View Full Version : 1st Gen Ram Tech
- timing gears
- No pulse to coil?
- New user cam question
- Crazy Eruption of Radiator Fluid??
- No spark?
- Unique Transmission Question (Yes, I did search all posts)
- 87 D150. Steering column swap and fried wires.
- cam talk
- Rear brake problems
- Stranded Please Help! (Fuel issue)
- universal 2bbl 318 carb problems??
- 74 Slant 6 rear end
- Wanting to put Lift kit, mud tires and smoke stacks on 1991 Dodge Ram D350 dually
- Would like to know what came originally on 1986 1/2 ton Royale version
- 1984 Dodge power ram help
- My detailed "HOW-TO" Smog Pump Removal Project
- 85 ram questions...
- Durango Sp360
- stalling issues 90 w150 318
- lokking at buying a 93 w250 cummins
- Chevy Carb on my dodge truck?? y?
- Help please!!!
- Tachless Gauge cluster....why not add a tach
- A-518 or 46RH transmission
- Dana 60 Front Wheel Bearing Removal
- help with timing 93 dodge with 318
- Power steering noise
- Please help!!!!!!!!!!!
- A Newbie to Dodge/Mopar
- parts id
- Engine Oil Light Does not Light Up When Key is Turned
- 1988 power ram
- Transmission Slips?
- Air cleaner Decals
- FT 727 to A 518 (46RH) swap questions
- '85 w150 flex plate issues HELP!!!
- taillight wiring diagram
- What model truck is this? VIN included.
- Polished Throttle body?
- IAC motor symptoms.
- Hvac unit
- tranny
- Temperature Light Does Not Come On
- Need to locate Engine I.D. for 1984ish 318
- won't stay running unless...
- 76 dodge fuel issue??
- Thermostat Housing Manifold Threads Stripped
- Help please? Replace parking brake cable
- 86 or 87 W100 fuel problem
- covering dash
- 85 power ram w150
- 1993 3/4 ton off road?
- upper/lower ball joint problems
- 46RH 4 speed/A518
- leaf spring rebuild
- 1st gen 318 runs terrible after head gaskets
- '88 W250 Died-No spark
- Alignment or something else...??
- 4 speed guys...
- happy new year !!
- Free Chilton library online!
- 360 down and out...motor options?
- Re-wiring Ram Charger
- '87 starter
- set clock in a 93' ?
- Disc brake swap on 73
- 87 W150 Worth,bed question
- Trans Videos
- '91 D150 Injectors
- rear brakes
- Engine mounts, vibration, 1989 W250
- Alright carb gurus, help me out here.
- Engine control modules questions 1991
- upper end click
- I have an 87 dodge w250
- Power wagon question
- w150 lift kit problems
- No Oil on dipsick
- A998/A999 differences?
- 93 w150 parts for 91 w250
- New member-mom trying to help son
- 1988 5.2L issue..need advice
- Truck Bed Bolts
- 1986 d150 carb problem?
- No fire!
- Stroking a 318
- spedometer issus 86 d100
- Dualing 85 rams
- Adding TBI to a carbureted 360
- what year question
- Took me long enough - Pics of Truck
- When is it time for a trans cooler?
- Transmission
- 1st Gen Ram Pressure pump leak
- 92 Power Ram 1500- Transmission problem?
- 727 transmission
- 1991 W150 rear end clunk???
- Unstable Revs
- Timing Problems w/ My '92
- Do not deal with these people
- NP435 4spd do I need new mainshaft?
- 92 Dodge w150 stalling, possible fix
- rain guard for w150
- Idle Speed Control Motor Question
- leaf spring sliders
- Freeze plug leaks
- Step Bed Question
- Engine ?'s
- 85 D350 to a W350
- Throttle cable loose
- A518 adaptability output shafts ?
- 1gen heater core not warming up
- Anyone have an idea?
- Ball joint torque specs?
- Windshield wipers do not work
- 1/2, 3/4, 1 ton differences?
- Time for a motor change
- Quick Question...How do you remove the trip odometer button?
- 79 engine options
- 1/2 ton to 3/4 ton suspension swap?
- Grinding for a lift?
