View Full Version : 1st Gen Ram Tech
- throttle rod adjust
- 91 W150 Power Loss
- Coolant around top of radiator
- 92 w150 electrical issues
- 91 D150 Project by an idiot.
- 1993 d150 air conditioner clutch bypass?
- How to remove C-clips with posi 9.25 ?
- I thought my truck was on fire!
- Revisiting trans/engine swap
- 1989 power ram with wrong motor?
- never ruin this part
- Any high friction brake pads available for these trucks?
- A518, no O/D.
- Transmission Vacuum Modulator
- 318 Rebuild
- 318 sputters at tip-in.
- Ground up re wiring.
- Where to get OEM/Aftermarket parts?
- Whats it worth, Need to sell
- Wiper issue.
- 1984 W 150. 318 2 barrel.
- Lifted Truck - Blocks have to GO!
- need help identifying parts
- The Mystery of the Disappearing ATF +4.
- Hello! New 1st Gen Owner Here with some questions.
- Need some rust help.
- Anyone ever get offers to sell your truck?
- (Newbie) 1st Gen rust repair
- 86 w150 318 4x4 sterring cup problem
- Rear Brake Over-adjusting
- Having Brake Issues!!
- Lighting problems.
- What is this thingymabobber on my 727 tailshaft?
- Weird Clicking Sound. U-joints? Trans mount?
- transmission rebuild soon
- New Truck Guy Looking for Advice on 318 Rebuild
- 318 smoking problem
- Death Shake in Rear End!
- Coil spacer question
- Burning rich
- Front axle, part-time t-case
- Odd thing and place to steal....
- cant find a np241 speedo housing. help!
- Adding Cab Marker / Clearance lights?
- 86 Dodge Ram
- Sun Visors
- 1988 318 Engine problem
- Steering knuckle and hub/bearign assembly
- may paint truck
- axle help
- engine to frame ground
- Manual door lock linkage
- Camshaft help
- 83 w150 need help
- Whats this worth? Can anyone do me a small Favor?
- Police car alternator anyone?
- '88 Ramcharger thread
- rectangular headlight measurement on my 1991
- Supercharger kit for the NON Magnum 318?
- Should I change my diff fluid?
- Anyone done a headlight brightener? You know the relay thing....
- A nice story.....
- complete wiring diagram for my 1991 w150....
- I may get the 1979 Macho Power Wagon...and something else
- 1993 D150 Power Door Lock Actuator
- HELP! Questions / Concerns 87 LE 150
- Fuel pressues regulator vacuum
- Odometer
- Covering Rusted Wheel Arch with Fender Flares?
- Cruise control unit grinding noise
- Transmission
- 87 W100 4x4 starting issue
- "NEW" 250 Cummins - Please Help Me Learn!
- 1987 Power RAM w150
- Stutter..miss.then die
- Recall on Dodge RAM 1500??
- Donor Truck????
- Ticking when truck starts
- 1/2 ton to full one tun
- KC Light Mounting
- truck randomly dies?
- Lost Gauges?
- Bulkhead
- need some help with 88 d150
- Need Info on '76 W-100 Front Axle
- heater motor troubleshoot.
- 85 dodge brochure
- 1990 ram hemi swap
- weird noise from drive line/ wheels
- 91 ram 150 idles nice dies above half throttle
- 88 w100 not always shifting into 3rd gear
- Interchangable driveshafts?
- Rearend Swap
- how many 3.9's here
- 2nd gen seat swap
- Need a front grille for a ´77 D100 Step
- 1993 w350 parts
- Got a Bunch Accomplished Today
- 360 shuts off once warm
- cat converter question
- Replacing head gaskets?
- My Speedo doesn't work....1991 W150
- what is the best repair manual out there?
- Headlight Issues
- W150 Custom Adjustable Drag Link <$100
- 1950 Dodge b2d dually
- Steering box question
- Lowered D250
- V-6 engine swap
- 1988 318 engine wiring harness
- HELP PLEASE! Fuse issues 85 w150
- 1st Gen Show Us Your Ram Thread???
- Dodge b2d questions
- Hmmmm A little advice please!
- 88 W150 Cummins Project!
- Lower Body Trim Question
- Carburetor
- SMOG issue
- Steering questions
- need help slant 6 to a 318
- am i screwed? leaking head gasket?
- 5.9 Magnum rebuild with mods
- oil light ?
