View Full Version : 1st Gen Ram Tech
- When is it time for a trans cooler?
- Transmission
- 1st Gen Ram Pressure pump leak
- 92 Power Ram 1500- Transmission problem?
- 727 transmission
- 1991 W150 rear end clunk???
- Unstable Revs
- Timing Problems w/ My '92
- Do not deal with these people
- NP435 4spd do I need new mainshaft?
- 92 Dodge w150 stalling, possible fix
- rain guard for w150
- Idle Speed Control Motor Question
- leaf spring sliders
- Freeze plug leaks
- Step Bed Question
- Engine ?'s
- 85 D350 to a W350
- Throttle cable loose
- A518 adaptability output shafts ?
- 1gen heater core not warming up
- Anyone have an idea?
- Ball joint torque specs?
- Windshield wipers do not work
- 1/2, 3/4, 1 ton differences?
- Time for a motor change
- Quick Question...How do you remove the trip odometer button?
- 79 engine options
- 1/2 ton to 3/4 ton suspension swap?
- Grinding for a lift?
- 1991 Ram 4x4
- Removal of Emmissions Control Devices Question for Older Trucks
- 1985 Ram electrical issues
- positive cable
- intake manifold/egr
- B250 springs on a D250???
- Brake Problems, tried everything, now what?
- 1986 Dodge W150 4wd Will not engage in reverse
- 87 wiring diagram
- Code 13
- Steel?
- New guy needing 1977 w100 help
- how to fix idle?
- '75 W200 won't idle
- Speedometer Violently Bouncing From 45 - 85 MPH
- picks of my 87 w150
- 86 ram wirinbg problems??
- Replacing Carter TQ with Edelbrock 1406 - 318 Engine
- Coil Connection Question?
- Lights do not work
- 1992 Ram Wiring Diagrams
- 1987 w150 318 rods warped
- a lot of vacuum and very high idle
- D50 diesel poppind
- Floor Pan Question
- Need help!!!!!
- 4x4 trans help???
- 360 Advanced Auto = ATK?
- 87 d100 dash guages all screwy help please
- Oil dipstick 1988 Dodge Ram D100 w/ 318 engine
- Why Did The Engine Stall?
- Leaf spring hanger - which one?
- 5.7 HEMI vs. 408 stroker vs. 440 Magnum
- Hello, I'm A New Member
- 1987 dodge w150 ignition switch
- Carburetor Fuel Leak - Carter Thermo-Quad
- 91 W150 Gearing?
- frame differences
- strange squeaking
- what heads do i have
- Multiple Dash Lights Not Working
- 1987 D150 wiring diagram?
- 78' d-100 will not idle
- 360 TB on a 318
- 1987 doge w150 sputtering after turning off
- Overheating issue...
- flickering/pulsating lights??
- 1984 D-100 318 Engine Block Coolant Drain Plug
- Summit Shifter '86 Ram /6
- Transmission Problems on 96 Ram
- shift kit
- 90 Ram Project
- 92 W150 starting in 3rd when you take off in drive???
- Fuel hose confusion
- Wierd problems.....
- Gas Tank Swap
- How Many Miles Has Your Truck Survived
- rebuildin my 318...suprsies inside
- EGR: Is it necessary?
- Nice but pricey?
- crank bad?
- 91 Dodge Power Wagon-tranny swap?
- Transfer case suggestions
- remember my crank walk?
- Help: Dumb Alt/wpump question!
- 1993 Dodge runs rough after warm-up
- Driver side floor pan
- Engine identification question.
- 1981 Ram slow to start
- lift
- 318 engine wiring
- 88 Ram w/ 318 - dip stick hitting crankshaft
- Rearend info.
- Cummins 3.9 Diesel Swap
- delayed start
- Ramcharger parts swap into 74 D100
- 1991 ram big block project
- Online Parts Database
- 1st Gen Forum?
- Alternator
- 1996 Ram 5.9 overheating
- Automatic to manual
- Exhaust Advice Needed
- Tow question on a 2001 1500 quad cab
- fuel injectors ??
