View Full Version : Dodge Stratus
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15
  1. Loud Humming Noise help
  2. New noise after replacing power steering rack and pump.
  3. 01 stratus 2.7l replacement
  4. rubbing and squeek on 1999 Dodge Stratus
  5. cigarette lighter / power outlet probs
  6. Spark Plugs?
  7. Where did these come from?
  8. from Russia with love:)))
  9. Car totalled!!
  10. Rear defrost, tinted.......
  11. Front left wheel click????
  12. 150,000 mile tranny?????
  13. Paint
  14. what is the inner and outer spline count
  15. 2004 R/T questions
  16. Performance chip
  17. radiator fans won't turn on
  18. stratus shutting off
  19. Replace spark plugs
  20. Spark plugs
  21. Hazy Headlight covers....
  22. Looking for a Cold Air Intake or Short Ram for your 2.4? Here ya go.
  23. Full Synthetic......
  24. 2000 Stratus Suspension.... Got any?
  25. noise after replacing timing belt
  26. what would u do????
  27. Secondary Air Injection System (Bank 1) ??
  28. Strange Transmission Noise in R/T. Bad or Normal?
  29. engine engine engine
  30. timing belt
  31. Engine Knock
  32. Tire Recommendations
  33. Front Wheel Bearing Replacement
  34. Getting 4 wheel disk brakes on a 03 SXT coupe
  35. '98 Stratus has been good
  36. Compass/Temp not working
  37. Probable electrical / computer issue with 4cyl 98 Stratus. Help??
  38. Anyone rebuilt there A608 (41TE)
  39. evap
  40. '00 Stratus, CRAP electrics
  41. radio problem
  42. Replacing 3.5" speakers on dashboard
  43. Replacing the clock spring
  44. Clunk?
  45. electrical problem?
  46. slipping P/S belt on 97 Strat
  47. 2001 dodge stratus not firing
  48. Power Steering Help!!!!
  49. DODGE STRATUS ALUMINUM WHEEL CENTER CAPS
  50. 02 R/T 3.0 ... 1 or 2 (o2 sensors) ?
  51. Need a little help, please
  52. 01 stratus R/T speaker help
  53. rattling noise
  54. my 2.4 dohc 98 stratus is not firing please help before i burn it to peices..
  55. 98 stratus 2.5L problem
  56. Stratus generations and service manuals
  57. steering column?
  58. Fuel injector connector removal PITA
  59. Anyone Else Have This Issue
  60. flowmaster delta flow 50
  61. Help???
  62. Need some help
  63. IS THERE A DIFFERENCE?
  64. Swap?
  65. Coupe vs Sedan Headlights
  66. COTM
  67. P0420 code now
  68. What size speakers and amp should i use???
  69. Will 20" rims fit on 98 stratus
  70. resistor blew AGAIN
  71. Floor mats
  72. newly installed hi/lo hid's also came with a big problem
  73. '99 Transmission Shift problem
  74. lock cylinder housing ?
  75. 1995 Stratus 2.4l Transmission Problem
  76. Location of Computer 1996 Stratus
  77. 96 stratus vibrating steering wheel
  78. 97 Stratus?
  79. Need Mass Air Flow Sensor
  80. Stratus 2.4 Starting Issues
  81. 2001 Dodge Stratus R/T transmission
  82. changing transmission solenoid ....
  83. axles
  84. Fuel pump priming
  85. FREE Stratus Repair Manual (JA - PDF format)
  86. Cruise Control on at Start-up
  87. make me fast!
  88. Programmers???
  89. starting problem
  90. Sqealing in Exhaust System of 02' when cranked
  91. What To Do???
  92. 1995 STRATUS SCANTOOL HELP PLEASE
  93. fuel door
  94. Freeze plug replacement
  95. Need a pully.... help please...
  96. Wanna buy an r/t
  97. My '03, 2 door Stratus R/t 3.0Liter
  98. HELP - Red light goes on sometimes in dash/instrument console
  99. 1996 Stratus 2.4L wont stay running
  100. ASD relay ?
  101. Steering screeching noise when turned left or right
  102. Defroster Switch
  103. 2002 Stratus Trans temp sensor
  104. Dodge Stratus PO601
  105. Turbo Project
  106. Blacked out Headlights
  107. BIIIIIIG Problem With my Guage Bezel!! Help please!!
  108. 98 stratus no bus
  109. window tint
  110. 96 stratus transmission cooler
  111. 99 stratus speaker problem
  112. 98 stratus timing belt kit
  113. Electrical issue
  114. '99 Stratus Upgrades
  115. 98 stratus problem?
  116. weird thing!!!
  117. replacing upper oxygen sensor 96 stratus
  118. Tranny Shift Solenoid
  119. 2004 stratus P301 code (cyl 1 misfire detected"
  120. R/t sedan manual transmission
  121. 2002 dodge sedan stratus r/t
  122. Cheapest way to replace bumper?
  123. 2002 stratus problems?