- Stumble/bog that is not the accelerator pump?
- 91 d150 4x4
- 318 erratic idle
- 84 dodge ram 250 318
- Valve covers
- '91 Dodge W150
- How do I find what transmission I have?
- 318 power need help!!!!
- 93Dodge W150 5.2 Engine sputter minor shake Help????
- 1st gen FAQ / Quick reference
- BBD carb & Vacuum Lines (83' 225/slant6)
- bracket problems
- Windshield Wiper Arm Removal?
- 93 ram 5.9 no start?? help
- 92 d150 not wanting to stay cranked up
- Stock wheel offset
- 1990 D150 lowering kit?
- Radio/Cluster Fuse 51 parasitic drain
- Need wiring diagram for power locks on 89 ram
- Wheel offset
- You Never Know What Youll Find
- timing/ knocking question
- 85 Prospector Stock Coil Springs
- Front windshield seal insert?
- Just picked up a 91 d150 on 20s
- Newly aquired 85
- Lean Burn system-rough idle
- 83 ram 2wd steering wheel off, tilt steering wheel
- Rough Idle at Cold Startup
- 93 5.9 gas engine problem
- emmission rollers test.. high co% running rich?
- Quick Reference Guide
- 87 d150 fuel tank
- Mirror type and size
- Bolt Patterns
- 1985 Dodge Prospector
- removable roof?
- power rebuild
- New floor pans
- Where is the voltage regulator
- 89 318 ramcharger timing advance
- bad head gasket?
- 92 d250 Will not start without boost jump
- Steering wheel upside down
- twin turbo Dodge 360?
- Just Joined and Thanks
- concealed hitch receiver
- New guy here
- 3rd gen seats
- help please out of ideas
- brake thunk
- front axle
- Cab side of wiring harness
- Strange noise. any ideas?
- Why is this thing still running rough?
- 90 dodge power ram 4 wheel drive won't engage
- clutches
- Gotta do a cab swap 77-85
- Questions about 1987 D150
- need body info!!!!!
- Hello!
- Truck won't start/electrical problems
- How much to fix the damage?
- Ticking in upper end of the engine. 87 d100 318
- Shift indicator
- Rumble Strip Noise
- Paint Codes - Help With interpretation
- 76 Dodge D150 4x4 club cab long bed
- Slight vibration
- 89 ram best way to fix rust for the money
- ecu replacement?
- Smog or no smog?
- need advice building a cheap 318
- Need help with parts please!
- Carb Questions
- fusible link? Heater fuse has no volts. Where to look?
- lifted leaf springs
- truck dies when you drive then automatically resumes power 1990 d150
- 92 D150 Fuel tank problems
- 1982 D150 Trans Inspection Northern VA
- '84 3/4T front axle into '86 RC
- Steering wheel
- Dual exhaust 89 ram w150, pipe routing, vacuum loss
- back pressure issue?
- Spark plug gap
- convert from power to manual steering
- Looking for shocks: 76 D200
- 1990 Ram D250 ignition cylinder
- violent vibration
- D250 1986 misc. questions
- "90 12v injector thread size?
- Looking for a set of 4 dodge hurricane rims, interested in other styles as well
- Rough start to a day...
- Do any of you?
- 318 stumbles when accelerating...but only when warmed up
- EFI in early 1st gen: Part II
- axles, misc parts etc
- Trim
- 1986 Ram D150 restoration project
- lost power going uphill
- 1985 Dodge truck parts
- Dies in Gear, 1987 Dodge W150 Holley 6280 2 Barrel Carb.
- 83 ram efi conversion
- rotor removal
- Need patch panels for 89 dodge ram fender above rear wheels, where to find them
- 83 d150 4wd conversion questions
- front driveshaft...85 w150
- 92 w-150 the saga continues
- 5.2 318 alternator
- Just bought 91 D150. DTC 12, 37 / RWAL DTC 9
- Borgeson steering shaft
- How to measure lift?
- First gen 5-speed.
- 4x4 transmissions
- 92 w-150 ECM sources
- tire size
- timing?????
- 318 headbolts
- Electrical Issues On Daily PLEASE HELP!!!
- '76 D200 starts then doesn't start
- headers
- Additives
- 1990 ram alternator problem
- Shaking at high speeds
- Spitting through carb and exhaust
- A/C questions 83 ram