- New to me 1985 W150
- $11 750 edelbrock
- plenum gasket
- 88 RAM D100 - Battery dies when off.
- Torque rear engine mount
- Tire pressure
- Cab Water Leak 1995 DodgeRam3500
- Coolant Sensor - how to troubleshoot....
- R.I.P. Torque Converter
- D150 full lowering kit diy
- 88 Ram D100 - Trouble reinstalling Brake Master Cylinder
- carburetor Question
- code 26 ?
- trans wires HELP!
- Subs
- 86 W350 won't stay running when hot??
- Suggestions Engine Swap
- Timing
- Need help with new project truck!
- data plate decipher,85 dodge d350
- Anyone have stock suspention parts 78-93?
- Yet another problem
- Hate the bench seat
- 91 idle problem
- oem fender well trim
- MSD Coil installed
- on board air
- 318 2bj timing 1986
- is this right
- eng & trans swap 88 to 84
- 1983 150 Custom Power Ram slant 6 help
- 318 to 360
- big block or not
- Rear dana 60 nightmare *long*
- fuel injection to carb
- Skyjacker D100CDKS-N 1 inch lift...
- Aftermarket Torque converter
- cowl cracks??
- Nothing lasts any more
- Help: No brake lights
- selling
- Getting Backfire through carb please help
- Cranks but doesnt fire?
- WANTED 74 D100 Step Side Parts
- 51 code
- Farm find - need help!
- magnum swap
- fuel problem 1986 360 4BBL
- Just bought an 82 D-150 and it has a stuttering issue
- help
- New ECM - New Problems
- need advice
- 2" Lift on '91 D150
- Door Issue
- DIY/ External voltage regulator conversion
- fuel pressure ??
- Posi
- rear spring hanger help !!!
- rear bumper tow rating 1985 d150
- no charge !! 84 d-250
- What are these wires??
- Overdrive?
- eng maint light what is it
- Convert to power windows
- Front Axle Identification? D250
- 93 and Older Parts Catalog??????? WTH
- 88 4x4 318 rebuild kit
- 1991 W150 4wd switch
- throttle body
- Mileage: TBI vs 2bbl
- 318 Carb Question
- How to paint "Dodge Ram"
- 93 D250 multi-function switch ??
- Lowering the rear
- 1985 dodge rear end problem
- Fuse panel diagram
- wanted!! 1990 ram club cab glass needed!!!
- 70's bumper/hood on 86
- 1973 D-100 4X4 restoration
- pcm problem?
- paint codes
- Screw you, smog pump!
- Mech Gauge Leak
- Starting problem
- idle question
- Truck jerks when I stop and take off
- Need help finding some seals
- captain chairs
- the stroker itch
- Really need help!
- 1979 Dodge Class C RV
- Steering Box - rebuild, replace, or remedy?
- rebuild or replace 318
- 4wd swap
- could this cause a knock in my 318
- A/C fix-maybe... Advice wanted
- 87 d100 383 swap
- Newbie here needs some help
- ac work
- Terribly loose steering
- dodge w100 custom '84
- D150 Computer
- 80's D150
- 86/88 Frankenram starter woes
- O/d switch ??
- gauge bezel options
- Diesel swap questions
- Front Mount Hitch
- 96 mag in a 90.
- 93 dodge 350 engine/trans bucking problem
- Dual Batteries?
- talk about old dodges 71-80
- 1974 dodge d100 lwb bounces like a roller coaster...help
- 85 d150 newbie help
- That classic nasty old farm truck tire
- 77 dodge truck
- WTB gas tank
- engine swap
- 1984 dodge w150 137k $1500 for sale
- The Big Fish That Got Away...
- Looking for help with my old dodge d100
- 1984 dodge w150 headlights not working
- '87 Ram 50 Wont Pass Smog -- Results Attached
- 91' Dodge D150 Question.
- '93 D150 No Start
- Interior options for my 81?
- Starting problem with an 87 D100, please help!
- What Transmissions and rear axle do i have here??
- 92 3.9l intake plenum gasket change?
- steering gear adjustment
- What year did they start using computers?
- electrical problems
- Twin Turbo 318
- thermostat