- 1991 Ram 4x4
- Removal of Emmissions Control Devices Question for Older Trucks
- 1985 Ram electrical issues
- positive cable
- intake manifold/egr
- B250 springs on a D250???
- Brake Problems, tried everything, now what?
- 1986 Dodge W150 4wd Will not engage in reverse
- 87 wiring diagram
- Code 13
- Steel?
- New guy needing 1977 w100 help
- how to fix idle?
- '75 W200 won't idle
- Speedometer Violently Bouncing From 45 - 85 MPH
- picks of my 87 w150
- 86 ram wirinbg problems??
- Replacing Carter TQ with Edelbrock 1406 - 318 Engine
- Coil Connection Question?
- Lights do not work
- 1992 Ram Wiring Diagrams
- 1987 w150 318 rods warped
- a lot of vacuum and very high idle
- D50 diesel poppind
- Floor Pan Question
- Need help!!!!!
- 4x4 trans help???
- 360 Advanced Auto = ATK?
- 87 d100 dash guages all screwy help please
- Oil dipstick 1988 Dodge Ram D100 w/ 318 engine
- Why Did The Engine Stall?
- Leaf spring hanger - which one?
- 5.7 HEMI vs. 408 stroker vs. 440 Magnum
- Hello, I'm A New Member
- 1987 dodge w150 ignition switch
- Carburetor Fuel Leak - Carter Thermo-Quad
- 91 W150 Gearing?
- frame differences
- strange squeaking
- what heads do i have
- Multiple Dash Lights Not Working
- 1987 D150 wiring diagram?
- 78' d-100 will not idle
- 360 TB on a 318
- 1987 doge w150 sputtering after turning off
- Overheating issue...
- flickering/pulsating lights??
- 1984 D-100 318 Engine Block Coolant Drain Plug
- Summit Shifter '86 Ram /6
- Transmission Problems on 96 Ram
- shift kit
- 90 Ram Project
- 92 W150 starting in 3rd when you take off in drive???
- Fuel hose confusion
- Wierd problems.....
- Gas Tank Swap
- How Many Miles Has Your Truck Survived
- rebuildin my 318...suprsies inside
- EGR: Is it necessary?
- Nice but pricey?
- crank bad?
- 91 Dodge Power Wagon-tranny swap?
- Transfer case suggestions
- remember my crank walk?
- Help: Dumb Alt/wpump question!
- 1993 Dodge runs rough after warm-up
- Driver side floor pan
- Engine identification question.
- 1981 Ram slow to start
- lift
- 318 engine wiring
- 88 Ram w/ 318 - dip stick hitting crankshaft
- Rearend info.
- Cummins 3.9 Diesel Swap
- delayed start
- Ramcharger parts swap into 74 D100
- 1991 ram big block project
- Online Parts Database
- 1st Gen Forum?
- Alternator
- 1996 Ram 5.9 overheating
- Automatic to manual
- Exhaust Advice Needed
- Tow question on a 2001 1500 quad cab
- fuel injectors ??
- New to me 1985 W150
- $11 750 edelbrock
- plenum gasket
- 88 RAM D100 - Battery dies when off.
- Torque rear engine mount
- Tire pressure
- Cab Water Leak 1995 DodgeRam3500
- Coolant Sensor - how to troubleshoot....
- R.I.P. Torque Converter
- D150 full lowering kit diy
- 88 Ram D100 - Trouble reinstalling Brake Master Cylinder
- carburetor Question
- code 26 ?
- trans wires HELP!
- Subs
- 86 W350 won't stay running when hot??
- Suggestions Engine Swap
- Timing
- Need help with new project truck!
- data plate decipher,85 dodge d350
- Anyone have stock suspention parts 78-93?
- Yet another problem
- Hate the bench seat
- 91 idle problem
- oem fender well trim
- MSD Coil installed
- on board air
- 318 2bj timing 1986
- is this right
- eng & trans swap 88 to 84
- 1983 150 Custom Power Ram slant 6 help
- 318 to 360
- big block or not
- Rear dana 60 nightmare *long*
- fuel injection to carb
- Skyjacker D100CDKS-N 1 inch lift...
- Aftermarket Torque converter
- cowl cracks??
- Nothing lasts any more
- Help: No brake lights
- selling
- Getting Backfire through carb please help
- Cranks but doesnt fire?