  124. 2000 Stratus stock alarm
  125. 01 R/T heat issue
  126. '04 Stratus Low Oil Pressure
  127. Stratus/3000gt exhaust manifold
  128. Electric Door Lock switch
  129. Voting is going on now!!
  130. Heater problem
  131. power lots of it
  132. 01 Stratus Accessory Belt
  133. crankshaft positioning sensor
  134. Front End Clicking Sound
  135. location of oil pressure sending sensor
  136. P0172
  137. Crazy mess of rough idle and random misfires - flashing CEL?
  138. General Stratus Questions
  139. Regional Sections!!
  140. Radio bezel removal
  141. 98 Stratus intermittant stalling problem
  142. V6 timing belt timed, but I've got contact
  143. Little/No Heat & stiff steering
  144. where to buy Mopar Power Steering Fluid (MS-9602)?
  145. wiring a amp
  146. Ticking/Rattling Through Timing Belt Cover - 2.4L
  147. Weird starting problem with my Stratus
  148. ecu
  149. Re: Chrysler Stratus Plasma Door Sills
  150. Need a cold air intake. Help!
  151. Stratus Alternator Belt
  152. 2.4l timing belt tensioner wtb
  153. 2001 Dodge Stratus R/T Coupe
  154. where is crankshaft position sensor ?
  155. PLEASE HELP!!!
  156. car wont start
  157. Please help to check VIN Dodge Stratus 2005
  158. Strange noises under my hood
  159. Same services, different prices, why?
  160. high temp and a hard hose
  161. bout to do my brakes....
  162. oil pressure light on.... then off
  163. Thinking about buying an '01 Stratus
  164. Transmission problem!
  165. Which grade of motor oil do you use
  166. How do I correct code P0703 ?
  167. Crank Pulley Stuck
  168. 97 Stratus - steering wheel shimmy
  169. mods?
  170. Trunk Leaking
  171. Body kit and CAI???
  172. Help!?
  173. Gurgling sound on startup, only when it's cold.
  174. engine hesistant
  175. Stratus Sedan power door lock actuator
  176. 30 Amp Heater fuse melted hole in fuse block?
  177. Any problems using Xenon lights?
  178. Brake Bulb in Trunk Lid-2002 Stratus
  179. TRANSMISSION ?
  180. keyless entry
  181. Re: Sill Plate Protectors
  182. Gauge Cluster
  183. Stratus UDP?
  184. idler or tensioner pulley
  185. How to install the windshiled washer nozzle
  186. 05 Shifter Sticking!
  187. Rear window de froster
  188. fog lights
  189. Heater issues
  190. check engine light is on and Transmission is messing up.
  191. Speaker Issues.
  192. Paint Color Question from Dealer.
  193. Need help with codes
  194. Stratus Exhaust
  195. **HELP ME ASAP**
  196. Power steering pressure line
  197. mirror help !!!!
  198. alternator confusion
  199. 99 Dodge Stratus
  200. Good Deal?
  201. Speaker size for 99 stratus
  202. Stereo Cuts Out When I Brake
  203. broke down on highway!!!!!!!!
  204. oil drain plug location?
  205. 98 Status OverHeat Problem
  206. turbo my stratus
  207. Same body style?
  208. Re: Heated Seats & Uconnect
  209. burn fuel and suck ass cuz my intake?
  210. Water pump
  211. Charching problems
  212. Should I stay away from 2G sedans with the V6 b/c of sludging?
  213. Electrical Genius?? 2001 Stratus SE
  214. 98 dodge stratus water pump.
  215. Re: Tire size
  216. 5 Speed swap into a Stratus.
  217. Horn prob
  218. losing water & over heating
  219. Battery on 2001 Stratus
  220. 01 stratus rear defrost
  221. 2.4 head swap
  222. Heater gets hot at high RPM's but cold when idling
  223. fuel,electrical who knows?
  224. 2.5 V6 changing Timming Belt
  225. How to unplug the PCM connector?
  226. I just got a stratus! Mod ideas anyone?
  227. Infinity stereo doesn't read all CD's
  228. PCM Bad or Just have a ghost under the hood
  229. 2001 SE strange clunking noise.
  230. Fuel Filter
  231. 97 Stratus Drains Battery
  232. Need Info On Stratus Door
  233. 97 Stratus 31 code
  234. NEED HELP A.S.A.P
  235. adjusting idle
  236. Mystery water leak
  237. shocks and struts
  238. Check Engine Light...Hesitation..."Camshaft Position Sensor"
  239. 99 stratus no brake lights?
  240. 02 R/T Transmission question
  241. '01 R/T Coupe Transmission swap
  242. wild graphist wanted $$$
  243. What kinda gas mileage do you get out of your R/T???
  244. Stratus Tires-which are the best
  245. 96 stratus trans problem
  246. 03 Stratus 2.4 crankshaft sensor
  247. 02 2.4 noisy when idling
  248. power windows
  249. TOP SPEED
  250. Top Speed
