View Full Version : 2nd Gen Neon
- where is the timing belt located on a 2004 dodge neon?
- Help with door ajar/headlights on/Key on chime.
- Popping/ clunk when turning left
- 04 dodge neon
- 2005 Neon 2.0L SOHC torque specs
- Engine Knock (Again)
- 2004 dodge neon engine noise
- engine is louder than before during acceleration
- [HOW TO] 04 Dodge Neon 2.0L VIN C - Cylinder Head (Installation)
- [HOW TO] 04 Dodge Neon 2.0L VIN C - Cylinder Head (Removal)
- Camshaft position sensor replacement and camshaft position magnet
- Timing Belt
- Coolant Diagram Question
- ATX compatibility
- air filter questions / emissions
- AC and power plug issue
- SRT-4 Car Show this November
- ATX, only 1st and R
- my 00 neon pulls at 2k rpm
- short throw
- I need Help. =(((((((((
- No reverse
- Going on a long trip
- Transmission Mount.. Help
- Neutral safety switch,,,I don,t think so
- Score !!!!!!
- Help my neon just died on me...
- 04 auto neon trans, rebuild kits and part number Question's
- 05 neon. engine diesels?
- K&N Filter?
- non ac model .installing ac
- Please Help me with P0340 need advise
- scoop "air dam" & grill questions
- Need an estimate, or second opinion,please!
- 2001 Dodge Neon body kit
- 01 model sat in grannys garage 5 years
- Timing belt tensioner?
- p0073 cel light problem
- Motor Mounts
- Carpet removal
- VSS---the engine killer
- Rough Idle while stopped SXT
- 2000 SE 5 speed
- 03 SXT to 01 SE body swap questions
- A/c still not working
- 2004 tranny problems, what do you think?
- 02 Neon SOHC eats LDP every two weeks
- Rust!!
- short ram intake
- Engine will NOT start!
- 2005 neon heater core replacement
- 05 SXT problems
- 6 Disc CD Changer error.
- Idea?
- 2004 dodge neon transmission HELP!!!!
- I think my engine is on it's last leg.
- cruise control
- 2003 dodge neon air filter box+hardware
- Cluster LEDs
- Question...
- Cam shaft for a SOHC?
- 2004 p0038 and p0141
- A/C giving me issues! Any help is appreciated
- Will this transmission mount fit ?
- Compressor Toggle Switch?
- Neon died
- replaced brakes and rotors
- trouble codes p0304, p0344,p2097 2005 neon
- Leaking
- Stereo install
- 2001 Neon Rough Idle
- 2003 Manual shift knob just moves back and forth
- A couple problems
- A couple problems
- A/C Question
- 2001 Dodge Neon Error Codes
- 2001 neon violently shakes with auto trans
- Code "P0456"
- What's wrong with my trunk?
- Bent Pulley
- Timing belt cover - where to get one?
- 2000 Dodge Neon 2.0L won't start, Help?
- 98 Neon Purchase next weekend maybe?
- SRT-4 Cluster
- Use key of same model
- How To Install Rear Speakers?
- Motor mounts (torque struts) - Just replaced both, still grinding
- Wont start help
- Power steering leak and clunk
- 2005 Dodge Neon SXT exhaust questions
- After minor fender bender
- 2003 neon sxt manual shifter cable question
- Transmission or maybe Electrical issue
- 03 Neon sxt Codes P0016, P0300, P0315, P0339
- Cluster Sweep
- Ugh! Why Is My New Head Gasket Leaking??
- alarm and door light problems
- Car losing power
- Seat problems
- Intermitent transmission shifting problem (p0700)
- Suspension ? Clunks
- What's up with my windshield?
- I seem to have lost a part on my car.
- neon trys to stall
- Adjust Windshield Wipers
- 8 or 4 gauge?
- 03 neon airconditionion question
- 00 neon stalling and backfires
- Old war vet fixes Neon for terminally ill wife.
- ABS and traction control lights?
- Error code P0204, 04 Neon SXT
- Help please! Neon keeps stalling
- Automatic transmission Jerk when changing gears
- Radiator/AC Question
- Short in Headlight Circuit
- Alternator Interchange
- 2005 Dodge Neon problem... stumped
- Performance parts
- 3 spd worth it?
- Lowering Question
- Need help identifying motor year for replacing blown motor
- Hopelessly Losttt
- Still showing a code...
- 2005 neon sxt noise drivers side
- Smog test
- Brake motive pads and rotors
- Please help on these codes
- Trans fluid: To change or not to change?
- Help Please, At A Total Loss...
