazy
  192. Oil Weight
  193. Ac evaporator removal?????
  194. Bought a Neon with some problems looking for some help!!
  195. Spped sensor in an 05 SXT Automatic
  196. Need Help On Upgrading My Headlights
  197. Gas cap
  198. ? about key fob for 2000 Neon SE
  199. Any one know if a stock srt-4 main
  200. Can't find my 01's problem listed...
  201. Water leaks on an '02
  202. Wtb: 15' tires any size used or new..asap
  203. Performance
  204. What is this on the spark plug tubes?
  205. Where to buy EGR Valve?
  206. Need help..losing ac pressure wtf
  207. SRT-4 engine in my SXT?
  208. 2000 Neon engine question
  209. Carbon Fiber Hood
  210. Motor Mount/Creeking Question
  211. Sunroof Leaking
  212. Drain Oil for Oil Change?
  213. is there any way to...?
  214. Synthetic motor oils
  215. LOOK for this hose!!!!
  216. Need Help w/ sanding
  217. Y'all better vote for me!
  218. These or those.which is better.
  219. highbeams
  220. Gauge pods and gauges????
  221. So what should i do?
  222. Best ECU's??Help
  223. 2.4?
  224. body kit- need an answer fast
  225. Fog light help!!
  226. Wheel help
  227. will these rims fit???
  228. Rex Motor Mounts Inserts
  229. UDP help again!
  230. Car Vibration
  231. Neon rear brakes
  232. Anybody?
  233. Neon sxt vs honda vtex who wins find out
  234. SXT Wheel Hub help
  235. Maybe my MPX Long Tube Stainless Steel Header for sale
  236. ABS Brakes on SXT
  237. few things for sale
  238. 1st gen struts on 2nd gen?
  239. K&N
  240. tried to wet sand...help..lol.
  241. Shop Manual for 2001 Neon ?
  242. 2001 2.0 SOHC vs 1997
  243. Srt4 owners!!
  244. 05 Dodge SXT
  245. anyone who repairs Neons...HELP!!
  246. 2001 Neon Error code: Downstream not matched
  247. Strange noise in the cab....
  248. 2001 Neon with Issues HELP!!!!!!
  249. How much do you drive
  250. TYC brand taillights?