- 2003 Neon battery drain
- need a front bumper for 2002 dodge neon
- 2003 Dodge Neon Oil Light flashes & beeps
- '00 rumbling at 25 & 45mph
- Evaporator
- Ground wire going to front strut?
- OK, what gives???
- 00 neon wiring problem
- body work
- Timing Belt/Water Pump Questions
- Exhaust Question on 2000 neon
- AutoStick on a neon; possible?
- 2 q's 1 about springs and the other about breaks
- Lower Control Arm Replacement Issue
- CEL codes fix
- Headed for the shredder
- Fog lights wiring
- shaking & sputtering
- Neon Runs for a little bit, dies, cools off, starts and runs, dies, etc etc
- o4 neon wont start after going into a ditch.
- 2002 dodge neon surging Idle
- 2005 Neon SXT transmission - no drive
- Stratus R/T springs and struts swap on a Neon ???
- Radiator Cooling Fan wont work
- 2002 Neon trouble starting and turning off
- 2000 nean shift n pull
- P1689 and 0171
- Help
- Rear door window help
- How To Change a Camshaft Position Sensor
- No Idle - Not rough - simply no idle (IAC?)
- Mysterious radio behavior
- Hard start when it's cold and is idiling/shaking rough....
- Rotors
- Help, Brakes applying while driving
- Rear seat belts in 2005 SX2.0/Neon
- Cruise Control Question
- Replace or flush coolant?
- Need some help with no start
- 03 neon
- Vavle train noise
- Whining noise at 30mph while on gas.
- 2001 dodge neon, smoking and backfiring during deacceleration
- 01 Neon es Front end noise
- Rough Idle when stopped at a red light
- Bad gas mileage
- Growl at all speeds
- Engine Knock
- 05 Neon SXT Project Car - Need your help.
- Key Question...
- pencil strut
- 2000 Dodge Neon wont shift into 3rd gear after the first five miles
- New sx owner seeking radiator advice
- 01 dodge neon fuse panel diagram/picture
- How to remove AC compressor?
- I know nothing about cars have question about a manual trans on a 03 neon before buy
- Spark Plug Wires
- A/C Problem :-/
- head gasket on my 03 sxt is gone!
- How are your front tires wearing?
- A couple of questions for a new Gen-2 Neon owner
- just bought 00 neon, I have a question about engine
- timing belt/ idle
- 2003 Neon SXT Help
- Another Problem. Need help asap
- 2003 Dodge Neon SX 2.0 Problem
- Repair Manual Timing Belt Procedure
- 2003 sxt auto shifting hard between gears but not consistant
- Need Help!
- Duraflex R34 Side Skirts?
- does anyone show their car.....
- 12 Hours to talk me about of this..
- Long trip planned
- I want to start working on my own car
- tach and speed odmeter problem please help???????
- speedodometer &tach on 2002 neon peged out please help?
- Dash lights / radio problem
- COMP 400 cams...valve springs?
- Please Help :/
- Pulstar?
- started tearing into the timing.
- 2005 Neon - Rough Idle, Whistling during acceleration
- Random Backfiring?
- 2004 Dodge Neon NXT?
- 2003 neon se to srt 4
- 2000 Dodge Neon Vacuum Lines
- No dash lights or tail lights
- timing belt jump/broke
- 01 Neon fouling spark plugs
- Dodge Neon SRT-4 Parts
- Need help!
- Issues on my 2001 neon R/T
- Oil Pressue Light ...
- Turbocharging?
- Various issues with my car
- Weird electrical(?) behavior(s)
- Transmission help!!!!
- Struts replacement time
- 2002 Neon stuck in 1st gear
- antifreeze smell in car
- Oil Leaking And White Smoke From Muffler HELP PLZ!!!!
- Engine light code: dirty CAT?
- Help!! Need my car back!
- 3 Speed Auto to 4 Speed Auto conversion
- Missing Belt
- Need electrical help asap please!!!!
- Power Steering gone
- Hose off Engine blows in exhaust
- Sluggish when starting off
- 2004 Dodge 2.0SX Emergency brake light
- need some helpfull input
- Rough Idle at Running Temperature
- PLEASE HELP! Car sputtering when idle, then revs up real fast...
- How do i change serp belts on my 02 neon
- wiper motor/switch?
- Starting problem!!!
- 05 SXT riding rough, squeaking when accelerating
- Heater Hard Lines
- just bought a 2001 neon and i need help with codes.
- P3044 basketcase cam\crank relearn?
- Blueish Smoke from under hood/over heating
